Quiet Air Purifier with Laser Sensor for Cleaner Home Air
Quiet Air Purifier with Laser Particle Sensor for Cleaner Home Air
Maintaining fresh, clean air at home is essential for health and comfort. If you're searching for a quiet air purifier with a laser particle sensor that efficiently cleans your home air, Wyze offers an outstanding solution. Designed to operate whisper-quietly while delivering powerful air purification, the Wyze Air Purifier family combines smart technology, customizable filters, and precise air quality monitoring to keep your indoor environment fresh and safe.
Wyze Air Purifier: Powerful, Quiet, and Smart
Whisper-Quiet Operation with High Performance
The Wyze Air Purifier is engineered to run at an ultra-quiet noise level of just 21 decibels—quieter than a purring kitten—making it perfect for bedrooms, nurseries, or any living space where silence matters. Despite its quiet operation, it boasts a Clean Air Delivery Rate (CADR) of 350, cycling through 12,000 cubic feet of air every hour. This means it refreshes your home's air volume rapidly and effectively.
Advanced Laser Particle Sensor for Real-Time Air Quality
Unlike traditional purifiers that rely on outdated infrared sensors, the Wyze Air Purifier uses a laser particle sensor that detects ultra-fine particles down to 0.3 microns with incredible speed—checking air quality 100 times per second. This precision allows the purifier to respond instantly to changes in your environment, ensuring your air stays clean and healthy.
Smart Controls and Air Quality Alerts
Control your purifier effortlessly via the Wyze app, compatible with Google Home and Alexa. The app provides real-time indoor and outdoor air quality data, personalized insights, and customizable fan speeds. Whether you want to run it on high before guests arrive or keep it low during nap time, the Wyze Air Purifier adapts to your lifestyle.
Customizable Premium Filters
Choose from three specialized HEPA filters to match your specific air cleaning needs:
  • Allergen Filter (Standard): Captures common allergens, dust, and pet dander.
  • Formaldehyde Filter (Premium): Destroys harmful chemicals and odors, including formaldehyde from new furniture or construction materials.
  • Wildfire Filter (Special Use): Optimized for wildfire smoke and heavy pollution absorption.
Each filter combines a pre-filter, true HEPA filtration, and granulated carbon or catalyst materials for superior air purification.
"A luxury air purifier without the luxury price tag."
Man holding air purifier in home setting Experience clean air quietly and smartly at home.
Wyze Air Filter: Tailored Air Purification for Your Home
Customize Your Air Quality
Just like you wouldn’t eat the same meal every day, your air purifier filter should fit your unique environment. The Wyze Air Filter line offers replacement filters designed to target specific pollutants:
  • Allergen Filter: Ideal for everyday allergens and pet odors.
  • Formaldehyde Filter: Premium-grade filter that captures and destroys formaldehyde and other VOCs.
  • Wildfire Filter: Specially formulated to absorb wildfire smoke and related pollutants.
Easy Filter Replacement
Replacing your filter is simple and hassle-free, ensuring your purifier always performs at its best. The filters are designed for quick swaps, so you can maintain optimal air quality without interruption.
Refurbished Wyze Air Purifier: Affordable and Reliable
Same Features, Lower Price
For budget-conscious buyers, the Refurbished Wyze Air Purifier offers the same quiet operation, 350 CADR, and laser particle detection technology at a reduced price. Certified and CARB compliant, it supports rooms up to 550 sq. ft and includes smart controls and air quality alerts.
Recommended Maintenance
To keep your refurbished purifier running efficiently, replace filters every 6 months. Compatible with all Wyze Air Filters, it ensures you never compromise on clean air quality.
Why Choose Wyze Air Purifiers?
  • Ultra-quiet operation (21 decibels) for peaceful home environments
  • Laser particle sensor for precise, real-time air quality monitoring
  • Smart app controls with Alexa and Google Home compatibility
  • Customizable filters for allergens, formaldehyde, and wildfire smoke
  • High CADR of 350 for fast and effective air cleaning
  • Easy filter replacement with subscription options available
Clean air is not a luxury—it's a necessity. Wyze Air Purifiers bring you peace of mind with smart, quiet, and powerful air purification.
Lifestyle image of clean home environment Breathe easier with smart home air quality solutions.
Summary of Wyze Air Purifier Products
ProductKey FeaturesPrice RangeFilter Options
Wyze Air Purifier21 dB noise, 350 CADR, laser sensor, smart app$169.99 - $194.99Allergen, Formaldehyde, Wildfire
Wyze Air Filter (Replacement)Custom filters for specific needs$37.99 - $63.99Allergen, Formaldehyde, Wildfire
Refurbished Wyze Air PurifierSame specs as new, budget-friendly$139.99Compatible with all filters
Keep Your Air Fresh and Healthy
Investing in a Wyze Air Purifier means you’re choosing a quiet, smart, and highly effective solution to improve your home’s air quality. With laser particle detection and customizable filters, you can breathe confidently knowing your air is clean and safe.
