Refurbished Smart Security Cameras: Fast Streaming & Motion Alerts
Refurbished Smart Security Cameras with Simplified UI, Fast Live Streaming, and Motion Alerts
When it comes to securing your home or business, having a reliable smart security camera that offers fast live streaming, intuitive controls, and instant motion alerts is essential. Our selection of refurbished Wyze smart security cameras delivers all these features and more, combining advanced technology with user-friendly interfaces to keep you connected and protected 24/7.
Wyze Cam v4: The Ultimate Wired Smart Security Camera
Experience unmatched clarity and smart features with the Wyze Cam v4, the clearest Wyze Cam ever made. This wired camera is perfect for both indoor and outdoor use, thanks to its IP65 weather resistance.
Key Features:
  • 2.5K QHD Resolution: Capture crystal-clear video with 2560 x 1440 pixels, providing detailed images day or night.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • Fast Live Streaming: Wi-Fi 6 support ensures a stronger, more reliable connection for smooth, real-time video.
  • Simplified Setup & Use: Bluetooth-enabled setup with a magnetic mount makes installation quick and tool-free.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription fees.
  • Smart Alerts: Receive instant notifications for motion, sound, smoke, and CO alarms.
  • Voice Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for smart home integration.
Available in multiple colors and pack sizes, the Wyze Cam v4 is a versatile choice for comprehensive home security. Wyze Cam v4 lifestyle Enjoy clear two-way audio communication with Wyze Cam v4, perfect for monitoring pets or talking to visitors.
Wyze Cam Pan v3: Dynamic 360° Pan and 180° Tilt Coverage
For those who want to cover every angle, the Wyze Cam Pan v3 offers a fully weatherproof, motorized pan and tilt camera that can rotate 360° horizontally and tilt 180° vertically.
Highlights:
  • IP65 Weather Resistance: Designed for indoor and outdoor use, it withstands rain, snow, and harsh weather.
  • Automatic Motion Tracking: The camera detects motion and smoothly follows the subject, ensuring nothing escapes its view.
  • Fast Live Streaming & Alerts: Get real-time notifications and crisp video feeds with advanced motion and sound detection.
  • Privacy Mode: Instantly disable the camera’s view by pointing it downward for complete privacy.
  • Two-Way Audio: Speak and listen through the camera using the Wyze app.
  • Custom Patrol Routes: Set up to 4 waypoints for the camera to automatically patrol your space.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This camera is ideal for monitoring large areas like backyards, garages, or living rooms with its wide field of view and intelligent tracking. Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 keeps your outdoor spaces secure in all weather conditions with its robust design.
Wyze Battery Cam Pro: Wire-Free Security with Long Battery Life
If you prefer a wireless solution without sacrificing video quality or smart features, the Wyze Battery Cam Pro is an excellent choice.
Features at a Glance:
  • 2.5K HDR Video: High dynamic range video ensures clear images in varying lighting conditions.
  • Wire-Free & No Hub Required: Easy to install anywhere with removable, rechargeable 6200mAh batteries lasting up to 6 months.
  • Integrated Spotlight & Siren: Built-in lighting and a 100 dB siren enhance security.
  • Radar + PIR Motion Detection: Advanced sensors reduce false alerts and improve motion detection accuracy.
  • IP65 Weatherproof: Reliable performance in rain, snow, and extreme temperatures.
  • Fast Live Streaming: Dual-band Wi-Fi (2.4 & 5 GHz) support for stable connections.
  • Two-Way Audio: Communicate through the camera with built-in speaker and microphone.
  • Local Storage: Supports microSD cards up to 256GB for continuous recording.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT.
Perfect for locations without easy access to power outlets, this camera offers flexible placement and robust security features.
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light
The Wyze Bulb Cam combines a 2K HD security camera with a smart LED light bulb, making it a discreet and functional security solution for outdoor lighting fixtures.
Why Choose Wyze Bulb Cam?
  • 2K HD Video with Color Night Vision: Clear video day and night with vibrant color even in darkness.
  • Instant Motion Alerts: Stay informed with push notifications when motion is detected.
