Refurbished Wyze V2 Outdoor Cam with Advanced Motion Detection
If you're searching for a reliable, budget-friendly outdoor security camera with advanced motion detection, the Refurbished Wyze Cam v2 is an excellent choice. This classic home security camera offers essential features that keep your property safe and monitored around the clock.
Why Choose the Refurbished Wyze Cam v2?
The Wyze Cam v2 is a proven performer in home security, now available refurbished to provide great value without compromising quality. It features:
  • 1080p Full HD video for clear, detailed footage.
  • Advanced motion tagging with custom zone detection and sensitivity settings, allowing you to focus on important areas.
  • Night vision up to 30 feet, ensuring visibility even in complete darkness.
  • Two-way audio for real-time communication through the built-in microphone and speaker.
  • Works with Alexa and Google Assistant, integrating seamlessly into your smart home ecosystem.
  • Continuous recording and live streaming capabilities to never miss a moment.
  • Compact and versatile with a 110° wide-angle lens and 3-axis design for flexible mounting.
This camera is perfect for outdoor use when paired with proper weather protection or sheltered areas, making it a smart, affordable option for enhancing your home security.
Advanced Motion Detection and Customization
The Wyze Cam v2’s motion detection technology is designed to reduce false alerts and focus on what matters most:
  • Custom zone detection lets you define specific areas to monitor, avoiding unnecessary notifications.
  • Adjustable motion sensitivity ensures alerts are tailored to your environment.
  • Motion tagging highlights detected movement in your video feed for quick review.
These features make the Wyze Cam v2 a practical choice for users who want precise and reliable motion detection without paying a premium.
Complementary Wyze Outdoor Security Options
For those looking to expand their outdoor security system with advanced features and weather resistance, consider these Wyze products that complement the Wyze Cam v2:
Wyze Cam Floodlight v2
Wyze Cam Floodlight v2 illuminating driveway at night Enhance your outdoor security with bright floodlights and 2K video.
  • 2K video resolution with color night vision and a wide 160° diagonal field of view.
  • Powerful 2800 lumens LED floodlights with AI-powered light control and dusk-to-dawn automation.
  • IP65 weather resistance for reliable outdoor performance.
  • Built-in two-way audio and a loud 105dB siren for active deterrence.
  • Supports 24/7 local recording with microSD card and integrates with Alexa, Google Assistant, and IFTTT.
This floodlight camera is ideal for driveways, porches, and backyards, providing both illumination and security in one device.
Wyze Duo Cam Pan
  • Combines two 2K cameras in one device: one fixed and one pan-and-tilt for full coverage.
  • 360° horizontal pan and 180° vertical tilt with automatic motion tracking.
  • Color night vision, integrated spotlights, and siren for enhanced security.
  • IP65 weather resistance and versatile mounting options.
  • Supports continuous local recording up to 512 GB microSD.
  • Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for users who want comprehensive outdoor surveillance with advanced tracking and multiple views.
Summary
The Refurbished Wyze Cam v2 offers a cost-effective solution for outdoor security with advanced motion detection, clear 1080p video, and smart home compatibility. For enhanced outdoor protection, pairing it with the Wyze Cam Floodlight v2 or Wyze Duo Cam Pan provides powerful lighting, wider coverage, and superior tracking capabilities.
Protect your home day and night with Wyze’s trusted security cameras designed for smart, affordable, and effective outdoor surveillance.
