Wyze Cam 20ft USB Extension Cable for Garden Trellis Setup
Prolonged Reach for Wyze Cam Setup on a Garden Trellis
Setting up your Wyze Cam on a garden trellis can be a fantastic way to monitor your outdoor space, keep an eye on your plants, or enhance your home security. However, the challenge often lies in the limited cable length, which restricts where you can place your camera. Fortunately, the Wyze Cam USB Extension Cable - 20ft offers a simple and affordable solution to extend your camera’s reach without compromising power or connectivity.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Your Camera Anywhere
Key Features:
  • Length: 20 feet of USB extension cable, significantly longer than the standard 6-foot cable included with Wyze Cams.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Ease of Use: Simply plug the extension cable between your Wyze Cam and its power source to gain extra length.
  • Durability: Designed to maintain stable power delivery and data transfer over the extended length.
Say goodbye to the frustration of short cables and enjoy the freedom to position your Wyze Cam exactly where you need it — like on a garden trellis, far from your power outlet.
Wyze Cam v4: The Ideal Camera for Outdoor Garden Surveillance
Why Choose Wyze Cam v4?
  • High-Resolution Video: Crystal-clear 2.5K QHD (2560x1440) resolution captures detailed footage of your garden and surroundings.
  • Enhanced Night Vision: Features 4 IR LEDs and 2 white spotlight LEDs for color night vision, ensuring your garden is monitored day and night.
  • Weather Resistance: Rated IP65, the Wyze Cam v4 is built to withstand outdoor conditions, making it perfect for garden trellis installation.
  • Flexible Mounting Options: Includes stand, wall mount, ceiling mount, and magnetic wall mount with adhesive for versatile placement.
  • Smart Features: Supports Alexa, Google Assistant, and IFTTT integrations for voice control and automation.
  • Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for reliable streaming and notifications.
  • Power: Comes with a 6-foot flat micro USB to USB-A cable, which can be extended using the 20ft USB extension cable for longer reach.
The Wyze Cam v4’s rugged design and advanced features make it an excellent choice for garden monitoring, especially when paired with the 20ft USB extension cable for flexible placement.
Wyze Cam v4 installed outdoors on a garden trellis
Enhance Your Outdoor Setup with the Wyze Cam v4 Outdoor Bundle
What’s Included:
  • Wyze Cam v4: The same high-quality camera with 2.5K QHD resolution and enhanced color night vision.
  • Wyze Outdoor Power Adapter: Designed to provide reliable power in outdoor environments.
  • Wyze MicroSD Card 128GB: Enables 24/7 local recording so you never miss a moment in your garden.
Benefits for Garden Trellis Setup:
  • Wired Power Source: The outdoor power adapter ensures your camera stays powered without worrying about battery life.
  • Continuous Recording: Local storage with the included microSD card means you can review footage anytime.
  • Weatherproof Design: Both the camera and power adapter are built to handle outdoor conditions, perfect for garden trellis mounting.
  • Wi-Fi 6 Support: Ensures stable connectivity even in areas with multiple devices.
This bundle is perfect for users who want a complete, reliable outdoor security solution with extended reach and continuous recording capabilities.
Tips for Setting Up Wyze Cam on a Garden Trellis with USB Extension Cable
  • Use the 20ft USB Extension Cable to position your Wyze Cam v4 at the optimal height and angle on your trellis without being limited by power outlet locations.
  • Secure the cable properly along the trellis to avoid tripping hazards or damage from weather.
  • Combine with the Outdoor Power Adapter (from the Outdoor Bundle) for a fully weatherproof power solution.
  • Leverage the camera’s mounting options to attach it firmly to the trellis, ensuring stable and clear footage.
  • Utilize Wyze app features like motion detection zones and notifications to monitor specific garden areas effectively.
Conclusion
For anyone looking to set up a Wyze Cam on a garden trellis, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that provides the freedom to place your camera exactly where you need it. Pair it with the Wyze Cam v4 or the Wyze Cam v4 Outdoor Bundle for a powerful, weather-resistant, and high-resolution outdoor security solution. Together, these products ensure your garden is monitored with crystal-clear video, day and night, without the limitations of short cables.
