Discover the Wyze Cordless Vacuum S: Slim, Powerful, and Perfect for Under-Bed Cleaning
If you're searching for a
slim cordless vacuum that easily reaches under beds and tight spaces, the
Wyze Cordless Vacuum S is your ideal cleaning companion. Designed with a lightweight and slim profile, this vacuum combines powerful suction with smart features to make home cleaning effortless and efficient.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Why Choose Wyze Cordless Vacuum S for Under-Bed Cleaning?
The Wyze Cordless Vacuum S stands out with its
slim design and lightweight build, making it perfect for sliding under beds, sofas, and other hard-to-reach areas. Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, it offers excellent maneuverability without sacrificing power.
- Slim dimensions: 12.4 x 4.5 x 8.7 inches (main unit) and 41.1 inches (assembled)
- Lightweight: Comparable to just 2.8 pounds of feathers
- Color: Steel grey with Wyze green accents for a modern look
Effortless vacuuming under furniture and around pets
Powerful Suction and Long-Lasting Battery for Deep Cleaning
The Wyze Cordless Vacuum S packs a punch with
20,000 Pa suction power in Turbo Mode, ensuring even the most stubborn dust and debris are removed from floors and under furniture.
Suction power modes:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
- Dual motors for enhanced cleaning efficiency
- 6-cell lithium-ion battery with 2,000mAh capacity, interchangeable for extended use
- Charging time: 4-6 hours to full charge
This combination of power and battery life means you can clean your entire home, including those tricky under-bed areas, without interruption.
Advanced Features for a Superior Cleaning Experience
Wyze Cordless Vacuum S is packed with smart features that elevate your cleaning routine:
- LED screen for easy mode and battery monitoring
- 3-stage filtration system including a HEPA filter to trap fine dust and allergens
- 6 daylight-bright LED lights on the brush head illuminate dark spaces under furniture
- Multiple attachments included:
- Crevice Tool for narrow spaces
- Floor Brush for general cleaning
- Dust Cap and HEPA Filter for maintenance
Bright LED lights help clean under furniture and in dark corners
Accessories to Enhance Your Wyze Cordless Vacuum S
To maximize your vacuum’s versatility and lifespan, Wyze offers a range of compatible accessories:
- Battery Pack ($59.99): Extend your cleaning time with an extra battery designed specifically for the Wyze Cordless Vacuum S.
- Charger ($4.99): Replacement charger to keep your vacuum powered up.
- Foldable Vacuum Tube ($15.99): Bends for easier reach under furniture without straining.
- HEPA Filter (2 Pack) ($15.99): Replace regularly to maintain optimal filtration.
- Mini Motorized Brush Head ($29.99): Perfect for cleaning car seats, sofas, and upholstery.
These accessories ensure your vacuum stays efficient and adaptable to all your cleaning needs.
Summary: The Ultimate Slim Cordless Vacuum for Your Home
The
Wyze Cordless Vacuum S is a lightweight, slim, and powerful vacuum designed to tackle hard-to-reach areas like under beds with ease. Its strong suction, long battery life, and smart features make it a top choice for anyone looking to simplify their cleaning routine.
Experience the freedom of cordless cleaning with Wyze — powerful, portable, and perfect for every corner of your home.
What makes the Wyze Cordless Vacuum S ideal for under-bed cleaning?
The Wyze Cordless Vacuum S features a slim and lightweight design, allowing it to easily slide under beds, sofas, and other hard-to-reach areas. Its main unit weighs only 2.8 lbs and measures just 12.4 x 4.5 x 8.7 inches, making it perfect for cleaning tight spaces.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, ensuring deep cleaning of dust and debris from floors and under furniture. It also offers Medium Mode (9,000 Pa) and ECO Mode (6,000 Pa) for versatile cleaning needs.What is the battery life of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is equipped with a 6-cell lithium-ion battery (2,000mAh) that provides up to 40 minutes of runtime in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. The battery is interchangeable for extended cleaning sessions.How long does it take to fully charge the Wyze Cordless Vacuum S?
It takes approximately 4-6 hours to fully charge the Wyze Cordless Vacuum S.What filtration system does the Wyze Cordless Vacuum S use?
The Wyze Cordless Vacuum S features a 3-stage filtration system, including a HEPA filter, to effectively trap fine dust and allergens, ensuring cleaner air in your home.Does the Wyze Cordless Vacuum S have LED lights for cleaning dark areas?
Yes, the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights on the brush head, making it easy to see and clean under furniture and in dark corners.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with multiple attachments, including a Crevice Tool for narrow spaces, a Floor Brush for general cleaning, a Dust Cap, and a HEPA Filter for maintenance.Are there accessories available for the Wyze Cordless Vacuum S?
Yes, Wyze offers a range of accessories for the Cordless Vacuum S, such as an extra Battery Pack, replacement Charger, Foldable Vacuum Tube for easier reach, HEPA Filter (2 Pack), and a Mini Motorized Brush Head for cleaning upholstery and car seats.What color is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes in a modern steel grey color with Wyze green accents.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and the fully assembled vacuum weighs 4.9 lbs, making it easy to maneuver and carry.