Feature(Refurbished) Wyze Cam v2Wyze Cam Floodlight v2Wyze Duo Cam Pan
Camera Resolution1080p Full HD (1920×1080)2K (Immaculate 2K image quality)2K (Two cameras)
Field of View110º wide angle lens160º wide-angle view360º pan, 180º tilt (two cameras: fixed + pan/tilt)
Night VisionIR night vision with 4x 850nm LEDs, up to 30 ftColor Night Vision with 2800 Lumens LEDsEnhanced Color Night Vision
Motion DetectionCustom zone detection, sensitivity settingsAdvanced motion detection, 270º PIR motion detectionMotion and sound detection, detection zones
Audio2-way audio (built-in speaker and mic)2-way talk + 105dB sirenEnhanced two-way talk
RecordingCloud clips saved 14 days, microSD continuous recording (microSD not included)24/7 local recording with microSD (up to 256GB), no subscription required24/7 local recording with microSD (up to 512GB)
Smart Assistant CompatibilityAlexa, Google AssistantAlexa, Google HomeAlexa, Google Assistant, IFTTT
Unique Features3-axis flexible design, CO2 & Smoke alarm sound detection2800 lumen floodlights, Ambient Light Mode, dusk-to-dawn automation, IP65 weatherproofTwo cameras in one, auto motion tracking, integrated spotlights and siren, IP65 weather resistance
Weather ResistanceNot specified (indoor use)IP65 weatherproofIP65 weather resistance
PowerWiredWiredWired
Mounting OptionsMagnetic base with metal plate and adhesive tapeFloodlight mount, plug-in mount availableFour unique mounting options
Price$19.99 USD (Refurbished)$89.98 USD$129.98 USD (1 Pack) / $69.98 USD (2 Pack)
What features does the Refurbished Wyze Cam v2 offer for outdoor security?The Refurbished Wyze Cam v2 provides 1080p Full HD video, advanced motion tagging with custom zone detection and adjustable sensitivity, night vision up to 30 feet, two-way audio, continuous recording, live streaming, and compatibility with Alexa and Google Assistant. Its compact design and 110° wide-angle lens make it ideal for flexible outdoor mounting when used with proper weather protection.
How does the Wyze Cam v2’s advanced motion detection work?The Wyze Cam v2 features advanced motion detection with custom zone selection, allowing you to monitor specific areas and reduce false alerts. You can adjust motion sensitivity to suit your environment, and motion tagging highlights detected movement in your video feed for easy review.
Is the Refurbished Wyze Cam v2 weatherproof for outdoor use?The Refurbished Wyze Cam v2 is suitable for outdoor use when paired with proper weather protection or installed in sheltered areas. For fully weather-resistant options, consider the Wyze Cam Floodlight v2 or Wyze Duo Cam Pan, both of which offer IP65 weather resistance.
Can I use the Wyze Cam v2 with Alexa or Google Assistant?Yes, the Wyze Cam v2 works seamlessly with Alexa and Google Assistant, allowing you to integrate it into your smart home ecosystem for voice control and automation.
What are the benefits of choosing a refurbished Wyze Cam v2?Choosing a refurbished Wyze Cam v2 offers excellent value, providing the same reliable performance and essential security features as a new device at a more affordable price, without compromising on quality.
What are the complementary Wyze outdoor security options?For enhanced outdoor security, consider the Wyze Cam Floodlight v2, which offers 2K video, powerful 2800 lumens LED floodlights, color night vision, and a 105dB siren, or the Wyze Duo Cam Pan, which combines two 2K cameras with 360° pan, 180° tilt, motion tracking, and IP65 weather resistance.
Does the Wyze Cam v2 support continuous recording and live streaming?Yes, the Wyze Cam v2 supports both continuous recording and live streaming, ensuring you never miss a moment and can monitor your property in real time.
How does the Wyze Cam v2 help reduce false motion alerts?The Wyze Cam v2 reduces false motion alerts by allowing you to set custom detection zones and adjust motion sensitivity, so you only receive notifications for activity in areas that matter most to you.
What is the night vision capability of the Wyze Cam v2?The Wyze Cam v2 features night vision with visibility up to 30 feet, ensuring clear footage even in complete darkness for reliable 24/7 security.
What are the key features of the Wyze Cam Floodlight v2?Can you tell me more about the Wyze Duo Cam Pan and its capabilities?Do you have any deals, ongoing sales, discounts, or promotions available?
