Wyze Smart LED Kit: Transform Your Home with Smart Lighting
Smart LED Kit: Illuminate and Automate Your Home with Wyze
Transform your living space with a smart LED kit that combines vibrant lighting, seamless automation, and smart control. Whether you want to brighten your home with customizable LED strips, control your lights remotely, or add smart plugs for effortless device management, Wyze offers a comprehensive range of products designed to make your home smarter and more energy-efficient.
Wyze Light Strip: Brilliant LED Accent Lighting
Add a splash of color and ambiance to any room with the Wyze Light Strip. Available in two lengths—16.4 feet and 32.8 feet—this LED strip lets you color your world with brilliant, customizable lighting.
  • Vibrant Colors & Effects: Choose from millions of colors and dynamic lighting effects to match your mood or occasion.
  • Flexible Installation: Easily install under cabinets, behind sofas, or along shelves to create stunning accent lighting.
  • App Control: Adjust brightness, colors, and schedules from your smartphone for ultimate convenience.
  • Voice Assistant Compatible: Works with Alexa and Google Assistant for hands-free control.
Enhance your living room or kitchen with vibrant LED lighting that adapts to your lifestyle.
Wyze Light Strip in Living Room Create cozy and colorful living spaces with Wyze Light Strip
Wyze Bulb White: Smart, Dimmable White Lighting
For those who prefer classic white lighting with smart features, the Wyze Bulb White is an excellent choice. It offers bright, warm white light with dimmable controls to set the perfect ambiance.
  • Dimmable Brightness: Easily adjust the light intensity to suit your activities, from reading to relaxing.
  • Multiple Pack Options: Available in 2, 4, or 6 packs to light up your entire home.
  • Smart Scheduling: Automate your lighting to turn on/off at specific times or mimic sunrise and sunset.
  • Vacation Mode: Simulate occupancy when you’re away for added security.
Perfect for bedrooms, living rooms, or any space where warm, comfortable lighting is desired.
Wyze Bulb White in Cozy Bedroom Set the mood with warm, dimmable smart bulbs
Wyze Plug & Wyze Plug Outdoor: Smart Power Control Indoors and Out
Complete your smart LED kit with Wyze Plug and Wyze Plug Outdoor to control your lighting and other devices effortlessly.
Wyze Plug (Indoor)
  • Make Any Device Smart: Turn lamps, fans, or coffee makers into smart devices.
  • App & Voice Control: Control your devices remotely or with Alexa and Google Assistant.
  • Scheduling & Automation: Set timers or automate based on your daily routine.
  • Energy Monitoring: Track power usage to save on electricity bills.
Wyze Plug Outdoor
  • Weatherproof Design: Built to withstand rain or shine, perfect for garden lights and outdoor decorations.
  • Remote Control: Manage outdoor lighting and devices from anywhere.
  • Scheduling & Monitoring: Set schedules for holiday inflatables or backyard parties with ease.
Take full control of your indoor and outdoor lighting with smart plugs designed for convenience and durability.
Wyze Plug in Home Setting Smart plugs bring effortless control to your home devices
Why Choose a Wyze Smart LED Kit?
"Smart LED kits from Wyze combine vibrant lighting, smart automation, and easy control to elevate your home experience."
  • Seamless Integration: All Wyze smart devices work together through a single app.
  • Affordable & Scalable: Start small with bulbs or plugs and expand your smart home over time.
  • Energy Efficient: Save energy with smart scheduling and monitoring features.
  • Voice Assistant Ready: Compatible with Alexa and Google Assistant for hands-free convenience.
Upgrade your home lighting and automation with Wyze’s smart LED kit products and enjoy a brighter, smarter lifestyle.
