Bluetooth Smart LED Color Bulbs with Music Syncing Features
Bluetooth Compatible Smart LED Color Bulbs Perfect for Music Syncing
Discover the ultimate smart LED color bulbs that seamlessly sync with your music and elevate your home lighting experience. Whether you're hosting a party, relaxing after work, or setting the perfect ambiance, these Bluetooth-enabled smart bulbs offer vibrant colors, customizable settings, and smart home integration to transform any space.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Experience the brilliance of the Wyze Bulb Color, a top-tier smart lighting solution designed for those who demand the best in color accuracy and brightness.
Key Features:
  • 16 Million Colors & Tunable White: Choose from an expansive palette of 16 million colors and adjust white tones from warm 1800K to cool 6500K to suit any mood or occasion.
  • Extra Brightness: With up to 1100 lumens, this bulb lights up your room with vivid, eye-catching illumination.
  • Bluetooth & Wi-Fi Connectivity: Connect effortlessly via Bluetooth or 2.4GHz Wi-Fi for smooth control through your smartphone.
  • Music Sync Capability: Perfect for syncing with your favorite tunes, the bulb reacts dynamically to music beats, creating immersive lighting effects.
  • Compatibility: Works with Android 9.0+ and iOS 15.0+ devices, and integrates with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Durability: Rated for 25,000 hours of life expectancy and suitable for damp locations, making it versatile for indoor use.
  • Energy Efficient: Consumes only 12 watts while delivering powerful lighting.
"Wyze Bulb Color is an insufferable snob, but it’s tough to get excited when you’re the greatest 16 million color smart bulb on earth."
Wyze Bulb Color in Living Room Vibrant smart lighting enhancing your living space
Wyze Bulb Color BR30: Smart Recessed Lighting with Music Mode
For recessed lighting fixtures, the Wyze Bulb Color BR30 offers a smart, color-changing solution that fits perfectly into your existing setup.
Highlights:
  • Dimmable & Color-Changing: Adjust brightness and select from 16 million ultra-accurate colors to create the perfect atmosphere.
  • Music Mode: Sync your lighting with music for dynamic, rhythmic light shows that bring your parties and relaxation time to life.
  • Wide Lumen Range: From a soft 30 lumens to a bright 950 lumens, this bulb adapts to your lighting needs.
  • Smart Features: Includes custom lighting scenes, sleep routines, vacation mode, and voice control via Alexa and Google Assistant.
  • Connectivity: Supports Bluetooth and 2.4GHz Wi-Fi for reliable smart control.
  • Compatibility: Designed for Android 9.0+ and iOS 15.0+ devices.
  • Long Life: Rated for 25,000 hours, ensuring lasting performance.
  • Note: Not compatible with dimmer switches.
Specifications:
  • Bulb Shape: BR30
  • Power: 11.5W (equivalent to 75W incandescent)
  • Color Temperature: 1800K - 6500K
  • Color Rendering Index: 90+
  • Base Type: E26
Cozy room with recessed smart lighting Smart recessed lighting setting the mood
Why Choose Bluetooth Compatible Smart LED Bulbs for Music Syncing?
Bluetooth-enabled smart bulbs like the Wyze Bulb Color and Wyze Bulb Color BR30 offer seamless, low-latency connections that make music syncing smooth and responsive. Unlike Wi-Fi-only bulbs, Bluetooth connectivity ensures your lights react instantly to beats and rhythms, enhancing your entertainment experience.
Additional Benefits:
  • Easy Setup: No complex network configurations needed; just pair and play.
  • Smart Home Integration: Use voice commands or automation routines to control your lighting hands-free.
  • Energy Savings: LED technology combined with smart controls helps reduce electricity consumption.
  • Versatility: Suitable for various rooms and fixtures, including lamps, recessed lighting, and more.
Summary
If you're looking for a Bluetooth compatible smart LED color bulb perfect for music syncing, the Wyze Bulb Color and Wyze Bulb Color BR30 stand out as exceptional choices. Both offer millions of colors, music sync modes, and smart home compatibility, making them ideal for creating immersive lighting experiences that dance to your favorite tunes.
