Secure Wyze Outdoor Power Adapter with Included Accessories
Secure Your Wyze Outdoor Power Adapter with Included Installation Accessories
When setting up your Wyze Cam v3 outdoors, ensuring a secure and weather-resistant power connection is essential. The Wyze Outdoor Power Adapter is designed specifically to provide reliable power to your Wyze Cam v3 in any outdoor environment. This guide will walk you through how to securely install the adapter using the included accessories, ensuring your camera stays powered safely and efficiently.
Wyze Outdoor Power Adapter Overview
The Wyze Outdoor Power Adapter is a must-have accessory for powering your Wyze Cam v3 outdoors. It is engineered to withstand the elements and provide a stable power source for your camera.
Key Features:
  • Compatibility: Works exclusively with Wyze Cam v3 and Wyze Cam v3 Pro (with Outdoor Power Adapter v2).
  • Weather Resistance: Rated IP67, making it highly resistant to rain, snow, dust, and other outdoor conditions.
  • Cable Length: Total cable length of 3.8 meters (12.5 feet), combining AC and DC cables for flexible placement.
  • Color: Available in white to blend seamlessly with most outdoor setups.
  • Installation Accessories Included: Comes with wire clips, screws, screw anchors, and a cable wrap to secure the adapter and cables neatly to walls or other surfaces.
The included installation accessories are designed to hold the adapter firmly in place, preventing cable sagging or accidental disconnections caused by wind or movement.
Important Usage Notes:
  • Plug the adapter directly into an outdoor-rated, covered power outlet.
  • Avoid using extension cords to prevent damage and warranty voidance.
  • Not compatible with Wyze Cam Outdoor models, as it may compromise their water resistance.
How to Securely Install the Wyze Outdoor Power Adapter
Proper installation is key to maintaining the durability and functionality of your outdoor camera setup. Follow these steps to secure your Wyze Outdoor Power Adapter using the included accessories:
Step 1: Choose the Installation Location
  • Select a covered outdoor power outlet that is protected from direct water exposure.
  • Ensure the outlet is within reach of the adapter’s 12.5-foot cable length.
Step 2: Prepare the Mounting Surface
  • Clean the wall or surface where you will mount the adapter and route the cable.
  • Use the included screw anchors if mounting on drywall or other hollow surfaces.
Step 3: Attach the Wire Clips
  • Use the wire clips and screws to fasten the power cable along the wall or eaves.
  • Space the clips evenly to prevent cable sagging and reduce strain on the connections.
Step 4: Use the Cable Wrap
  • Organize any excess cable length with the included cable wrap to keep the installation tidy and safe from tangling or damage.
Step 5: Connect and Test
  • Plug the adapter into the outdoor outlet.
  • Connect the DC end to your Wyze Cam v3.
  • Power on the camera and verify it is receiving power and functioning correctly.
Properly securing the adapter and cable not only protects your equipment but also enhances the overall aesthetic of your outdoor security setup.
Why Use the Wyze Outdoor Power Adapter?
Using the Wyze Outdoor Power Adapter ensures your Wyze Cam v3 operates reliably outdoors without interruption. Here’s why it’s the best choice:
  • Durability: IP67 rating means it can handle harsh weather conditions without failure.
  • Convenience: Easy plug-and-play installation with all necessary mounting hardware included.
  • Safety: Designed specifically for Wyze Cam v3 power requirements, ensuring optimal performance.
  • Neat Installation: Accessories help keep cables organized and secure, reducing trip hazards and wear.
Additional Tips for Outdoor Power Setup
  • Always plug the adapter directly into a weatherproof outlet; avoid extension cords.
  • Position the cable clips to avoid sharp bends or pinching.
  • If mounting on a vertical surface, ensure the adapter hangs securely and the cable runs downward to prevent water ingress.
  • Regularly inspect the cable and adapter for signs of wear or damage, especially after severe weather.
Summary
The Wyze Outdoor Power Adapter is the ideal solution for powering your Wyze Cam v3 outdoors. With its weather-resistant design and included installation accessories—wire clips, screws, anchors, and cable wrap—you can secure your power setup quickly and confidently. Proper installation not only protects your camera but also ensures continuous, reliable surveillance for your home or business.
Secure your outdoor camera power with the Wyze Outdoor Power Adapter and enjoy peace of mind knowing your security system is protected rain or shine.
Outdoor Security Camera Installation Secure your Wyze Cam v3 outdoors with the Wyze Outdoor Power Adapter and included accessories. Organized Cable Installation Use the included wire clips and cable wrap to keep your outdoor power cable tidy and secure. Weather Resistant Power Adapter The IP67-rated Wyze Outdoor Power Adapter withstands rain, snow, and dust for reliable outdoor power.
