Refurbished Wyze Wired Doorbell: Package Detection & Smart Alerts
Refurbished Wyze Wired Doorbell for Package Detection and Smart Alerts
When it comes to securing your home entrance and ensuring you never miss a package delivery, the Wyze Video Doorbell v2 stands out as a top choice. This refurbished wired doorbell combines high-resolution video, smart alerts, and package detection features to keep you connected and informed at all times.
Wyze Video Doorbell v2: Advanced Wired Doorbell for Smart Home Security
Crystal Clear 2K Video Quality
The Wyze Video Doorbell v2 offers stunning 2K (2048 x 1536) resolution, providing crystal-clear video footage of your doorstep. With a wide 166.8° diagonal field of view, it captures more area, reducing blind spots and ensuring you see every detail.
Smart Package Detection & Real-Time Alerts
Equipped with a CMOS Starlight Sensor and motion detection technology, this doorbell can detect packages left at your door and send instant smart alerts to your phone. Whether you’re at work or on vacation, you can monitor deliveries and visitors in real-time.
Two-Way Audio & Voice Deterrence
Communicate directly with visitors or delivery personnel through the built-in microphone and speaker. The doorbell also features motion-activated voice deterrence to help ward off unwanted guests.
Local and Cloud Storage Options
Store your video recordings locally on a microSD card (up to 256GB supported) or opt for cloud storage with a Wyze Security Plan for added convenience and backup.
Durable and Weather-Resistant Design
Built with polycarbonate and resin materials, the doorbell is IP65 certified for weather resistance, making it reliable in various climates. It operates efficiently between -4°F to 122°F (-20°C to 50°C).
Easy Installation and Compatibility
Designed for wired installation with 16V-24V AC power, the doorbell comes with a chime controller and installation kit for a hassle-free setup. It integrates seamlessly with Alexa, Google Assistant, and IFTTT for smart home automation.
Homeowner checking smart doorbell alert on phone Alt text: Homeowner receiving smart alert from Wyze wired doorbell on smartphone
Enhance Your Doorbell Setup with the Wyze Video Doorbell v2 Wedge Kit
Perfect Angle Adjustment for Maximum Coverage
The Wyze Video Doorbell v2 Wedge Kit is an essential accessory designed to eliminate blind spots caused by angled door frames or porches with stairs. It includes a 15° horizontal bracket and two 7.5° vertical brackets, allowing you to customize the doorbell’s viewing angle for superior package detection and visitor monitoring.
Weather-Resistant and Easy to Install
Made from durable plastic and weather-resistant materials, the wedge kit ensures long-lasting performance outdoors. Installation is quick and straightforward, making it a perfect companion for your Wyze Video Doorbell v2.
Why Choose a Refurbished Wyze Wired Doorbell?
Refurbished Wyze Video Doorbell v2 units offer the same high-quality features and performance as new models but at a more affordable price point. Each unit undergoes rigorous testing to ensure reliability and functionality, making it a smart investment for budget-conscious homeowners seeking advanced package detection and smart alert capabilities.
Summary of Key Features
FeatureWyze Video Doorbell v2Wedge Kit Accessory
Video Resolution2K (2048 x 1536)N/A
Field of View (Diagonal)166.8°Adjustable angle brackets (15°, 7.5°)
Package DetectionYesEnhances viewing angle for detection
Two-Way AudioYesN/A
StorageLocal microSD (up to 256GB), CloudN/A
Weather ResistanceIP65 CertifiedWeather-resistant plastic
PowerWired 16V-24V ACN/A
Smart Home IntegrationAlexa, Google Assistant, IFTTTCompatible with Doorbell v2 only
Warranty1 Year1 Year
Investing in the refurbished Wyze Video Doorbell v2 with the optional Wedge Kit ensures you get a comprehensive wired doorbell solution optimized for package detection and smart alerts. Stay connected, secure, and informed with this powerful smart home device.
