Top Smart Doorbells Compatible with Alexa & Google Home
Best Smart Doorbells Compatible with Alexa and Google Home Integration
Looking for a smart doorbell that seamlessly integrates with Alexa and Google Home? Discover the top Wyze smart doorbells designed to enhance your home security while offering hands-free voice control. Whether you want wired or battery-powered options, advanced AI detections, or a complete front porch security solution, these smart doorbells deliver convenience, clarity, and connectivity.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Alexa & Google Home
Experience crystal-clear 2K video resolution with the Wyze Video Doorbell v2, the clearest and most capable wired video doorbell from Wyze. This model offers:
  • 2K HD Video & Local microSD Storage: Capture every detail on your porch with stunning 2K resolution and continuous local recording via an onboard microSD card slot.
  • Two-Way Audio & Real-Time Alerts: Communicate instantly with visitors through the Wyze app, no matter where you are.
  • Motion-Activated Voice Deterrence: Automatically warn visitors they’re being recorded with a customizable voice prompt.
  • Works with Existing Chimes: Keep your traditional doorbell chime ringing with the included chime controller.
  • IP65 Weatherproof: Built to withstand rain, snow, and harsh weather conditions.
  • Alexa & Google Home Integration: View live feeds and receive smart alerts on your Alexa or Google Assistant devices.
  • Pre-Roll Motion Recording: Capture 3-6 seconds before motion events for full context.
  • Custom Detection Zones & Quick Responses: Tailor motion alerts and send preset voice messages like “Be there shortly” or “Leave the package at the door.”
This wired doorbell is perfect for homeowners wanting high-resolution video and reliable wired power with smart home compatibility. Wyze Video Doorbell v2 Lifestyle Wyze Video Doorbell v2 installed on a front porch, showcasing smart home security integration.
Wyze Video Doorbell Pro: Wireless or Wired with Ultra-Wide View
For those seeking flexibility, the Wyze Video Doorbell Pro offers both wired and battery-powered installation options with premium features:
  • Wider Ultra-Wide Viewing Angle: Capture more of your porch and surroundings with a broader field of view.
  • Crystal-Clear HD Resolution: Enjoy sharp video quality for clear identification.
  • Fast Notifications & Dual-Band Wi-Fi Extender Chime: Receive alerts quickly and enjoy enhanced Wi-Fi connectivity.
  • Smart Detection Alerts with Cam Plus: Get person, package, vehicle, and pet detection notifications.
  • Motion-Activated Security Light: Automatically illuminate your porch when motion is detected.
  • Two-Way Audio & Quick Responses: Talk to visitors and use preset voice replies.
  • 20 Unique Chime Tunes & Adjustable Volume: Customize your doorbell sound.
  • Alexa & Google Assistant Compatible: Easily view live video and control your doorbell hands-free.
  • Easy Installation: Mount with screws or use a screw-free adhesive plate for quick setup.
Ideal for users who want a versatile, high-performance doorbell with smart home voice assistant integration. Wyze Video Doorbell Pro Installation Wyze Video Doorbell Pro mounted on a stylish home exterior, highlighting easy installation and smart features.
Wyze Duo Cam Battery Doorbell: Advanced Dual-Camera Battery Doorbell
The Wyze Duo Cam Doorbell is the most advanced battery-powered option, featuring dual cameras for comprehensive coverage:
  • Dual Camera Views: Front camera captures 2K video, while the bottom camera monitors packages in 1080p.
  • Two-Way Audio & Real-Time AI Alerts: Communicate with visitors and receive smart notifications for people, packages, and more.
  • Motion-Activated Voice Deterrence: Warn visitors automatically with a recorded message.
  • Includes Wyze Wi-Fi Chime & Removable Battery Pack: Enjoy wireless convenience with included accessories.
  • Supports 24/7 Local Recording: Add a microSD card for continuous recording or use hardwired power.
  • IP65 Weather Resistant: Durable for all weather conditions.
  • Alexa & Google Assistant Integration: View live feeds and control your doorbell with voice commands.
  • Wide Field of View: Front camera offers 132° horizontal and 100° vertical coverage.
Perfect for those who want a wireless, feature-rich doorbell with dual-camera monitoring and smart home compatibility. Wyze Duo Cam Doorbell Lifestyle Wyze Duo Cam Doorbell installed on a modern porch, demonstrating dual-camera coverage and smart home integration.