  • Smart LED Light: Up to 800 lumens brightness with motion-activated lighting and scheduling.
  • Easy Installation: Fits standard E26 sockets, no extra wiring needed.
  • Local and Cloud Storage: Supports microSD cards up to 256GB and optional cloud storage.
  • Two-Way Audio & Siren: Communicate and deter intruders with built-in speaker and 95 dB siren.
  • IP65 Weather Resistant: Designed for outdoor use in various climates.
  • Smart Controls: Compatible with Wyze Automations, manual control, and schedules.
Ideal for porches, garages, or any outdoor light fixture, the Bulb Cam offers security without compromising style or convenience. Wyze Bulb Cam lifestyle Wyze Bulb Cam blends security and lighting seamlessly for your outdoor spaces.
Wyze Video Doorbell v2: Clear, Wired Door Security
Enhance your front door security with the Wyze Video Doorbell v2, offering 2K video clarity and essential smart features.
Features Include:
  • 2K Video Resolution: Capture every detail with sharp, clear video.
  • Two-Way Audio: Talk to visitors or delivery personnel from anywhere.
  • Motion-Activated Voice Deterrence: Automatically plays a warning message to deter unwanted guests.
  • Local microSD Storage: Save video locally without monthly fees.
  • Real-Time Alerts: Instant notifications on your phone for motion or doorbell presses.
  • Easy Installation: Wired connection ensures continuous power and reliable performance.
This doorbell camera is a must-have for anyone wanting to monitor their entryway with high-quality video and smart alerts.
Why Choose Refurbished Wyze Smart Security Cameras?
Refurbished Wyze cameras offer the same advanced features and reliability as new models, with the added benefit of cost savings and environmental sustainability. Each unit undergoes rigorous testing to ensure optimal performance, making them a smart choice for budget-conscious consumers who don’t want to compromise on security.
Conclusion
Whether you need a wired camera with enhanced night vision, a pan-and-tilt model for full coverage, a wireless battery-powered option, a discreet bulb camera, or a smart video doorbell, Wyze’s refurbished smart security cameras deliver fast live streaming, simplified user interfaces, and instant motion alerts. Protect your home with confidence and convenience today.
Product Highlights Summary
  • Wyze Cam v4: Wired, 2.5K QHD, color night vision, spotlight, Wi-Fi 6
  • Wyze Cam Pan v3: 360° pan, 180° tilt, weatherproof, motion tracking
  • Wyze Battery Cam Pro: Wire-free, 2.5K HDR, long battery life, radar motion detection
  • Wyze Bulb Cam: 2-in-1 camera and smart LED bulb, 2K video, motion-activated light
  • Wyze Video Doorbell v2: Wired, 2K video, two-way audio, voice deterrence
Secure your space with Wyze’s innovative, easy-to-use smart cameras designed for every need.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2
TypeWired Security CameraWired Pan & Tilt Security CameraWireless Battery-Powered CameraOutdoor Security Camera + LED BulbWired Video Doorbell
Video Resolution2.5K QHD (2560 x 1440)Not explicitly stated (2.5K comparable)2.5K HDR (2560 x 1440)2K HD (2304 x 1296)2K (2048 x 1536)
Field of View (Diagonal)115.9°360° Pan, 180° Tilt134°166°166.8°
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color NV)Color Night Vision + IR Night VisionIR Night Vision (6 x 940nm IR LEDs)
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way Audio (Built-in speaker & mic)Two-Way AudioTwo-Way Audio
SirenYes (Integrated, 99 dB)Not specifiedYes (100 dB SPL)Yes (95 dB at 4 in)Not specified
SpotlightMotion-activated SpotlightNoIntegrated SpotlightIntegrated Smart LED Light BulbNo
Power SourceWiredWiredRemovable, Rechargeable BatteryWired (120V AC)Wired (16V-24V AC)
Weather ResistanceIP65IP65IP65IP65IP65
WirelessNoNoYesNoNo
Wi-Fi SupportWi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi 2.4 GHz2.4 & 5 GHz Wi-FiWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Local StorageMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GBMicroSD up to 256 GB
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTT
MountingMagnetic mount, screw-freeMount with Pan/Tilt mechanism1/4" - 20 standard mountStandard E26 bulb socketWall mount included
