Plug-In Security Cameras with Smart Assistant Integration for Home Safety
Enhance your home safety with advanced plug-in security cameras that seamlessly integrate with smart assistants like Alexa and Google Assistant. These devices offer easy installation, powerful lighting, and crisp video quality to keep your home secure and monitored at all times. Below, explore the top Wyze plug-in security cameras and smart plugs designed to elevate your home security system with smart assistant compatibility.
Wyze Cam Floodlight Plug-In Mount: Simple, Reliable, and Outdoor-Ready
The
Wyze Cam Floodlight Plug-In Mount is the perfect accessory for those who want a hassle-free floodlight camera setup without the need for complex electrical work.
Key Features:
- Plug-n-play installation eliminates the need for a junction box, making setup quick and affordable.
- Compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models.
- Comes with a 20 ft (6m) power cord for flexible placement.
- Designed for outdoor use with an operating temperature range from -22°F to 122°F.
- Certified for safety and durability with multiple UL and RoHS certifications.
- Includes mounting kits and foam tape for secure installation.
This mount is ideal for upgrading your existing Wyze floodlight cameras to a smart, plug-in solution that works effortlessly with your home automation system.
Experience bright, reliable outdoor lighting and security with Wyze Cam Floodlight.
Wyze Cam Floodlight Pro + Plug-In Mount: Premium 2.5K QHD Security with Smart Assistant Integration
For those seeking top-tier video quality and smart home compatibility, the
Wyze Cam Floodlight Pro + Plug-In Mount bundle offers an all-in-one solution.
Highlights:
- 2.5K QHD resolution (2560x1440) delivers crystal-clear video footage.
- Color night vision ensures vibrant, detailed images even in low light.
- Ultra-wide 180° field of view covers large outdoor areas.
- Powerful 3000 lumens floodlight brightens your property.
- Supports microSD cards up to 256GB for local video storage.
- IP65 water resistance rating for reliable outdoor performance.
- Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy plug-in mount with a 20 ft power cord for flexible installation.
- Operates in temperatures from -4°F to 140°F.
This floodlight camera is perfect for homeowners who want a smart, high-resolution security camera with seamless voice assistant integration.
Wyze Cam Floodlight v2 + Plug-In Mount: Advanced 2K HD Security with Smart Features
The
Wyze Cam Floodlight v2 + Plug-In Mount bundle offers a balance of performance and affordability with smart assistant compatibility.
Features:
- 2K HD video quality with vibrant color night vision.
- Wide 160° field of view captures more of your surroundings.
- Advanced motion detection alerts you instantly.
- Bright 2800-lumen LEDs illuminate your outdoor space.
- Built-in 105dB siren for deterrence.
- Includes a 20 ft power cord and plug-in mount for easy installation.
- Compatible with Alexa and Google Assistant for voice commands.
- No junction box needed, simplifying setup.
This model is ideal for users who want reliable floodlight security with smart home integration at a competitive price.
Wyze Plug Outdoor: Smart Power Control for Your Outdoor Devices
Complement your security cameras with the
Wyze Plug Outdoor, a smart plug designed to power outdoor devices with voice assistant support.
Benefits:
- Weather-resistant with an IP64 rating, suitable for rain or shine.
- Control outdoor lights, holiday decorations, or garden equipment via the Wyze app.
- Supports Alexa voice commands for hands-free control.
- Monitor energy usage and set schedules to optimize power consumption.
- Dual outlets with overload protection.
- Operates in temperatures from -4°F to 120°F.
- Connects via 2.4GHz WiFi and Bluetooth V4.2 with up to 300 feet range.
This smart plug is perfect for automating your outdoor environment and enhancing your home’s smart ecosystem.
Wyze Plug: Indoor Smart Plug with Voice Assistant Compatibility
For indoor smart power management, the
Wyze Plug offers a compact and efficient solution.
Features:
- Compatible with Alexa, Google Assistant, and IFTTT for voice control.
- Easy scheduling and remote control through the Wyze app.
- Supports devices up to 15A max output.
- Designed for indoor use with a sleek white finish.
- Operates between -4°F and 104°F.
- Comes in 2-pack or 4-pack options for multiple device control.
Use the Wyze Plug to make your everyday devices smarter and integrate them into your home safety routines.
Control your home devices effortlessly with Wyze Plug and voice assistants.
Why Choose Wyze Plug-In Security Cameras with Smart Assistant Integration?
