Secure Wall Mount Kit for All Wyze Cam Versions at Home
When it comes to securing your home with Wyze cameras, having the right mounting accessories is essential. Whether you own a Wyze Cam v2, v3, v3 Pro, or the latest Wyze Cam v4, this guide covers the best secure wall mount kits and accessories designed to provide stable, flexible, and weather-resistant installation options for your smart home security.
Wyze Cam Mounting Kit: The Essential Mount for Wyze Cam v2, v3, and v3 Pro
Reliable and Easy Installation
The
Wyze Cam Mounting Kit is specifically designed for Wyze Cam v2, v3, and v3 Pro models. This kit includes a sturdy mounting bracket, strong adhesive for secure placement, and a longer Micro USB cable to ensure your camera can be positioned exactly where you need it without worrying about power constraints.
- Compatible with Wyze Cam v2, v3, and v3 Pro
- Includes mounting bracket, adhesive, and extended Micro USB cable
- Simple installation for indoor or outdoor use
- Affordable and effective solution at $5.99
This mounting kit is perfect for users who want a hassle-free way to secure their Wyze cameras on walls or ceilings, providing a stable base that keeps your camera safe and optimally positioned.
Wyze Window Mount: Clear View with No Glare or Reflection
Perfect for Glass Surfaces
For those who want to mount their Wyze Cam v3, v3 Pro, or v4 on a window, the
Wyze Window Mount offers a unique solution. This accessory attaches your camera directly to glass surfaces, eliminating glare and reflections that can interfere with image quality.
- Compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto
- Provides a clear, unobstructed view through windows
- Ideal for RVs, campers, or homes with large glass areas
- Easy to install and reposition as needed
This mount enhances your exterior security by allowing you to place your camera inside while still monitoring outdoor areas clearly.
Wyze Universal Mount (Long): Versatile and Durable Mounting Solution
Extended Reach and Flexibility
The
Wyze Universal Mount (Long) is a heavy-duty metal mount with a longer neck, designed for versatile mounting applications such as ceilings, patios, or other hard-to-reach spots. It supports all Wyze cameras with a standard 1/4”-20 mount, including Wyze Cam v1, v2, v3, v3 Pro, and Pan versions.
- Durable metal construction with adjustable angles
- Supports up to 2 kg (70 oz) load-bearing capacity
- Includes screws and drywall anchors for secure installation
- Not compatible with Wyze Cam OG or OG Telephoto
This mount is perfect for users who need a robust and flexible mounting option that can be adjusted to capture the best angles for home security.
Wyze Cam v4: Advanced Camera with Multiple Mounting Options
Cutting-Edge Security Camera with Secure Mounting
The
Wyze Cam v4 is the latest in Wyze’s lineup, offering 2.5K QHD resolution, enhanced color night vision, and a motion-activated spotlight. It supports multiple mounting options including wall mount, ceiling mount, stand, and magnetic wall mount with adhesive, making it highly adaptable for secure installation.
- 2.5K QHD video resolution with wide dynamic range
- IP65 weather resistance for outdoor durability
- Multiple mounting options: wall, ceiling, magnetic adhesive, and stand
- Compatible with Alexa, Google Assistant, and IFTTT
- Includes a wall mount plate, screw kit, and 6-foot flat micro USB cable
With its polycarbonate body and glass/plastic lens, the Wyze Cam v4 is designed for both indoor and outdoor use, providing reliable security with flexible mounting solutions.
Wyze Cam Floodlight Plug-In Mount: Easy Power Solution for Floodlight Cameras
Simplify Outdoor Floodlight Installation
For Wyze Cam Floodlight users, the
Wyze Cam Floodlight Plug-In Mount offers a plug-and-play power solution that eliminates the need for complex junction box installations. This mount comes with a durable 20-foot cable and a velcro strap for clean cable management.
- Compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro
- No electrician or junction box required
- Easy installation with outdoor-rated cable
- Available in black or white to match your home exterior
This mount is ideal for those who want to add powerful lighting and security without the hassle or cost of professional electrical work.
Secure your home with easy-to-install Wyze floodlight mounts.
Conclusion
Choosing the right secure wall mount kit for your Wyze camera depends on your specific model and installation needs. Whether you want a simple mounting bracket for your Wyze Cam v3, a window mount for glare-free views, a versatile universal mount for flexible positioning, or a plug-in mount for your floodlight camera, Wyze offers reliable and affordable accessories to keep your home safe and your cameras securely installed.
Invest in these mounting solutions to maximize your Wyze camera’s performance and ensure your home security system is both effective and aesthetically pleasing.
What is the best wall mount kit for Wyze Cam v2, v3, and v3 Pro?
The Wyze Cam Mounting Kit is specifically designed for Wyze Cam v2, v3, and v3 Pro. It includes a sturdy mounting bracket, strong adhesive, and an extended Micro USB cable for easy and secure installation on walls or ceilings, both indoors and outdoors.Can I mount my Wyze Cam on a window without glare or reflection?
Yes, the Wyze Window Mount is designed for Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto. It attaches directly to glass surfaces, eliminating glare and reflections for a clear, unobstructed view, making it ideal for homes, RVs, and campers.Which Wyze mount is suitable for hard-to-reach places like ceilings or patios?
The Wyze Universal Mount (Long) is a heavy-duty metal mount with an extended neck, perfect for ceilings, patios, and other challenging locations. It supports all Wyze cameras with a standard 1/4”-20 mount, except for Wyze Cam OG and OG Telephoto.What mounting options are available for the Wyze Cam v4?
The Wyze Cam v4 supports multiple mounting options, including wall mount, ceiling mount, stand, and magnetic wall mount with adhesive. It comes with a wall mount plate, screw kit, and a 6-foot flat micro USB cable for flexible installation indoors or outdoors.Is there an easy way to install Wyze Cam Floodlight without a junction box?
Yes, the Wyze Cam Floodlight Plug-In Mount offers a plug-and-play power solution with a 20-foot outdoor-rated cable and velcro strap for cable management. It is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro, and does not require an electrician or junction box.Are Wyze camera mounts weather-resistant for outdoor use?
Many Wyze camera mounts, such as the Wyze Cam Mounting Kit and Wyze Cam v4 mounting options, are designed for both indoor and outdoor use. The Wyze Cam v4 itself is IP65 weather-resistant, ensuring durability in various weather conditions.Which Wyze cameras are compatible with the Universal Mount (Long)?
The Wyze Universal Mount (Long) is compatible with Wyze Cam v1, v2, v3, v3 Pro, and Pan versions. It is not compatible with Wyze Cam OG or OG Telephoto.What accessories are included with the Wyze Cam Mounting Kit?
The Wyze Cam Mounting Kit includes a mounting bracket, strong adhesive for secure placement, and an extended Micro USB cable, providing everything needed for a stable and flexible camera installation.How do I choose the right Wyze camera mount for my needs?
Choosing the right Wyze camera mount depends on your camera model and installation location. For wall or ceiling mounting, use the Wyze Cam Mounting Kit or Universal Mount. For window installation, use the Wyze Window Mount. For floodlight cameras, the Floodlight Plug-In Mount offers easy power and installation.
