Fast Notification Smart Security Cameras for Home Surveillance
When it comes to protecting your home, having a smart security camera that delivers fast notifications and reliable surveillance is essential. Whether you want to monitor your front porch, backyard, or indoor spaces, Wyze offers a range of advanced cameras designed to keep you informed instantly and secure your property day and night. Below, explore the top Wyze smart security cameras that combine cutting-edge technology, weather resistance, and smart home integration for the ultimate home surveillance experience.
Wyze Cam v4: Crystal-Clear 2.5K QHD with Enhanced Color Night Vision
Superior Image Quality and Night Vision
Wyze Cam v4 is the clearest Wyze camera ever made, boasting a stunning 2.5K Quad High Definition resolution that captures every detail with precision. Its enhanced color night vision technology allows you to see vibrant colors even in low-light conditions, revealing details that traditional black-and-white night vision cameras miss.
Fast and Smart Notifications
Equipped with advanced motion and sound detection, Wyze Cam v4 sends instant alerts to your phone whenever activity is detected. It supports customizable motion detection zones so you only get notified about what matters most. Plus, it can alert you to smoke and carbon monoxide alarms, adding an extra layer of safety.
Robust Features for All-Weather Use
With an IP65 weather-resistant rating, Wyze Cam v4 is perfect for both indoor and outdoor use. It includes a motion-activated spotlight and a 99 dB siren to deter intruders effectively. The camera supports 24/7 local recording to a microSD card (up to 256GB) without requiring a subscription.
Seamless Smart Home Integration
Wyze Cam v4 works effortlessly with Alexa, Google Assistant, and IFTTT, allowing you to control your camera with voice commands and automate your home security setup. The camera also supports Wi-Fi 6 for a stronger, more reliable connection.
"Wyze Cam v4 gives your home superhero vision with vibrant color night vision and fast alerts."
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Coverage
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 offers weather-resistant, full-area coverage for your home.
Dynamic Pan, Tilt, and Motion Tracking
Wyze Cam Pan v3 is a versatile indoor/outdoor camera featuring 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your property. Its automatic motion-tracking quietly follows moving objects, ensuring nothing escapes your watchful eye.
Weatherproof and Durable
Rated IP65 for weather resistance, this camera can brave rain, snow, or shine when paired with the Wyze Outdoor Power Adapter (sold separately). It’s built to withstand outdoor conditions while delivering crystal-clear 2.5K video with color night vision.
Privacy Mode and Two-Way Audio
When you want privacy, activate the camera’s Privacy Mode to point the lens downward and disable recording. The built-in two-way audio lets you communicate through the camera, perfect for greeting visitors or warding off unwanted guests.
Smart Alerts and Custom Zones
Receive instant notifications for motion and sound detection, with options to set custom detection zones. The camera also alerts you to smoke and CO alarms, keeping your home safe from multiple threats.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Wyze Cam Floodlight v2 illuminating driveway at night Powerful floodlight camera lighting up your driveway with smart alerts.
Powerful 2800 Lumens LED Floodlight
Wyze Cam Floodlight v2 combines a 2K security camera with two dimmable LED light panels delivering 2800 lumens of brightness. This powerful lighting ensures your outdoor areas are well-lit, deterring intruders and improving video clarity at night.
Wide 160° Field of View with Color Night Vision
Capture a broad view of your property with a 160° diagonal field of view. The camera’s color night vision and AI-powered light control provide clear, vibrant footage even in darkness.
Smart Features and Voice Deterrence
This floodlight camera includes a 105 dB siren and motion-activated voice deterrence to scare off unwanted visitors. It supports two-way audio, allowing you to speak through the camera remotely.
Weather Resistant and Smart Home Compatible
With an IP65 rating, the Wyze Cam Floodlight v2 is built to withstand harsh weather conditions. It integrates seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Battery Cam Pro: Wire-Free, Long-Lasting Security Anywhere
Wire-Free Convenience with Long Battery Life
Wyze Battery Cam Pro offers 2.5K HDR video resolution in a completely wire-free design. Its removable, rechargeable battery packs provide up to 6 months of battery life on a single charge, making it ideal for locations without easy access to power.
Advanced Motion Detection with Radar + PIR
This camera uses dual radar and PIR sensors for highly accurate motion detection, reducing false alerts. It also features an integrated spotlight and 100 dB siren for active deterrence.
Weatherproof and Flexible Installation
Rated IP65 for weather resistance, the Battery Cam Pro can be installed indoors or outdoors with ease. It supports both 2.4 GHz and 5 GHz Wi-Fi for reliable connectivity.
Two-Way Audio and Smart Assistant Support
Communicate through the camera with two-way audio and control it via Alexa, Google Assistant, or IFTTT integrations.
Why Choose Wyze for Fast Notification Smart Security Cameras?
Wyze smart cameras combine high-resolution video, rapid alert systems, and smart home compatibility to provide comprehensive home surveillance. Whether you need wired or wire-free options, indoor or outdoor coverage, Wyze has a solution tailored to your security needs.
With features like enhanced color night vision, AI-powered motion tracking, and powerful deterrents such as sirens and spotlights, Wyze cameras ensure you never miss a moment and can respond quickly to any security event.
Summary of Featured Products
  • Wyze Cam v4: 2.5K QHD, enhanced color night vision, motion-activated spotlight, Wi-Fi 6, Alexa/Google compatible.
  • Wyze Cam Pan v3: 360° pan, 180° tilt, IP65 weatherproof, motion tracking, privacy mode.
  • Wyze Cam Floodlight v2: 2K video, 2800 lumens floodlight, color night vision, 105 dB siren, smart voice deterrence.
