Wyze Mesh Router Pro vs Standard: Device Support & Coverage
Wyze Mesh Router Pro vs Standard Device Support
When choosing a mesh router for your home or office, understanding the device support and performance differences between the Wyze Wi-Fi 6E Mesh Router Pro and the Wyze Wi-Fi 6 Mesh Router is essential. Both routers are designed to eliminate dead spots and provide seamless internet coverage, but they differ significantly in technology, device capacity, and coverage area.
Wyze Wi-Fi 6E Mesh Router Pro: Cutting-Edge Performance and Device Support
Advanced Wi-Fi 6E Technology
The Wyze Wi-Fi 6E Mesh Router Pro is equipped with the latest Wi-Fi 6E technology, which includes access to the new, uncongested 6 GHz band. This means faster speeds and less interference compared to traditional Wi-Fi bands.
  • Maximum Internet Speed: Up to 2.5 Gbps
  • Wi-Fi Bands Supported: 2.4 GHz, 5 GHz, and 6 GHz (Tri-band)
Wi-Fi Data Rates:
  • 2.4 GHz: 576 Mbps
  • 5 GHz: 2400 Mbps
  • 6 GHz: 2400 Mbps
Extensive Device Support and Coverage
  • Devices Supported: 75+ simultaneously
  • Coverage per Router: 2000 sq. ft.
  • Antennas: 6 per node for robust signal strength
  • Hardware Accelerators: Dedicated Wi-Fi and routing performance accelerators ensure smooth data flow even with many connected devices.
Additional Features
  • Wired backhaul support for stable mesh connections
  • Parental controls for managing device access
  • Simple Bluetooth Low Energy 5.1 provisioning for easy setup
  • Security protocols including WPA3-PSK for enhanced wireless security
  • Multiple operation modes: Router, Bridge, and Auto WAN/LAN sensing
The Wyze Mesh Router Pro is ideal for large homes or smart homes with many connected devices, offering superior speed and coverage.
Wyze Wi-Fi 6E Mesh Router Pro in a modern home setting Alt text: Lifestyle image of Wyze Wi-Fi 6E Mesh Router Pro providing seamless home internet coverage
Wyze Wi-Fi 6 Mesh Router: Reliable Standard with Solid Device Support
Wi-Fi 6 Technology for Modern Homes
The Wyze Wi-Fi 6 Mesh Router uses the latest Wi-Fi 6 (802.11ax) technology but does not include the 6 GHz band found in the Pro model. It operates on dual bands (2.4 GHz and 5 GHz), providing fast and reliable internet for everyday use.
  • Maximum Internet Speed: Up to 1 Gbps
  • Wi-Fi Bands Supported: 2.4 GHz and 5 GHz (Dual-band)
Wi-Fi Data Rates:
  • 2.4 GHz: 576 Mbps
  • 5 GHz: 2400 Mbps
  • Devices Supported: 50+ simultaneously
  • Coverage per Router: 1500 sq. ft.
  • Antennas: 4 per node
  • Hardware Accelerators: Dedicated Wi-Fi and routing performance accelerators for efficient data handling
Additional Features
  • Wired backhaul for mesh stability
  • Parental controls for device management
  • Bluetooth Low Energy 5.1 provisioning for easy setup
  • Security with WPA3-PSK and WPA2-PSK encryption
  • Operation modes include Router, Bridge, and Auto WAN/LAN sensing
This router is perfect for smaller homes or apartments with moderate device usage, offering reliable speeds and coverage at a more affordable price point.
Wyze Wi-Fi 6 Mesh Router in a cozy home office Alt text: Lifestyle image of Wyze Wi-Fi 6 Mesh Router in a home office setup
Key Differences in Device Support and Coverage
FeatureWyze Wi-Fi 6E Mesh Router ProWyze Wi-Fi 6 Mesh Router
Wi-Fi TechnologyWi-Fi 6E (Tri-band)Wi-Fi 6 (Dual-band)
Maximum SpeedUp to 2.5 GbpsUp to 1 Gbps
Devices Supported75+ devices50+ devices
Coverage per Router2000 sq. ft.1500 sq. ft.
Antennas per Node64
Frequency Bands2.4 GHz, 5 GHz, 6 GHz2.4 GHz, 5 GHz
Hardware AcceleratorsDedicated Wi-Fi & RoutingDedicated Wi-Fi & Routing
Price Range (approximate)HigherMore affordable
Conclusion: Which Wyze Mesh Router Fits Your Needs?
  • Choose the Wyze Wi-Fi 6E Mesh Router Pro if you have a large home, many smart devices, or require the fastest speeds with the latest Wi-Fi 6E technology. Its support for 75+ devices and tri-band coverage ensures a seamless internet experience without dead zones.
  • Opt for the Wyze Wi-Fi 6 Mesh Router if you have a smaller space or fewer connected devices and want a reliable, cost-effective mesh solution with solid Wi-Fi 6 performance.
