Energy Efficient Smart LED Bulbs for Damp Indoor Spaces
Energy Efficient Smart LED Bulbs for Damp Indoor Areas
When it comes to lighting solutions that combine energy efficiency, smart technology, and suitability for damp indoor environments, Wyze offers a range of smart LED bulbs designed to meet your needs. Whether you want vibrant color-changing ambiance or crisp white illumination, these bulbs provide smart control, durability, and energy savings — perfect for bathrooms, kitchens, basements, and other damp indoor spaces.
Wyze Bulb Color: Vibrant Smart LED for Damp Locations
Experience the ultimate in smart lighting with the Wyze Bulb Color, a top-tier smart LED bulb that supports 16 million colors and tunable white light. This bulb is specifically rated as suitable for damp locations, making it ideal for indoor areas prone to moisture such as bathrooms or covered porches.
Key Features:
  • Brightness: Extra bright at 1100 lumens, adjustable from 30 to 1100 lumens.
  • Color Range: 16 million colors plus tunable white (1800K to 6500K) for any mood or occasion.
  • Energy Efficient: Consumes only 12 watts while delivering powerful light.
  • Smart Control: Connects via 2.4GHz WiFi and Bluetooth, compatible with Alexa, Google Assistant, and IFTTT.
  • Durability: Rated for damp locations, with an operating temperature range from -4°F to 104°F and humidity tolerance up to 85%.
  • Long Life: 25,000 hours life expectancy ensures years of reliable use.
  • Form Factor: Standard A19 bulb shape with E26 base fits most fixtures.
  • Certifications: Energy Star, UL, FCC, and more for safety and efficiency compliance.
Perfect for adding color and smart convenience to your bathroom, laundry room, or any damp indoor space.
Wyze Bulb Color in Living Room Ambiance Smart color-changing bulb enhancing living room ambiance
Wyze Bulb Color BR30: Smart Recessed Lighting for Damp Areas
For recessed lighting fixtures, the Wyze Bulb Color BR30 offers a dimmable, color-changing smart bulb that fits seamlessly into your existing setup. It is also rated for damp locations, making it a great choice for bathrooms, kitchens, or covered indoor spaces where moisture is a concern.
Highlights:
  • Brightness Range: 30 to 950 lumens, equivalent to a 75W incandescent bulb.
  • Color Options: 16 million colors with a wide color temperature range (1800K - 6500K).
  • Smart Features: Voice control, custom lighting scenes, sleep routines, vacation and music modes.
  • Energy Use: Efficient 11.5 watts power consumption.
  • Compatibility: Works with Alexa, Google Assistant, and Bluetooth/WiFi connectivity.
  • Durability: Rated for damp locations, not suitable for enclosed luminaires or dimmer switches.
  • Long Life: 25,000 hours lifespan.
  • Form Factor: BR30 shape with E26 base for recessed fixtures.
Ideal for smart recessed lighting in damp indoor areas, providing customizable ambiance and energy savings.
Wyze Bulb White: Energy Efficient Smart White LED for Damp Locations
If you prefer classic white lighting with smart features, the Wyze Bulb White is an excellent choice. It is suitable for damp locations, making it perfect for practical lighting needs in bathrooms, basements, or utility rooms.
Features:
  • Brightness: Adjustable from 30 to 800 lumens with a wide dimmable range.
  • Color Temperature: Tunable between warm 2700K and cool 6500K white light.
  • Energy Efficient: Uses only 9.5 watts while delivering bright, clear light.
  • Smart Connectivity: Supports 2.4GHz WiFi and Bluetooth, compatible with Alexa, Google Assistant, and IFTTT.
  • Durability: Rated for damp locations with operating temperature from -4°F to 104°F and humidity tolerance up to 85%.
  • Long Life: 25,000 hours life expectancy.
  • Form Factor: Standard A19 bulb shape with E26 base.
  • Certifications: UL, FCC, CUL, and more ensuring safety and energy efficiency.
Perfect for everyday smart white lighting in damp indoor spaces with easy app and voice control.
Wyze Bulb White in Cozy Bedroom Smart white bulb creating warm, comfortable bedroom lighting
Why Choose Wyze Smart LED Bulbs for Damp Indoor Areas?
Wyze smart bulbs combine energy efficiency, smart home integration, and durability for damp environments, making them a smart investment for modern homes.
  • Energy Savings: All bulbs consume low wattage while providing bright, high-quality light.
  • Smart Control: Manage your lighting remotely via app or voice commands with Alexa and Google Assistant.
  • Damp Location Rated: Safe and reliable performance in bathrooms, kitchens, and other moisture-prone indoor areas.
  • Long Lifespan: 25,000 hours of use reduces replacement frequency and waste.
  • Customizable Ambiance: Choose from millions of colors or tunable white light to suit any mood or task.
