Customizable Smart LED Kits for Vibrant Wall Accent Lighting
Customizable Smart LED Kit for Vibrant Wall Accent Lighting
Transform your living space with a customizable smart LED kit designed to bring vibrant, dynamic accent lighting to your walls. Whether you want to create a cozy ambiance, energize your workspace, or set the perfect mood for entertaining, these smart lighting products offer seamless control, rich colors, and smart home integration to elevate your environment.
Wyze Light Strip: Brilliant LED Accent Lighting
Bring your walls to life with the Wyze Light Strip, a versatile LED strip that delivers stunning color and brightness for accent lighting.
  • Vibrant Colors: Choose from 16 million colors to perfectly match your mood or décor.
  • Length Options: Available in 16.4 feet and 32.8 feet lengths to fit any room size.
  • Customizable Zones: Control the entire strip as one zone for uniform lighting.
  • Easy Installation: Adhesive backing and included clips make mounting simple and secure.
  • Cuttable Design: Trim the strip to fit your exact space without waste.
  • Music Sync Feature: Lights pulse and change with your favorite tunes using the built-in microphone.
  • Connectivity: Supports 2.4 GHz WiFi and Bluetooth for reliable app control.
  • Long Life: Rated for 25,000 hours of vibrant illumination.
  • Indoor Use Only: Perfect for living rooms, bedrooms, or entertainment areas.
Color your world with brilliant LED accent lighting that adapts to your lifestyle and style preferences.
Wyze Light Strip in Living Room Ambiance Alt text: Vibrant Wyze Light Strip accent lighting behind sofa in modern living room
Wyze Bulb Color BR30: Dynamic Color-Changing Smart Bulb
Add depth and personality to your recessed lighting fixtures with the Wyze Bulb Color BR30, a smart bulb that offers millions of colors and customizable lighting scenes.
  • 16 Million Colors: Create any ambiance from vibrant party hues to soft, relaxing tones.
  • Wide Lumen Range: 30 to 950 lumens to brighten or dim your space perfectly.
  • Dimmable & Smart: Adjust brightness and color via app or voice commands.
  • Voice Control: Compatible with Alexa, Google Assistant, and IFTTT.
  • Custom Scenes & Routines: Set sleep routines, vacation modes, and music modes for immersive experiences.
  • Long Life Expectancy: Up to 25,000 hours of reliable use.
  • Easy Installation: Fits standard E26 sockets in recessed fixtures.
  • Operating Temperature: Works well in typical home environments (-4°F to 104°F).
  • Not for Use with Dimmer Switches: Designed for smart control only.
Light up your life with a smart bulb that adapts to your mood and lifestyle, perfect for vibrant wall accent lighting.
Colorful smart bulb lighting a cozy room Alt text: Cozy room illuminated by color-changing smart bulb with warm lighting
Wyze Switch: Smart Control for Your Lighting Setup
Upgrade your existing lighting to smart control with the Wyze Switch, enabling you to manage your lights from anywhere and create custom automations.
  • Turn Any Light Smart: Control traditional lights remotely via the Wyze app.
  • Multi-Tap Actions: Customize single, double, and triple taps to control other Wyze devices like cameras and vacuums.
  • Automation & Scheduling: Set timers, schedules, and vacation modes to automate your lighting.
  • Power Loss Recovery: Lights return to previous state after power outages.
  • Seamless Integration: Works perfectly within the Wyze ecosystem.
  • Available in Packs: Choose 1-pack or 3-pack options for multiple rooms.
  • Easy Installation: Fits standard switch boxes for quick upgrade.
Control your vibrant wall accent lighting effortlessly with smart switches that put convenience at your fingertips.
Wyze Plug: Smart Power for Your Lighting Devices
Enhance your smart lighting setup by powering your LED kits and lamps with the Wyze Plug, turning any device into a smart device.
  • Smart Control: Turn devices on/off remotely via app.
  • Scheduling & Automation: Set timers and schedules to sync lighting with your daily routine.
  • Voice Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
  • Compact Design: Fits easily into any outlet without blocking adjacent sockets.
