Smart Air Purifiers with Laser Sensor, App Control & Alerts
Smart Air Purifiers with Laser Sensor, App Control, and Alerts
When it comes to maintaining a healthy indoor environment, a smart air purifier equipped with advanced laser sensors, app control, and real-time air quality alerts is a must-have. Wyze offers a range of air purifiers designed to deliver clean air efficiently while providing you with full control and insights through an intuitive app. Whether you want to monitor allergens, formaldehyde, wildfire smoke, or other pollutants, Wyze’s smart air purifiers and custom filters have you covered.
Wyze Air Purifier: Premium Performance Meets Smart Technology
Powerful Air Cleaning with Laser Particle Detection
The Wyze Air Purifier is engineered to cycle an impressive 12,000 cubic feet of air every hour, boasting a Clean Air Delivery Rate (CADR) of 350 m³/h. Its laser particle sensor detects ultra-fine particles down to 0.3 microns with remarkable precision, scanning the air 100 times per second. This means you get near real-time, highly accurate air quality readings that keep you informed and safe.
Whisper-Quiet Operation
Operating at just 21 decibels on its lowest setting, the Wyze Air Purifier is quieter than a purring kitten, making it perfect for bedrooms, nurseries, or offices where silence is golden.
Smart Controls and App Integration
Control your purifier from anywhere using the Wyze app, compatible with both Alexa and Google Home. The app provides actionable air quality alerts, detailed pollutant tracking, and the ability to customize fan speeds or set schedules. The device also features a child lock and a dimmable display for convenience.
Customizable Filters for Every Need
Choose from three premium HEPA filters tailored to your environment:
  • Allergen Filter (Standard): Captures common allergens and pet dander.
  • Formaldehyde Filter (Premium): Destroys harmful chemicals and odors, including carcinogenic formaldehyde from new furniture or tobacco smoke.
  • Wildfire Filter (Special Use): Optimized for wildfire smoke and heavy pollution.
Easy Maintenance and Portability
With a handy carry handle and simple filter replacement steps, maintaining your air purifier is hassle-free. Wyze Air Purifier in Living Room Experience clean air effortlessly with Wyze Air Purifier in your home environment.
Wyze Air Filter: Customize Your Clean Air Experience
Tailored Filters for Specific Air Quality Challenges
Wyze Air Filters allow you to customize your air purification based on your unique needs. Whether you’re dealing with seasonal allergies, chemical pollutants, or wildfire smoke, these filters are designed to target specific contaminants effectively.
  • Allergen Filter: Combines a pre-filter, HEPA 13, and granulated carbon to trap allergens and odors.
  • Formaldehyde Filter: A premium-grade filter with activated manganese to destroy formaldehyde and other VOCs.
  • Wildfire Filter: Features chemically modified granulated carbon to absorb fire-related pollutants.
Easy Filter Replacement
Replacing your filter is quick and straightforward, ensuring your purifier always performs at its best.
(Refurbished) Wyze Air Purifier: Affordable Smart Air Quality Solution
Same Features, Lower Price
For budget-conscious buyers, the refurbished Wyze Air Purifier offers the same powerful 350 CADR, whisper-quiet 21 dB operation, and smart features including laser particle detection and app alerts. It supports all three filter types and is CARB certified for safety and performance.
Ideal for Medium-Sized Rooms
Designed to purify spaces up to 550 sq. ft (42 m²), it’s perfect for bedrooms, living rooms, or home offices.
Why Choose Wyze Smart Air Purifiers?
"A luxury air purifier without a luxury price tag."
Wyze combines cutting-edge laser sensor technology with smart app controls to give you a comprehensive air quality management system. From hyper-local outdoor air quality tracking to personalized indoor alerts, Wyze empowers you to breathe easier and live healthier.
Summary of Key Features
FeatureWyze Air Purifier (New)Wyze Air Filter (Custom)Refurbished Wyze Air Purifier
CADR350 m³/hN/A350 m³/h
Noise Level21 dBN/A21 dB
Laser Particle SensorYesN/AYes
App Control & AlertsYesN/AYes
Compatible FiltersAllergen, Formaldehyde, WildfireAllergen, Formaldehyde, WildfireAllergen, Formaldehyde, Wildfire
Room CoverageUp to 550 sq. ftN/AUp to 550 sq. ft
Alexa & Google Home SupportYesN/AYes
Price Range$169.99 - $194.99$37.99 - $63.99$139.99
Enhance Your Smart Home Air Quality Today
Investing in a Wyze smart air purifier means you’re choosing advanced laser sensor technology, customizable filtration, and seamless app control to keep your indoor air fresh and healthy. Whether you want the latest model or a refurbished option, Wyze offers smart solutions tailored to your lifestyle and budget. Wyze Plug controlling home devices Integrate your air purifier with other Wyze smart home devices for complete control.
Related Accessories: Wyze Air Filters
To maintain optimal air quality, pairing your Wyze Air Purifier with the right filter is essential. Choose from allergen, formaldehyde, or wildfire filters to match your environment and breathing needs. Replacing Wyze Air Filter Simple filter replacement keeps your air purifier running at peak performance.
