Wireless Home Security Cameras with Advanced Motion Detection
Wireless Home Security Cameras with Advanced Motion Detection Alerts
Protect your home with the latest wireless security cameras that combine cutting-edge motion detection technology with high-resolution video and smart home integration. Whether you want to monitor your front porch, backyard, or indoor spaces, these cameras offer advanced alerts to keep you informed instantly.
Wyze Battery Cam Pro: Wire-Free Security with Radar + PIR Motion Detection
Experience the freedom of wire-free installation with the Wyze Battery Cam Pro, designed for versatile indoor and outdoor use. This camera features:
  • 2.5K HDR Video Resolution (2560 x 1440) for crystal-clear footage.
  • Radar + PIR Motion Detection for precise alerts that reduce false alarms.
  • Integrated Spotlight & 100 dB Siren to deter intruders immediately.
  • Removable, Rechargeable 6200mAh Battery Packs lasting up to 6 months on a single charge.
  • IP65 Weatherproof Rating ensures reliable performance in rain, snow, or shine.
  • Dual-band WiFi support (2.4 & 5 GHz) for stable connectivity.
  • Wide 134° diagonal field of view to cover large areas.
  • Two-way audio with built-in speaker and MEMS digital microphone.
  • Local storage support up to 256 GB microSD cards.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home automation.
This camera is perfect for those seeking a flexible, wire-free solution with advanced motion detection that can distinguish between people, animals, and vehicles.
Wyze Cam v4: Wired Camera with Enhanced Color Night Vision & Motion-Activated Spotlight
For users who prefer a wired setup with powerful features, the Wyze Cam v4 offers:
  • 2.5K QHD (2560x1440) resolution with wide dynamic range.
  • Enhanced Color Night Vision supported by 4 IR LEDs and 2 white spotlight LEDs (72 lumens).
  • Motion-Activated Spotlight to illuminate and alert you to activity.
  • Wi-Fi 6 Support for faster and more reliable connections.
  • 24/7 local recording with microSD card support up to 512 GB.
  • IP65 weather resistance for outdoor durability.
  • Two-way audio with noise and echo cancellation.
  • Digital zoom up to 8x.
  • Multiple mounting options including stand, wall, ceiling, and magnetic mounts.
  • Integrations with Alexa, Google Assistant, and IFTTT.
This camera is ideal for homeowners wanting a wired camera with superior night vision and smart spotlight features to enhance security.
Wyze Cam Pan v3: 360° Pan & 180° Tilt with Advanced Motion Tracking
Cover every angle with the Wyze Cam Pan v3, a versatile indoor/outdoor camera featuring:
  • 1080p Full HD video resolution with smooth 20 fps daytime and 15 fps nighttime video.
  • 360° horizontal and 180° vertical rotation for complete room or yard coverage.
  • IP65 Weatherproof design for outdoor use (requires separate outdoor power adapter).
  • Advanced motion tracking that follows movement automatically.
  • Four IR LEDs for night vision.
  • Supports local storage up to 256 GB microSD cards.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Push notifications for instant motion alerts.
Perfect for those who want a dynamic camera that can pan and tilt to track motion, providing comprehensive surveillance with smart alerts. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3: Weatherproof 360° coverage
Wyze Cam Floodlight v2: Bright 2800 Lumens with AI-Powered Motion Alerts
Illuminate and secure your property with the Wyze Cam Floodlight v2, combining powerful lighting and smart security:
  • 2K (2304 x 1296) video resolution with color night vision.
  • 2800 lumens of dimmable LED light panels with 5000K color temperature.
  • 160° wide-angle field of view to cover large outdoor areas.
  • AI-powered light control and motion detection for precise alerts.
  • Built-in 105 dB siren and two-way audio.
  • Dusk-to-dawn automation for hands-free lighting.
  • IP65 weather resistance for all-season durability.
  • Integrates seamlessly with Alexa, Google Assistant, and IFTTT.
This floodlight camera is perfect for driveways, backyards, and front porches where bright illumination and smart alerts are essential. Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2: Bright security lighting with smart alerts
Wyze Bulb Cam: Discreet 2-in-1 Security Camera and Smart LED Bulb
For a subtle security solution, the Wyze Bulb Cam combines a smart LED bulb with a 2K security camera:
  • 2K HD video (2304 x 1296) with color night vision.
  • 160° field of view with wide diagonal angle of 166°.
  • Motion-activated light and push notifications for instant alerts.
  • Fits standard E26 light sockets for easy installation.
  • Up to 800 lumens brightness with 3000K warm light.
  • Two-way audio and 95 dB siren.
  • IP65 weather resistance for outdoor use.
  • Compatible with Android 7.0+ and iOS 14.0+.
Ideal for users who want to blend security cameras into existing lighting fixtures without compromising on video quality or motion detection. Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam: Discreet security with smart lighting
Why Choose Wyze Wireless Security Cameras?
Wyze cameras combine affordability with advanced technology, offering high-resolution video, smart motion detection, and seamless integration with popular voice assistants. Their wireless options provide flexible installation without sacrificing performance, making them ideal for modern smart homes.
With options ranging from wire-free battery-powered cameras to wired floodlights and pan-tilt models, Wyze has a solution tailored to your home security needs. Advanced motion detection alerts ensure you stay informed instantly, helping you protect what matters most.
Enhance your home security today with Wyze’s wireless cameras featuring advanced motion detection alerts, crystal-clear video, and smart home compatibility.