  • Indoor Use: Perfect for lamps, LED strips, and accent lighting.
  • Connectivity: 2.4 GHz WiFi ensures stable connection.
Available in 2-pack and 4-pack bundles.
Make your normal devices smart and integrate your lighting setup into a fully connected home.
Wyze Plug controlling smart lighting in home Alt text: Lifestyle image of Wyze Plug controlling smart lighting in a modern home
Wyze Bulb White: Dimmable White Lighting for Accent and Ambient Use
For those who prefer classic white lighting with smart features, the Wyze Bulb White offers adjustable brightness and color temperature.
  • Brightness Range: 30 to 800 lumens with dimmable control.
  • Color Temperature: Adjustable from warm 2700K to cool 6500K.
  • Wide Beam Angle: 230° for broad, even lighting.
  • Long Life: 25,000 hours of use.
  • Smart Control: Via app, voice assistants, and automation.
  • Suitable for Damp Locations: Ideal for indoor accent lighting in kitchens, bedrooms, and bathrooms.
  • Multiple Pack Sizes: Available in 2, 4, and 6 packs.
Perfect for subtle wall accent lighting that can be brightened or softened to suit any occasion.
Why Choose a Customizable Smart LED Kit for Wall Accent Lighting?
Vibrant wall accent lighting transforms your space from ordinary to extraordinary. With smart LED kits, you gain full control over color, brightness, and scheduling, allowing you to tailor your environment to your mood and lifestyle. Integration with voice assistants and smart home ecosystems makes managing your lighting effortless and fun.
These Wyze smart lighting products combine innovation, ease of use, and style to help you create stunning wall accents that impress and inspire.
Enhance your home ambiance today with these customizable smart LED lighting solutions designed for vibrant, dynamic wall accent lighting.
FeatureWyze Light StripWyze Bulb Color BR30Wyze SwitchWyze PlugWyze Bulb White
TypeConnected Home - LED Light StripConnected Home - Smart Bulb (BR30)Connected Home - Smart SwitchConnected Home - Smart PlugConnected Home - Smart Bulb
Price$19.99 (16.4 ft), $35.99 (32.8 ft)$27.98 (2-Pack), $49.98 (4-Pack)$14.99 (1 Pack), $41.98 (3 Pack)$24.98 (2 Pack), $39.98 (4 Pack)$23.99 (2 Pack), $39.99 (4 Pack), $59.99 (6 Pack)
Colors16 million colors16 million colorsN/AN/AWhite light (2700K - 6500K)
DimmableYesYesN/AN/AYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
ConnectivityWiFi (2.4 GHz), BluetoothWiFi (2.4 GHz), BluetoothWiFi (2.4 GHz)WiFi (2.4 GHz)WiFi (2.4 GHz), Bluetooth
Size/Variants16.4 ft, 32.8 ft2-Pack, 4-Pack1 Pack, 3 Pack2 Pack, 4 Pack2 Pack, 4 Pack, 6 Pack
Power SourceCorded ElectricStandard E26 socketWired switchPlug-inStandard E26 socket
Special FeaturesMusic Mode, Sun Match, Vacation Mode, Sleep Routines, Timers & AutomationsBrighter/dimmer (30-950 lm), Sun Match, Notifications, Sleep Routines, Music Mode (with grouping)Multi-tap control, Automations, Vacation Mode, Power loss recoveryEnergy monitoring, Overload protectionDimmable, 90+ CRI, Suitable for damp locations
Max BrightnessNot specified950 lumens maxN/AN/A30-800 lumens
Compatible with Wyze AppYesYesYesYesYes
WarrantyNot specified30-day hassle-free returnsNot specified1 YearNot specified
Indoor/Outdoor UseIndoor onlyIndoor onlyIndoor onlyIndoor onlySuitable for damp locations
What is a customizable smart LED kit for wall accent lighting?A customizable smart LED kit for wall accent lighting is a set of smart lighting products, such as LED strips, smart bulbs, switches, and plugs, designed to add vibrant, dynamic lighting effects to your walls. These kits offer features like color customization, app and voice control, scheduling, and smart home integration to help you create the perfect ambiance in any room.
