Best Wi-Fi 6 Routers for 50+ Devices | Wyze Mesh Solutions
Best Routers Supporting Over 50 Devices with Wi-Fi 6 Standard
If you're looking for a router that can handle over 50 devices seamlessly while delivering the latest Wi-Fi 6 technology, Wyze offers two outstanding mesh router options designed for modern smart homes. These routers provide robust coverage, high speeds, and smart features to keep your entire home connected without lag or dead zones.
Wyze Wi-Fi 6 Mesh Router: Reliable Coverage for 50+ Devices
Powerful Wi-Fi 6 Performance
The Wyze Wi-Fi 6 Mesh Router is engineered to support 50+ devices simultaneously, making it ideal for busy households or small offices with multiple smart devices, phones, laptops, and streaming gadgets. It delivers internet speeds up to 1 Gbps, ensuring fast and stable connections for all your devices.
Extensive Coverage & Customizable Setup
Each router covers up to 1500 square feet, and with mesh technology, you can add multiple units to eliminate dead spots and extend coverage throughout your home. The router supports wired backhaul for even faster and more reliable connections between mesh nodes.
User-Friendly Features
  • Simple plug-and-play setup guided by the Wyze app
  • Parental controls to manage device access and screen time
  • Two Ethernet ports for wired connections
  • Top-tier components including optimized antennas and a powerful processor for stability and speed
"Wyze Mesh Router makes every room the fastest room in your house."
Wyze Wi-Fi 6 Mesh Router in a modern home office setup Wyze Wi-Fi 6 Mesh Router delivering fast home internet
Wyze Wi-Fi 6E Mesh Router Pro: Next-Level Speed and Capacity
Cutting-Edge Wi-Fi 6E Technology
For those who want the absolute best in home networking, the Wyze Wi-Fi 6E Mesh Router Pro unlocks the new 6 GHz band, providing access to an uncongested frequency for ultra-fast speeds. It supports internet speeds up to 2.5 Gbps and can handle 75+ devices simultaneously without slowing down.
Larger Coverage Area
Each Pro router covers up to 2000 square feet, perfect for larger homes or offices. Like the standard model, it supports wired backhaul and mesh expansion to customize your network coverage.
Premium Features for Smart Homes
  • Access to the new 6 GHz band for future-proof connectivity
  • Simple setup and parental controls via the Wyze app
  • Designed with high-end components for smooth, reliable performance
"Wyze Mesh Router Pro is Wi-Fi at its Wi-Finest."
Wyze Wi-Fi 6E Mesh Router Pro on a stylish bookshelf Wyze Wi-Fi 6E Mesh Router Pro blending into home decor
Why Choose Wyze Mesh Routers for Your Smart Home?
Designed for Today’s Connected Lifestyle
With the explosion of smart devices in homes—from phones and laptops to smart cameras and IoT gadgets—your router needs to handle many connections at once. Wyze Mesh Routers prioritize devices based on need, reduce battery drain on connected devices, and maintain high speeds for all users.
Complete Network Control
Manage your network effortlessly with the Wyze app:
  • View daily network status and device connections
  • Group and name devices for easy management
  • Create and share guest networks securely
Expandable and Flexible
Both Wyze Mesh Router models support mesh expansion and wired backhaul, allowing you to tailor your network to your home’s size and layout.
Summary of Key Specs
FeatureWyze Wi-Fi 6 Mesh RouterWyze Wi-Fi 6E Mesh Router Pro
Max Devices Supported50+75+
Max SpeedUp to 1 GbpsUp to 2.5 Gbps
Coverage per Router1500 sq ft2000 sq ft
Wi-Fi StandardWi-Fi 6 (802.11ax)Wi-Fi 6E (802.11ax + 6 GHz band)
Ethernet Ports22
Parental ControlsYesYes
SetupWyze app guidedWyze app guided
Upgrade your home network with Wyze Mesh Routers and enjoy fast, reliable Wi-Fi that supports all your devices effortlessly.
Product Highlights
This selection of Wyze mesh routers ensures you get the best Wi-Fi 6 technology with the capacity to support over 50 devices, perfect for smart homes, home offices, and connected lifestyles. Whether you choose the Wyze Wi-Fi 6 Mesh Router or the advanced Wi-Fi 6E Mesh Router Pro, you’ll experience seamless, high-speed internet coverage throughout your space.
