Smart Doorbell Cameras with Alexa and Google Voice Control
Looking for a smart doorbell camera that seamlessly integrates with Alexa or Google Assistant? Wyze offers some of the most advanced and affordable smart doorbell cameras designed to enhance your home security with voice control features. Whether you want wired or battery-powered options, Wyze has you covered with crystal-clear video, two-way audio, and intelligent alerts.
Wyze Video Doorbell v2: Wired 2K Clarity with Voice Control
Experience clear, reliable home security with Wyze Video Doorbell v2.
The Wyze Video Doorbell v2 is a wired video doorbell that delivers stunning 2K video resolution (2048 x 1536) with a wide 166.8° diagonal field of view, ensuring you never miss a visitor or package. Equipped with a CMOS Starlight Sensor and 6 infrared LEDs, it provides excellent night vision and motion-activated voice deterrence to ward off unwanted guests.
Key Features:
- 2K HD Video & Local Storage: Capture detailed video with local microSD storage up to 256GB and optional cloud storage via Wyze Security Plan.
- Two-Way Audio: Communicate with visitors in real-time using the built-in microphone and speaker.
- Voice Assistant Integration: Works flawlessly with Alexa and Google Assistant for hands-free control.
- Weather Resistant: IP65 rating ensures durability in all weather conditions.
- Motion-Activated Voice Alerts: Warn visitors with customizable voice messages.
- Easy Installation: Comes with a chime controller, wall plate, wedge for angled mounting, and all necessary hardware.
This doorbell is perfect for homeowners who want a wired solution with premium video quality and smart home compatibility.
Wyze Duo Cam Battery Doorbell: Dual Cameras for Ultimate Coverage
Dual camera views for people and packages with Wyze Duo Cam Doorbell.
For those seeking a wireless, battery-powered option, the Wyze Duo Cam Battery Doorbell offers two cameras in one device: a front-facing 2K camera and a bottom-facing 1080p camera. This dual-camera setup provides comprehensive coverage to monitor both visitors and packages on your porch.
Standout Features:
- Dual 2K & 1080p Cameras: Front camera with 132° horizontal FOV and bottom camera with 121° horizontal FOV.
- Battery Powered with USB-C Charging: Includes a removable 6200mAh lithium-ion battery pack for up to several months of use.
- Two-Way Audio & Siren: Talk to visitors and deter intruders with a 90 dB siren.
- AI-Powered Alerts: Real-time detection for people, packages, and motion with voice deterrence.
- Local & Cloud Storage: Supports up to 256GB microSD card and cloud storage on AWS.
- Voice Assistant Compatibility: Works with Alexa and Google Assistant for voice commands.
- Weatherproof: IP65 rating for reliable outdoor use.
This doorbell is ideal for renters or those who prefer a wireless setup without sacrificing advanced features.
Wyze Video Doorbell Pro: Wider View and Flexible Power Options
Quick install and smart home ready with Wyze Video Doorbell Pro.
The Wyze Video Doorbell Pro combines the best of wired and wireless technology with a wider ultra-wide viewing angle and HD video quality. It supports both hardwired and battery power, making installation quick and flexible.
Highlights:
- Ultra-Wide Viewing Angle: Capture more of your porch with a wider field of view.
- Fast Notifications: Dual-band Wi-Fi extender chime ensures you never miss alerts.
- Smart Detection: Person, package, vehicle, and pet detection with Cam Plus subscription.
- Two-Way Audio & Security Light: Communicate instantly and illuminate your porch with motion-activated light.
- Easy Installation: Mount with screws or adhesive plate in just 30 seconds.
- Voice Control: Fully compatible with Alexa and Google Assistant.
- Customizable Chimes: Choose from 20 unique tunes and 8 sound levels.
Perfect for users who want a versatile doorbell with premium features and easy setup.
Why Choose Wyze Smart Doorbell Cameras?
Wyze smart doorbell cameras combine affordability, advanced technology, and seamless smart home integration. With Alexa and Google Assistant compatibility, you can answer your door, receive alerts, and control your security system hands-free.