Experience the future of clean air with Wyze’s smart air purifiers — precise, customizable, and always connected.
FeatureWyze Air Purifier (New)Wyze Air Purifier (Refurbished)Wyze Air Filter (Accessory)
Price$169.99 - $194.99 (depending on filter variant)$139.99$37.99 - $63.99 (depending on filter type)
Pre-installed Filter OptionsAllergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)Any FilterAllergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)
CADR350 CADR (m³/h not specified)350 CADR214 - 362 m³/h (varies by filter)
Noise Level21 - 54 decibels (whisper-quiet)21 decibelsN/A (filter only)
Smart FeaturesSmart controls, AQ alerts, laser particle detection, Alexa & Google Home compatibleSmart controls, AQ alerts, laser particle detection, Alexa & Google Home compatibleN/A (filter only)
Filter TypeTrue HEPA with granulated carbon and catalyst materialsTrue HEPA with granulated carbon and catalyst materialsTrue HEPA with granulated carbon and catalyst materials
Air Quality SensorLaser particle sensor (0.3 microns, 100x/sec)Laser particle sensorN/A
Dimensions8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)Same as newSame as new
Weight1.5 - 1.9 lb (varies by filter)Same as new1.5 - 1.9 lb (varies by filter)
Filter Service Life4 - 12 months (varies by filter)Same as new4 - 12 months (varies by filter)
WarrantyStandard Wyze warrantyFinal Sale, no returnsStandard Wyze warranty
Return Policy30-day hassle-free returnsNo returns (Final Sale)Standard Wyze return policy
AvailabilityLow stock (43 left)Sold outAvailable
What makes Wyze Smart Air Purifiers different from traditional air purifiers?Wyze Smart Air Purifiers feature advanced laser particle sensors for real-time air quality monitoring, app control with alerts, and compatibility with Alexa and Google Home. They offer customizable HEPA filters for allergens, formaldehyde, and wildfire smoke, providing a tailored and connected air purification experience.
How does the laser particle sensor in Wyze Air Purifiers work?The laser particle sensor in Wyze Air Purifiers detects ultra-fine particles as small as 0.3 microns, scanning the air 100 times per second. This technology provides near real-time, highly accurate air quality readings, helping you monitor and respond to indoor air pollution effectively.
Can I control Wyze Air Purifiers remotely?Yes, Wyze Air Purifiers can be controlled remotely through the Wyze app, which is available for both iOS and Android devices. The app allows you to adjust fan speeds, set schedules, receive air quality alerts, and track pollutants from anywhere.
Are Wyze Air Purifiers compatible with smart home systems?Yes, Wyze Air Purifiers are compatible with Alexa and Google Home, allowing you to integrate them into your smart home ecosystem for voice control and automation.
What types of filters are available for Wyze Air Purifiers?Wyze offers three types of HEPA filters: the Allergen Filter for common allergens and pet dander, the Formaldehyde Filter for harmful chemicals and odors, and the Wildfire Filter optimized for smoke and heavy pollution. Each filter is designed to target specific air quality challenges.
How often should I replace the filter in my Wyze Air Purifier?Filter replacement frequency depends on usage and air quality, but Wyze Air Purifiers are designed for easy filter changes. The Wyze app can help track filter life and alert you when it’s time for a replacement to ensure optimal performance.
What is the Clean Air Delivery Rate (CADR) of Wyze Air Purifiers?Wyze Air Purifiers have a CADR of 350 m³/h, meaning they can efficiently cycle and clean large volumes of air, making them suitable for rooms up to 550 sq. ft.
How quiet are Wyze Air Purifiers during operation?Wyze Air Purifiers operate as quietly as 21 decibels on their lowest setting, making them ideal for bedrooms, nurseries, and offices where minimal noise is important.
Are there affordable options for Wyze Air Purifiers?Yes, Wyze offers refurbished air purifiers that provide the same powerful performance, smart features, and filter compatibility as new models, but at a lower price point.
What room size can Wyze Air Purifiers effectively cover?Wyze Air Purifiers are designed to purify spaces up to 550 square feet (42 m²), making them suitable for medium-sized rooms such as bedrooms, living rooms, and home offices.
How do I choose the right Wyze Air Filter for my needs?Select the Allergen Filter for general allergens and pet dander, the Formaldehyde Filter for chemical pollutants and odors, or the Wildfire Filter for smoke and heavy pollution. Each filter is tailored to address specific air quality concerns.
Is it easy to maintain and move Wyze Air Purifiers?Yes, Wyze Air Purifiers feature a convenient carry handle for portability and are designed for simple, hassle-free filter replacement, making maintenance easy.
Are Wyze Air Purifiers CARB certified?Yes, both new and refurbished Wyze Air Purifiers are CARB certified, ensuring they meet strict safety and performance standards for air cleaning devices.
What are the specific features of the Wyze Air Purifier that make it stand out?Can you explain how the laser particle sensor works in the Wyze Air Purifier?Do you have any ongoing sales or discounts for the Wyze Air Purifier?