What features does the Wyze Light Strip offer for accent lighting?The Wyze Light Strip provides 16 million color options, customizable zones, easy installation with adhesive backing, cuttable design for a perfect fit, music sync feature, and reliable connectivity via 2.4 GHz WiFi and Bluetooth. It is available in 16.4 ft and 32.8 ft lengths and is rated for 25,000 hours of indoor use.
How do I install the Wyze Light Strip?The Wyze Light Strip is easy to install with its adhesive backing and included mounting clips. Simply peel and stick the strip to your desired surface, trim it to fit your space if needed, and plug it in. The setup process is quick and requires no special tools.
Can the Wyze Light Strip sync with music?Yes, the Wyze Light Strip features a built-in microphone that allows the lights to pulse and change colors in sync with your favorite music, creating a dynamic and immersive lighting experience.
What is the Wyze Bulb Color BR30 and how does it enhance accent lighting?The Wyze Bulb Color BR30 is a smart, color-changing bulb designed for recessed lighting fixtures. It offers 16 million colors, adjustable brightness from 30 to 950 lumens, app and voice control, custom scenes and routines, and a long lifespan of up to 25,000 hours, making it ideal for creating vibrant wall accent lighting.
Is the Wyze Bulb Color BR30 compatible with voice assistants?Yes, the Wyze Bulb Color BR30 works with Alexa, Google Assistant, and IFTTT, allowing you to control your lighting with simple voice commands.
Can I use the Wyze Bulb Color BR30 with a dimmer switch?No, the Wyze Bulb Color BR30 is not designed for use with traditional dimmer switches. It should be controlled via the Wyze app or compatible voice assistants for optimal performance.
What is the Wyze Switch and how does it make lighting smart?The Wyze Switch is a smart light switch that allows you to control your existing lights remotely via the Wyze app. It supports multi-tap actions to control other Wyze devices, offers automation and scheduling features, and fits standard switch boxes for easy installation.
How does the Wyze Plug work with smart lighting setups?The Wyze Plug turns any device, such as lamps or LED strips, into a smart device. It allows you to control power remotely, set schedules and automations, and integrate with Alexa, Google Assistant, and IFTTT. Its compact design fits easily into any outlet, making it perfect for smart lighting setups.
What are the benefits of the Wyze Bulb White for accent lighting?The Wyze Bulb White offers adjustable brightness (30 to 800 lumens), tunable color temperature (2700K to 6500K), a wide 230° beam angle, and smart control via app or voice assistants. It is suitable for damp locations and available in multiple pack sizes, making it ideal for subtle and customizable accent lighting.
Can I control Wyze smart lighting products with my smartphone?Yes, all Wyze smart lighting products, including the Wyze Light Strip, Bulb Color BR30, Switch, Plug, and Bulb White, can be controlled via the Wyze app on your smartphone. This allows you to adjust colors, brightness, schedules, and more from anywhere.
Are Wyze smart lighting products compatible with smart home ecosystems?Yes, Wyze smart lighting products integrate seamlessly with popular smart home ecosystems, including Alexa, Google Assistant, and IFTTT, enabling voice control and automation with other smart devices.
How long do Wyze smart lighting products last?Wyze smart lighting products, such as the Wyze Light Strip, Bulb Color BR30, and Bulb White, are rated for up to 25,000 hours of use, providing long-lasting and reliable illumination for your home.
Can I automate my wall accent lighting with Wyze products?Yes, Wyze products support automation and scheduling features, allowing you to set timers, routines, and vacation modes to automate your wall accent lighting according to your daily routine or preferences.
Why should I choose a customizable smart LED kit for wall accent lighting?A customizable smart LED kit gives you full control over your lighting's color, brightness, and scheduling. It enhances your home's ambiance, adapts to your mood and lifestyle, and integrates with smart home systems for effortless management and a modern, vibrant look.
What features does the Wyze Light Strip offer for accent lighting?Can the Wyze Bulb Color BR30 be used in recessed lighting fixtures?Are there any ongoing sales or discounts available for Wyze products?