Additional Accessories
- Wyze Video Doorbell v2 Wedge Kit: Adjust your doorbell’s viewing angle perfectly for angled door frames or porches with stairs. This accessory eliminates blind spots and enhances your security coverage.
Summary of Wyze Smart Doorbell Cameras
Product | Power Type | Video Resolution | Voice Control | Special Features |
Wyze Video Doorbell v2 | Wired | 2K (2048x1536) | Alexa, Google | Local microSD storage, voice deterrence |
Wyze Duo Cam Battery Doorbell | Battery & Wired | Dual 2K + 1080p | Alexa, Google | Dual cameras, AI alerts, removable battery |
Wyze Video Doorbell Pro | Wired or Battery | HD Ultra-wide | Alexa, Google | Fast notifications, motion light, easy install |
Enhance your home security with Wyze’s smart doorbell cameras that offer crystal-clear video, two-way communication, and voice control through Alexa or Google Assistant. Choose the model that fits your lifestyle and enjoy peace of mind with smart, reliable home monitoring.
What smart doorbell cameras from Wyze work with Alexa and Google Assistant?
All Wyze smart doorbell cameras, including the Wyze Video Doorbell v2, Wyze Duo Cam Battery Doorbell, and Wyze Video Doorbell Pro, are fully compatible with Alexa and Google Assistant for hands-free voice control.What are the main features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K HD video resolution, a wide 166.8° field of view, two-way audio, local microSD storage up to 256GB, motion-activated voice alerts, night vision, weather resistance (IP65), and seamless integration with Alexa and Google Assistant.Does Wyze offer a battery-powered smart doorbell camera?
Yes, the Wyze Duo Cam Battery Doorbell is a battery-powered option featuring dual cameras (2K front and 1080p bottom), AI-powered alerts, two-way audio, a 90 dB siren, and compatibility with Alexa and Google Assistant.What is unique about the Wyze Duo Cam Battery Doorbell?
The Wyze Duo Cam Battery Doorbell features two cameras in one device: a front-facing 2K camera and a bottom-facing 1080p camera, providing comprehensive coverage for both visitors and packages. It also offers AI-powered alerts, two-way audio, and a removable battery pack.Can I use Wyze Video Doorbell Pro with both wired and battery power?
Yes, the Wyze Video Doorbell Pro supports both wired and battery-powered installation, offering flexibility and easy setup for any home.What are the benefits of using Wyze smart doorbell cameras?
Wyze smart doorbell cameras provide advanced security features at an affordable price, including crystal-clear video, two-way communication, motion detection, customizable alerts, and seamless integration with Alexa and Google Assistant for hands-free control.Do Wyze doorbell cameras support local and cloud storage?
Yes, Wyze doorbell cameras support local storage via microSD cards (up to 256GB) and offer optional cloud storage through the Wyze Security Plan or AWS, depending on the model.Are Wyze smart doorbell cameras weather resistant?
All Wyze smart doorbell cameras, including the Video Doorbell v2, Duo Cam Battery Doorbell, and Video Doorbell Pro, have an IP65 weather resistance rating, making them suitable for outdoor use in various weather conditions.What installation options are available for Wyze doorbell cameras?
Wyze doorbell cameras offer flexible installation options. The Video Doorbell v2 is wired, the Duo Cam Battery Doorbell is battery-powered (with optional wired support), and the Video Doorbell Pro can be installed using either wired or battery power. Easy installation hardware is included with each model.Are there accessories available for Wyze doorbell cameras?
Yes, Wyze offers accessories such as the Wyze Video Doorbell v2 Wedge Kit, which allows you to adjust the viewing angle of your doorbell for better coverage and to eliminate blind spots.How do Wyze doorbell cameras enhance home security?
Wyze doorbell cameras enhance home security with features like high-definition video, wide viewing angles, two-way audio, motion-activated alerts, AI-powered detection for people and packages, and integration with Alexa and Google Assistant for real-time notifications and hands-free operation.