The Front Porch Security Bundle: Complete Smart Home Solution
For ultimate convenience, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock for comprehensive front door security:
  • Wyze Video Doorbell & Chime: 1080p HD video with two-way audio to see and speak to visitors.
  • Wyze Lock Bolt Matte Black: Lock and unlock your door remotely, view lock history, and control access via the Wyze app.
  • Seamless Integration: Control your doorbell and lock from one app, with Alexa and Google Home compatibility.
  • Remote Access & Notifications: Monitor your front porch and door status from anywhere.
This bundle is perfect for smart home enthusiasts looking for an integrated security and access management system.
Optional Accessory: Wyze Video Doorbell v2 Wedge Kit
Enhance your Wyze Video Doorbell v2 installation with the Wedge Kit accessory:
  • Adjust Viewing Angle: Includes a 15° horizontal bracket and two 7.5° vertical brackets to eliminate blind spots.
  • Weather Resistant & Durable: Made from sturdy plastic with a 1-year warranty.
  • Quick Installation: Easy to mount and compatible exclusively with Doorbell v2.
Ideal for porches with stairs or angled door frames to maximize your doorbell’s field of view.
Why Choose Wyze Smart Doorbells with Alexa and Google Home?
"Wyze smart doorbells offer a perfect blend of high-quality video, smart AI detections, and seamless voice assistant integration, making your home safer and smarter."
  • Voice Assistant Compatibility: Effortlessly view live video and receive alerts on Alexa and Google Home devices.
  • Advanced AI Detection: Get notified about people, packages, vehicles, and pets with Cam Plus subscription.
  • Flexible Power Options: Choose wired or battery-powered models to fit your home setup.
  • Weatherproof & Durable: Designed to withstand all weather conditions.
  • Two-Way Communication: Talk to visitors or delivery personnel from anywhere.
  • Easy Installation: Most models install quickly with included hardware or adhesive options.
Upgrade your home security with Wyze smart doorbells that work perfectly with Alexa and Google Home for a truly connected smart home experience.
Summary of Featured Products
Product NameVideo QualityPower TypeAlexa & Google HomeSpecial Features
Wyze Video Doorbell v22K WiredWiredYesLocal microSD, voice deterrence
Wyze Video Doorbell ProHD Wired/BattWired/BatteryYesUltra-wide view, security light
Wyze Duo Cam Battery DoorbellDual 2K/1080pBattery/WiredYesDual cameras, removable battery
Front Porch Security Bundle1080p WiredWiredYesIncludes Wyze Lock for access control
Wyze Video Doorbell v2 Wedge KitN/AAccessoryN/AAdjustable mounting angles
Enhance your smart home with these Alexa and Google Home compatible doorbells for reliable, intelligent front door security.
FeatureWyze Video Doorbell v2Wyze Video Doorbell ProThe Front Porch Security BundleWyze Duo Cam Battery Doorbell
Video Resolution2K (2048 x 1536)HD (exact resolution not specified)1080p HDFront: 2K (2048 x 1536), Bottom: 1080p
Field of ViewHead-to-toe view (exact degrees not specified)Ultra-wide, head-to-toe view (exact degrees not specified)120° Vertical x 88° HorizontalFront: 132° H x 100° V, Bottom: 121° H x 60° V
Power TypeWiredWired or Battery-poweredWired (Doorbell v2 included)Battery or Hardwired (10-24V AC)
Local StoragemicroSD card slot (continuous local recording)Not specifiedNot specifiedmicroSD support up to 256GB (exFAT)
Cloud Storage14-day free, Cam Plus subscription optional14-day free, Cam Plus subscription optionalNot specifiedAWS Cloud storage
Two-Way AudioYesYesYesYes
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect)YesNot specifiedYes
Night VisionColor Night Vision (Starlight sensor)Not specifiedIR Night Light (4 x 940nm LEDs)IR Night Light (6 x 850 nm LEDs), Color Night Vision
Weather ResistanceIP65Not specifiedIP65IP65
Chime IncludedYes (Chime Controller included)Yes (Wi-Fi Extender chime included)Yes (Wyze Chime included)Yes (Wyze Wi-Fi Chime included)
Quick ResponsesYes (preset quick responses)Yes (preset quick responses)Not specifiedNot specified
AI Detection (Person, Package, Vehicle)With Cam Plus subscriptionWith Cam Plus subscriptionNot specifiedYes (real-time AI detections and alerts)
Installation TimeWired installationWired or wireless, install in 30 secondsWired installation (includes Doorbell v2)Battery or wired installation
Additional FeaturesPre-roll motion recording (3-6 seconds)Motion-activated security lightIncludes Wyze Lock for remote locking/unlockingDual camera views (front and bottom), removable battery pack
Price (USD)$44.98$99.98 (sold out)From $123.99 (bundle including Doorbell v2 and Lock)$89.98 - $109.99
Are Wyze smart doorbells compatible with Alexa and Google Home?Yes, all featured Wyze smart doorbells—including the Wyze Video Doorbell v2, Wyze Video Doorbell Pro, and Wyze Duo Cam Battery Doorbell—are fully compatible with Alexa and Google Home. You can view live video feeds, receive alerts, and control your doorbell hands-free using your preferred voice assistant.