Wyze offers a range of plug-in floodlight cameras and smart plugs that combine easy installation, powerful lighting, and crisp video quality with seamless integration to Alexa, Google Assistant, and IFTTT. These products empower you to monitor and control your home security system with simple voice commands or app control, enhancing your home safety and convenience.
Summary of Featured Products
Product Name | Resolution / Features | Smart Assistant Integration | Price (USD) |
Wyze Cam Floodlight Plug-In Mount | Mount for floodlight cameras | Compatible with Wyze smart cameras | $19.98 |
Wyze Cam Floodlight Pro + Mount | 2.5K QHD, 180° FOV, 3000 lumens | Alexa, Google Assistant, IFTTT | $169.96 |
Wyze Cam Floodlight v2 + Mount | 2K HD, 160° FOV, 2800 lumens, siren | Alexa, Google Assistant | $109.96 |
Wyze Plug Outdoor | Weather-resistant smart outdoor plug | Alexa | $15.99+ |
Wyze Plug | Indoor smart plug | Alexa, Google Assistant, IFTTT | $24.98+ |
Secure your home effortlessly with Wyze’s plug-in security cameras and smart plugs that bring together convenience, smart assistant integration, and reliable performance.
Quick and easy installation with Wyze plug-in floodlight cameras.
What are the benefits of Wyze plug-in security cameras with smart assistant integration?
Wyze plug-in security cameras offer easy installation, powerful lighting, and high-quality video. They seamlessly integrate with smart assistants like Alexa and Google Assistant, allowing you to monitor and control your home security system using voice commands or the Wyze app for enhanced safety and convenience.Which Wyze floodlight cameras are compatible with the Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro models, providing a simple and reliable installation without the need for a junction box.How easy is it to install Wyze plug-in security cameras?
Wyze plug-in security cameras are designed for plug-n-play installation, eliminating the need for complex electrical work or a junction box. Each mount includes a 20 ft power cord and mounting kits for flexible and secure placement.Do Wyze security cameras work with Alexa and Google Assistant?
Yes, Wyze security cameras such as the Floodlight Pro and Floodlight v2 are compatible with Alexa and Google Assistant, enabling voice control and smart home automation. Some models also support IFTTT for additional integration.What is the video quality of Wyze Cam Floodlight Pro and v2?
The Wyze Cam Floodlight Pro offers 2.5K QHD resolution (2560x1440) with color night vision and a 180° field of view. The Wyze Cam Floodlight v2 provides 2K HD video quality, vibrant color night vision, and a 160° field of view.Are Wyze plug-in security cameras suitable for outdoor use?
Yes, Wyze plug-in security cameras and mounts are designed for outdoor use, with weather-resistant ratings such as IP65 for the Floodlight Pro and operating temperature ranges from as low as -22°F up to 140°F, ensuring reliable performance in various weather conditions.Can I store video footage locally with Wyze security cameras?
Yes, Wyze Cam Floodlight Pro supports microSD cards up to 256GB for local video storage, allowing you to record and access footage without relying solely on cloud storage.What smart plugs does Wyze offer for home automation?
Wyze offers the Wyze Plug Outdoor, a weather-resistant smart plug for outdoor devices, and the Wyze Plug for indoor use. Both support voice control via Alexa, and the indoor plug also works with Google Assistant and IFTTT.How does the Wyze Plug Outdoor enhance outdoor automation?
The Wyze Plug Outdoor features an IP64 weather-resistant rating, dual outlets with overload protection, energy monitoring, scheduling, and Alexa voice command support. It connects via 2.4GHz WiFi and Bluetooth, making it ideal for automating outdoor lights, decorations, or garden equipment.What are the key features of the Wyze Plug for indoor use?
The Wyze Plug is a compact indoor smart plug that supports Alexa, Google Assistant, and IFTTT. It allows for easy scheduling, remote control via the Wyze app, and supports devices up to 15A. It is available in 2-pack or 4-pack options.Do Wyze plug-in security cameras require a junction box for installation?
No, Wyze plug-in security cameras and mounts are designed for easy installation without the need for a junction box, making setup quick and affordable.What is the operating temperature range for Wyze plug-in security products?
Wyze plug-in security cameras and plugs operate in a wide range of temperatures. For example, the Floodlight Plug-In Mount works from -22°F to 122°F, the Floodlight Pro from -4°F to 140°F, and the Wyze Plug Outdoor from -4°F to 120°F.