Both routers offer simple setup, parental controls, and robust security, making them excellent choices for modern smart homes. Wyze Mesh Router Pro setup process in a stylish living room Alt text: Lifestyle image showing Wyze Mesh Router Pro setup in a stylish living room
Wi-Fi TechnologyWi-Fi 6EWi-Fi 6
Maximum Internet SpeedUp to 2.5 GbpsUp to 1 Gbps
Frequency Bands2.4 GHz, 5 GHz, and new 6 GHz band2.4 GHz and 5 GHz
Number of Devices Supported75+ devices50+ devices
Coverage per Router2000 square feet1500 square feet
Wired Backhaul SupportYesYes
Parental ControlsYesYes
SetupSimple setup with Wyze appSimple setup with Wyze app
System Bandwidth5400 Mbps total system bandwidthNot specified
Max Speed to Single DeviceUp to 1.2 GbpsNot specified
Price (1 Pack)$98.99$99.99
Price (2 Pack)$167.99$99.99 (2 Pack only)
Coverage CustomizationYesYes
Device Management via AppYesYes
Guest NetworkYesYes
Additional FeaturesAccess to uncongested 6 GHz band, future-proofOptimized antenna, stronger power amplifier, bigger processor with more memory
What is the difference between the Wyze Wi-Fi 6E Mesh Router Pro and the Wyze Wi-Fi 6 Mesh Router?The Wyze Wi-Fi 6E Mesh Router Pro features advanced Wi-Fi 6E technology with tri-band support (2.4 GHz, 5 GHz, and 6 GHz), higher maximum speeds up to 2.5 Gbps, support for 75+ devices, and coverage of up to 2000 sq. ft. per router. The Wyze Wi-Fi 6 Mesh Router uses dual-band Wi-Fi 6 (2.4 GHz and 5 GHz), supports up to 50+ devices, offers speeds up to 1 Gbps, and covers up to 1500 sq. ft. per router.
How many devices can the Wyze Wi-Fi 6E Mesh Router Pro support?The Wyze Wi-Fi 6E Mesh Router Pro can support 75 or more devices simultaneously, making it ideal for large homes or smart homes with many connected devices.
How many devices can the Wyze Wi-Fi 6 Mesh Router support?The Wyze Wi-Fi 6 Mesh Router can support 50 or more devices at the same time, which is suitable for smaller homes or apartments with moderate device usage.
What is the coverage area of each Wyze mesh router?The Wyze Wi-Fi 6E Mesh Router Pro covers up to 2000 square feet per router, while the Wyze Wi-Fi 6 Mesh Router covers up to 1500 square feet per router.
What are the maximum internet speeds supported by Wyze mesh routers?The Wyze Wi-Fi 6E Mesh Router Pro supports maximum internet speeds up to 2.5 Gbps, while the Wyze Wi-Fi 6 Mesh Router supports speeds up to 1 Gbps.
Which frequency bands do the Wyze mesh routers support?The Wyze Wi-Fi 6E Mesh Router Pro supports tri-band frequencies: 2.4 GHz, 5 GHz, and 6 GHz. The Wyze Wi-Fi 6 Mesh Router supports dual-band frequencies: 2.4 GHz and 5 GHz.
Do Wyze mesh routers support wired backhaul?Yes, both the Wyze Wi-Fi 6E Mesh Router Pro and the Wyze Wi-Fi 6 Mesh Router support wired backhaul for stable mesh connections.
What security features do Wyze mesh routers offer?Both Wyze mesh routers offer advanced security protocols, including WPA3-PSK for enhanced wireless security. The standard Wyze Wi-Fi 6 Mesh Router also supports WPA2-PSK encryption.
Are parental controls available on Wyze mesh routers?Yes, both the Wyze Wi-Fi 6E Mesh Router Pro and the Wyze Wi-Fi 6 Mesh Router include parental controls for managing device access and internet usage.
Which Wyze mesh router is best for large homes or smart homes?The Wyze Wi-Fi 6E Mesh Router Pro is best for large homes or smart homes with many connected devices, thanks to its tri-band Wi-Fi 6E technology, higher device support, and greater coverage area.
Which Wyze mesh router is more affordable?The Wyze Wi-Fi 6 Mesh Router is more affordable compared to the Wyze Wi-Fi 6E Mesh Router Pro, making it a great choice for smaller spaces or users with fewer connected devices.
How easy is it to set up a Wyze mesh router?Both Wyze mesh routers offer simple setup with Bluetooth Low Energy 5.1 provisioning, making the installation process quick and user-friendly.
What are the key differences in performance between the Wyze Wi-Fi 6E Mesh Router Pro and the Wyze Wi-Fi 6 Mesh Router?How many devices can the Wyze Wi-Fi 6E Mesh Router Pro support simultaneously?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze routers?
