Wyze Cam v4: The Ultimate Security Camera with Google Assistant Integration
When it comes to securing your home with smart technology, the
Wyze Cam v4 stands out as a top choice. Designed for seamless integration with Google Assistant, this security camera offers voice control convenience, allowing you to monitor your home hands-free. Whether you want to check live footage or control your camera settings, just ask Google Assistant.
Crystal-Clear 2.5K QHD Resolution
Wyze Cam v4 delivers stunning 2.5K Quad High Definition video quality, capturing every detail with remarkable clarity. This high resolution ensures you never miss a moment, whether it’s day or night.
Enhanced Color Night Vision
Unlike traditional black-and-white night vision, Wyze Cam v4 features
Enhanced Color Night Vision. This technology uses advanced hardware to reveal vibrant colors even in low-light conditions, giving you superhero-like vision to detect intruders or monitor your property after dark.
Motion-Activated Spotlight and Siren
The camera includes a built-in motion-activated spotlight that lights up your surroundings when movement is detected, deterring unwanted visitors. Additionally, a powerful 99 dB siren can be triggered remotely to scare off intruders, adding an extra layer of protection.
24/7 Local Recording with MicroSD Support
Wyze Cam v4 supports continuous local recording to a microSD card (up to 512GB), so you can store days of footage without relying solely on cloud storage. This feature ensures you have access to your video history anytime, even without an internet connection.
Wi-Fi 6 Support for Reliable Connectivity
Equipped with Wi-Fi 6 compatibility, Wyze Cam v4 maintains a stronger and more reliable connection at greater distances, reducing lag and improving video streaming quality.
Smart Detection and Alerts
With motion and sound detection, Wyze Cam v4 sends instant alerts to your phone when activity is detected. You can customize motion detection zones to focus on specific areas, minimizing false alarms. The camera also listens for smoke and CO alarms, alerting you immediately in case of emergencies.
Easy Setup and Versatile Mounting
Setup is hassle-free with Bluetooth® support—no QR codes needed. The camera’s magnetic base and included mounting options (stand, wall, ceiling, or adhesive magnetic mount) make installation quick and tool-free.
Compatibility with Google Assistant and Alexa
Wyze Cam v4 integrates smoothly with Google Assistant, enabling voice commands like “Hey Google, show me the front door camera.” It also supports Amazon Alexa and IFTTT, giving you flexible smart home automation options.
Wyze Cam v4 providing smart home security with voice control
Wyze Cam v4 Home Security Bundle: Comprehensive Protection
For those looking to secure multiple areas, the
Wyze Cam v4 Home Security Bundle offers four cameras with 128GB microSD cards included. This bundle provides everything you need for indoor and outdoor security with the same advanced features:
- 2.5K QHD video resolution with Wide Dynamic Range (WDR) for vibrant colors
- Enhanced Color Night Vision and motion-activated spotlight
- Improved two-way audio for clear communication
- IP65 weather resistance for reliable outdoor use
- Person detection and smart alerts for precise notifications
- 24/7 local recording with ample storage capacity
This bundle is perfect for whole-home coverage, ensuring every corner is monitored with high-quality video and smart alerts.
Wyze Cam v4 Outdoor Bundle: Weatherproof Security with Voice Control
The
Wyze Cam v4 Outdoor Bundle is tailored for outdoor security needs. It includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB microSD card, providing a complete setup for reliable outdoor surveillance.
Key Outdoor Features:
- IP65 weather resistance to withstand rain, snow, and extreme temperatures
- Motion-activated spotlight and siren to deter intruders
- Enhanced Color Night Vision for clear nighttime monitoring
- Wi-Fi 6 support for stable connectivity even in outdoor environments
- Compatibility with Google Assistant and Alexa for voice control
This bundle ensures your outdoor spaces are protected with the same smart features and convenience as indoor cameras.
Wyze Cam v4 outdoor security with enhanced night vision
Why Choose Wyze Cam v4 for Google Assistant Voice Control?
"Wyze Cam v4 combines cutting-edge video quality, smart home integration, and affordable pricing, making it the best security camera for Google Assistant users."
- Voice Control Convenience: Easily view live feeds and control your camera with simple voice commands.
- Advanced Night Vision: See vibrant colors in the dark, unlike traditional cameras.
- Reliable Connectivity: Wi-Fi 6 ensures smooth streaming and quick alerts.
- Flexible Installation: Multiple mounting options and easy setup with Bluetooth.