FeatureWyze Video Doorbell v2Wyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellAccessory Kit for Doorbell v2
Local StoragemicroSD card slot for 24/7 local recordingN/A
Two-way AudioYesN/A
Motion-activated Voice DeterrenceYes (requires Cam Plus or Cam Protect subscription)N/A
Pre-roll Motion Recording3-6 secondsN/A
Weather ResistanceIP65Weather-resistant thick plastic
Night VisionColor Night Vision with award-winning starlight sensorN/A
Works with Existing ChimeYes, includes chime controllerN/A
Compatibility with Smart AssistantsAlexa, Google HomeN/A
Included Angle Adjustment30° Corner Kit included15° Horizontal + 2x 7.5° Vertical wedges included
PurposeVideo doorbell with full featuresAdjust viewing angle for Doorbell v2 to reduce blind spots
MaterialNot specifiedThick, weather-resistant plastic
Price$44.98 (Doorbell + Chime Controller)$8.99 (Wedge Kit Only), $51.97 (Doorbell v2 + Wedge Kit)
What is the Wyze Video Doorbell v2 and what features does it offer?The Wyze Video Doorbell v2 is a wired smart doorbell that provides 2K (2048 x 1536) high-resolution video, a wide 166.8° field of view, smart package detection, real-time alerts, two-way audio, and motion-activated voice deterrence. It supports both local microSD card storage (up to 256GB) and cloud storage, and is weather-resistant with an IP65 rating.
What are the benefits of choosing a refurbished Wyze Wired Doorbell?Refurbished Wyze Video Doorbell v2 units offer the same high-quality features and performance as new models but at a more affordable price. Each refurbished unit undergoes rigorous testing to ensure reliability and functionality, making it a smart choice for budget-conscious homeowners seeking advanced package detection and smart alerts.
How does the Wyze Video Doorbell v2 detect packages and send alerts?The Wyze Video Doorbell v2 uses a CMOS Starlight Sensor and advanced motion detection technology to identify packages left at your door. It sends instant smart alerts to your smartphone, allowing you to monitor deliveries and visitors in real-time, whether you are at home or away.
Is the Wyze Video Doorbell v2 weather-resistant?Yes, the Wyze Video Doorbell v2 is built with durable polycarbonate and resin materials and is IP65 certified for weather resistance. It operates efficiently in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it suitable for various climates.
What storage options are available for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 supports local storage via a microSD card (up to 256GB) and offers cloud storage options through a Wyze Security Plan. This provides flexibility for video recording and backup.
Is the Wyze Video Doorbell v2 compatible with smart home systems?Yes, the Wyze Video Doorbell v2 integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for easy smart home automation and voice control.
What is included with the Wyze Video Doorbell v2 for installation?The Wyze Video Doorbell v2 comes with a chime controller and an installation kit, making the wired installation process straightforward. It is designed for use with 16V-24V AC power systems.
What is the Wyze Video Doorbell v2 Wedge Kit and how does it improve coverage?The Wyze Video Doorbell v2 Wedge Kit is an accessory that includes a 15° horizontal bracket and two 7.5° vertical brackets. It allows you to adjust the doorbell’s viewing angle, eliminating blind spots caused by angled door frames or porches with stairs, and enhancing package detection and visitor monitoring.
Is the Wyze Video Doorbell v2 Wedge Kit weather-resistant and easy to install?Yes, the Wedge Kit is made from durable, weather-resistant plastic and is designed for quick and easy installation, making it a perfect companion for the Wyze Video Doorbell v2.
What warranty is provided with the refurbished Wyze Video Doorbell v2 and Wedge Kit?Both the refurbished Wyze Video Doorbell v2 and the Wedge Kit accessory come with a 1-year warranty, ensuring peace of mind and reliable performance.
What are the key features of the Wyze Video Doorbell v2?How does the package detection feature work on the Wyze Video Doorbell v2?Is there a warranty for the refurbished Wyze Video Doorbell v2?
