Top Wyze Smart 2-Way Cameras for Home Security & Communication
Discover the Best Smart 2-Way Cameras for Home Security
When it comes to securing your home with smart technology, 2-way cameras offer the perfect blend of surveillance and communication. Whether you want to monitor your front porch, keep an eye on pets, or talk to visitors remotely, these smart 2-way cams provide crystal-clear video and seamless two-way audio. Explore the top Wyze smart 2-way cameras designed to fit various needs, from wired floodlight cams to wireless battery-powered options.
Wyze Cam Floodlight v2: Powerful Smart Floodlight Camera with Two-Way Talk
Experience ultimate outdoor security with the
Wyze Cam Floodlight v2, a smart 2-way camera that combines bright lighting and high-quality video surveillance.
Key Features:
- 2K Video with Color Night Vision: Capture sharp 2304 x 1296 resolution footage day and night with vivid color even in low light.
- 2800 Lumens Dimmable LED Floodlights: Illuminate your driveway or backyard with powerful, adjustable lighting.
- 160° Wide-Angle View: Covers a broad area to reduce blind spots.
- Two-Way Audio: Built-in speaker and microphone allow you to communicate directly through the camera.
- AI-Powered Light Control & Dusk-to-Dawn Automation: Lights activate intelligently based on motion and ambient light.
- Weather Resistant (IP65): Durable polycarbonate body designed to withstand outdoor elements.
- Local Storage & Smart Assistant Integration: Supports up to 256 GB microSD cards and works with Alexa, Google Assistant, and IFTTT.
Dominate the dark and keep your home safe with a smart floodlight camera that talks back.
Bright, smart floodlight camera for outdoor security
Wyze Cam v4: High-Resolution Outdoor Smart Camera with Two-Way Audio
For those seeking a versatile wired camera with advanced features, the
Wyze Cam v4 offers exceptional video quality and smart communication.
Highlights:
- 2.5K QHD Resolution: Ultra-clear 2560 x 1440 video for detailed monitoring.
- Enhanced Color Night Vision & Motion-Activated Spotlight: See everything clearly, even in the dark.
- Two-Way Talk with Noise & Echo Cancellation: Crisp audio for seamless conversations.
- Wi-Fi 6 Support & Alexa/Google Assistant Compatibility: Future-proof connectivity and smart home integration.
- IP65 Weatherproof: Reliable for both indoor and outdoor use.
- Local Storage up to 512 GB & Cloud Options: Flexible storage solutions to keep your footage safe.
Stay connected and secure with a smart camera that delivers crystal-clear video and instant communication.
Wyze Cam Pan v3: 360° Pan-Tilt Smart Camera with Two-Way Talk
Cover every angle with the
Wyze Cam Pan v3, a smart 2-way camera designed for full-room or outdoor surveillance with pan and tilt capabilities.
Features:
- 360° Horizontal & 180° Vertical View: Pan and tilt to monitor every corner.
- 1080p HD Video with Night Vision: Clear video quality day and night.
- Two-Way Audio with Noise & Echo Cancellation: Talk and listen without distortion.
- IP65 Weather Resistance: Suitable for outdoor use with the optional power adapter.
- Supports up to 256 GB microSD Storage: Local recording for continuous monitoring.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
Perfect for dynamic monitoring with the ability to talk and listen from anywhere.
Versatile pan-tilt camera for indoor/outdoor use
Wyze Battery Cam Pro: Wire-Free Smart Camera with Two-Way Audio
Enjoy the freedom of wireless security with the
Wyze Battery Cam Pro, a smart 2-way camera that requires no hub and offers long-lasting battery life.
Standout Specs:
- 2.5K HDR Video Resolution: High-definition video with vibrant colors.
- Integrated Spotlight & Siren: Deter intruders with bright light and loud siren.
- Radar + PIR Motion Detection: Advanced sensors for accurate alerts.
- Up to 6 Months Battery Life: Rechargeable battery packs for extended use.
- Two-Way Audio: Built-in speaker and microphone for real-time communication.
- Dual-Band Wi-Fi (2.4 & 5 GHz) & IP65 Weatherproof: Reliable wireless connection and outdoor durability.
Ideal for flexible placement without wiring hassles, with smart communication built-in.
Wyze Cam OG: Affordable Smart Camera with Two-Way Talk and Spotlight
For budget-conscious users, the
Wyze Cam OG offers essential smart 2-way communication and security features.
Features Include:
- 1080p HD Video with Color Night Vision: Clear video quality day and night.
- Built-in Spotlight & 90 dB Siren: Enhanced security with light and sound deterrents.
- Two-Way Audio with Noise & Echo Cancellation: Communicate clearly through the camera.
- Fast Live Streaming & Custom Detection Zones: Quick alerts and tailored monitoring.
- IP65 Weather Resistance: Suitable for indoor and outdoor use.
- Supports up to 256 GB microSD Storage: Local video storage without subscription.
A reliable, budget-friendly smart camera with two-way talk and spotlight.
