Wyze Duo Cam Doorbells: Detect Packages Even Under Furniture
Advanced Doorbell Cameras Designed to Detect Incoming Packages Even Under Furniture
When it comes to securing your home and ensuring you never miss a package delivery—even when placed under furniture or in hard-to-see spots—Wyze offers cutting-edge doorbell cameras tailored to your needs. Featuring high-resolution video, intelligent detection, and versatile installation options, these smart doorbells provide peace of mind and convenience. Explore the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell, two of the most advanced doorbell cameras designed to capture every moment with clarity and precision.
Wyze Video Doorbell v2: Wired Power with Crystal Clear 2K Video
Wyze Video Doorbell v2 Lifestyle Experience sharp 2K video and smart detection with Wyze Video Doorbell v2. The Wyze Video Doorbell v2 is a wired video doorbell that delivers exceptional 2K (2048 x 1536) video resolution, ensuring you see every detail clearly. Its CMOS Starlight Sensor and wide 166.8° diagonal field of view capture a broad area, perfect for monitoring packages left near or even under furniture.
Key Features:
  • 2K Video Quality: Crisp, detailed video day and night with 6 infrared (940nm) IR lights for clear night vision.
  • Wide Field of View: 135° horizontal and 103° vertical coverage to minimize blind spots.
  • Local & Cloud Storage: Supports up to 256GB microSD card for local recording plus optional cloud storage with Wyze Security Plan.
  • Motion-Activated Voice Deterrence: Automatically warns unwanted visitors with a customizable voice alert.
  • Two-Way Audio: Communicate with visitors or delivery personnel directly through the doorbell.
  • Weather Resistant: IP65 rating ensures reliable performance in rain, snow, or shine.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Installation & Accessories:
  • Includes a wedge kit option to adjust the camera angle, ideal for doorways with stairs or angled frames, helping you capture packages placed under furniture or in tricky spots.
  • Comes with a chime controller for audible alerts inside your home.
Wyze Duo Cam Battery Doorbell: Dual Cameras for Ultimate Package Detection
Wyze Duo Cam Doorbell Lifestyle Dual camera views for comprehensive coverage of your doorstep and packages. The Wyze Duo Cam Battery Doorbell is Wyze’s most advanced battery-powered doorbell, featuring two cameras to monitor both visitors and packages simultaneously. This dual-camera setup is especially effective for detecting packages placed under furniture or in low-visibility areas.
Standout Features:
Dual Camera Views:
  • Front camera: 2K resolution (2048 x 1536) with 132° horizontal and 100° vertical field of view.
  • Bottom camera: 1080p resolution with 121° horizontal and 60° vertical field of view, perfect for monitoring packages on the ground or under furniture.
  • Battery Powered with Optional Hardwired Setup: 6200 mAh removable lithium-ion battery with USB-C charging, plus the option to hardwire for continuous power.
  • AI-Powered Detection & Alerts: Real-time AI detects people and packages, sending instant alerts to your phone.
  • Two-Way Audio & Siren: Communicate with visitors and deter unwanted guests with a 90 dB siren and motion-activated voice warnings.
  • Local & Cloud Storage: Supports up to 256GB microSD card for 24/7 local recording and cloud storage via AWS.
  • Weatherproof & Durable: IP65 rating ensures protection against harsh weather conditions.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice commands and automation.
Included Accessories:
  • Wyze Wi-Fi Chime for indoor alerts.
  • Corner kit and back plate for flexible mounting options to optimize camera angles.
Why Choose Wyze Doorbell Cameras for Package Detection?
"Never miss a package again—even if it’s placed under furniture or in hard-to-see spots."
Both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are engineered to provide comprehensive coverage of your doorstep area. Their wide-angle lenses, high-resolution video, and intelligent detection capabilities ensure that packages are captured clearly, no matter where they are placed.
  • Wide and Adjustable Viewing Angles: With included wedge kits and dual cameras, you can customize the view to cover blind spots such as under furniture or porch stairs.
  • High-Resolution Video: 2K video quality captures fine details, making it easier to identify packages and visitors.
  • Smart Alerts & Voice Deterrence: Receive instant notifications and deter package thieves with motion-activated voice warnings.
  • Flexible Power Options: Choose between wired or battery-powered models to suit your home’s setup.
Enhance Your Doorbell Setup with Wyze Accessories
To maximize your doorbell camera’s effectiveness, consider these Wyze accessories:
  • Wyze Video Doorbell v2 Wedge Kit: Adjust your doorbell’s angle for better coverage on angled door frames or porches with stairs, eliminating blind spots where packages might be hidden.
  • Wyze Universal Wi-Fi Chime: Easily hear your doorbell alerts anywhere in your home without complicated wiring.
Conclusion
For homeowners seeking a reliable doorbell camera that excels at detecting incoming packages—even those placed under furniture—the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell stand out as top choices. With advanced video quality, intelligent detection, and flexible installation options, these smart doorbells provide comprehensive security and convenience. Upgrade your home security today with Wyze’s innovative doorbell cameras designed to keep you connected and informed, no matter where your packages are placed.
