Refurbished Wyze Wired Doorbell with Alexa & Google Integration
Refurbished Wyze Wired Doorbell with Alexa and Google Integration
Looking for a reliable, feature-packed wired doorbell that seamlessly integrates with Alexa and Google Assistant? The Wyze Video Doorbell v2 is your perfect choice. This refurbished model offers crystal-clear 2K video, local storage, and smart home compatibility, making it an excellent addition to your home security setup. Alongside the doorbell, Wyze offers a range of smart cameras and accessories that complement your wired doorbell system, enhancing your home’s security and convenience.
Wyze Video Doorbell v2: Wired Doorbell with Smart Integration
Crisp 2K Video Quality and Wide Field of View
The Wyze Video Doorbell v2 delivers sharp 2K (2048 x 1536) resolution video, ensuring you never miss a detail at your doorstep. With a wide 166.8° diagonal field of view, it captures a broad area, giving you a comprehensive look at visitors and packages.
Smart Features for Enhanced Security
  • Two-way audio lets you communicate with visitors in real-time.
  • Motion-activated voice deterrence helps ward off unwanted guests.
  • Real-time alerts notify you instantly when motion or a visitor is detected.
  • Local microSD storage supports up to 256GB, so you can save footage without relying solely on the cloud.
  • Alexa and Google Assistant integration allows you to control and view your doorbell through voice commands and smart displays.
Durable and Weather-Resistant
Built with polycarbonate housing and rated IP65 for weather resistance, the doorbell withstands rain, snow, and extreme temperatures from -4°F to 122°F (-20°C to 50°C), making it ideal for all climates.
Easy Installation and Included Accessories
The package includes everything you need for installation: chime controller, wall plate, wedge for angled mounting, wire caps, screws, and a quick start guide.
Wyze Cam v4: The Perfect Companion for Your Doorbell
Superior 2.5K QHD Video and Color Night Vision
Wyze Cam v4 offers crystal-clear 2.5K Quad HD video with enhanced color night vision, allowing you to see vibrant details even in low light. Its CMOS Starlight Sensor and Wide Dynamic Range (WDR) technology ensure bright, balanced images day and night.
Continuous Power and Recording
Unlike battery-powered cameras, Wyze Cam v4 is wired for continuous power, ensuring uninterrupted monitoring. It supports 24/7 local recording via a microSD card (up to 512GB) and offers cloud storage options with subscription plans.
Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, Wyze Cam v4 fits seamlessly into your smart home ecosystem. Use voice commands to view live feeds or control your camera settings.
Robust Build and Versatile Mounting
Constructed from durable polycarbonate with glass and plastic lenses, the camera is weather-resistant (IP65) and operates in temperatures from -4°F to 122°F (-20°C to 50°C). Multiple mounting options include stand, wall, ceiling, and magnetic adhesive mounts.
Additional Security Features
  • Motion and sound detection with customizable zones
  • Smoke and CO alarm alerts with automatic video recording
  • Built-in 99dB siren and two-way talk with noise and echo cancellation
  • Wi-Fi 6 support for stronger, more reliable connections
Cam v4 + Lamp Socket v2 Bundle: Smart Lighting Meets Security
Power Your Wyze Cam v4 Without an Outlet
The Lamp Socket v2 lets you power your Wyze Cam v4 directly from an outdoor light fixture, eliminating the need for additional wiring or outlets. Installation is as simple as screwing in a lightbulb.
Motion-Activated Smart Lighting
When paired with Wyze Cam v4, the lamp socket enables your outdoor lights to turn on automatically upon motion detection, enhancing security and convenience.
Expandable and Easy to Control
You can link multiple lamp sockets for broader coverage and control all your smart lights remotely via the Wyze app. Features like dusk-to-dawn automation help save energy and provide peace of mind.
Why Choose Wyze for Your Home Security?
Wyze products combine affordability, advanced technology, and smart home compatibility to deliver comprehensive security solutions. Whether you want a wired doorbell with Alexa and Google integration or a high-resolution outdoor camera, Wyze offers reliable devices designed to keep your home safe and connected.
Summary of Featured Products
ProductKey Features
Wyze Video Doorbell v2Wired 2K video, Alexa & Google integration, motion alerts, local storage, weather-resistant
Wyze Cam v42.5K QHD video, color night vision, continuous power, Wi-Fi 6, smart home compatible
Cam v4 + Lamp Socket v2 BundlePowers Cam v4 via light socket, motion-activated lighting, easy installation
Smart Home Security Setup Enhance your home security with Wyze wired doorbell and smart cameras.