Wyze Bulb Cam: 2-in-1 Smart LED Bulb and Camera with Two-Way Audio
Combine lighting and security with the
Wyze Bulb Cam, a unique smart 2-way camera integrated into a standard light bulb.
Key Benefits:
- 2K HD Video with Color Night Vision: Clear footage with wide 160° field of view.
- Up to 800 Lumens Brightness: Powerful LED light with motion-activated and scheduled controls.
- Two-Way Audio: Built-in microphone and speaker for communication.
- Easy Installation: Fits standard E26 sockets, perfect for porches or garages.
- Local Storage Support up to 256 GB: No subscription needed for video storage.
- IP65 Weatherproof: Durable for outdoor use.
Perfect for discreet security with smart lighting and two-way communication.
Smart bulb camera combining light and security
Why Choose Wyze Smart 2-Way Cameras?
Smart 2-way cameras from Wyze provide not only high-quality video surveillance but also seamless communication, allowing you to interact with visitors, pets, or intruders in real-time. With features like color night vision, weather resistance, and smart home integration, these cameras are designed to keep your home safe and connected 24/7.
Whether you prefer wired floodlight cams, pan-tilt models, wireless battery cams, or innovative bulb cams, Wyze offers a smart 2-way camera to fit your lifestyle and security needs.
Summary of Smart 2-Way Cameras by Wyze
Model | Video Resolution | Two-Way Audio | Power Source | Weatherproof | Special Features |
Wyze Cam Floodlight v2 | 2K (2304x1296) | Yes | Hardwired | IP65 | 2800 Lumens floodlight, AI lighting |
Wyze Cam v4 | 2.5K QHD | Yes | Wired (5V adapter) | IP65 | Wi-Fi 6, motion spotlight |
Wyze Cam Pan v3 | 1080p HD | Yes | Wired (5V adapter) | IP65 | 360° pan-tilt, noise cancellation |
Wyze Battery Cam Pro | 2.5K HDR | Yes | Rechargeable Battery | IP65 | Radar + PIR detection, 6-month life |
Wyze Cam OG | 1080p HD | Yes | Wired (5V adapter) | IP65 | Budget-friendly, spotlight & siren |
Wyze Bulb Cam | 2K HD | Yes | 120V AC (bulb socket) | IP65 | 2-in-1 bulb & camera, motion light |
Secure your home smarter with Wyze’s range of smart 2-way cameras tailored for every environment and budget.
Feature | Wyze Cam Floodlight v2 | Wyze Cam v4 | Wyze Cam Pan v3 | Wyze Battery Cam Pro | Wyze Cam OG | Wyze Bulb Cam |
Type | Floodlight Camera | Wired Camera | Pan/Tilt Wired Camera | Battery Camera | Wired Camera | Bulb Camera |
Price (USD) | $89.98 | $35.98 (1 Pack) | $39.98 (1 Pack) | $159.98 (1 Pack) | $29.98 (1 Pack) | $49.98 |
Color Options | Black, White | Black, White, Grey, Clear | Black, White | Black, White | Black, White | N/A |
Video Resolution | 2K (approx. 1920x1080+) | 2.5K QHD (2560x1440) | 1080p (1920x1080) | 2.5K HDR (2560x1440) | 1080p (1920x1080) | 2K (2304x1296) |
Field of View (FOV) | 160° wide-angle | 115.9° (D) x 98.5° (H) x 53.1° (V) | 360° horizontal, 180° vertical | 134° (DFOV), 108° (HFOV), 56° (VFOV) | 120° | 160° diagonal (166°), horizontal 144°, vertical 82.5° |
Night Vision | Color Night Vision | Enhanced Color Night Vision | 4 IR LEDs (850 nm) | 2 IR LEDs + 2 White LEDs (187 lumens) | 4 IR LEDs (850 nm) | Color Night Vision + IR Night Vision |
Lighting | 2 x 2800 Lumens LEDs, motion-activated | Motion-activated spotlight | No built-in floodlight | Integrated Spotlight | Built-in 40 Lumens Spotlight | Smart LED bulb, up to 800 lumens |
Audio | Two-way talk + 105 dB siren | Enhanced two-way talk + 99 dB siren | Two-way audio, noise & echo cancellation | Two-way audio + 100 dB siren | Built-in speaker & mic, noise & echo cancellation | Two-way audio, 95 dB siren |
Motion Detection | 270° PIR motion detection area | Motion & sound detection, custom zones | Push notifications | Radar + PIR motion detection | Motion detection, custom zones | Motion warning, push notifications |
Local Storage | microSD up to 256 GB | microSD up to 256 GB | microSD up to 256 GB | microSD up to 256 GB | microSD up to 256 GB | microSD up to 256 GB |
Cloud Storage | Optional Cam Plus subscription | Optional Cam Plus subscription | Optional Cam Plus subscription | Optional Cam Plus subscription | Optional Cam Plus subscription | Cloud storage via AWS |
Power Source | Wired | Wired | Wired | Battery (removable, rechargeable) | Wired | Wired (standard E26 socket) |
Weather Resistance | IP65 | IP65 | IP65 | IP65 | IP65 | IP65 |
Connectivity | Wi-Fi 2.4 GHz | Wi-Fi 6 (2.4 GHz) | Wi-Fi 2.4 GHz | Wi-Fi 2.4 & 5 GHz | Wi-Fi 2.4 GHz | Wi-Fi 2.4 GHz |
Smart Assistant Integration | Alexa, Google Assistant | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant |
Special Features | AI-Powered Light Control, Ambient Light Mode, Dusk-to-Dawn Automation | Wi-Fi 6 support, Auto-zoom with AI, Smoke & CO alerts | 360° pan, 180° tilt, 8x digital zoom | Wire-free, radar motion detection, up to 6 months battery life | Faster live streaming, 3X faster notifications | 2-in-1 camera and smart bulb, manual & motion-activated light control |
Dimensions | Not specified | Not specified | 124mm x 60mm x 63mm | 2.5 x 1.8 x 3.5 inches | 1.89 x 1.89 x 1.89 inches | Telescoping length 1.18 in (3 cm) |
Weight | Not specified | Not specified | 11.29 oz (320 g) | 0.94 lbs (approx. 426 g) | 4.1 oz (116 g) | Not specified |
Warranty | Not specified | Not specified | 1 Year | Not specified | 1 Year | 1 Year |
What are smart 2-way cameras and how do they enhance home security?