FeatureWyze Bulb ColorWyze Bulb Color BR30
Bulb ShapeA19BR30
Base TypeE26E26
Lumen Output30 lm (dimmer) - 1100 lm (brighter)30 lm (dimmer) - 950 lm (brighter)
Wattage Equivalent75W75W
Color Options16 million colors16 million colors
Color Temperature RangeTunable white (exact range not specified)Tunable white (Sun Match: 1800K - 6500K)
CRI Rating90+90+
DimmableYes (takes offense if used)Yes (not for use in dimmer switches)
White Light Temperature ControlYesYes
Custom PresetsYesYes
NotificationsBrilliant notifications supportedBrilliant notifications supported
Sleep RoutinesYesYes
Music ModeYes (requires grouping with Light Strip)Yes (requires grouping with Light Strip)
Voice ControlAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYes
GroupingYesYes
CompatibilityStandard socketsFits recessed/can lighting sockets
Notable LimitationsTakes offense if dimmedNot for use in dimmer switches
Price (2-Pack)$26.26$27.98
Price (4-Pack)$44.44$49.98
Price (6-Pack)$64.98Not available
What are Bluetooth compatible smart LED color bulbs?Bluetooth compatible smart LED color bulbs are advanced lighting solutions that connect to your smartphone or smart home devices via Bluetooth. They offer features like vibrant color options, customizable settings, and the ability to sync with music for dynamic lighting effects.
How do Wyze Bulb Color and Wyze Bulb Color BR30 sync with music?Both Wyze Bulb Color and Wyze Bulb Color BR30 feature music sync capabilities. They use Bluetooth connectivity to react instantly to music beats, creating immersive lighting effects that enhance parties, relaxation, or any entertainment experience.
What devices are compatible with Wyze Bulb Color and Wyze Bulb Color BR30?Wyze Bulb Color and Wyze Bulb Color BR30 are compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher. They also integrate with Alexa, Google Assistant, and IFTTT for voice and automation control.
Can I control Wyze smart bulbs with my voice?Yes, both Wyze Bulb Color and Wyze Bulb Color BR30 support voice control through Alexa and Google Assistant, allowing you to adjust lighting hands-free.
What is the color range and brightness of Wyze Bulb Color?Wyze Bulb Color offers 16 million colors and tunable white light from 1800K (warm) to 6500K (cool). It provides up to 1100 lumens of brightness, making it suitable for a variety of lighting needs.
What are the main features of Wyze Bulb Color BR30?Wyze Bulb Color BR30 is designed for recessed lighting and offers 16 million color options, dimmable brightness from 30 to 950 lumens, music sync mode, custom lighting scenes, sleep routines, vacation mode, and voice control. It is not compatible with dimmer switches.
How energy efficient are Wyze smart LED bulbs?Wyze smart LED bulbs are highly energy efficient. The Wyze Bulb Color consumes only 12 watts, while the Wyze Bulb Color BR30 uses 11.5 watts (equivalent to a 75W incandescent bulb), helping you save on electricity bills.
How long do Wyze smart LED bulbs last?Both Wyze Bulb Color and Wyze Bulb Color BR30 are rated for 25,000 hours of use, ensuring long-lasting performance and reliability.
Are Wyze smart bulbs suitable for damp locations?Yes, Wyze Bulb Color is suitable for use in damp locations, making it versatile for various indoor environments.
Do I need a Wi-Fi connection to use Wyze smart bulbs?Wyze smart bulbs can connect via both Bluetooth and 2.4GHz Wi-Fi. Bluetooth allows for easy setup and instant music syncing, while Wi-Fi enables remote control and smart home integration.
Can I use Wyze Bulb Color BR30 with dimmer switches?No, Wyze Bulb Color BR30 is not compatible with dimmer switches. It is designed to be dimmed and controlled through the Wyze app or voice assistants.
What are the benefits of Bluetooth connectivity in smart LED bulbs?Bluetooth connectivity in smart LED bulbs ensures seamless, low-latency connections for instant music syncing and easy setup without complex network configurations.
What are the key features of the Wyze Bulb Color?How does the music sync capability work with the Wyze Bulb Color?Are there any ongoing sales or discounts for the Wyze Bulb Color?
