Smart LED Bulbs: Tunable White & High CRI for Home Automation
Smart LED Bulbs with Tunable White and Accurate Color Rendering for Home Automation
Enhance your home automation setup with smart LED bulbs that offer tunable white light and exceptional color accuracy. Whether you want to create the perfect ambiance for relaxing evenings, energize your workspace, or highlight your home’s décor, these smart bulbs provide versatile lighting solutions with seamless app and voice control integration.
Wyze Bulb Color BR30: Vibrant Tunable White with Ultra-Accurate Colors
The Wyze Bulb Color BR30 is designed for recessed lighting fixtures, delivering a powerful and customizable lighting experience. This smart bulb offers:
  • Tunable White Range: 1800K to 6500K, allowing you to adjust from warm cozy tones to crisp daylight.
  • Color Rendering Index (CRI) 90+: Ensures colors appear natural and vivid, perfect for home environments where accurate color perception matters.
  • 16 Million Colors: Choose from a vast palette to set any mood or theme.
  • Wide Lumen Range: From a soft 30 lumens to a bright 950 lumens, it can both out-shine and out-dim many competitors.
  • Smart Features: Voice control compatibility, custom lighting scenes, sleep routines, vacation mode, and music sync mode.
  • Connectivity: Works over 2.4GHz Wi-Fi and Bluetooth for reliable smart home integration.
  • Long Life: Rated for 25,000 hours of use.
  • Base & Shape: E26 base with BR30 shape, ideal for recessed fixtures.
Note: Not compatible with dimmer switches.
This bulb is perfect for living rooms, kitchens, or any space where recessed lighting is preferred and you want full control over color and brightness. Living room with smart color lighting Create vibrant, tunable white lighting in your living space
Wyze Bulb Color: Bright, Tunable White with Exceptional Versatility
For those seeking a versatile A19 smart bulb, the Wyze Bulb Color offers:
  • Extra Bright Output: Up to 1100 lumens, bright enough for most rooms.
  • Tunable White: Adjustable color temperature from 1800K (warm) to 6500K (cool daylight).
  • CRI 90+: Accurate color rendering for true-to-life illumination.
  • 16 Million Colors: Customize your lighting with millions of hues.
  • Smart Controls: Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth.
  • Long Lifespan: 25,000 hours.
  • Base & Shape: E26 base, A19 shape, suitable for standard fixtures.
  • Damp Location Rated: Safe for bathrooms and covered outdoor areas.
This bulb is ideal for bedrooms, home offices, or any room where bright, tunable white light and rich color options are desired. Bedroom with smart color lighting Set the perfect bedroom ambiance with tunable white smart lighting
Why Choose Tunable White and High CRI Smart Bulbs?
Accurate color rendering (CRI 90+) means your smart bulbs will display colors more naturally and vividly, enhancing the look of your home’s interior and artwork. Tunable white lighting lets you adjust the warmth or coolness of your light to match the time of day or your mood, improving comfort and productivity.
Both Wyze Bulb Color BR30 and Wyze Bulb Color provide these features, making them excellent choices for smart home enthusiasts who want precise control over their lighting environment.
Additional Smart Lighting Options
While the focus here is on smart LED bulbs with tunable white and accurate color rendering, Wyze also offers other smart lighting and home automation products that complement your setup, such as smart sockets and outdoor lighting solutions.
Summary of Key Specs
FeatureWyze Bulb Color BR30Wyze Bulb Color (A19)
Color Temperature Range1800K - 6500K1800K - 6500K
Color Rendering Index (CRI)90+90+
Brightness (Lumens)30 - 95030 - 1100
Color Options16 million colors16 million colors
Power Consumption11.5W12W
Base TypeE26E26
Bulb ShapeBR30A19
ConnectivityWi-Fi (2.4GHz), BluetoothWi-Fi (2.4GHz), Bluetooth
Voice Assistant SupportAlexa, Google AssistantAlexa, Google Assistant
Life Expectancy25,000 hours25,000 hours
Suitable for Damp LocationsYesYes
Conclusion
For smart home automation enthusiasts looking for smart LED bulbs with tunable white and accurate color rendering, the Wyze Bulb Color BR30 and Wyze Bulb Color (A19) stand out as top choices. They combine vibrant color options, precise white tuning, and smart features that integrate seamlessly with your home ecosystem. Upgrade your home lighting today with these smart bulbs to enjoy personalized, energy-efficient, and beautifully rendered light that adapts to your lifestyle.