FeatureWyze Air Purifier (New)Wyze Air FilterWyze Air Purifier (Refurbished)
TypeConnected HomeConnected Home (Accessory)Refurbished Connected Home
Price$169.99 - $194.99 (depending on filter variant)$37.99 - $63.99 (depending on filter type)$139.99
Pre-installed Filter OptionsAllergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)Allergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)Any Filter (Allergen, Formaldehyde, Wildfire)
CADR350 CADRN/A350 CADR
Noise Level21 decibels (whisper-quiet)N/A21 decibels
Filter CompositionTrue HEPA + Granulated Carbon (varies by filter)Allergen: Pre-Filter + HEPA 13 + Granulated Carbon Formaldehyde: Pre-Filter + HEPA 12 + Activated Manganese + Carbon Wildfire: Pre-Filter + HEPA 12 + Chemically Modified CarbonSame as new purifier (supports all filter types)
Filter Replacement PriceFilters sold separately: $37.99 - $63.99$37.99 - $63.99Filters sold separately: $37.99 - $63.99
Filter Replacement IntervalRecommended every 6 months4-12 months depending on filter typeRecommended every 6 months
Room CoverageUp to 550 sq. ft (42 m²)N/AUp to 550 sq. ft (42 m²)
Power SupplyAC 120V / 60 HzN/AAC 120V / 60 Hz
Smart FeaturesSmart controls, AQ alerts, laser particle detection, Alexa & Google Home compatibleN/ASmart controls, AQ alerts, laser particle detection, Alexa & Google Home compatible
Air Quality SensorLaser particle sensor (0.3 microns, 100x/sec)N/ALaser particle sensor (0.3 microns, 100x/sec)
Noise Level Range21 - 54 decibelsN/A21 decibels
WarrantyNot specifiedNot specifiedNot specified
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified (Final Sale)
Additional NotesHandles allergens, formaldehyde, wildfire smokeCustomize air filtration to specific needsSame features as new but refurbished unit
What makes the Wyze Air Purifier a quiet air purifier for home use?The Wyze Air Purifier operates at an ultra-quiet noise level of just 21 decibels, making it quieter than a purring kitten. This makes it ideal for bedrooms, nurseries, and any living space where a peaceful environment is important.
How does the laser particle sensor in the Wyze Air Purifier work?The Wyze Air Purifier uses an advanced laser particle sensor that detects ultra-fine particles as small as 0.3 microns. It checks air quality 100 times per second, providing real-time, precise monitoring and allowing the purifier to respond instantly to changes in your indoor air.
What is the Clean Air Delivery Rate (CADR) of the Wyze Air Purifier?The Wyze Air Purifier boasts a high Clean Air Delivery Rate (CADR) of 350, which means it can cycle through 12,000 cubic feet of air every hour. This ensures rapid and effective air purification for your home.
Can I control the Wyze Air Purifier with my smartphone or smart home devices?Yes, the Wyze Air Purifier can be controlled via the Wyze app, which is compatible with Google Home and Alexa. The app provides real-time indoor and outdoor air quality data, personalized insights, and customizable fan speeds.
What types of filters are available for the Wyze Air Purifier?Wyze offers three specialized HEPA filters: the Allergen Filter for dust and pet dander, the Formaldehyde Filter for harmful chemicals and odors, and the Wildfire Filter for smoke and heavy pollution. Each filter combines a pre-filter, true HEPA filtration, and granulated carbon or catalyst materials.
How often should I replace the filter in my Wyze Air Purifier?It is recommended to replace your Wyze Air Purifier filter every 6 months to maintain optimal performance and air quality.
Is there a refurbished Wyze Air Purifier option available?Yes, Wyze offers a Refurbished Air Purifier that features the same quiet operation, 350 CADR, and laser particle detection technology as the new model, but at a lower price. It is certified, CARB compliant, and supports rooms up to 550 sq. ft.
Are Wyze Air Purifier filters easy to replace?Yes, Wyze Air Purifier filters are designed for quick and hassle-free replacement, ensuring your purifier always performs at its best. Subscription options are also available for convenient filter replacements.
What are the benefits of using a Wyze Air Purifier in my home?Wyze Air Purifiers offer ultra-quiet operation, precise real-time air quality monitoring with a laser particle sensor, smart app controls, customizable filters for different air quality needs, a high CADR of 350, and easy filter replacement. These features ensure clean, healthy air for your home.
Which Wyze Air Purifier filter should I choose for my needs?Choose the Allergen Filter for everyday allergens and pet odors, the Formaldehyde Filter for harmful chemicals and VOCs, or the Wildfire Filter for smoke and heavy pollution. Each filter is tailored to target specific pollutants in your environment.
What are the specific features of the Wyze Air Purifier that make it suitable for bedrooms and nurseries?How does the laser particle sensor in the Wyze Air Purifier compare to traditional infrared sensors?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Air Purifier?