What are the main differences between Wyze Video Doorbell v2 and Wyze Video Doorbell Pro?Wyze Video Doorbell v2 is a wired-only doorbell offering 2K HD video, local microSD storage, and pre-roll motion recording. Wyze Video Doorbell Pro provides both wired and battery-powered installation, an ultra-wide viewing angle, HD video, and a built-in security light. Both models support Alexa and Google Home integration.
Does Wyze offer a battery-powered smart doorbell option?Yes, Wyze offers battery-powered options such as the Wyze Video Doorbell Pro (which can also be wired) and the Wyze Duo Cam Battery Doorbell. These models provide flexible installation and are ideal for homes without existing doorbell wiring.
What advanced security features do Wyze smart doorbells provide?Wyze smart doorbells offer advanced features like AI-powered person, package, vehicle, and pet detection (with Cam Plus subscription), two-way audio, motion-activated voice deterrence, customizable detection zones, and pre-roll motion recording for enhanced security.
Can I use my existing doorbell chime with Wyze Video Doorbell v2?Yes, Wyze Video Doorbell v2 is designed to work with your existing mechanical or digital doorbell chime using the included chime controller, so you can keep your traditional doorbell sound.
Is local video storage available on Wyze smart doorbells?Yes, Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell both support local video storage via a microSD card, allowing for continuous recording and playback without a subscription.
Are Wyze smart doorbells weatherproof?Yes, Wyze smart doorbells are IP65 weatherproof, making them suitable for outdoor installation and able to withstand rain, snow, and harsh weather conditions.
What is the Wyze Duo Cam Battery Doorbell and how does it work?The Wyze Duo Cam Battery Doorbell is a dual-camera, battery-powered smart doorbell. It features a 2K front camera for visitors and a 1080p bottom camera for package monitoring, providing comprehensive coverage of your porch. It supports two-way audio, AI alerts, and works with Alexa and Google Assistant.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell with chime and a Wyze Lock Bolt Matte Black. This bundle allows you to monitor your front porch and control door access remotely, all from the Wyze app, with Alexa and Google Home compatibility.
How easy is it to install Wyze smart doorbells?Wyze smart doorbells are designed for easy installation. The Wyze Video Doorbell Pro and Duo Cam Battery Doorbell offer both screw and adhesive mounting options, while the Wyze Video Doorbell v2 includes all necessary hardware for wired installation. Most models can be set up in minutes.
What is the Wyze Video Doorbell v2 Wedge Kit used for?The Wyze Video Doorbell v2 Wedge Kit is an accessory that allows you to adjust the viewing angle of your doorbell. It includes horizontal and vertical brackets to eliminate blind spots, making it ideal for porches with stairs or angled door frames.
Do Wyze smart doorbells support two-way audio communication?Yes, all Wyze smart doorbells feature two-way audio, allowing you to speak with visitors or delivery personnel directly through the Wyze app, no matter where you are.
Can Wyze smart doorbells detect packages and people?Yes, with a Cam Plus subscription, Wyze smart doorbells can send smart notifications for people, packages, vehicles, and pets, enhancing your front porch security.
What power options are available for Wyze smart doorbells?Wyze offers both wired and battery-powered smart doorbell models. The Wyze Video Doorbell v2 is wired, while the Wyze Video Doorbell Pro and Wyze Duo Cam Battery Doorbell can be installed using either battery or wired power.
What features does the Wyze Video Doorbell v2 offer for home security?Can you tell me more about the installation process for the Wyze Video Doorbell Pro?Are there any ongoing promotions or discounts for Wyze smart doorbells?