- Comprehensive Security: Motion, sound, smoke, and CO detection keep you informed and safe.
Whether you want a single camera or a full home security system, Wyze Cam v4 offers unmatched value and smart features tailored for Google Assistant integration.
Wyze Cam v4 monitoring a child’s playroom with voice control
Product Summary
Product Name | Resolution | Night Vision | Voice Assistant Compatibility | Storage | Price Range |
Wyze Cam v4 + FREE 32GB Card | 2.5K QHD | Enhanced Color Night Vision | Google Assistant, Alexa | microSD up to 512GB | $35.98 |
Wyze Cam v4 Home Security Bundle | 2.5K QHD | Enhanced Color Night Vision | Google Assistant, Alexa | 128GB microSD included | $169.99 |
Wyze Cam v4 Outdoor Bundle | 2.5K QHD | Enhanced Color Night Vision | Google Assistant, Alexa | 128GB microSD included | $69.99 |
Conclusion
For a security camera that integrates flawlessly with Google Assistant for voice control, the
Wyze Cam v4 is the clear winner. Its superior video quality, enhanced night vision, smart detection features, and easy setup make it an ideal choice for modern smart homes. Whether you need a single camera or a full security bundle, Wyze Cam v4 offers reliable protection and smart home convenience at an affordable price.
Product Tags Recap
- Wyze Cam v4 + FREE 32GB MicroSD Card:
- Wyze Cam v4 (single and multi-packs):
- Wyze Cam v4 Home Security Bundle:
- Wyze Cam v4 Outdoor Bundle:
What is the video resolution of Wyze Cam v4?
Wyze Cam v4 features a 2.5K Quad High Definition (QHD) resolution, delivering crystal-clear video quality and capturing every detail both day and night.Does Wyze Cam v4 support Google Assistant voice control?
Yes, Wyze Cam v4 is designed for seamless integration with Google Assistant, allowing you to control your camera and view live footage using simple voice commands.How does Enhanced Color Night Vision work on Wyze Cam v4?
Wyze Cam v4 uses advanced hardware to provide Enhanced Color Night Vision, enabling you to see vibrant colors even in low-light conditions, unlike traditional black-and-white night vision cameras.Can Wyze Cam v4 record video locally without cloud storage?
Yes, Wyze Cam v4 supports 24/7 local recording to a microSD card (up to 512GB), allowing you to store days of footage and access your video history even without an internet connection.What smart detection features does Wyze Cam v4 offer?
Wyze Cam v4 provides motion and sound detection, customizable motion detection zones, and can listen for smoke and CO alarms, sending instant alerts to your phone when activity or emergencies are detected.Is Wyze Cam v4 suitable for outdoor use?
Yes, Wyze Cam v4 is IP65 weather resistant, making it reliable for outdoor use in rain, snow, and extreme temperatures. The Outdoor Bundle includes a weatherproof power adapter and a 128GB microSD card for complete outdoor security.What mounting options are available for Wyze Cam v4?
Wyze Cam v4 offers versatile mounting options, including a magnetic base, stand, wall, ceiling, or adhesive magnetic mount, making installation quick and tool-free.Does Wyze Cam v4 support Wi-Fi 6?
Yes, Wyze Cam v4 is equipped with Wi-Fi 6 compatibility, ensuring a stronger and more reliable connection with reduced lag and improved video streaming quality.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes four cameras, each with a 128GB microSD card, offering comprehensive indoor and outdoor security with advanced features like 2.5K QHD video, Enhanced Color Night Vision, motion-activated spotlight, and person detection.What comes with the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB microSD card, providing a complete setup for reliable and weatherproof outdoor surveillance.Is Wyze Cam v4 compatible with Amazon Alexa?
Yes, Wyze Cam v4 is compatible with both Google Assistant and Amazon Alexa, allowing for flexible smart home automation and voice control.How loud is the Wyze Cam v4 siren?
Wyze Cam v4 features a powerful 99 dB siren that can be triggered remotely to deter intruders and enhance your home security.How easy is it to set up Wyze Cam v4?
Wyze Cam v4 offers hassle-free setup with Bluetooth support, eliminating the need for QR codes. Its versatile mounting options make installation quick and easy.What is the price range for Wyze Cam v4 and its bundles?
The Wyze Cam v4 + FREE 32GB Card is priced at $35.98, the Wyze Cam v4 Home Security Bundle at $169.99, and the Wyze Cam v4 Outdoor Bundle at $69.99.
