Best Wyze Security Cameras for Android & iOS: Cam v4 & More
Best Security Cameras Compatible with Android and iOS: Featuring Wyze Cam v4
When it comes to securing your home or business, having a reliable security camera that works seamlessly with both Android and iOS devices is essential. Wyze offers a range of smart cameras designed to provide crystal-clear video, smart notifications, and easy integration with your mobile devices. Among these, the Wyze Cam v4 stands out as a top choice for its advanced features and affordability. This guide highlights the Wyze Cam v4 and other compatible Wyze cameras, helping you choose the perfect security solution for your needs.
Wyze Cam v4: The Ultimate Smart Security Camera
Crystal-Clear 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 delivers stunning 2.5K Quad High Definition video, capturing every detail with vibrant colors thanks to its Wide Dynamic Range (WDR) technology. Unlike traditional night vision, the enhanced color night vision lets you see more clearly in low-light conditions, revealing details invisible to the naked eye.
Smart Features for 24/7 Protection
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB) without any subscription fees.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for uninterrupted monitoring.
  • Smart Alerts: Receive instant notifications on your Android or iOS device for motion, sound, smoke, or CO alarms.
  • AI Auto-Zoom & Smart Focus: The camera intelligently tracks movement, focusing on what matters while keeping the bigger picture in view.
Easy Setup & Integration
Wyze Cam v4 uses Bluetooth® for hassle-free setup without QR codes. It also integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation.
Weather-Resistant & Versatile
With an IP65 rating, Wyze Cam v4 is suitable for both indoor and outdoor use, capable of withstanding rain, snow, and dust. Wyze Cam v4 lifestyle Wyze Cam v4 mounted outdoors for home security
Wyze Cam v4 Home Security Bundle: Comprehensive Protection
For those looking to secure multiple areas, the Wyze Cam v4 Home Security Bundle offers four Wyze Cam v4 units paired with four 128GB microSD cards. This bundle provides:
  • All the features of the Wyze Cam v4 in a convenient package.
  • Ample local storage for continuous recording across multiple cameras.
  • Cost savings compared to buying cameras and storage separately.
Ideal for whole-home coverage, this bundle ensures you never miss a moment, day or night.
Additional Wyze Cameras Compatible with Android and iOS
Wyze Cam Pan v3: 360° Pan & 180° Tilt for Full Coverage
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera with a 360° horizontal and 180° vertical field of view. It offers:
  • 1080p HD video with 4 IR LEDs for night vision.
  • 8x digital zoom and smooth pan/tilt control to track movement.
  • IP65 weather resistance for outdoor use (requires outdoor power adapter).
  • Two-way audio with noise and echo cancellation.
  • Compatibility with Android 9.0+ and iOS 15.0+ devices.
  • Integration with Alexa, Google Assistant, and IFTTT.
This camera is perfect for monitoring large rooms or outdoor spaces with dynamic coverage. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather-resistant for outdoor use
Wyze Cam Floodlight v2: Bright Security with 2K Video
The Wyze Cam Floodlight v2 combines powerful lighting and security with:
  • 2800 lumens of dimmable LED light panels.
  • 2K video resolution with color night vision.
  • 160° wide-angle field of view.
  • Built-in siren (105 dB) and two-way audio.
  • Dusk-to-dawn automation and AI-powered light control.
  • IP65 weather resistance for reliable outdoor performance.
  • Compatible with Android 9.0+ and iOS 15.0+ devices, plus Alexa, Google Assistant, and IFTTT.
This camera is ideal for illuminating and securing driveways, porches, and backyards. Wyze Cam Floodlight v2 illuminating driveway Wyze Cam Floodlight v2 lighting up a driveway with smart security
Wyze Bulb Cam: Discreet Outdoor Security & Smart Lighting
The Wyze Bulb Cam is a unique 2-in-1 device that functions as both a smart LED bulb and a security camera. Features include:
  • 2K HD video with color night vision.