  • Wyze Battery Cam Pro: Wire-free, 2.5K HDR, radar + PIR detection, rechargeable battery, IP65 weatherproof.
Secure your home with Wyze’s fast notification smart security cameras and enjoy peace of mind knowing you’re always connected to what matters most.
Two-way audio with Wyze Cam Stay connected with two-way audio for real-time communication.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Battery Cam Pro
TypeWired CameraWired Camera (Pan & Tilt)Wired Lighting CameraBattery Camera (Wireless)
Video Resolution2.5K QHD (2560x1440)Not explicitly stated (Comparable 2.5K)2K (2304x1296)2.5K HDR (2560x1440)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° Pan, 180° Tilt160° Diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)
Night VisionEnhanced Color Night VisionColor Night Vision with Starlight SensorColor Night VisionIR LEDs + White LEDs (Color Night Vision)
AudioTwo-way talk, 99dB waterproof speakerTwo-way audioTwo-way audio with built-in speaker & micTwo-way audio with built-in speaker & mic
SirenBuilt-in siren (99 dB)Not specifiedBuilt-in siren (105 dB)Built-in siren (100 dB SPL @ 0.1m)
Power SourceWired (Indoor USB Power Adapter)Wired (requires Outdoor Power Adapter for outdoor use)Hardwired (110-120V AC)Removable, Rechargeable Battery Packs
Weather ResistanceIP65IP65IP65IP65
ConnectivityWi-Fi 6, 2.4 GHz Wi-FiWi-Fi (2.4 GHz)802.11 b/g/n 2.4 GHzWi-Fi 2.4 & 5 GHz (802.11a/n/g/b)
Local StoragemicroSD card up to 512 GB (required)microSD card up to 256 GBmicroSD up to 256 GB (ExFAT format)microSD card up to 256 GB
Cloud StorageSubscription availableSubscription availableNot specifiedSubscription available
Motion DetectionYes, with motion detection zonesYes, with motion tracking and custom zonesYesRadar + PIR Motion Detection
Additional FeaturesMotion-activated spotlight, AI Auto-Zoom, Smoke & CO alerts, Bluetooth 5.2Pan Scan™ patrol, Privacy Mode, Smoke & CO alerts2800 Lumens LED lights, Ambient Light Mode, AI-Powered Light Control, Dusk-to-Dawn automationIntegrated spotlight, radar motion detection, removable battery, up to 6 months battery life
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)Not specified9.5in x 7.7in x 7.0in (24.13 x 19.56 x 17.78 cm)2.5 x 1.8 x 3.5 inches
Weight0.49 lb (222 g)Not specified2.76 lbs (1.25 kg)0.94 lbs
Colors AvailableWhite, Grey, Black, Clear (some sold out)Black, WhiteBlack, WhiteBlack, White
Price (Single Pack)$35.98$39.98$89.98$159.98
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
What are the key features of Wyze Cam v4 for home security?Wyze Cam v4 offers 2.5K Quad High Definition resolution, enhanced color night vision, fast motion and sound notifications, customizable detection zones, smoke and CO alarm alerts, IP65 weather resistance, a motion-activated spotlight, 99 dB siren, 24/7 local recording to microSD (up to 256GB), and seamless integration with Alexa, Google Assistant, IFTTT, and Wi-Fi 6.
How does Wyze Cam Pan v3 provide complete home surveillance coverage?Wyze Cam Pan v3 features 360° horizontal pan and 180° vertical tilt, automatic motion tracking, IP65 weather resistance (with outdoor adapter), 2.5K video with color night vision, privacy mode, two-way audio, and instant notifications for motion, sound, smoke, and CO alarms.
What makes Wyze Cam Floodlight v2 effective for outdoor security?Wyze Cam Floodlight v2 combines a 2K security camera with two dimmable LED panels delivering 2800 lumens, a wide 160° field of view, color night vision, AI-powered light control, a 105 dB siren, motion-activated voice deterrence, two-way audio, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
Is Wyze Battery Cam Pro suitable for locations without power outlets?Yes, Wyze Battery Cam Pro is completely wire-free, featuring a removable, rechargeable battery that lasts up to 6 months per charge. It offers 2.5K HDR video, dual radar and PIR motion detection, an integrated spotlight, 100 dB siren, IP65 weather resistance, and supports both 2.4 GHz and 5 GHz Wi-Fi.
Do Wyze security cameras support two-way audio communication?Yes, all featured Wyze cameras, including Wyze Cam v4, Cam Pan v3, Floodlight v2, and Battery Cam Pro, support two-way audio, allowing you to communicate in real time with visitors or deter intruders remotely.
Can Wyze security cameras be integrated with smart home systems?Wyze cameras are compatible with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation for enhanced convenience and security.
Are Wyze security cameras weatherproof for outdoor use?Yes, Wyze Cam v4, Cam Pan v3 (with outdoor adapter), Floodlight v2, and Battery Cam Pro all have an IP65 weather resistance rating, making them suitable for both indoor and outdoor installation.
How do Wyze cameras provide fast notifications for home security events?Wyze cameras use advanced motion and sound detection, customizable detection zones, and AI-powered features to send instant alerts to your phone whenever activity is detected, ensuring you are always informed of important events.
Do Wyze cameras require a subscription for 24/7 recording?No, Wyze Cam v4 supports 24/7 local recording to a microSD card (up to 256GB) without requiring a subscription, allowing continuous video storage on the device.
What types of deterrents do Wyze security cameras offer?Wyze cameras feature active deterrents such as motion-activated spotlights, powerful sirens (up to 105 dB), and voice deterrence to help scare off intruders and enhance your home’s security.
What features does the Wyze Cam v4 offer for home security?Can you explain how the motion detection zones work on the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze Cam v4?