Product Summary
Wyze Cam USB Extension Cable - 20ft Extend your camera’s reach with a reliable 20-foot USB extension cable compatible with multiple Wyze Cam models. Wyze Cam v4 High-resolution, weather-resistant camera with enhanced night vision and flexible mounting options, perfect for outdoor garden surveillance. Wyze Cam v4 Outdoor Bundle Complete outdoor security kit including Wyze Cam v4, outdoor power adapter, and 128GB microSD card for continuous recording.
Enhance your garden security setup today with these Wyze products designed for extended reach and reliable outdoor performance!
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam v4 Outdoor Bundle
Product TypeAccessory (USB Extension Cable)CameraCamera Bundle
Compatible ModelsWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v4 + Outdoor Power Adapter + 128GB microSD Card
Cable Length20 ft USB extension6 ft Flat micro USB to USB-A6 ft Flat micro USB to USB-A
Price$7.99$69.99 (varies by variant)$69.99
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Motion-Activated SpotlightN/AYesYes
Local RecordingN/A24/7 local recording (microSD card required)24/7 local recording (microSD card included)
Wi-Fi SupportN/AWi-Fi 6, 2.4 GHz Wi-FiWi-Fi 6, 2.4 GHz Wi-Fi
Alexa & Google Assistant CompatibleN/AYesYes
Weather ResistanceN/AIP65IP65
Power Adapter IncludedN/AIndoor USB Power Adapter includedWyze Outdoor Power Adapter included
microSD Card IncludedN/ANo128GB microSD Card included
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountStand, Wall mount, Ceiling mount, Magnetic mount
Warranty30-day hassle-free returns1 Year1 Year
What is the Wyze Cam USB Extension Cable - 20ft and how does it help with garden trellis setups?The Wyze Cam USB Extension Cable - 20ft is a long USB cable designed to extend the reach of your Wyze Cam’s power connection. It allows you to place your Wyze Cam on a garden trellis or other outdoor locations far from a power outlet, providing flexibility in camera placement without compromising power or connectivity.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
What are the key features of the Wyze Cam v4 for outdoor garden surveillance?The Wyze Cam v4 offers 2.5K QHD (2560x1440) high-resolution video, enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, IP65 weather resistance, flexible mounting options, smart integrations with Alexa, Google Assistant, and IFTTT, Wi-Fi 6 support, and comes with a 6-foot flat micro USB to USB-A cable.
How does the Wyze Cam v4 Outdoor Bundle enhance garden security?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a weatherproof outdoor power adapter, and a 128GB microSD card for 24/7 local recording. This bundle ensures reliable power, continuous video storage, and weather resistance, making it ideal for garden trellis installations.
Can I use the Wyze Cam v4 with a 20ft USB extension cable outdoors?Yes, the Wyze Cam v4 can be used with the 20ft USB extension cable outdoors. This setup allows you to position your camera at the optimal location on your garden trellis, even if the nearest power outlet is far away. For best results, use the outdoor power adapter for weatherproof power delivery.
What are the benefits of using a Wyze Cam on a garden trellis?Mounting a Wyze Cam on a garden trellis allows you to monitor your outdoor space, keep an eye on your plants, and enhance home security. With the right accessories, such as the 20ft USB extension cable and outdoor power adapter, you can achieve flexible placement and reliable performance.
How do I secure the Wyze Cam and extension cable on a garden trellis?To secure your Wyze Cam and extension cable on a garden trellis, use the camera’s flexible mounting options (stand, wall mount, ceiling mount, or magnetic wall mount with adhesive) and fasten the cable along the trellis to prevent tripping hazards or weather damage. Ensure all connections are protected from the elements for long-term durability.
Does the Wyze Cam v4 support continuous recording for garden surveillance?Yes, the Wyze Cam v4 supports continuous recording when used with a microSD card, such as the 128GB card included in the Wyze Cam v4 Outdoor Bundle. This allows you to review footage at any time and ensures you never miss important moments in your garden.
Is the Wyze Cam v4 weatherproof for outdoor use?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use on a garden trellis or other exposed locations.
What smart features does the Wyze Cam v4 offer for garden monitoring?The Wyze Cam v4 supports smart features such as motion detection zones, notifications, and integrations with Alexa, Google Assistant, and IFTTT for voice control and automation, making it easy to monitor specific areas of your garden.
Can you provide tips for securely mounting the Wyze Cam on a garden trellis?What are the benefits of using the Wyze Cam v4 for outdoor surveillance?Do you have any deals, ongoing sales, discounts, or promotions available?