Wi-Fi TechnologyWi-Fi 6Wi-Fi 6E
Maximum Internet SpeedUp to 1 GbpsUp to 2.5 Gbps
Frequency Bands2.4 GHz and 5 GHz2.4 GHz, 5 GHz, and new 6 GHz band
Device Capacity50+ devices75+ devices
SetupSimple setup with Wyze appSimple setup with Wyze app
Wired Backhaul SupportYesYes
System BandwidthNot specified5400 Mbps total system bandwidth
Speed to Single DeviceNot specifiedUp to 1.2 Gbps
Price (2 Pack)$99.99$167.99
Included Ethernet Ports2Not explicitly specified
App Network Control FeaturesNetwork status, device management, guest networkNetwork status, device management, guest network
Target UseModern smart homes with moderate device countHigh device count and future-proof homes
What is the best router for supporting over 50 devices with Wi-Fi 6?The Wyze Wi-Fi 6 Mesh Router is an excellent choice for supporting over 50 devices with the latest Wi-Fi 6 technology. It offers robust coverage, high speeds up to 1 Gbps, and smart features ideal for busy households or small offices with multiple connected devices.
How many devices can the Wyze Wi-Fi 6 Mesh Router support?The Wyze Wi-Fi 6 Mesh Router is engineered to support 50+ devices simultaneously, making it perfect for smart homes and offices with many connected gadgets.
What is the coverage area of the Wyze Wi-Fi 6 Mesh Router?Each Wyze Wi-Fi 6 Mesh Router covers up to 1500 square feet. You can add more units to create a mesh network and eliminate dead spots throughout your home.
What are the key features of the Wyze Wi-Fi 6 Mesh Router?Key features include Wi-Fi 6 support, coverage for 50+ devices, speeds up to 1 Gbps, mesh expansion, wired backhaul, two Ethernet ports, parental controls, and easy setup via the Wyze app.
What is the difference between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?The Wyze Wi-Fi 6 Mesh Router supports 50+ devices, up to 1 Gbps speeds, and covers 1500 sq ft per unit. The Wyze Wi-Fi 6E Mesh Router Pro supports 75+ devices, up to 2.5 Gbps speeds, covers 2000 sq ft per unit, and adds access to the new 6 GHz band for even faster, less congested connections.
How many devices can the Wyze Wi-Fi 6E Mesh Router Pro handle?The Wyze Wi-Fi 6E Mesh Router Pro can handle 75+ devices simultaneously, making it ideal for large smart homes or offices with many connected devices.
What is the coverage area of the Wyze Wi-Fi 6E Mesh Router Pro?Each Wyze Wi-Fi 6E Mesh Router Pro covers up to 2000 square feet, and you can expand coverage by adding more mesh units.
Does the Wyze Mesh Router support wired backhaul?Yes, both the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro support wired backhaul for faster and more reliable connections between mesh nodes.
Are parental controls available on Wyze Mesh Routers?Yes, both Wyze Mesh Router models offer parental controls, allowing you to manage device access and screen time through the Wyze app.
How do I set up a Wyze Mesh Router?Setup is simple and guided by the Wyze app. Just plug in your router, follow the app instructions, and enjoy fast, reliable Wi-Fi throughout your home.
Can I manage my network and devices with the Wyze app?Yes, the Wyze app allows you to view network status, manage connected devices, group and name devices, and create secure guest networks.
Are Wyze Mesh Routers suitable for smart homes?Absolutely. Wyze Mesh Routers are designed for modern smart homes, supporting dozens of devices, prioritizing connections, and reducing battery drain on connected gadgets.
How many Ethernet ports do Wyze Mesh Routers have?Both the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro feature two Ethernet ports for wired connections.
Can I expand my Wyze Mesh Router network?Yes, both Wyze Mesh Router models support mesh expansion, allowing you to add more units to increase coverage and eliminate dead zones.
What Wi-Fi standards do Wyze Mesh Routers support?The Wyze Wi-Fi 6 Mesh Router supports Wi-Fi 6 (802.11ax), while the Wyze Wi-Fi 6E Mesh Router Pro supports Wi-Fi 6E (802.11ax with the 6 GHz band).
What are the key differences between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?Can you explain how the mesh technology works in the Wyze routers?Are there any ongoing promotions or discounts available for the Wyze routers?