Summary of Wyze Smart LED Kit Products
ProductKey FeaturesPrice Range (USD)
Wyze Light StripColorful LED lighting, app control$19.99 - $35.99
Wyze Bulb WhiteDimmable white light, scheduling$23.99 - $59.99
Wyze Plug (Indoor)Smart plug, energy monitoring$24.98 - $39.98
Wyze Plug OutdoorWeatherproof, outdoor smart plug$15.99 - $34.98
FeatureWyze PlugWyze Bulb WhiteWyze Light Strip
TypeConnected HomeConnected HomeConnected Home
ColorWhiteWhiteNot specified (LED strip colors)
Size/Variants2 Pack, 4 Pack2 Pack, 4 Pack, 6 Pack16.4 ft, 32.8 ft
Price Range$24.98 - $39.98$23.99 - $59.99$19.99 - $35.99
Dimensions2.7" x 2.0" x 1.5"4.6" x 2.4" x 2.4"Length: 16.4 ft or 32.8 ft
Weight5.3 oz0.31 lbs10.8 oz (16.4 ft), 1.01 lbs (32.8 ft)
Weather ResistanceIndoor use onlySuitable for damp locationsIndoor use only
Operating Temperature-4°F to 104°F (-20°C to 40°C)-4°F to 104°F-4°F to 122°F (-20°C to 50°C)
Input Voltage100-120 VAC, 60HzAC 120V~60 Hz100-240V, 50/60 Hz
Output15A Max9.5 watts18 watts (16.4 ft), 36 watts (32.8 ft)
Connectivity2.4GHz WiFi802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth
CompatibilityAndroid 5.0+, iOS 9.0+Android 9.0+, iOS 15.0+Not specified
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specified
LumensN/A30-800 lumensBlue: 0.8 lm/LED, Red: 1.0 lm/LED, Green: 2.5 lm/LED (per meter)
Color TemperatureN/A2700K - 6500K16 million colors (RGB)
Life ExpectancyN/A25,000 hours25,000 hours
Special FeaturesMake devices smartDimmable, bright white lightLED accent lighting, cuttable, adhesive backing, music feature (mic)
Warranty1 YearNot specifiedNot specified
What is included in the Wyze Smart LED Kit?The Wyze Smart LED Kit includes a range of smart home products such as Wyze Light Strips, Wyze Bulb White smart bulbs, Wyze Plug (Indoor), and Wyze Plug Outdoor. These products are designed to provide customizable lighting, smart automation, and convenient control for your home.
How do I control Wyze Light Strips and smart bulbs?You can control Wyze Light Strips and Wyze Bulb White smart bulbs using the Wyze app on your smartphone. The app allows you to adjust brightness, change colors, set schedules, and automate your lighting. Both products are also compatible with Alexa and Google Assistant for hands-free voice control.
Are Wyze Light Strips customizable?Yes, Wyze Light Strips are highly customizable. You can choose from millions of colors and dynamic lighting effects to match your mood or occasion. The strips are available in 16.4 feet and 32.8 feet lengths and can be easily installed under cabinets, behind furniture, or along shelves.
What are the benefits of Wyze Bulb White smart bulbs?Wyze Bulb White smart bulbs offer dimmable, warm white lighting that can be adjusted to suit any activity. They feature smart scheduling, vacation mode for added security, and are available in multiple pack sizes to light up your entire home.
Can I automate my lighting with Wyze products?Yes, Wyze products support smart scheduling and automation. You can set your lights and plugs to turn on or off at specific times, mimic sunrise and sunset, or automate based on your daily routine for convenience and energy savings.
What is the difference between Wyze Plug and Wyze Plug Outdoor?Wyze Plug is designed for indoor use and allows you to make any device smart, control it remotely, and monitor energy usage. Wyze Plug Outdoor is weatherproof, making it ideal for controlling outdoor lighting and devices. Both support scheduling, automation, and voice control.
Are Wyze smart plugs compatible with voice assistants?Yes, both Wyze Plug (Indoor) and Wyze Plug Outdoor are compatible with Alexa and Google Assistant, allowing you to control your devices with simple voice commands.
How do Wyze smart products help save energy?Wyze smart products help save energy through features like smart scheduling, automation, and energy monitoring. You can track power usage, set devices to turn off when not needed, and optimize your home’s energy consumption.
Can I expand my Wyze smart home system over time?Absolutely. Wyze smart home products are affordable and scalable, allowing you to start with a few devices and expand your system as needed. All devices integrate seamlessly through the Wyze app.
What is the price range for Wyze Smart LED Kit products?Wyze Smart LED Kit products range in price: Wyze Light Strip ($19.99 - $35.99), Wyze Bulb White ($23.99 - $59.99), Wyze Plug Indoor ($24.98 - $39.98), and Wyze Plug Outdoor ($15.99 - $34.98).
Can you tell me more about the features of the Wyze Light Strip?How do I control the Wyze Bulb White with my smartphone?Do you have any ongoing sales or discounts for the smart LED kit?
