Upgrade Your Home Internet with Wyze Mesh Routers Supporting Wired and Wireless Backhaul
When it comes to upgrading your home internet, choosing a mesh router that supports both wired and wireless backhaul is essential for seamless, high-speed connectivity throughout your home. Wyze offers two outstanding mesh router options designed to eliminate dead zones, support multiple devices, and provide flexible wired or wireless backhaul setups. Whether you want reliable Wi-Fi 6 performance or the cutting-edge Wi-Fi 6E technology, Wyze has you covered.
Wyze Wi-Fi 6 Mesh Router: Fast, Reliable, and Easy to Set Up
Powerful Wi-Fi 6 Technology for Modern Homes
The Wyze Wi-Fi 6 Mesh Router delivers internet speeds up to 1 Gbps, making every room in your home the fastest room. With Wi-Fi 6 technology, it supports over 50 devices simultaneously without slowing down, perfect for smart homes filled with phones, laptops, smart TVs, and IoT devices.
Extensive Coverage and Flexible Backhaul Options
Each router covers up to 1,500 square feet, and you can expand coverage by adding more units. It supports both wired backhaul via two Ethernet ports and wireless backhaul, giving you the flexibility to optimize your network for speed and stability.
Top-Tier Components and User-Friendly Controls
Wyze uses optimized antennas, stronger power amplifiers, and a powerful processor to ensure stable and fast connections. The Wyze app offers complete network control, including device management, parental controls, guest networks, and daily status reports.
"Wyze Mesh Router makes every room the fastest room in your house."
Enjoy seamless Wi-Fi coverage in your home office with Wyze Mesh Router.
Wyze Wi-Fi 6E Mesh Router Pro: Next-Level Speed and Coverage
Experience the Power of Wi-Fi 6E and the 6 GHz Band
The Wyze Wi-Fi 6E Mesh Router Pro takes your home internet to the next level with speeds up to 2.5 Gbps and access to the new, uncongested 6 GHz band. This means faster connections, less interference, and future-proof performance for the latest devices.
Superior Device Capacity and Coverage
Supporting 75+ devices and covering up to 2,000 square feet per router, the Mesh Router Pro is ideal for larger homes or tech-heavy households. It ensures no device has to wait in line for bandwidth.
Wired and Wireless Backhaul for Maximum Flexibility
Like the standard Mesh Router, the Pro model supports wired backhaul with Ethernet ports and wireless backhaul, allowing you to customize your network setup for optimal speed and reliability.
Advanced Network Management
Control your entire network effortlessly with the Wyze app, including device grouping, guest network creation, and real-time health monitoring.
"Wyze Mesh Router Pro is Wi-Fi at its Wi-Finest."
Seamless whole-home Wi-Fi coverage with Wyze Wi-Fi 6E Mesh Router Pro.
Why Choose a Mesh Router with Wired and Wireless Backhaul?
Enhanced Stability and Speed
Wired backhaul uses Ethernet cables to connect mesh nodes, reducing wireless interference and boosting overall network performance. Wireless backhaul offers convenience and flexibility when running cables is impractical.
Scalability for Growing Smart Homes
As you add more smart devices, a mesh system with both backhaul options ensures your network can handle increased demand without sacrificing speed or coverage.
Easy Setup and Management
Wyze mesh routers come with simple plug-and-play setup guided by the Wyze app, making it easy for anyone to upgrade their home internet without technical headaches.
Summary: Which Wyze Mesh Router is Right for You?
Feature | Wyze Wi-Fi 6 Mesh Router | Wyze Wi-Fi 6E Mesh Router Pro |
Max Speed | Up to 1 Gbps | Up to 2.5 Gbps |
Wi-Fi Technology | Wi-Fi 6 | Wi-Fi 6E (includes 6 GHz band) |
Device Support | 50+ devices | 75+ devices |
Coverage per Router | 1,500 sq ft | 2,000 sq ft |
Backhaul Support | Wired & Wireless | Wired & Wireless |
Parental Controls & App | Yes | Yes |
Ideal For | Medium homes, smart device hubs | Large homes, future-proof networks |
Upgrade your home internet today with Wyze mesh routers that combine powerful technology, flexible backhaul options, and easy management to keep your entire home connected at top speed.
What is a Wyze Mesh Router and how does it improve home internet?
A Wyze Mesh Router is a Wi-Fi system designed to eliminate dead zones and provide seamless, high-speed internet coverage throughout your home. By supporting both wired and wireless backhaul, Wyze mesh routers ensure stable connections, faster speeds, and the ability to support multiple devices simultaneously.What is the difference between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?
The Wyze Wi-Fi 6 Mesh Router offers speeds up to 1 Gbps, supports over 50 devices, and covers up to 1,500 square feet per unit. The Wyze Wi-Fi 6E Mesh Router Pro delivers faster speeds up to 2.5 Gbps, supports 75+ devices, covers up to 2,000 square feet per router, and includes access to the new 6 GHz band for less interference and future-proof performance.How does wired and wireless backhaul work with Wyze mesh routers?
Wyze mesh routers support both wired and wireless backhaul. Wired backhaul uses Ethernet cables to connect mesh nodes, reducing wireless interference and boosting network performance. Wireless backhaul connects nodes wirelessly, offering flexibility when running cables is not practical. Both options help optimize your network for speed and stability.How many devices can Wyze mesh routers support?
The Wyze Wi-Fi 6 Mesh Router supports over 50 devices simultaneously, while the Wyze Wi-Fi 6E Mesh Router Pro can handle 75+ devices, making them ideal for smart homes with many connected devices.What is the coverage area for Wyze mesh routers?
Each Wyze Wi-Fi 6 Mesh Router covers up to 1,500 square feet, and the Wyze Wi-Fi 6E Mesh Router Pro covers up to 2,000 square feet per router. You can expand coverage by adding more units to your mesh network.Is it easy to set up and manage Wyze mesh routers?
Yes, Wyze mesh routers feature a simple plug-and-play setup guided by the Wyze app. The app allows you to manage devices, set up parental controls, create guest networks, and monitor your network’s health in real time.What are the benefits of choosing a mesh router with both wired and wireless backhaul?
Choosing a mesh router with both wired and wireless backhaul provides enhanced stability, speed, and flexibility. Wired backhaul reduces interference and maximizes performance, while wireless backhaul offers convenience when running cables is not possible. This ensures your network can scale with your smart home needs.Does the Wyze mesh router support parental controls and guest networks?
Yes, both Wyze Wi-Fi 6 Mesh Router and Wyze Wi-Fi 6E Mesh Router Pro support parental controls and guest networks, all easily managed through the Wyze app.Which Wyze mesh router is best for large homes or future-proofing my network?
The Wyze Wi-Fi 6E Mesh Router Pro is ideal for large homes and users who want future-proof performance. It offers higher speeds (up to 2.5 Gbps), supports more devices (75+), covers more area per router (2,000 sq ft), and includes the latest Wi-Fi 6E technology with access to the 6 GHz band.Can I expand my Wyze mesh network by adding more routers?
Yes, you can expand your Wyze mesh network by adding additional mesh routers, increasing your Wi-Fi coverage and supporting more devices as your needs grow.