DimensionsNot specifiedNot specified2.5 x 1.8 x 3.5 inchesStandard bulb size4.3 x 1.7 x 0.9 inches
WeightNot specifiedNot specified0.94 lbsNot specifiedNot specified
Operating TemperatureNot specifiedNot specified-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
Special FeaturesAuto-zoom with AI, Motion-activated spotlight & siren, Smoke & CO alerts360° pan & 180° tilt, Motion tracking, Privacy modeRadar + PIR motion detection, Rechargeable battery, Up to 6 months battery life2-in-1 camera & smart LED bulb, Motion-activated light, Digital zoomMotion-activated voice deterrence, Real-time alerts, Digital zoom
Price (1 Pack)$35.98$39.98$159.98$49.98$44.98
What are the benefits of choosing refurbished Wyze smart security cameras?Refurbished Wyze smart security cameras offer the same advanced features and reliability as new models, but at a lower cost. Each camera undergoes rigorous testing to ensure optimal performance, making them a smart and environmentally friendly choice for budget-conscious consumers who don’t want to compromise on security.
What features does the Wyze Cam v4 offer for home security?The Wyze Cam v4 provides 2.5K QHD resolution for crystal-clear video, enhanced color night vision, a motion-activated spotlight and 99 dB siren, fast live streaming with Wi-Fi 6, simplified Bluetooth setup, 24/7 local recording with microSD support, instant smart alerts, and compatibility with Alexa, Google Assistant, and IFTTT.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weather resistant, making it ideal for both indoor and outdoor use. Its durable design ensures reliable performance in various weather conditions.
How does the Wyze Cam Pan v3 provide full coverage security?The Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, automatic motion tracking, IP65 weather resistance, fast live streaming, privacy mode, two-way audio, custom patrol routes, and smart home integration, making it perfect for monitoring large areas indoors or outdoors.
What makes the Wyze Battery Cam Pro a good choice for wireless security?The Wyze Battery Cam Pro is completely wire-free, powered by removable, rechargeable batteries that last up to 6 months. It offers 2.5K HDR video, integrated spotlight and siren, radar and PIR motion detection, IP65 weatherproofing, dual-band Wi-Fi, two-way audio, local storage, and compatibility with Alexa, Google Assistant, and IFTTT.
Can I use Wyze security cameras without a subscription?Yes, most Wyze security cameras, including the Wyze Cam v4, Wyze Battery Cam Pro, and Wyze Bulb Cam, support local storage via microSD cards up to 256GB, allowing for continuous recording without monthly subscription fees.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It fits standard E26 sockets, offers color night vision, instant motion alerts, up to 800 lumens brightness, motion-activated lighting, two-way audio, a 95 dB siren, and is IP65 weather resistant for outdoor use.
How does the Wyze Video Doorbell v2 enhance front door security?The Wyze Video Doorbell v2 delivers 2K video resolution, two-way audio, motion-activated voice deterrence, local microSD storage, real-time alerts, and easy wired installation, making it an excellent choice for monitoring and communicating with visitors at your entryway.
Are Wyze smart security cameras compatible with voice assistants?Yes, all featured Wyze smart security cameras are compatible with popular voice assistants such as Alexa and Google Assistant, as well as IFTTT for smart home automation.
What types of alerts do Wyze security cameras provide?Wyze security cameras offer instant notifications for motion, sound, smoke, and CO alarms, as well as real-time alerts for doorbell presses and motion detection, keeping you informed of any activity around your property.
How easy is it to install Wyze refurbished smart security cameras?Wyze refurbished smart security cameras are designed for easy installation. Many models feature tool-free setup, Bluetooth-enabled pairing, magnetic mounts, and compatibility with standard light sockets, making them user-friendly for quick and hassle-free installation.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam Pan v3 and its capabilities?Are there any ongoing sales or discounts available for Wyze products?