Smart 2-way cameras are advanced security devices that provide both high-quality video surveillance and two-way audio communication. This allows homeowners to monitor their property, interact with visitors, pets, or deter intruders in real-time, enhancing overall home security and convenience.Which Wyze smart 2-way camera is best for outdoor security?
The Wyze Cam Floodlight v2 is ideal for outdoor security. It features 2K video resolution, 2800 lumens dimmable LED floodlights, a 160° wide-angle view, two-way audio, AI-powered light control, and IP65 weather resistance, making it perfect for illuminating and monitoring driveways, backyards, and entrances.What features does the Wyze Cam v4 offer for home monitoring?
The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, two-way talk with noise and echo cancellation, Wi-Fi 6 support, Alexa and Google Assistant compatibility, IP65 weatherproofing, and flexible storage options up to 512 GB locally or via the cloud.Can I use Wyze smart 2-way cameras indoors and outdoors?
Yes, most Wyze smart 2-way cameras, including the Wyze Cam Floodlight v2, Cam v4, Cam Pan v3, Battery Cam Pro, Cam OG, and Bulb Cam, are IP65 weather resistant, making them suitable for both indoor and outdoor use.What is the benefit of two-way audio in Wyze cameras?
Two-way audio in Wyze cameras allows you to communicate directly through the camera using its built-in microphone and speaker. This feature is useful for talking to visitors, instructing delivery personnel, checking in on pets, or warning potential intruders.Are there wireless Wyze smart 2-way camera options available?
Yes, the Wyze Battery Cam Pro is a wire-free smart camera with two-way audio, 2.5K HDR video, integrated spotlight and siren, radar and PIR motion detection, up to 6 months of battery life, and IP65 weatherproofing, making it ideal for flexible placement without wiring.What is the Wyze Cam Pan v3 and how does it provide full-room coverage?
The Wyze Cam Pan v3 is a smart 2-way camera with 360° horizontal and 180° vertical pan-tilt capabilities, 1080p HD video, night vision, two-way audio with noise and echo cancellation, and IP65 weather resistance. It allows you to monitor every corner of a room or outdoor area remotely.Is there a budget-friendly Wyze smart 2-way camera option?
Yes, the Wyze Cam OG is an affordable smart camera that offers 1080p HD video, color night vision, a built-in spotlight and 90 dB siren, two-way audio with noise and echo cancellation, fast live streaming, custom detection zones, and IP65 weather resistance.What makes the Wyze Bulb Cam unique among smart 2-way cameras?
The Wyze Bulb Cam is a 2-in-1 device that combines a smart LED bulb with a security camera. It offers 2K HD video, color night vision, up to 800 lumens brightness, two-way audio, easy installation in standard E26 sockets, local storage up to 256 GB, and IP65 weatherproofing.Do Wyze smart 2-way cameras support local storage?
Yes, most Wyze smart 2-way cameras support local storage via microSD cards, with capacities ranging from up to 256 GB to 512 GB depending on the model. This allows for continuous recording and playback without a subscription.Can Wyze smart 2-way cameras be integrated with smart home systems?
Yes, Wyze smart 2-way cameras are compatible with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, enabling seamless integration and voice control within your smart home ecosystem.What is the difference between the various Wyze smart 2-way camera models?
Wyze offers a range of smart 2-way cameras to suit different needs: the Floodlight v2 for powerful outdoor lighting and security, Cam v4 for high-resolution wired monitoring, Cam Pan v3 for 360° coverage, Battery Cam Pro for wireless flexibility, Cam OG for budget-friendly security, and Bulb Cam for discreet lighting and surveillance.
What are the key features of the Wyze Cam Floodlight v2?Can you tell me more about the video quality of the Wyze Cam v4?Are there any ongoing promotions or discounts for Wyze cameras?
