Refurbished Wyze Wired Doorbell Kit with Chime
Looking for a reliable, smart, and easy-to-install wired doorbell kit with chime? Wyze offers excellent options that combine high-quality video doorbells with compatible chimes, perfect for upgrading your home security and convenience. Whether you want a standalone wired doorbell with a dedicated chime or a full front porch security bundle, Wyze has you covered with refurbished products that deliver great value.
Wyze Video Doorbell v2 with Chime Controller
The Wyze Video Doorbell v2 is the clearest and most capable wired video doorbell from Wyze, now available as a refurbished kit including the Wyze Chime Controller. This kit is ideal for anyone wanting a wired doorbell solution with smart features and a compatible chime.
- 2K HD Video Quality: Capture every detail with 2048 x 1536 resolution and a wide 135° horizontal field of view.
- Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation let you communicate with visitors in real time.
- Smart Motion Detection: Receive alerts and activate voice deterrence when motion is detected.
- Local Storage: Supports microSD cards up to 256GB for continuous local recording.
- Weather Resistant: Rated IP65 for reliable outdoor use in various climates.
- Easy Installation: Comes with a chime controller that works with nearly every mechanical chime, simplifying wiring.
- Compatibility: Works with Alexa, Google Assistant, and IFTTT for smart home integration.
- Included in Kit: Video Doorbell v2, Chime Controller, wall plate, wedge for angled mounting, installation kit, wire caps, screws, and quick start guide.
This wired doorbell kit is perfect for homeowners who want a dependable wired connection with smart features and a compatible chime that integrates seamlessly with existing mechanical doorbell systems.
Alt text: Person answering Wyze wired video doorbell from smartphone
Wyze Wired Chime Options
Wyze Chime (Standalone Wired Chime)
If you already own a Wyze Wired Doorbell (v1) or Wyze Wired Doorbell v2 and need a compatible chime, the Wyze Chime standalone unit is a great choice.
- Compatibility: Works exclusively with Wyze Wired Doorbell v1 and Wyze Wired Doorbell (wired).
- Simple Setup: Plug and play with your wired doorbell system.
- Compact Design: Small and unobtrusive, fits easily in any room.
- Note: Does not work with Wyze Video Doorbell Pro or Wyze Video Doorbell v2 (which uses the Chime Controller instead).
This chime is ideal for those who want a dedicated wired chime without additional smart features.
Wyze Universal Wi-Fi Chime
For a wireless chime solution that works with all Wyze Cams and doorbells, including wired models, the Wyze Universal Wi-Fi Chime offers flexibility and convenience.
- Wireless Convenience: No complicated wiring; just plug into a standard power outlet.
- Multiple Tones: Choose from 17 different chime sounds to suit your preference.
- Smart Automations: Set the chime to ring when your Wyze camera detects a person, even if they don’t press the doorbell.
- Compatibility: Works with all Wyze cameras and doorbells, including wired models.
- Easy Installation: Compact black plastic design (81 x 53 x 38 mm) with simple setup.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
- Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 122°F.
This wireless chime is perfect for those who want a fuss-free, smart chime option that can be placed anywhere inside the home.
Complete Front Porch Security Bundle
For a comprehensive smart home security upgrade, consider the refurbished Front Porch Security Bundle. This kit includes:
- Wyze Video Doorbell (1080p HD): View your front porch with clear video and two-way audio.
- Wyze Chime: Comes with a modern chime offering multiple sound options.
- Wyze Lock: Remotely lock and unlock your door, and monitor lock history via the Wyze app.
- Smart Features: Works with Alexa and Google Assistant for voice control.
- All-in-One Security: Monitor motion events, receive alerts, and control access remotely.
This bundle is ideal for users who want a full smart security setup with wired doorbell and chime included, plus smart lock capabilities.
Why Choose Refurbished Wyze Wired Doorbell Kits with Chime?