FeatureWyze Video Doorbell v2Wyze Duo Cam Battery DoorbellWyze Video Doorbell v2 Wedge KitWyze Universal Wi-Fi Chime
TypeWired Video DoorbellBattery-Powered Video DoorbellAccessory (Wedge Kit)Accessory (Wi-Fi Chime)
Video Resolution2K (2048 x 1536)Front: 2K (2048 x 1536), Bottom: 1080pN/AN/A
Video FormatH.264Not specifiedN/AN/A
Field of View (Horizontal)135°Front: 132°, Bottom: 121°N/AN/A
Frame Rate (Day/Night)20 FPS / 15 FPS20 FPS / 15 FPSN/AN/A
Power16V-24V AC, ≥10VABattery (Lithium-ion 6200 mAh) / AC 10-24V ACN/A10-24V AC, 10VA 60Hz
StoragemicroSD up to 256GB FAT32microSD up to 256GB exFATN/AN/A
AudioTwo-way audio (ECM microphone, 8Ω 1W speaker)Two-way audio, siren 90 dBN/ASpeaker (φ40mm)
Motion-Activated Voice DeterrenceYesYesN/AN/A
ConnectivityWi-Fi 2.4 GHz b/g/nWi-Fi 2.4 & 5 GHz a/b/g/n, Bluetooth 5.0N/AWi-Fi 2.4 GHz b/g/n
Weather ResistanceIP65IP65Weather resistantIndoor use, no weather resistance specified
Dimensions4.3" x 1.7" x 0.9" (110mm x 44mm x 24mm)5.90" x 1.88" x 1.18" (150mm x 48mm x 30mm)N/A81 x 53 x 38 mm
WeightNot specified0.92 lbs (416 g)N/ANot specified
Included ItemsDoorbell v2, Chime Controller, Wall Plate, Wedge (30°), Installation Kit, Wire Caps, Extension Wires, Screws, Wall Anchors, Quick Start GuideDuo Cam Doorbell, Wi-Fi Chime, Back Plate, Corner Kit, USB-C Cable, Wire Nuts, Jump Wire, Extension Wires, Screws, Expansion Tubes, Adhesive Tape, Detaching Pin, Removable Battery Pack, Quick Start Guide15° Horizontal Bracket, 2x 7.5° Vertical Brackets, 6 Short Screws, Quick Start GuideWi-Fi Chime, Quick Start Guide
CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Compatible with Doorbell v2 onlyWorks with all Wyze Cams and Doorbells
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/AAlexa, Google Assistant, IFTTT
Warranty1 Year1 Year1 YearNot specified
Price$44.98$89.98 - $109.99$8.99 (Wedge Kit Only), $51.97 (Doorbell + Wedge)$19.98
What makes Wyze doorbell cameras effective for detecting packages under furniture?Wyze doorbell cameras, including the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell, feature wide-angle lenses, high-resolution video, and intelligent detection technology. These features allow them to capture clear footage of packages, even if they are placed under furniture or in hard-to-see spots. Adjustable viewing angles and dual-camera setups further enhance their ability to monitor tricky areas.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers 2K video resolution, a wide 166.8° diagonal field of view, night vision with 6 infrared IR lights, motion-activated voice deterrence, two-way audio, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT. It also supports local storage with up to a 256GB microSD card and optional cloud storage.
How does the Wyze Duo Cam Battery Doorbell improve package detection?The Wyze Duo Cam Battery Doorbell features dual cameras: a front-facing 2K camera and a bottom-facing 1080p camera. This setup allows for comprehensive coverage of both visitors and packages, especially those placed on the ground or under furniture. AI-powered detection and instant alerts ensure you never miss a delivery.
Can Wyze doorbell cameras be installed on angled door frames or near stairs?Yes, both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell come with wedge kits or corner kits that allow you to adjust the camera angle. This flexibility helps eliminate blind spots and ensures packages placed under furniture or on porch stairs are visible.
Do Wyze doorbell cameras support local and cloud storage?Yes, both Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell support local storage with microSD cards up to 256GB for continuous recording. They also offer optional cloud storage through the Wyze Security Plan or AWS, providing multiple options for video backup.
Are Wyze doorbell cameras weather resistant?Yes, both models have an IP65 weather resistance rating, ensuring reliable performance in rain, snow, or shine.
What smart home integrations are available with Wyze doorbell cameras?Wyze doorbell cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for voice commands, automation, and seamless integration with your smart home ecosystem.
What power options are available for Wyze doorbell cameras?The Wyze Video Doorbell v2 is a wired device, while the Wyze Duo Cam Battery Doorbell offers a 6200 mAh removable lithium-ion battery for wireless operation and can also be hardwired for continuous power.
What accessories are available to enhance Wyze doorbell camera performance?Wyze offers accessories such as the Wyze Video Doorbell v2 Wedge Kit for adjustable camera angles and the Wyze Universal Wi-Fi Chime for easy-to-hear alerts throughout your home.
How do Wyze doorbell cameras help deter package theft?Wyze doorbell cameras feature motion-activated voice deterrence and a 90 dB siren (on the Duo Cam model) to warn and deter unwanted visitors or potential package thieves. Instant smart alerts also keep you informed of any activity at your doorstep.
What are the key features of the Wyze Video Doorbell v2?How does the dual camera setup of the Wyze Duo Cam Battery Doorbell work?Do you have any ongoing sales or discounts for Wyze doorbell cameras?
