Refurbished Smart Color LED Bulbs for Damp Locations
Refurbished Smart Color LED Bulbs for Versatile Damp Location Usage
Looking for smart color LED bulbs that combine vibrant lighting with reliable performance in damp environments? Our selection of refurbished Wyze smart bulbs offers exactly that—advanced smart lighting solutions designed to brighten your home with millions of colors, while being suitable for damp locations such as bathrooms, covered patios, and kitchens. Discover the perfect smart bulb to elevate your lighting experience with energy efficiency, voice control, and customizable settings.
Wyze Bulb Color BR30: Smart, Dimmable, and Colorful for Recessed Fixtures
The Wyze Bulb Color BR30 is a powerful smart bulb designed specifically for recessed lighting fixtures. It delivers a wide lumen range from 30 to 950 lumens, equivalent to a 75W traditional bulb, making it ideal for both bright task lighting and cozy ambient settings.
Key Features:
  • 16 million ultra-accurate colors to set any mood or occasion.
  • Dimmable with smooth brightness control (note: not compatible with dimmer switches).
  • Wide color temperature range from 1800K (warm) to 6500K (cool daylight).
  • High color rendering index (CRI 90+) for vivid, true-to-life colors.
  • Suitable for damp locations, perfect for bathrooms and covered outdoor areas.
  • Long life expectancy of 25,000 hours.
  • Connectivity: Wi-Fi (802.11 b/g/n 2.4GHz) and Bluetooth for seamless smart home integration.
  • Voice control compatibility with Alexa and Google Assistant.
  • Additional smart modes like sleep routines, vacation mode, and music sync.
Dimensions & Specs:
  • Bulb shape: BR30
  • Base: E26 standard socket
  • Power consumption: 11.5W
  • Operating temperature: -4°F to 104°F
This bulb is perfect for recessed lighting in damp locations where you want vibrant, customizable color lighting without sacrificing brightness or control. Wyze Bulb Color BR30 in Living Room Experience vibrant color lighting in your living space with Wyze Bulb Color BR30.
Wyze Bulb Color A19: The Ultimate 16 Million Color Smart Bulb for Damp Areas
The Wyze Bulb Color (A19) is a versatile smart bulb that offers the brightest output in the Wyze color bulb lineup, reaching up to 1100 lumens. It’s designed for standard fixtures and is suitable for damp locations, making it a great choice for kitchens, bathrooms, and covered porches.
Highlights:
  • 16 million colors with tunable white light from 1800K to 6500K.
  • Extra bright with up to 1100 lumens, ideal for well-lit rooms.
  • Dimmable for personalized lighting ambiance.
  • High CRI (90+) ensures colors appear natural and vibrant.
  • Smart connectivity via 2.4GHz Wi-Fi and Bluetooth.
  • Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Rated for damp locations, but not for fully enclosed fixtures.
  • Long lifespan of 25,000 hours.
Physical Specs:
  • Bulb shape: A19
  • Base: E26
  • Power: 12 watts
  • Dimensions: 2.5 x 2.5 x 5 inches
This bulb is perfect for users who want a bright, colorful smart bulb that can handle the moisture and humidity of damp environments while offering full smart home integration. Wyze Bulb Color in Bedroom Create the perfect bedroom ambiance with Wyze Bulb Color A19.
Wyze Bulb White: Reliable Smart White LED for Damp Locations
If you prefer classic white lighting with smart features, the Wyze Bulb White is an excellent choice. It offers adjustable brightness and color temperature, suitable for damp locations, and integrates seamlessly into your smart home setup.
Features:
  • Brightness range from 30 to 800 lumens.
  • Color temperature options: 2700K (warm) to 6500K (cool daylight).
  • Dimmable with smooth control.
  • High CRI (90+) for natural white light.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Rated for damp locations, perfect for bathrooms and covered outdoor fixtures.
  • Connectivity via Wi-Fi and Bluetooth.
Specs:
  • Bulb shape: A19
  • Base: E26
  • Power: 9.5 watts
  • Dimensions: 4.6 in x 2.4 in x 2.4 in
This bulb is ideal for those who want dependable white lighting with smart controls in damp environments. Wyze Bulb White in Cozy Bedroom Enjoy warm, smart white lighting with Wyze Bulb White.
Why Choose Refurbished Wyze Smart Bulbs for Damp Locations?
Refurbished Wyze smart bulbs offer an eco-friendly and cost-effective way to upgrade your home lighting with the latest smart features. Each bulb is tested to ensure quality and performance, providing you with reliable, versatile lighting solutions that thrive in damp environments.
  • Versatility: Suitable for bathrooms, covered patios, kitchens, and other damp locations.
  • Smart Control: Use voice commands, smartphone apps, and automation routines.
  • Energy Efficient: Low wattage with high lumen output saves energy.