  • Motion-activated light and ambient light control.
  • Fits standard E26 sockets for easy installation.
  • Supports local storage up to 256GB microSD cards.
  • Two-way audio and 95 dB siren.
  • IP65 weather resistance for outdoor use.
  • Compatible with Android 7.0+ and iOS 14.0+ devices.
Perfect for those who want a subtle security camera integrated into existing light fixtures.
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security
For flexible placement without wiring hassles, the Wyze Battery Cam Pro offers:
  • 2.5K HDR video resolution.
  • Wire-free operation with rechargeable battery packs.
  • Integrated spotlight and siren.
  • Radar + PIR motion detection for accurate alerts.
  • IP65 weatherproof design.
  • Dual-band Wi-Fi (2.4 & 5 GHz) support.
  • Compatible with Android and iOS devices.
Ideal for locations where power outlets are unavailable or for quick deployment.
Why Choose Wyze Cameras for Android and iOS?
Wyze cameras provide a perfect blend of affordability, advanced technology, and seamless mobile compatibility. Whether you use an Android or iOS device, Wyze’s intuitive app ensures you stay connected to your home security anytime, anywhere.
  • Cross-platform compatibility: Works flawlessly with Android and iOS apps.
  • Smart home integration: Supports Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Local and cloud storage options: Flexible recording solutions to fit your preferences.
  • Weather-resistant designs: Suitable for indoor and outdoor use.
  • Affordable pricing: High-end features without breaking the bank.
Conclusion
For those seeking security cameras compatible with both Android and iOS devices, the Wyze Cam v4 and its related Wyze camera lineup offer exceptional value and performance. From the advanced Wyze Cam v4 with 2.5K resolution and color night vision to the versatile Pan v3 and powerful Floodlight v2, Wyze has a solution for every security need. Choose Wyze for smart, reliable, and easy-to-use security cameras that keep your home safe day and night.
Product Tags Summary
FeatureWyze Cam v4Wyze Cam v4 Home Security BundleWyze Cam Pan v3Wyze Cam Floodlight v2Wyze Bulb CamWyze Battery Cam Pro
Price$35.98 (1 Pack)$169.99 (4 Cameras + 4x 128GB microSD)$39.98 (1 Pack)$89.98$49.98$159.98 (1 Pack)
Video Resolution2.5K QHD (2560 x 1440)2.5K QHD (2560 x 1440)1080p (1920 x 1080)2K (2304 x 1296)2K (2304 x 1296)2.5K HDR (2560 x 1440)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)Same as Wyze Cam v4360° horizontal, 180° vertical160° diagonal160° diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionIR Night Vision (4 IR LEDs)Color Night VisionColor Night VisionIR LEDs + White LEDs (Color Night)
AudioEnhanced Two-Way TalkImproved 2-Way AudioTwo-Way Audio with Noise & Echo CancellationTwo-Way AudioTwo-Way AudioTwo-Way Audio with MEMS Mic
Siren99 dBNot specified (likely same as v4)Not specified105 dB95 dB100 dB
SpotlightMotion-Activated SpotlightIncluded (4 Cameras)NoIntegrated LED Floodlight (2800 lumens)NoIntegrated Spotlight
Power SourceWiredWiredWiredHardwiredStandard E26 Socket (120V AC)Rechargeable Battery Packs (wireless)
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GB (128GB cards included)microSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Wi-Fi SupportWi-Fi 6Wi-Fi 62.4 GHz only (802.11 b/g/n)2.4 GHz (802.11 b/g/n)2.4 GHz (802.11 b/g/n)2.4 & 5 GHz (802.11a/n/g/b)
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Special FeaturesMotion-activated spotlight, Smoke & CO alerts, AI Auto-ZoomBundle includes 4 cameras + 4x 128GB microSD cards360° pan, 180° tilt, 8x digital zoom2800 Lumens LED floodlight, Ambient Light Mode, AI-Powered Light Control2-in-1 camera & smart LED bulb, motion-activated lightRadar + PIR motion detection, removable battery, up to 6 months battery life
DimensionsNot specifiedSame as Wyze Cam v4124mm x 60mm x 63mm9.5in x 7.7in x 7.0inNot specified2.5 x 1.8 x 3.5 inches
WeightNot specifiedSame as Wyze Cam v411.29 oz (320 g)2.76 lbs (1.25 kg)Not specified0.94 lbs
WarrantyNot specifiedNot specified1 Year1 Year1 YearNot specified
What are the best security cameras compatible with both Android and iOS devices?Wyze offers several top-rated security cameras that work seamlessly with both Android and iOS devices, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Bulb Cam, and Wyze Battery Cam Pro. These cameras provide advanced features, easy mobile integration, and reliable performance for home and business security.