Refurbished Wyze wired doorbell kits with chime provide an affordable way to upgrade your home security without compromising on quality or features. These products undergo rigorous testing to ensure reliability and come with the same smart home integrations as new units.
- Save money while enjoying premium features.
- Easy installation with included chime controllers or wireless chimes.
- Compatible with a wide range of Wyze cameras and smart home ecosystems.
- Durable and weather-resistant for outdoor use.
- Multiple chime sound options to customize your home experience.
Enhance your home’s security and convenience today with Wyze’s refurbished wired doorbell kits and chimes — smart, reliable, and budget-friendly solutions for modern living.
Product Summary
Wyze Video Doorbell v2 + Chime Controller
Wired doorbell kit with 2K video, two-way audio, and compatible chime controller.
Compatible with Wyze Wired Doorbell v1 and wired models, simple plug-in chime.
Wireless chime compatible with all Wyze cameras and doorbells, 17 tones, smart automations.
Complete smart home bundle with Wyze Video Doorbell, Chime, and Lock for full porch security.
Experience the perfect blend of wired reliability and smart convenience with Wyze’s refurbished wired doorbell kits and chimes.
What is included in the Refurbished Wyze Wired Doorbell Kit with Chime?
The Refurbished Wyze Wired Doorbell Kit with Chime includes the Wyze Video Doorbell v2, Chime Controller, wall plate, wedge for angled mounting, installation kit, wire caps, screws, and a quick start guide. This kit provides everything you need for a smart, wired doorbell solution with a compatible chime.What are the main features of the Wyze Video Doorbell v2 with Chime Controller?
The Wyze Video Doorbell v2 with Chime Controller offers 2K HD video quality (2048 x 1536 resolution), a 135° horizontal field of view, two-way audio with noise and echo cancellation, smart motion detection with alerts, local storage support up to 256GB microSD, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.Is the Wyze Wired Doorbell Kit with Chime easy to install?
Yes, the Wyze Wired Doorbell Kit with Chime is designed for easy installation. The included chime controller works with nearly every mechanical chime, simplifying the wiring process. The kit also comes with all necessary mounting hardware and a quick start guide.What is the difference between the Wyze Chime and the Wyze Universal Wi-Fi Chime?
The Wyze Chime is a standalone wired chime compatible exclusively with Wyze Wired Doorbell v1 and v2 (wired models), offering a simple plug-and-play setup. The Wyze Universal Wi-Fi Chime is a wireless chime that works with all Wyze cameras and doorbells, features 17 different chime sounds, smart automations, and can be placed anywhere indoors.Can I use the Wyze Universal Wi-Fi Chime with any Wyze doorbell or camera?
Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze cameras and doorbells, including both wired and wireless models. It offers wireless convenience, multiple chime tones, and smart home integration with Alexa, Google Assistant, and IFTTT.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD), Wyze Chime, and Wyze Lock. This bundle provides clear video, two-way audio, multiple chime sound options, remote lock/unlock capabilities, and smart home integration for comprehensive front porch security.Are refurbished Wyze wired doorbell kits reliable?
Yes, refurbished Wyze wired doorbell kits undergo rigorous testing to ensure reliability and performance. They offer the same smart home integrations and features as new units, providing a cost-effective way to upgrade your home security.What smart home systems are Wyze wired doorbells and chimes compatible with?
Wyze wired doorbells and chimes are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your existing smart home ecosystem.Is the Wyze Video Doorbell v2 weather resistant?
Yes, the Wyze Video Doorbell v2 is rated IP65, making it weather resistant and suitable for reliable outdoor use in various climates.Can I store video footage locally with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 supports local storage with microSD cards up to 256GB, allowing for continuous local recording of video footage.Why should I choose a refurbished Wyze wired doorbell kit with chime?
Choosing a refurbished Wyze wired doorbell kit with chime allows you to save money while enjoying premium features, easy installation, smart home compatibility, durable weather-resistant design, and customizable chime sound options—all backed by Wyze’s quality assurance.
