Wyze Battery Cam Pro: Solar-Powered Security for Off-Grid Homes
Efficient Battery Cameras for Off-Grid Properties
When it comes to securing off-grid properties, choosing a reliable, efficient battery camera with solar panel compatibility is essential. Wyze offers top-tier solutions designed to provide high-quality surveillance without the hassle of constant recharging or wiring. Below, we explore the Wyze Battery Cam Pro and its solar-compatible variants, perfect for remote locations powered by solar energy.
Wyze Battery Cam Pro: Powerful Wire-Free Security
High-Resolution Video & Advanced Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), ensuring crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it captures vivid details even in low light. The camera features radar plus PIR motion detection, providing accurate alerts while minimizing false alarms.
Long-Lasting Battery & Weatherproof Design
Powered by a removable, rechargeable 6200mAh battery pack, the Wyze Battery Cam Pro can last up to 6 months on a single charge, making it ideal for off-grid use. Its IP65 weatherproof rating means it withstands rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F), ensuring reliable operation in harsh outdoor environments.
Smart Features & Easy Installation
This camera supports dual-band WiFi (2.4 & 5 GHz) and integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation. The included wall mount and standard 1/4” - 20 mounting thread allow flexible installation options without the need for a hub or wiring.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Remote Locations
Solar Panel Compatibility for Continuous Operation
For off-grid properties relying on solar energy, the Wyze Battery Cam Pro + Solar Panel bundle is a perfect match. The solar panel is designed to extend the camera’s battery life by harnessing sunlight, reducing the need for manual recharging.
Features That Enhance Off-Grid Security
  • 2.5K HDR Video with color night vision thanks to integrated white LEDs.
  • Radar + PIR Motion Detection for precise movement alerts.
  • Integrated Spotlight & Siren to deter intruders.
  • Weatherproof IP65 rating ensures durability in all weather conditions.
  • Supports local storage up to 256GB microSD and cloud recording with Cam Plus.
Easy Setup & Smart Integration
The solar panel comes with a 13-foot power cable and a 360° adjustable mount, allowing you to position it optimally for maximum sun exposure. The camera and solar panel combo supports both 2.4 GHz and 5 GHz WiFi, ensuring stable connectivity even in remote areas.
Off-grid property owners can enjoy peace of mind with a security system that stays powered by the sun, reducing maintenance and maximizing uptime.
Wyze Battery Cam Pro in Outdoor Setting
Wyze Battery Cam Solar Panel Accessory: Power Your Camera with the Sun
Designed for Seamless Solar Charging
The Wyze Battery Cam Solar Panel accessory is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor models. It features a weather-resistant IP65 design and an easy 360° mount, making it simple to install on any surface exposed to sunlight.
Key Benefits
  • 2.5W, 5V DC solar power rating to keep your camera charged.
  • 13-foot micro USB cable for flexible placement.
  • Durable construction to withstand outdoor elements.
  • Includes all mounting hardware and adapter cables for quick setup.
This solar panel accessory is an excellent choice for extending the battery life of your Wyze camera, especially in remote or off-grid locations where power outlets are unavailable. Solar Panel Mounted on Remote Property
Why Choose Wyze Battery Cameras for Off-Grid Security?
  • Wire-Free Convenience: No need for complex wiring or hubs.
  • Long Battery Life: Up to 6 months on a single charge.
  • Solar Compatibility: Extend operation with dedicated solar panels.
  • Robust Weatherproofing: IP65 rating for all-weather reliability.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
  • High-Quality Video: 2.5K HDR resolution with night vision capabilities.
Whether you need standalone battery-powered cameras or a solar-powered security system, Wyze offers versatile, efficient solutions tailored for off-grid properties.
Additional Accessories to Enhance Your Setup
Wyze Removable Battery Pack
Keep your cameras running longer with an extra 6200mAh rechargeable battery pack. Easily swap batteries to avoid downtime and maintain continuous surveillance.
Wyze Battery Charging Dock
Charge two batteries simultaneously with this compact dock, ensuring you always have a fully charged battery ready for your camera.