Conclusion
For energy efficient, smart LED bulbs designed specifically for damp indoor areas, Wyze offers a versatile lineup:
  • Wyze Bulb Color for vibrant, colorful lighting with damp location rating.
  • Wyze Bulb Color BR30 for recessed fixtures with smart color and dimming.
  • Wyze Bulb White for classic, bright white smart lighting in damp spaces.
Upgrade your home lighting with these smart, energy-saving bulbs that bring convenience, style, and safety to your damp indoor environments.
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze Bulb White
TypeSmart Lighting (A19 shape)Connected Home (BR30 shape)Connected Home (A19 shape)
Base TypeE26E26E26
ShapeA19BR30A19
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)30 lm - 800 lm
Wattage Equivalent75W75W9.5W
Color Options16 million colors16 million colorsWhite light only
Color Temperature RangeTunable white (1800K - 6500K approx.)Tunable white (Sun Match feature)2700K - 6500K
CRI Rating90+90+90+
DimmableYes (but "takes offense" humorously)Yes (not for use with dimmer switches)Yes
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Special FeaturesCustom presets, notifications, sleep routines, music mode, groupingSun Match, custom scenes, notifications, sleep routines, music mode, groupingDimmable, bright white light
Compatible AppWyze appWyze appWyze app
Pack Variants & Price2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)2-Pack ($27.98), 4-Pack ($49.98)2 Pack ($23.99), 4 Pack ($39.99), 6 Pack ($59.99)
WarrantyNot specifiedNot specifiedNot specified
Suitable for Damp LocationsNot specifiedNot specifiedYes
Are Wyze smart LED bulbs suitable for damp indoor areas like bathrooms and kitchens?Yes, Wyze smart LED bulbs, including the Wyze Bulb Color, Wyze Bulb Color BR30, and Wyze Bulb White, are specifically rated for damp locations. This makes them ideal for use in bathrooms, kitchens, basements, laundry rooms, and other indoor spaces prone to moisture.
What are the energy efficiency benefits of Wyze smart LED bulbs?Wyze smart LED bulbs are highly energy efficient, consuming low wattage while delivering bright, high-quality light. For example, the Wyze Bulb Color uses only 12 watts, the Wyze Bulb Color BR30 uses 11.5 watts, and the Wyze Bulb White uses just 9.5 watts. All models are designed to help reduce energy consumption and lower electricity bills.
Can I control Wyze smart bulbs with my voice or smartphone?Yes, Wyze smart bulbs offer smart control via 2.4GHz WiFi and Bluetooth. They are compatible with Alexa, Google Assistant, and IFTTT, allowing you to manage your lighting remotely through voice commands or the Wyze app.
What is the lifespan of Wyze smart LED bulbs?All Wyze smart LED bulbs are designed for long-lasting performance, with a life expectancy of up to 25,000 hours. This reduces the need for frequent replacements and minimizes waste.
Do Wyze smart bulbs offer color-changing and tunable white light options?Yes, the Wyze Bulb Color and Wyze Bulb Color BR30 support 16 million colors and tunable white light (1800K to 6500K), allowing you to customize your lighting for any mood or occasion. The Wyze Bulb White offers tunable white light from warm 2700K to cool 6500K.
Are Wyze smart bulbs compatible with recessed lighting fixtures?The Wyze Bulb Color BR30 is specifically designed for recessed lighting fixtures, featuring a BR30 shape and E26 base. It is ideal for smart recessed lighting in damp indoor areas.
What certifications do Wyze smart LED bulbs have for safety and efficiency?Wyze smart LED bulbs are certified by organizations such as Energy Star, UL, FCC, and CUL, ensuring they meet high standards for safety, energy efficiency, and performance.
Can Wyze smart bulbs be used in enclosed fixtures or with dimmer switches?Wyze Bulb Color BR30 is not suitable for use in enclosed luminaires or with dimmer switches. For optimal performance and safety, always follow the manufacturer's installation guidelines.
What is the brightness range of Wyze smart LED bulbs?Wyze smart LED bulbs offer adjustable brightness. The Wyze Bulb Color ranges from 30 to 1100 lumens, the Wyze Bulb Color BR30 from 30 to 950 lumens, and the Wyze Bulb White from 30 to 800 lumens, allowing you to set the perfect lighting level for any space.
Why should I choose Wyze smart LED bulbs for my home’s damp indoor areas?Wyze smart LED bulbs combine energy efficiency, smart home integration, customizable lighting, and durability for damp environments. They are a smart investment for modern homes, providing reliable performance, convenience, and style in moisture-prone indoor spaces.
What are the specific features of the Wyze Bulb Color BR30 for damp areas?Can you explain how the smart control features work with the Wyze bulbs?Do you have any deals, ongoing sales, discounts, or promotions for Wyze smart bulbs?
