Best Wi-Fi 6 Mesh Routers with Dual Band Gigabit Ethernet
Best Wi-Fi 6 Mesh Routers with Dual Band Gigabit Ethernet Ports
Looking for a powerful Wi-Fi 6 mesh router that supports dual band gigabit Ethernet ports? Whether you want to eliminate dead zones, connect multiple devices seamlessly, or enjoy blazing-fast internet speeds, Wyze offers top-tier solutions designed for modern smart homes. Explore the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro — both equipped with dual band gigabit Ethernet ports and advanced features to elevate your home network.
Wyze Wi-Fi 6 Mesh Router: Fast, Reliable, and Easy to Use
Lightning-Fast Speeds and Wide Coverage
The Wyze Wi-Fi 6 Mesh Router delivers internet speeds up to 1 Gbps using the latest Wi-Fi 6 technology. Each router covers up to 1,500 square feet and supports 50+ devices simultaneously, making it perfect for busy households with multiple smart devices.
Dual Band Gigabit Ethernet Ports & Wired Backhaul
This router includes two gigabit Ethernet ports, allowing you to connect wired devices directly for ultra-stable connections. It also supports wired backhaul, which means you can link multiple mesh units with Ethernet cables to maximize speed and reduce wireless interference.
Smart Features for Modern Homes
  • Parental Controls: Manage device access and set usage schedules easily.
  • Simple Setup: Guided by the Wyze app, setup is plug-and-play and hassle-free.
  • Network Control: Monitor your network health, connected devices, and guest access all from the app.
Built to Last
With optimized antennas, a powerful processor, and premium components, the Wyze Wi-Fi 6 Mesh Router balances performance and sleek design for a first-class home networking experience. Wyze Wi-Fi 6 Mesh Router in Home Office Setup Alt text: Wyze Wi-Fi 6 Mesh Router on desk in modern home office
Wyze Wi-Fi 6E Mesh Router Pro: Next-Level Speed and Coverage
Ultra-Fast Wi-Fi 6E Technology
Step into the future with the Wyze Wi-Fi 6E Mesh Router Pro, offering internet speeds up to 2.5 Gbps. It unlocks the new, uncongested 6 GHz band, delivering up to 1.2 Gbps to a single device — faster than traditional wired gigabit connections.
Expanded Coverage and Device Support
Covering up to 2,000 square feet per router and supporting 75+ devices simultaneously, this router is ideal for larger homes or tech-heavy environments where many devices demand bandwidth at once.
Like its Wi-Fi 6 counterpart, the Mesh Router Pro features two gigabit Ethernet ports for wired connections and supports wired backhaul to ensure seamless, high-speed mesh networking throughout your home.
Advanced Network Management
  • Parental Controls & Guest Network: Keep your network secure and organized.
  • Wyze App Integration: Get daily status reports, device management, and easy setup.
  • Future-Proof Performance: Designed to handle the increasing demands of smart homes and next-gen devices.
Wyze Wi-Fi 6E Mesh Router Pro on Bookshelf Alt text: Wyze Wi-Fi 6E Mesh Router Pro placed on a stylish bookshelf in a living room
Why Choose a Dual Band Gigabit Ethernet Mesh Router?
"Fast doesn't just mean speed; it means managing many devices at once without lag."
Dual band gigabit Ethernet ports provide the flexibility to connect wired devices like gaming consoles, smart TVs, or desktop PCs directly to your router for the most reliable and fastest connections. Combined with mesh technology, these routers eliminate dead spots and maintain consistent speeds throughout your home. Both Wyze Wi-Fi 6 and Wi-Fi 6E Mesh Routers are designed to handle the demands of modern smart homes, supporting dozens of devices simultaneously without compromising performance.
Summary: Which Wyze Mesh Router Fits Your Needs?
FeatureWyze Wi-Fi 6 Mesh RouterWyze Wi-Fi 6E Mesh Router Pro
Max Internet SpeedUp to 1 GbpsUp to 2.5 Gbps
Wi-Fi TechnologyWi-Fi 6Wi-Fi 6E (includes 6 GHz band)
Coverage per Router1,500 sq ft2,000 sq ft
Device Support50+ devices75+ devices
Ethernet Ports2 Gigabit Ports2 Gigabit Ports
Wired Backhaul SupportYesYes
Parental Controls & AppYesYes
Ideal ForMedium homes, smart device hubsLarger homes, future-proof setups
Experience seamless, high-speed internet with Wyze’s Wi-Fi 6 and Wi-Fi 6E mesh routers — the perfect solution for homes that demand reliable connectivity and easy network management.