  • Long-lasting: 25,000 hours of life expectancy reduces replacement frequency.
  • Vibrant Colors & Tunable Whites: Customize your lighting to fit any mood or task.
Summary of Refurbished Smart Color LED Bulbs for Damp Locations
ProductBulb ShapeLumensColor OptionsDamp Location RatedConnectivitySpecial Features
Wyze Bulb Color BR30BR3030 - 95016 million colorsYesWi-Fi, BluetoothMusic mode, vacation mode
Wyze Bulb Color A19A1930 - 110016 million colorsYesWi-Fi, BluetoothAlexa, Google Assistant, IFTTT
Wyze Bulb WhiteA1930 - 800Tunable whiteYesWi-Fi, BluetoothDimmable, warm to cool white
Upgrade your home lighting with these refurbished smart bulbs designed for versatile damp location usage. Enjoy vibrant colors, smart automation, and reliable performance all in one package.
FeatureWyze Bulb Color BR30Wyze Bulb ColorWyze Bulb White
Bulb ShapeBR30A19A19
Base TypeE26E26E26
Lumen Output30 lm (dim) - 950 lm (bright)30 lm (dim) - 1100 lm (bright)30 lm - 800 lm
Wattage Equivalent75W75W9.5 watts
Color Options16 million colors16 million colorsWhite light only
Color Temperature RangeTunable white light, Sun Match featureTunable white light2700K - 6500K
CRI Rating90+90+90+
DimmableYes (Not for use with dimmer switches)YesYes
Smart FeaturesCustom presets, notifications, sleep routines, music mode, voice control, vacation mode, groupingCustom presets, notifications, sleep routines, music mode, voice control, vacation mode, groupingDimmable controls, voice control, Alexa, Google Assistant, IFTTT integration
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Compatible withAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Operating Temperature-4°F to 104°FNot specified (likely similar)-4°F to 104°F
DimensionsNot specifiedNot specified4.6 in x 2.4 in x 2.4 in
WeightNot specifiedNot specified0.31 lbs
Price (2-Pack)$27.98$26.26$23.99
What are refurbished Wyze smart bulbs for damp locations?Refurbished Wyze smart bulbs are pre-owned bulbs that have been tested and restored to full working condition. They offer advanced smart lighting features and are rated for use in damp locations such as bathrooms, kitchens, and covered patios.
Are Wyze smart bulbs suitable for bathrooms and covered outdoor areas?Yes, Wyze smart bulbs, including the Color BR30, Color A19, and White models, are rated for damp locations, making them ideal for bathrooms, kitchens, and covered outdoor spaces like patios and porches.
What is the difference between Wyze Bulb Color BR30 and Wyze Bulb Color A19?The Wyze Bulb Color BR30 is designed for recessed lighting fixtures and offers up to 950 lumens, while the Wyze Bulb Color A19 fits standard fixtures and provides up to 1100 lumens. Both offer 16 million colors, are dimmable, and are suitable for damp locations.
Can I control Wyze smart bulbs with voice assistants?Yes, Wyze smart bulbs are compatible with popular voice assistants such as Amazon Alexa and Google Assistant. Some models also support IFTTT for automation and integration with other smart home devices.
Do Wyze smart bulbs work with Wi-Fi and Bluetooth?Yes, all refurbished Wyze smart bulbs support both Wi-Fi (2.4GHz) and Bluetooth connectivity, allowing for easy setup and seamless smart home integration.
Are Wyze smart bulbs energy efficient?Yes, Wyze smart bulbs are designed to be energy efficient, offering high lumen output with low wattage. This helps save energy while providing bright, customizable lighting.
How long do refurbished Wyze smart bulbs last?Refurbished Wyze smart bulbs have a long life expectancy of up to 25,000 hours, reducing the need for frequent replacements.
Can I use Wyze smart bulbs in fully enclosed fixtures?Wyze smart bulbs are rated for damp locations but are not recommended for use in fully enclosed fixtures, as this may affect their performance and lifespan.
What color options are available with Wyze smart bulbs?Wyze Bulb Color models offer 16 million ultra-accurate colors and tunable white light from 1800K to 6500K. The Wyze Bulb White provides adjustable white light from warm (2700K) to cool daylight (6500K).
What special smart features do Wyze bulbs offer?Wyze smart bulbs include features such as dimmable brightness, customizable color settings, sleep routines, vacation mode, music sync, and compatibility with smart home automation platforms.
Why should I choose refurbished Wyze smart bulbs?Refurbished Wyze smart bulbs are an eco-friendly and cost-effective way to upgrade your lighting. Each bulb is tested for quality and performance, offering reliable, energy-efficient, and versatile lighting solutions for damp environments.
What are the key features of the Wyze Bulb Color BR30?Can you tell me more about the Wyze Bulb Color A19 and its specifications?Do you have any ongoing sales or discounts for the Wyze smart bulbs?