What makes the Wyze Cam v4 a top choice for home security?The Wyze Cam v4 stands out for its 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight and siren, 24/7 local recording to microSD card, Wi-Fi 6 support, smart alerts, AI auto-zoom, and easy Bluetooth setup. It is weather-resistant (IP65 rated) and integrates with Alexa, Google Assistant, and IFTTT for smart home automation.
Does the Wyze Cam v4 support continuous recording without a subscription?Yes, the Wyze Cam v4 supports 24/7 continuous local recording to a microSD card (up to 256GB) without requiring any subscription fees, allowing you to store and review footage at your convenience.
Are Wyze security cameras weather-resistant for outdoor use?Many Wyze cameras, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Bulb Cam, and Wyze Battery Cam Pro, feature IP65 weather resistance, making them suitable for both indoor and outdoor use in various weather conditions.
Can Wyze cameras be integrated with smart home systems?Yes, Wyze cameras are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, enabling voice control and automation for enhanced convenience and security.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes four Wyze Cam v4 units and four 128GB microSD cards, providing comprehensive coverage and ample local storage for continuous recording across multiple areas of your home or business.
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 360° pan and 180° tilt for full coverage, 1080p HD video, night vision with 4 IR LEDs, 8x digital zoom, two-way audio, IP65 weather resistance, and compatibility with Android 9.0+ and iOS 15.0+ devices. It also integrates with Alexa, Google Assistant, and IFTTT.
How does the Wyze Cam Floodlight v2 enhance outdoor security?The Wyze Cam Floodlight v2 combines 2800 lumens of dimmable LED lighting with 2K video resolution, color night vision, a 160° wide-angle view, built-in siren, two-way audio, dusk-to-dawn automation, and AI-powered light control. It is IP65 weather-resistant and compatible with Android and iOS devices.
What is unique about the Wyze Bulb Cam?The Wyze Bulb Cam is a 2-in-1 device that functions as both a smart LED bulb and a security camera. It features 2K HD video, color night vision, motion-activated lighting, easy installation in standard E26 sockets, local storage support, two-way audio, and IP65 weather resistance.
Is there a wire-free security camera option from Wyze?Yes, the Wyze Battery Cam Pro is a wire-free security camera that offers 2.5K HDR video, rechargeable battery packs, integrated spotlight and siren, radar and PIR motion detection, IP65 weatherproof design, dual-band Wi-Fi support, and compatibility with both Android and iOS devices.
Why should I choose Wyze cameras for Android and iOS compatibility?Wyze cameras are designed for seamless cross-platform compatibility, offering intuitive apps for both Android and iOS. They provide advanced features, smart home integration, flexible storage options, weather-resistant designs, and affordable pricing, making them an excellent choice for reliable home security.
What are the key features of the Wyze Cam v4 that make it stand out?Can you explain how the Wyze Cam v4 integrates with smart home devices like Alexa and Google Assistant?Are there any ongoing promotions or discounts available for the Wyze Cam v4?