Bulb ShapeBR30A19
Base TypeE26E26
Lumen Output30 lm (dim) - 950 lm (bright)30 lm (dim) - 1100 lm (bright)
Wattage Equivalent75W75W
DimmableYes (Not for use in dimmer switches)Yes
White Light Temperature ControlYesYes
Custom Presets/ScenesYesYes
Brilliant NotificationsYesYes
Sleep RoutinesYesYes
Music ModeYes (Requires grouping with Wyze Light Strip or Pro)Yes (Requires grouping with Wyze Light Strip or Pro)
Voice ControlAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYes
GroupingYesYes
Compatible FixturesStandard recessed/can lighting fixturesStandard fixtures
Notable LimitationsNot for use in dimmer switchesNo specific limitation mentioned
What are the benefits of using smart LED bulbs with tunable white and high CRI?Smart LED bulbs with tunable white and a high Color Rendering Index (CRI 90+) provide natural and vivid color representation, making your home’s interior and artwork look their best. Tunable white lighting allows you to adjust the warmth or coolness of your light to match your mood, time of day, or activity, enhancing comfort and productivity.
What is the difference between Wyze Bulb Color BR30 and Wyze Bulb Color (A19)?The Wyze Bulb Color BR30 is designed for recessed lighting fixtures and offers a brightness range of 30 to 950 lumens, while the Wyze Bulb Color (A19) is suitable for standard fixtures and provides up to 1100 lumens. Both bulbs feature tunable white (1800K-6500K), CRI 90+, 16 million color options, smart controls, and a 25,000-hour lifespan. The BR30 has a BR30 shape, and the A19 has an A19 shape.
Are Wyze smart bulbs compatible with voice assistants?Yes, both Wyze Bulb Color BR30 and Wyze Bulb Color (A19) are compatible with popular voice assistants such as Amazon Alexa and Google Assistant, allowing for hands-free control and integration with your smart home ecosystem.
Can I use Wyze smart bulbs in damp locations like bathrooms or covered outdoor areas?Yes, both Wyze Bulb Color BR30 and Wyze Bulb Color (A19) are rated for use in damp locations, making them safe for bathrooms and covered outdoor spaces.
What is the color temperature range of Wyze smart bulbs?Both Wyze Bulb Color BR30 and Wyze Bulb Color (A19) offer a tunable white color temperature range from 1800K (warm, cozy light) to 6500K (cool daylight), allowing you to customize your lighting to suit any mood or activity.
How many colors can Wyze smart bulbs display?Wyze smart bulbs can display up to 16 million colors, giving you endless options to create the perfect ambiance for any occasion.
What connectivity options do Wyze smart bulbs support?Wyze smart bulbs support both 2.4GHz Wi-Fi and Bluetooth connectivity, ensuring reliable integration with your smart home network and easy setup.
Are Wyze smart bulbs compatible with dimmer switches?No, Wyze smart bulbs are not compatible with dimmer switches. They offer their own dimming capabilities through the Wyze app and voice control.
How long do Wyze smart bulbs last?Both Wyze Bulb Color BR30 and Wyze Bulb Color (A19) are rated for a lifespan of 25,000 hours, providing long-lasting and energy-efficient lighting.
What smart features do Wyze smart bulbs offer?Wyze smart bulbs offer a range of smart features, including voice control, custom lighting scenes, sleep routines, vacation mode, music sync mode, and compatibility with automation platforms like IFTTT.
What base types and shapes are available for Wyze smart bulbs?Both Wyze Bulb Color BR30 and Wyze Bulb Color (A19) use the standard E26 base. The BR30 is designed for recessed fixtures, while the A19 is suitable for standard light fixtures.
What are the smart features of the Wyze Bulb Color BR30?Can you explain the difference between the Wyze Bulb Color BR30 and the Wyze Bulb Color A19?Do you have any deals, ongoing sales, discounts, or promotions for smart bulbs?