Maximum Internet SpeedUp to 1 GbpsUp to 2.5 Gbps
Device CapacitySupports 50+ devicesSupports 75+ devices
Coverage per Router1500 square feet2000 square feet
Frequency Bands2.4 GHz and 5 GHz2.4 GHz, 5 GHz, and 6 GHz (uncongested)
Ethernet Ports2Not explicitly stated (assumed similar)
Parental ControlsYesYes
SetupSimple setup with Wyze appSimple setup with Wyze app
Price (2 Pack)$99.99 (compare at $199.98)$167.99 (compare at $347.98)
Coverage CustomizationYesYes
Prioritization of DevicesYesYes
Battery Life ImprovementYes (via Wi-Fi 6 features)Yes (via Wi-Fi 6E features)
Additional FeaturesOptimized antenna, stronger power amplifier, bigger processor with more memoryAccess to new 6 GHz band, premium components for future-proofing
Network Control via Wyze AppYesYes
What are the main differences between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?The Wyze Wi-Fi 6 Mesh Router offers speeds up to 1 Gbps, covers up to 1,500 sq ft per router, and supports 50+ devices. The Wyze Wi-Fi 6E Mesh Router Pro delivers faster speeds up to 2.5 Gbps, covers up to 2,000 sq ft per router, and supports 75+ devices. The 6E model also unlocks the new 6 GHz band for less congestion and even faster wireless connections.
Do Wyze mesh routers have dual band gigabit Ethernet ports?Yes, both the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro feature two gigabit Ethernet ports, allowing you to connect wired devices like gaming consoles, smart TVs, or desktop PCs for ultra-stable and fast connections.
What is wired backhaul and do Wyze mesh routers support it?Wired backhaul allows you to connect multiple mesh router units using Ethernet cables, maximizing speed and reducing wireless interference. Both Wyze Wi-Fi 6 and Wi-Fi 6E Mesh Routers support wired backhaul for seamless, high-speed mesh networking throughout your home.
How many devices can Wyze mesh routers support simultaneously?The Wyze Wi-Fi 6 Mesh Router supports 50+ devices at once, while the Wyze Wi-Fi 6E Mesh Router Pro supports 75+ devices, making them ideal for smart homes with many connected devices.
What is the coverage area for each Wyze mesh router?The Wyze Wi-Fi 6 Mesh Router covers up to 1,500 square feet per unit, while the Wyze Wi-Fi 6E Mesh Router Pro covers up to 2,000 square feet per unit. You can add more units to expand coverage as needed.
Do Wyze mesh routers offer parental controls and guest network features?Yes, both Wyze mesh routers include parental controls to manage device access and set usage schedules, as well as guest network options to keep your main network secure.
How easy is it to set up a Wyze mesh router?Setting up a Wyze mesh router is simple and hassle-free, thanks to the guided setup process in the Wyze app. The app also allows you to monitor network health, manage connected devices, and control guest access.
Why should I choose a dual band gigabit Ethernet mesh router for my home?Dual band gigabit Ethernet mesh routers provide fast, reliable connections for both wired and wireless devices. They eliminate dead zones, support multiple devices without lag, and ensure consistent speeds throughout your home, making them ideal for modern smart homes.
Are Wyze mesh routers suitable for large homes or tech-heavy environments?Yes, especially the Wyze Wi-Fi 6E Mesh Router Pro, which is designed for larger homes and environments with many devices. Its expanded coverage and support for 75+ devices make it perfect for tech-heavy households.
Is the Wyze Wi-Fi 6E Mesh Router Pro future-proof?Yes, the Wyze Wi-Fi 6E Mesh Router Pro is built to handle the increasing demands of smart homes and next-generation devices, thanks to its advanced Wi-Fi 6E technology, high device support, and robust performance.
What are the key differences between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?How many devices can the Wyze Wi-Fi 6 Mesh Router support at once?Is there a warranty available for the Wyze Wi-Fi 6 Mesh Router?