FeatureWyze Battery Cam ProWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Bulb Cam
TypeBattery Wireless CameraWired CameraWired Pan-Tilt CameraWired Floodlight CameraWired Bulb Camera
Video Resolution2.5K HDR2.5K QHD1080p (1920x1080)2K (2304x1296)2K (2304x1296)
Field of ViewNot specified115.9° (D) x 98.5° (H) x 53.1° (V)120° FOV160° Diagonal160° (Diagonal), 166° (Diagonal), 144° (H), 82.5° (V)
Night VisionColor Night Vision (with HDR)Enhanced Color Night VisionIR Night Vision (4 IR LEDs 850 nm)Color Night VisionColor Night Vision + IR Night Vision
SpotlightIntegrated Spotlight (150 lumens)Motion-activated SpotlightNo spotlightIntegrated SpotlightMotion-Activated Light
SirenIntegrated Siren99 dB SirenNo siren105 dB Siren95 dB Siren
AudioTwo-way audio (built-in mic & speaker)Enhanced Two-way TalkTwo-way audio with noise & echo cancellationTwo-way audioTwo-way audio
Power SourceBattery (removable, rechargeable)Wired (requires power adapter)Wired (requires power adapter)Hardwired (110-120V AC)Hardwired (120V AC, E26 socket)
Weather ResistanceIP65IP65IP65IP65IP65
Connectivity2.4 & 5 GHz Wi-FiWi-Fi 6 (requires Wi-Fi 6 router)2.4 GHz Wi-Fi only2.4 GHz Wi-Fi2.4 GHz Wi-Fi
Local StorageMicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)
Motion DetectionRadar + PIR motion detectionMotion and sound detection with zonesMotion detectionMotion detectionMotion detection
Mounting OptionsFlexible, includes universal mount for ceilingMagnetic mount, screw-freeScrew mount (1/4"-20), pan & tiltWall or ceiling mountFits standard E26 light socket
DimensionsNot specifiedNot specified124mm x 60mm x 63mm9.5in x 7.7in x 7.0in (24.13cm x 19.56cm x 17.78cm)Not specified
WeightNot specifiedNot specified11.29 oz (320 g)2.76 lbs (1.25 kg)Not specified
Special FeaturesRemovable battery packs, solar panel option, radar + PIR, local recordingWi-Fi 6 support, AI auto-zoom, smoke & CO alerts, Alexa/Google/IFTTT integration360° pan, 180° tilt, noise & echo cancellation, Alexa/Google/IFTTT integration2800 lumens LED, AI-powered light control, dusk-to-dawn automation2-in-1 camera & smart LED bulb, up to 800 lumens brightness, supports linking up to 5 bulbs
Price (1 Pack)$89.98$35.98$39.98$89.98$49.98
What are the key features of Wyze wireless home security cameras?Wyze wireless home security cameras offer advanced motion detection alerts, high-resolution video, smart home integration, and flexible installation options. Features include 2.5K HDR video, radar and PIR motion detection, weatherproof designs, two-way audio, local storage support, and compatibility with Alexa, Google Assistant, and IFTTT.
How does the Wyze Battery Cam Pro provide wire-free security?The Wyze Battery Cam Pro is a wire-free security camera with removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge. It features 2.5K HDR video, radar + PIR motion detection for precise alerts, an integrated spotlight, a 100 dB siren, and IP65 weatherproofing for reliable indoor and outdoor use.
What makes the Wyze Cam v4 ideal for night vision and wired security?The Wyze Cam v4 is a wired security camera with enhanced color night vision, supported by 4 IR LEDs and 2 white spotlight LEDs. It offers 2.5K QHD resolution, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, IP65 weather resistance, and multiple mounting options, making it perfect for users seeking superior night vision and reliable wired performance.
How does the Wyze Cam Pan v3 provide 360° coverage and motion tracking?The Wyze Cam Pan v3 features 360° horizontal and 180° vertical rotation, allowing it to cover entire rooms or outdoor areas. Its advanced motion tracking automatically follows movement, while 1080p Full HD video, night vision, two-way audio, and IP65 weatherproofing ensure comprehensive surveillance and instant motion alerts.
What are the benefits of the Wyze Cam Floodlight v2 for outdoor security?The Wyze Cam Floodlight v2 combines a 2K security camera with 2800 lumens of dimmable LED lighting, providing bright illumination and AI-powered motion alerts. It features a 160° wide-angle view, built-in 105 dB siren, dusk-to-dawn automation, IP65 weather resistance, and seamless integration with smart home systems, making it ideal for driveways, backyards, and front porches.
How does the Wyze Bulb Cam offer discreet security and smart lighting?The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED bulb. It fits standard E26 sockets, offers 160° field of view, motion-activated lighting, push notifications, two-way audio, a 95 dB siren, and IP65 weather resistance, making it a subtle yet effective security solution for both indoor and outdoor use.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT. This allows for seamless integration and automation within your smart home ecosystem.
What storage options are available for Wyze security cameras?Wyze security cameras support local storage via microSD cards, with capacities up to 256 GB or 512 GB depending on the model. This enables continuous or event-based recording without the need for cloud subscriptions.
Are Wyze cameras suitable for outdoor use?Many Wyze cameras, including the Battery Cam Pro, Cam v4, Cam Pan v3, Cam Floodlight v2, and Bulb Cam, feature IP65 weather resistance, making them suitable for outdoor installation in various weather conditions.
Why should I choose Wyze wireless security cameras for my home?Wyze wireless security cameras offer a combination of affordability, advanced technology, high-resolution video, smart motion detection, and easy integration with smart home devices. Their flexible installation options and instant motion alerts make them an excellent choice for enhancing home security.
What features does the Wyze Battery Cam Pro offer for outdoor use?Can you explain how the motion detection technology works in the Wyze cameras?Do you have any deals, ongoing sales, discounts, or promotions available for the Wyze cameras?
