Best Water-Sealed Power Cable for Wyze Camera by the Pool
Recommended Water-Sealed Power Cable for Wyze Cameras by the Pool
When setting up your Wyze camera to monitor your pool area, ensuring a reliable, weatherproof power connection is essential. Exposure to water, rain, and outdoor elements demands a power cable and adapter that can withstand moisture and provide continuous, safe power. The Wyze Outdoor Power Adapter is the ideal solution designed specifically for outdoor use, including poolside installations.
Wyze Outdoor Power Adapter: The Ultimate Weather-Resistant Power Solution
Designed for Outdoor Durability
The Wyze Outdoor Power Adapter is built to endure rain, snow, and shine with an IP67 weather-resistant rating, making it perfectly suited for powering your Wyze cameras near pools or other wet environments. This high level of protection ensures the adapter is dust-tight and can withstand immersion in water up to 1 meter deep for 30 minutes, providing peace of mind for outdoor camera setups.
Compatibility and Convenience
  • Compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with appropriate adapters).
  • Comes with a 12.5 ft (3.8 m) cable length, allowing flexible placement around your pool area without needing extension cords.
  • Includes a weatherproof L-shaped Micro USB adapter to maintain a secure, water-sealed connection to your camera.
  • Operates safely in temperatures ranging from -30°C to 50°C (-22°F to 122°F), ideal for all seasons.
What’s Included
  • Wyze Outdoor Power Adapter
  • Wire clips and screws for secure mounting
  • Weatherproof L-shaped Micro USB adapter
  • USB-C adapter (for Battery Cam Pro) available in some variants
Ready for rain, snow, or shine, this adapter ensures your Wyze camera stays powered and protected outdoors.
Wyze Cam Pan v3 monitoring outdoor pool area Wyze Cam Pan v3 with Outdoor Power Adapter, perfect for poolside security
Wyze Cam Pan v3: Perfect Outdoor Camera for Pool Surveillance
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical field of view, allowing you to monitor every corner of your pool area without blind spots. Its smooth pan and tilt capabilities ensure you can adjust the camera remotely to focus on any activity.
Weather-Resistant and Robust
  • Rated IP65 for weather resistance, the camera is built to handle outdoor conditions including rain and dust.
  • Operates in temperatures from -20°C to 50°C (-4°F to 122°F), suitable for poolside environments.
  • Requires the Wyze Outdoor Power Adapter for safe outdoor power connection.
High-Quality Video and Audio
  • Full HD 1080p video resolution with 4 IR LEDs for night vision.
  • Built-in microphone and speaker enable two-way audio, so you can communicate or deter unwanted visitors.
  • Supports up to 256 GB microSD card for local storage.
Combine the Wyze Cam Pan v3 with the Outdoor Power Adapter for a seamless, weatherproof pool monitoring system.
Why Choose Wyze Outdoor Power Adapter for Your Poolside Wyze Camera?
  • Waterproof and dustproof: IP67 rating ensures no damage from splashes or rain.
  • Long cable length: 12.5 ft cable gives you flexibility in camera placement around your pool.
  • Easy installation: Comes with mounting clips and screws for neat, secure setup.
  • Compatible with multiple Wyze cameras: Supports v3, v4, Pan v3, and Battery Cam Pro with adapters.
  • Safe operation: Certified by FCC and UL, with a 1-year warranty.
Additional Outdoor Power Options (Not Recommended for Poolside Use)
While the Wyze Plug Outdoor and Wyze Plug are excellent smart plugs for outdoor power needs, they are not designed specifically for water-sealed camera power connections. The Wyze Plug Outdoor has an IP64 rating, which is less water-resistant than the IP67 rating of the Wyze Outdoor Power Adapter, making it less ideal for direct camera power near pools.
Summary
For a Wyze camera pointed at your pool, the Wyze Outdoor Power Adapter is the recommended water-sealed power cable solution. It offers superior weather resistance, long cable length, and compatibility with Wyze’s outdoor cameras like the Pan v3, ensuring your pool area is monitored safely and reliably in all weather conditions.