Invest in a refurbished Wyze wired doorbell with Alexa and Google integration today and elevate your home security with smart, reliable technology.
FeatureWyze Video Doorbell v2Wyze Cam v4Cam v4 + Lamp Socket v2 Bundle
TypeWired Video DoorbellWired Security CameraWyze Cam v4 + Lamp Socket v2
Video Resolution2K2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Field of ViewHead-to-toe view (exact degrees not specified)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°Same as Wyze Cam v4
Local StoragemicroSD card slot (continuous local recording)microSD card up to 256GB (continuous local recording)Same as Wyze Cam v4
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionSame as Wyze Cam v4
Two-Way AudioYesYes (Improved 2-way audio)Yes (via Cam v4)
Motion-Activated FeaturesVoice deterrence (with subscription), alertsMotion-activated spotlight, alertsSame as Wyze Cam v4
Night VisionColor Night Vision (Starlight sensor)Enhanced Color Night VisionSame as Wyze Cam v4
Weather ResistanceIP65IP65Lamp Socket: Not weatherproof; Cam v4: IP65
Power SourceWiredWiredWired (Cam v4) + Lamp Socket powers Cam without outlet
Compatibility with Smart AssistantsAlexa, Google HomeAlexa, Google Assistant, IFTTTSame as Wyze Cam v4
Additional FeaturesPre-roll motion recording (3-6 seconds), chime controller included, 30° corner kitWi-Fi 6 support, Auto-zoom with AI, smoke & CO alerts, magnetic mountLamp Socket features: Motion-activated lights, dusk to dawn scheduling, linkability
DimensionsNot specified2in x 2in x 2 3/8in (51 x 51 x 60 mm approx.)Lamp Socket: 56.5mm x 56.5mm x 65mm
WeightNot specified0.49 lb (222 g)Lamp Socket: 80 g
Price (approximate)$44.98$35.98$49.96
WarrantyNot specified1 Year1 Year
What features does the refurbished Wyze Video Doorbell v2 offer?The refurbished Wyze Video Doorbell v2 provides crystal-clear 2K video resolution, a wide 166.8° field of view, two-way audio, motion-activated voice deterrence, real-time alerts, local microSD storage up to 256GB, and seamless integration with Alexa and Google Assistant.
Is the Wyze Video Doorbell v2 compatible with Alexa and Google Assistant?Yes, the Wyze Video Doorbell v2 is fully compatible with both Alexa and Google Assistant, allowing you to control and view your doorbell using voice commands and smart displays.
How weather-resistant is the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 is built with durable polycarbonate housing and is rated IP65 for weather resistance. It operates in temperatures ranging from -4°F to 122°F (-20°C to 50°C), making it suitable for all climates.
What is included with the Wyze Video Doorbell v2 package?The package includes the Wyze Video Doorbell v2, a chime controller, wall plate, wedge for angled mounting, wire caps, screws, and a quick start guide for easy installation.
What are the key features of the Wyze Cam v4?Wyze Cam v4 offers 2.5K Quad HD video, enhanced color night vision, continuous wired power, 24/7 local recording (up to 512GB microSD), cloud storage options, Alexa and Google Assistant compatibility, IFTTT support, motion and sound detection, smoke and CO alarm alerts, a built-in 99dB siren, two-way talk, and Wi-Fi 6 connectivity.
Can the Wyze Cam v4 be used outdoors?Yes, the Wyze Cam v4 is weather-resistant with an IP65 rating and operates in temperatures from -4°F to 122°F (-20°C to 50°C), making it suitable for both indoor and outdoor use.
How does the Cam v4 + Lamp Socket v2 Bundle work?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 directly from an outdoor light fixture, eliminating the need for extra wiring or outlets. The lamp socket also enables motion-activated smart lighting and can be controlled remotely via the Wyze app.
What smart home integrations are available with Wyze products?Wyze products, including the Video Doorbell v2 and Cam v4, integrate with Alexa, Google Assistant, and IFTTT, allowing for voice control, smart display viewing, and automation within your smart home ecosystem.
Does the Wyze Video Doorbell v2 support local storage?Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB, allowing you to save video footage without relying solely on cloud storage.
Why choose Wyze for home security?Wyze offers affordable, advanced, and reliable smart home security solutions. Their products feature high-resolution video, smart integrations, weather resistance, and easy installation, making them ideal for comprehensive home protection.
Can you tell me more about the features of the Wyze Cam v4?How does the Wyze Cam v4 integrate with smart home systems?Do you have any ongoing sales or discounts for Wyze products?
