Refurbished Wired Wyze Video Doorbell for Smart Home Alerts
Enhance your home security with the
Wyze Video Doorbell v2, a top-tier wired video doorbell designed to deliver crystal-clear video and smart alerts directly to your phone. Perfect for smart home enthusiasts, this refurbished model offers all the essential features you need to monitor your front door with confidence and convenience.
Wyze Video Doorbell v2: Wired Security with 2K Clarity
Exceptional Video Quality and Coverage
The Wyze Video Doorbell v2 captures every detail with stunning 2K resolution (2048 x 1536), providing sharper and clearer images than standard HD doorbells. Its wide 166.8° diagonal field of view ensures you see everything happening on your porch, from visitors to packages.
- Video Resolution: 2K (2048 x 1536)
- Field of View: 135° horizontal, 103° vertical, 166.8° diagonal
- Lens & Sensor: Resin lens with CMOS Starlight Sensor for enhanced low-light performance
- Frame Rate: 20 FPS during the day, 15 FPS at night
Smart Features for Real-Time Alerts
Stay connected with two-way audio that lets you speak to visitors from anywhere. Receive instant motion-activated alerts on your smartphone, and deter unwanted guests with voice deterrence features.
- Two-Way Audio: Built-in microphone and speaker with noise and echo cancellation
- Motion-Activated Voice Deterrence: Warn off suspicious activity automatically
- Local Storage: Supports microSD cards up to 256GB for continuous recording
- Cloud Storage: Optional with Wyze Security Plan
Durable and Weather-Resistant
Built to withstand the elements, the doorbell is IP65 rated, ensuring reliable operation in rain, snow, or heat.
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
- Weather Resistance: IP65 certified for dust and water protection
- Material: Polycarbonate body for durability
Easy Installation and Included Accessories
The wired design requires 16V-24V AC power and comes with everything needed for installation, including a chime controller, wall plate, wedge for angled mounting, wire caps, and screws.
The Front Porch Security Bundle: Complete Smart Home Protection
For those looking to expand their smart home security, the
Front Porch Security Bundle pairs the Wyze Video Doorbell v2 with the Wyze Lock and Wyze Chime, creating a comprehensive front door security system.
Features of the Bundle
- 1080p HD Video Doorbell: View your porch in crisp detail with two-way audio
- Remote Lock Control: Lock or unlock your door from anywhere using the Wyze app
- Motion Event History: Review motion alerts and lock activity logs for peace of mind
- Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant
This bundle is ideal for users who want an integrated smart home experience, combining video monitoring with secure access control.
Why Choose a Refurbished Wyze Video Doorbell?
Opting for a refurbished Wyze Video Doorbell v2 means you get the same high-quality features and performance at a more affordable price point. Each unit is tested and certified to meet Wyze’s standards, ensuring reliability and longevity.
"Refurbished does not mean compromised — it means smart savings with trusted quality."
Summary: Key Specs at a Glance
Feature | Wyze Video Doorbell v2 |
Video Resolution | 2K (2048 x 1536) |
Field of View | 166.8° diagonal |
Power | Wired 16V-24V AC |
Weather Resistance | IP65 Certified |
Audio | Two-way with noise cancellation |
Storage | Local microSD up to 256GB + Cloud option |
Compatibility | Android 9.0+, iOS 15.0+ |
Smart Home Integration | Alexa, Google Assistant, IFTTT |
Warranty | 1 Year |
Alt text: Homeowner answering door remotely with Wyze Video Doorbell v2
Conclusion
The
Wyze Video Doorbell v2 refurbished model is an excellent choice for anyone seeking a reliable, wired video doorbell that integrates seamlessly into a smart home ecosystem. Whether purchased alone or as part of the Front Porch Security Bundle, it offers advanced video quality, smart alerts, and durable design to keep your home safe and connected.
Upgrade your home security today with Wyze’s trusted technology and enjoy peace of mind with every alert.
What is the video resolution of the refurbished Wyze Video Doorbell v2?
The refurbished Wyze Video Doorbell v2 offers stunning 2K resolution (2048 x 1536), providing sharper and clearer images than standard HD doorbells.Does the Wyze Video Doorbell v2 support two-way audio?
Yes, the Wyze Video Doorbell v2 features built-in two-way audio with noise and echo cancellation, allowing you to speak to visitors from anywhere using your smartphone.Is the refurbished Wyze Video Doorbell v2 weather-resistant?
Absolutely. The Wyze Video Doorbell v2 is IP65 certified, making it dust and water resistant for reliable operation in rain, snow, or heat.What smart home platforms is the Wyze Video Doorbell v2 compatible with?
The Wyze Video Doorbell v2 works seamlessly with Alexa, Google Assistant, and IFTTT for easy smart home integration.What storage options are available for the Wyze Video Doorbell v2?
You can use a microSD card up to 256GB for local continuous recording, and there is also an optional cloud storage plan available through Wyze.What is included with the Wyze Video Doorbell v2 for installation?
The package includes a chime controller, wall plate, wedge for angled mounting, wire caps, and screws—everything you need for easy installation.What is the operating temperature range for the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 operates reliably in temperatures ranging from -4°F to 122°F (-20°C to 50°C).What are the benefits of choosing a refurbished Wyze Video Doorbell v2?
Choosing a refurbished Wyze Video Doorbell v2 means you get the same high-quality features and performance at a more affordable price. Each unit is tested and certified to meet Wyze’s standards for reliability and longevity.What is the warranty on the refurbished Wyze Video Doorbell v2?
The refurbished Wyze Video Doorbell v2 comes with a 1-year warranty for peace of mind.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock, and Wyze Chime, providing comprehensive front door security with video monitoring and remote lock control.Can I control the Wyze Video Doorbell v2 and Wyze Lock remotely?
Yes, with the Wyze app, you can view your porch, speak to visitors, and lock or unlock your door from anywhere.What power source does the Wyze Video Doorbell v2 require?
The Wyze Video Doorbell v2 is a wired device that requires 16V-24V AC power for operation.Is the Wyze Video Doorbell v2 suitable for both Android and iOS devices?
Yes, the Wyze Video Doorbell v2 is compatible with Android 9.0+ and iOS 15.0+ devices.
