Discover the Wyze Cordless Vacuum S: Low Profile, High Performance Cleaning
If you're searching for a
cordless vacuum with a low profile head that easily slides under couches and furniture, the
Wyze Cordless Vacuum S is your perfect cleaning companion. Designed to combine powerful suction with lightweight portability, this vacuum is ideal for tackling hard-to-reach areas without the hassle of cords.
Why Choose Wyze Cordless Vacuum S?
Ultra-Powerful Suction for Deep Cleaning
The Wyze Cordless Vacuum S boasts an impressive
20,000 Pa suction power in Turbo Mode, ensuring even the most stubborn dirt and pet hair are effortlessly removed. It offers multiple suction modes to suit your cleaning needs:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility lets you balance power and battery life depending on the task.
Lightweight and Ergonomic Design
Weighing just
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as feathers, making it easy to maneuver around your home. Its
low profile head measures only
4.5 inches wide, allowing it to glide effortlessly under couches, beds, and other low-clearance furniture.
Long-Lasting, Interchangeable Battery
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), this vacuum provides up to
40 minutes of continuous cleaning in ECO mode. The battery is interchangeable, so you can extend your cleaning sessions by swapping in a fully charged pack.
Smart Features for Enhanced Usability
- LED screen displays suction mode and battery status clearly.
- Two motors deliver consistent power and efficiency.
- 3-stage filtration system with HEPA filter traps fine dust and allergens.
- 6 daylight-bright LED lights on the brush head illuminate dark corners and under furniture for thorough cleaning.
Effortlessly clean under couches and sofas with the low profile Wyze Cordless Vacuum S
Dimensions & Portability
- Main Unit Dimensions: 12.4 x 4.5 x 8.7 inches
- Assembled Unit Length: 41.1 inches
- Color: Steel grey with Wyze green accents
The slim and sleek design ensures you can store the vacuum easily and reach tight spaces without strain.
Included Attachments for Versatile Cleaning
The Wyze Cordless Vacuum S comes with a comprehensive set of tools to tackle various surfaces and spots:
- Crevice Tool for narrow gaps
- Floor Brush for hard floors and carpets
- Dust Cap
- HEPA Filter and Filter Housing
- Standard Tube
- Quick Start Guide
These attachments enhance the vacuum’s flexibility, making it perfect for homes with pets, kids, and diverse flooring.
Enhance Your Wyze Vacuum Experience with Accessories
To keep your Wyze Cordless Vacuum S running at peak performance or to customize your cleaning, consider these official accessories:
Wyze Cordless Vacuum S - Battery Pack
Need extra runtime? This
replacement battery pack is designed specifically for the Wyze Cordless Vacuum S, allowing you to double your cleaning time without waiting for a recharge.
Price: $59.99
Wyze Cordless Vacuum S - Charger
Keep your vacuum powered up with an official
replacement charger compatible with the Wyze Cordless Vacuum S.
Price: $4.99
This
foldable tube accessory bends to reach awkward angles and tight spaces, reducing the need to contort yourself while cleaning. Compatible only with Wyze Cordless Vacuum models.
Price: $15.99
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
Maintain optimal air quality by regularly replacing your vacuum’s HEPA filters. This pack includes two filters designed exclusively for the Wyze Cordless Vacuum.
Price: $15.99
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning
car seats, sofas, and upholstery, this mini brush head attachment is compact and motorized for deep cleaning in small areas.
Price: $29.99
Pet-friendly and lightweight for everyday home cleaning
Summary: The Ideal Cordless Vacuum for Low Clearance Cleaning
The
Wyze Cordless Vacuum S stands out as a top choice for anyone needing a
cordless vacuum with a low profile head. Its combination of powerful suction, lightweight design, long battery life, and smart features makes it perfect for sliding under couches and cleaning hard-to-reach areas with ease.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." — Wyze
Experience hassle-free, efficient cleaning with the Wyze Cordless Vacuum S and its range of accessories designed to keep your home spotless.
What makes the Wyze Cordless Vacuum S ideal for cleaning under furniture?
The Wyze Cordless Vacuum S features a low profile head that is only 4.5 inches wide, allowing it to easily slide under couches, beds, and other low-clearance furniture. Its lightweight design and slim dimensions make it perfect for reaching hard-to-access areas.How powerful is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers up to 20,000 Pa of suction power in Turbo Mode, making it highly effective at removing stubborn dirt, dust, and pet hair. It also features Medium (9,000 Pa) and ECO (6,000 Pa) modes to balance power and battery life.How long does the battery last on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S provides up to 40 minutes of continuous cleaning in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is interchangeable, so you can extend your cleaning time by swapping in a fully charged battery pack.What smart features does the Wyze Cordless Vacuum S offer?
The vacuum includes an LED screen that displays suction mode and battery status, two motors for consistent power, a 3-stage filtration system with a HEPA filter, and six LED lights on the brush head to illuminate dark corners and under furniture.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a crevice tool for narrow gaps, a floor brush for hard floors and carpets, a dust cap, a HEPA filter and filter housing, a standard tube, and a quick start guide. These attachments make it versatile for various cleaning needs.Is the Wyze Cordless Vacuum S suitable for homes with pets?
Yes, the Wyze Cordless Vacuum S is pet-friendly. Its powerful suction and HEPA filtration system effectively remove pet hair and allergens, making it ideal for homes with pets.What are the dimensions and weight of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and weighs just 2.8 lbs. When fully assembled, it is 41.1 inches long and weighs 4.9 lbs, making it lightweight and easy to maneuver.What accessories are available for the Wyze Cordless Vacuum S?
Official accessories include a replacement battery pack, replacement charger, foldable vacuum tube for reaching awkward angles, a 2-pack of HEPA filters, and a mini motorized brush head for cleaning car seats, sofas, and upholstery.How does the HEPA filtration system in the Wyze Cordless Vacuum S work?
The Wyze Cordless Vacuum S uses a 3-stage filtration system with a HEPA filter to trap fine dust and allergens, ensuring cleaner air and a healthier home environment.Can I extend the cleaning time of my Wyze Cordless Vacuum S?
Yes, you can extend your cleaning sessions by purchasing an additional interchangeable battery pack, allowing you to swap batteries and continue cleaning without waiting for a recharge.