Secure your off-grid property efficiently with Wyze Battery Cam Pro and solar panel solutions — combining advanced technology, long-lasting power, and smart features for peace of mind anywhere.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
Product TypeCameraCamera + Solar Panel BundleAccessory (Solar Panel)
Video Resolution2.5K HDR2.5K HDRN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable Battery + Solar Panel (continuous)Solar Panel (extends battery life)
WirelessYes, Wire-Free, No Hub RequiredYes, Wire-Free, No Hub RequiredN/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionN/A
Integrated Spotlight & SirenYesYesN/A
Weatherproof RatingIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/A
Battery Life ExtensionRemovable battery packs, hot-swapSolar panel extends battery lifeExtends battery life for Wyze Battery Cam Pro
SetupBluetoothⓇ Setup, no QR codeBluetoothⓇ Setup, no QR codeMountable anywhere, weather resistant
Included ItemsCamera onlyCamera + Solar PanelSolar panel, wall mount, USB cables, screws
Price (USD)$89.98 (1 Pack White/Black)$109.98 (Bundle White/Black)$24.99 (Solar Panel), $5.99 (USB-C Adapter)
DimensionsN/AN/A173 mm x 120 mm x 17 mm
Solar Power RatingN/AN/A2.5W, 5VDC
Cable Length (Power Cable)N/AN/A13 ft (4m)
CompatibilityWyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro, Wyze Cam Outdoor v1/v2
What makes the Wyze Battery Cam Pro ideal for off-grid property security?The Wyze Battery Cam Pro is perfect for off-grid properties because it offers wire-free installation, a long-lasting 6200mAh rechargeable battery (up to 6 months per charge), and solar panel compatibility for continuous power. Its IP65 weatherproof rating ensures reliable operation in harsh outdoor environments, and it delivers high-quality 2.5K HDR video with advanced motion detection.
How does the Wyze Battery Cam Pro + Solar Panel bundle benefit remote locations?The Wyze Battery Cam Pro + Solar Panel bundle is designed for remote, off-grid locations by harnessing solar energy to keep the camera charged. This reduces the need for manual recharging and ensures continuous surveillance. The bundle includes a 13-foot cable and a 360° adjustable mount for optimal sun exposure, making it easy to install in any sunny location.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, making it resistant to rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F). This ensures reliable performance in all weather conditions, making it suitable for outdoor and off-grid use.
What smart features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro supports dual-band WiFi (2.4 & 5 GHz) and integrates with Alexa, Google Assistant, and IFTTT for smart home automation. It also features radar plus PIR motion detection, integrated spotlight and siren, and supports both local microSD storage (up to 256GB) and cloud recording with Cam Plus.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro is compatible with the Wyze Battery Cam Solar Panel accessory, which provides seamless solar charging. The solar panel features a weather-resistant IP65 design, a 13-foot micro USB cable, and a 360° adjustable mount for flexible installation.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro can last up to 6 months on a single charge, depending on usage and environmental conditions. Using the compatible solar panel can further extend the battery life by providing continuous charging from sunlight.
What video quality does the Wyze Battery Cam Pro provide?The Wyze Battery Cam Pro delivers 2.5K HDR video resolution (2560 x 1440) with a CMOS-Starlight sensor and F1.6 lens, ensuring clear, detailed footage both day and night. It also features color night vision with integrated white LEDs.
What accessories are available for the Wyze Battery Cam Pro?Available accessories include the Wyze Removable Battery Pack (6200mAh) for easy battery swaps and the Wyze Battery Charging Dock, which can charge two batteries simultaneously. These accessories help maintain continuous surveillance by minimizing downtime.
Does the Wyze Battery Cam Pro require a hub or wiring for installation?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub or complex wiring. It comes with a wall mount and a standard 1/4” - 20 mounting thread for flexible and easy installation.
What storage options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud recording through the Cam Plus subscription service, giving you flexible options for saving and accessing your footage.
What are the key features of the Wyze Battery Cam Pro?How does the solar panel extend the battery life of the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for the Wyze Battery Cam Pro?