FeatureWyze Outdoor Power AdapterWyze Cam v3Wyze Cam v3 Pro
TypeAccessoryCameraCamera
Weather ResistanceIP67IP65IP65
CompatibilityWorks with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Wired smart cameraWired smart camera
ResolutionN/A1080p HD (implied, standard for v3)2.5K (2560x1440)
Night VisionN/AColor Night VisionColor Night Vision
Built-in SpotlightN/ANoYes
Integrated SirenN/ANoYes
Edge AIN/ANoYes
AudioN/ABuilt-in speaker & microphone; 2-way audioBuilt-in speaker & microphone; 2-way audio; Noise & echo cancellation
Power Adapter Input110-240V (AC/DC)Requires Outdoor Power Adapter (sold separately)Requires Outdoor Power Adapter v2 (sold separately)
Power Adapter Output5V/2000mAN/A5V/2000mA
Power Cable Length6 ft (1.8 m)N/A6 ft (1.8 m)
Field of ViewN/ANot specified116°
Video FPSN/ADaytime 20 fps / Nighttime 15 fpsDaytime 20 fps / Nighttime 15 fps
Digital ZoomN/A8x8x
Local Storage SupportN/AmicroSD slot (up to 128GB recommended)Supports up to 256GB microSD in exFAT format
ConnectivityN/A802.11 b/g/n 2.4 GHz802.11 b/g/n 2T2R 2.4 GHz
Operating TemperatureN/ANot specified-4°F to 131°F (-20°C to 55°C)
DimensionsN/ANot specified2.05 in x 2.05 in x 2.3 in (52 mm x 52 mm x 58.5 mm)
WeightN/ANot specified4.23 oz (120 g)
Mounting MethodsN/AMagnetic mount, screw kit, adjustable standMagnetic, screw, tape
WarrantyNot specifiedNot specified1 year
NotesRequired for outdoor use of Wyze Cam v3 Pro, Cam Pan v3, Battery Cam Pro; Adapters NOT compatible with OG Stack KitWired camera with color night vision and outdoor IP65 ratingPro version with higher resolution, spotlight, siren, edge AI, requires Outdoor Power Adapter v2 for outdoor use
What is the Wyze Outdoor Power Adapter and what cameras is it compatible with?The Wyze Outdoor Power Adapter is a weather-resistant power supply designed specifically for the Wyze Cam v3 and Wyze Cam v3 Pro (with Outdoor Power Adapter v2). It is not compatible with Wyze Cam Outdoor models, as using it may compromise their water resistance.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is rated IP67, making it highly resistant to rain, snow, dust, and other outdoor conditions. This ensures reliable power for your Wyze Cam v3 in any weather.
What installation accessories are included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with wire clips, screws, screw anchors, and a cable wrap. These accessories help you securely mount the adapter and organize the power cable for a neat and safe installation.
How long is the cable on the Wyze Outdoor Power Adapter?The total cable length of the Wyze Outdoor Power Adapter is 3.8 meters (12.5 feet), combining both the AC and DC cables. This allows for flexible placement of your Wyze Cam v3 outdoors.
How do I securely install the Wyze Outdoor Power Adapter outdoors?To securely install the Wyze Outdoor Power Adapter, choose a covered outdoor power outlet within reach of the 12.5-foot cable. Clean the mounting surface, use the included screw anchors for hollow surfaces, attach the wire clips and screws to fasten the cable, organize excess cable with the cable wrap, and plug the adapter directly into the outlet. Finally, connect it to your Wyze Cam v3 and verify it is working.
Can I use an extension cord with the Wyze Outdoor Power Adapter?No, it is recommended to plug the Wyze Outdoor Power Adapter directly into an outdoor-rated, covered power outlet. Using extension cords can cause damage and may void the warranty.
Why should I use the Wyze Outdoor Power Adapter for my Wyze Cam v3?The Wyze Outdoor Power Adapter is specifically designed for the Wyze Cam v3, ensuring optimal performance, safety, and durability. Its IP67 rating protects against harsh weather, and the included accessories help keep your installation neat and secure.
How do the included installation accessories help with outdoor setup?The included wire clips, screws, screw anchors, and cable wrap allow you to securely fasten the power cable to walls or other surfaces, prevent cable sagging, reduce strain on connections, and keep your installation organized and safe from damage.
What are some tips for maintaining my Wyze Outdoor Power Adapter setup?Always plug the adapter directly into a weatherproof outlet, avoid sharp bends or pinching in the cable, ensure the adapter hangs securely if mounted vertically, and regularly inspect the cable and adapter for wear or damage, especially after severe weather.
What are the key features of the Wyze Outdoor Power Adapter?How do I securely install the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models?