Wyze Plug Indoor lifestyle Wyze Plug Indoor for smart home convenience (not water-sealed for pool cameras)
Product Highlights
  • IP67 weather resistance
  • 12.5 ft cable length
  • Compatible with Wyze Cam v3, v4, Pan v3, Battery Cam Pro
  • Includes weatherproof L-shaped Micro USB adapter
  • Operating temperature: -30°C to 50°C
  • FCC and UL certified
Wyze Cam Pan v3
  • 360° pan, 180° tilt
  • IP65 weather resistance
  • Full HD 1080p video with night vision
  • Two-way audio
  • Supports microSD storage up to 256 GB
  • Operating temperature: -20°C to 50°C
Protect your poolside Wyze camera with the Wyze Outdoor Power Adapter for a secure, weatherproof power connection that keeps your home safe and monitored year-round.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3
TypeAccessoryCamera
Weather ResistanceIP67IP65
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/outdoor use, requires Outdoor Power Adapter for outdoor use
Power Adapter RequiredN/ARequires Wyze Outdoor Power Adapter (sold separately) for outdoor use
Power Adapter VariantsOutdoor Adapter + L-shaped Adapter + USB-C Adapter, Outdoor Adapter + L-shaped Adapter, L-shaped Micro USB Adapter (Only)N/A
Price Range$5.99 - $19.99$39.98 (1 Pack), $77.96 (2 Pack), $114.94 (3 Pack)
DimensionsNot specified124mm (H) x 60mm (W) x 63mm (D)
WeightNot specified11.29 oz (320 g)
Camera FeaturesN/A360° pan, 180° tilt, automatic motion tracking, two-way audio, color night vision, privacy mode
Video ResolutionN/A1920 x 1080 (1080p)
Field of ViewN/A120°
ConnectivityN/A802.11 b/g/n, 2.4GHz Wi-Fi
Power Adapter Output5V/2000mA5V/2000mA (via power adapter)
Operating TemperatureNot specified-20°C to 50°C (-4°F to 122°F)
Included ItemsN/A1x Wyze Cam Pan v3, 1x 6' micro USB Cable, 1x Power Adapter, 1x Mounting Kit, 1x Quick Start Guide
WarrantyNot specified1-Year
Special NotesAdapters will NOT work with OG Stack KitFor outdoor use, requires Outdoor Power Adapter
What is the best water-sealed power cable for Wyze cameras by the pool?The Wyze Outdoor Power Adapter is the recommended water-sealed power cable for Wyze cameras installed near pools. It features an IP67 weather-resistant rating, ensuring reliable and safe power even in wet environments.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 rated, making it dust-tight and capable of withstanding immersion in water up to 1 meter deep for 30 minutes. This makes it ideal for outdoor and poolside camera installations.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with the appropriate adapters).
How long is the cable on the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) cable, providing flexible placement options around your pool area without the need for extension cords.
What is included with the Wyze Outdoor Power Adapter?The package includes the Wyze Outdoor Power Adapter, wire clips and screws for secure mounting, a weatherproof L-shaped Micro USB adapter, and a USB-C adapter (for Battery Cam Pro) in some variants.
Can the Wyze Cam Pan v3 be used outdoors by the pool?Yes, the Wyze Cam Pan v3 is IP65 weather-resistant and operates in temperatures from -20°C to 50°C (-4°F to 122°F), making it suitable for outdoor pool surveillance when paired with the Wyze Outdoor Power Adapter.
What are the key features of the Wyze Cam Pan v3 for pool monitoring?The Wyze Cam Pan v3 offers 360° pan and 180° tilt for full coverage, Full HD 1080p video with night vision, two-way audio, and supports up to 256 GB microSD card for local storage.
Why is the Wyze Outdoor Power Adapter better than Wyze Plug Outdoor for poolside cameras?The Wyze Outdoor Power Adapter has an IP67 rating, providing superior water and dust resistance compared to the Wyze Plug Outdoor's IP64 rating. This makes it safer and more reliable for powering cameras near pools.
Is the Wyze Outdoor Power Adapter safe to use in extreme temperatures?Yes, the Wyze Outdoor Power Adapter operates safely in temperatures ranging from -30°C to 50°C (-22°F to 122°F), making it suitable for all seasons.
Does the Wyze Outdoor Power Adapter come with a warranty?Yes, the Wyze Outdoor Power Adapter is FCC and UL certified and comes with a 1-year warranty for peace of mind.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models besides the ones mentioned?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
