Indoor LED Lighting Strip That Syncs with Music Beats
Transform your indoor space with vibrant LED lighting that dances to your favorite tunes. If you're looking for an indoor LED lighting strip that syncs with music beats, the Wyze Light Strip is the perfect choice. Designed for indoor use, this smart light strip offers brilliant color customization and a unique music sync feature that brings your environment to life.
Wyze Light Strip: Brilliant LED Accent Lighting with Music Sync
Dynamic Color and Length Options
The Wyze Light Strip comes in two convenient sizes:
  • 16.4 feet (18 watts)
  • 32.8 feet (36 watts)
With 16 million colors to choose from, you can customize your lighting to match any mood or occasion. Whether you want a subtle glow or a vibrant party atmosphere, this strip has you covered.
Music Beat Sync Feature
What sets the Wyze Light Strip apart is its built-in microphone that allows the lights to pulse and change colors in sync with your music beats. This feature creates an immersive audio-visual experience, perfect for parties, gaming setups, or relaxing with your favorite playlists.
Easy Installation and Customization
  • Adhesive backing for simple mounting on walls, under cabinets, or behind furniture.
  • Cuttable design lets you tailor the strip length to your space.
  • Controlled via the Wyze app over 2.4 GHz Wi-Fi or Bluetooth for seamless integration.
Long-lasting and Energy Efficient
  • Life expectancy of 25,000 hours.
  • Low power consumption with 12V power adapter.
  • Safe indoor use with operating temperatures from -4°F to 122°F.
Color your world with brilliant LED accent lighting that moves to your music.
Wyze Light Strip in Living Room Create a vibrant living room ambiance with Wyze Light Strip syncing to music beats.
Enhance Your Smart Home Lighting Experience
While the Wyze Light Strip is the prime choice for music-synced indoor LED lighting, you can complement your setup with other Wyze smart home products for a fully integrated experience.
Wyze Switch: Smart Control for Your Lights
Turn your existing lights into smart lights with the Wyze Switch. Control your lighting remotely, set schedules, and create automations that work in harmony with your Wyze Light Strip.
  • Multi-tap controls to trigger other Wyze devices.
  • Compatible with voice assistants for hands-free operation.
  • Vacation mode and power loss recovery for convenience.
Wyze Switch in Kitchen Smart Wyze Switch lets you control your lighting effortlessly.
Why Choose Wyze for Your Indoor LED Lighting?
  • Seamless App Integration: Control all your Wyze devices from a single app.
  • Affordable and Reliable: High-quality products at budget-friendly prices.
  • Customizable and Expandable: Add more Wyze smart devices to enhance your home automation.
  • Energy Efficient: Save power while enjoying stunning lighting effects.
Summary of Products for Indoor LED Lighting with Music Sync
Product NameKey FeaturePrice Range
Wyze Light Strip16 million colors, music sync$19.99 - $35.99
Wyze SwitchSmart light control, multi-tap$14.99 - $41.98
Elevate your indoor ambiance with Wyze Light Strip — the ultimate LED lighting strip that syncs with music beats for a dynamic and colorful experience.
### Product Tags and Highlights
FeatureWyze Light StripWyze Switch
TypeConnected Home - LED Accent LightingConnected Home - Smart WiFi Light Switch
Variants16.4 Feet ($19.99, sold out), 32.8 Feet ($35.99, sold out)1 Pack ($14.99), 3 Pack ($41.98, sold out)
Colors16 million colorsControls normal lights (no color)
Key FeaturesPeel, stick, plug anywhere; Music Mode with built-in mic; Sun Match; Voice Control (Alexa, Google Assistant); Vacation Mode; Sleep Routines; Timers & AutomationsTurn normal lights smart; Multi-tap controls for other Wyze devices; Voice Control; Timers & Schedules; Vacation Mode; Power Loss Recovery
InstallationPlug-in strip with adhesiveEasy installation replacing existing switch
Voice Assistant SupportAlexa, Google AssistantAlexa, Google Assistant
App ControlWyze appWyze app
AutomationYesYes
Power SourcePlug-in power adapterWired light switch
Special ModesMusic Mode sync to music beat; Sun MatchMulti-tap customizable actions (single, double, triple press, press-and-hold)
CompatibilityWorks with Wyze ecosystemIntegrates with Wyze ecosystem and devices
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Light Strip and how does it work?The Wyze Light Strip is an indoor LED lighting strip that offers 16 million color options and a unique music sync feature. It uses a built-in microphone to detect music beats, allowing the lights to pulse and change colors in sync with your favorite songs. The strip is controlled via the Wyze app over 2.4 GHz Wi-Fi or Bluetooth, making it easy to customize and integrate into your smart home.
Does the Wyze Light Strip sync with music beats?Yes, the Wyze Light Strip features a built-in microphone that enables the lights to pulse and change colors in real-time with your music beats. This creates an immersive audio-visual experience, perfect for parties, gaming, or relaxing at home.
What sizes are available for the Wyze Light Strip?The Wyze Light Strip is available in two sizes: 16.4 feet (18 watts) and 32.8 feet (36 watts). Both sizes offer the same vibrant color customization and music sync capabilities.
How do I install the Wyze Light Strip?The Wyze Light Strip features an adhesive backing for easy mounting on walls, under cabinets, or behind furniture. It is also cuttable, allowing you to tailor the strip length to fit your specific space.
Is the Wyze Light Strip energy efficient?Yes, the Wyze Light Strip is designed for energy efficiency, operating on a 12V power adapter with low power consumption. It has a life expectancy of 25,000 hours, making it a long-lasting and cost-effective lighting solution.
Can I control the Wyze Light Strip with my smartphone?Absolutely. The Wyze Light Strip can be controlled via the Wyze app on your smartphone using 2.4 GHz Wi-Fi or Bluetooth. The app allows you to customize colors, set schedules, and activate the music sync feature.
Is the Wyze Light Strip safe for indoor use?Yes, the Wyze Light Strip is designed specifically for indoor use and operates safely within temperatures ranging from -4°F to 122°F.
What is the Wyze Switch and how does it complement the Wyze Light Strip?The Wyze Switch is a smart light switch that allows you to control your existing lights remotely, set schedules, and create automations. It can be used alongside the Wyze Light Strip for a fully integrated smart home lighting experience, including multi-tap controls and compatibility with voice assistants.
Why should I choose Wyze for indoor LED lighting with music sync?Wyze offers affordable, reliable, and energy-efficient smart lighting solutions. With seamless app integration, customizable options, and the ability to expand your smart home setup, Wyze is an excellent choice for anyone looking to enhance their indoor ambiance with music-synced LED lighting.
What is the price range for the Wyze Light Strip and Wyze Switch?The Wyze Light Strip is priced between $19.99 and $35.99, depending on the length. The Wyze Switch ranges from $14.99 to $41.98, offering smart control features for your lighting setup.
What are the different lengths available for the Wyze Light Strip?How does the music sync feature work on the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions?
