Power Multiple Wyze Cameras Outdoors with One Adapter
Powering Multiple Wyze Cameras Outdoors with a Single Dedicated Adapter
When it comes to securing your outdoor spaces with Wyze cameras, having a reliable and weatherproof power source is essential. The Wyze Outdoor Power Adapter is designed specifically to power multiple Wyze cameras outdoors safely and efficiently, ensuring continuous surveillance rain or shine. This guide highlights how you can use this adapter to power your Wyze cameras outdoors, including the popular Wyze Cam Pan v3, Wyze Cam v4, and other compatible models.
Wyze Outdoor Power Adapter: The Ultimate Outdoor Power Solution
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter is built to withstand harsh outdoor conditions with an IP67 weather resistance rating. Whether it's rain, snow, or intense sun, this adapter keeps your cameras powered without interruption.
  • Input Power: 100V-240V AC
  • Output Power: 5V 2A DC
  • Cable Lengths: 12.5 ft (3.8 m) main cable, 3.9 ft (1.2 m) AC cable, 8.5 ft (2.6 m) DC cable
  • Operating Temperature: -22°F to 122°F (-30°C to 50°C)
  • Connector to Camera: Micro USB
  • Certifications: FCC, UL
  • Warranty: 1 Year
Compatibility and Convenience
This adapter is compatible with a range of Wyze cameras including:
  • Wyze Cam v3 Pro and Pan v3 (requires L-shaped MicroUSB Adapter)
  • Wyze Battery Cam Pro (requires USB-C adapter)
  • Wyze Cam v3, v4, and other outdoor models
Note: The adapter does not work with the OG Stack Kit.
Included Accessories
  • Wyze Outdoor Power Adapter
  • Wire Clips (x8) and Screws (x6) with Anchors (x6) for secure installation
  • Weatherproof L-shaped Micro-USB Adapter
This comprehensive kit makes it easy to set up and power multiple cameras outdoors with a neat and weatherproof installation.
Wyze Cam Pan v3: 360° Outdoor Surveillance Powered Reliably
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 powered outdoors through the Wyze Outdoor Power Adapter, ready for all weather conditions. The Wyze Cam Pan v3 is a versatile indoor/outdoor camera featuring 360° horizontal and 180° vertical pan and tilt capabilities. It offers full HD 1080p video with night vision and two-way audio, making it perfect for monitoring large outdoor areas.
  • Weather Resistance: IP65 rated for outdoor use
  • Field of View: 120° FOV
  • Night Vision: 4 IR LEDs (850 nm)
  • Audio: Built-in speaker and microphone with noise & echo cancellation
  • Connectivity: 2.4 GHz Wi-Fi (no 5 GHz support)
  • Power: Requires Wyze Outdoor Power Adapter for safe outdoor use
With the Wyze Outdoor Power Adapter, you can power multiple Pan v3 cameras outdoors, ensuring continuous 24/7 surveillance without worrying about battery life or weather damage.
Wyze Cam v4: High-Resolution Outdoor Security with Easy Power
The Wyze Cam v4 takes outdoor security to the next level with crystal-clear 2.5K QHD resolution and enhanced color night vision. It features a motion-activated spotlight and supports Wi-Fi 6 for faster, more reliable connectivity.
  • Video Resolution: 2560 x 1440 (2.5K QHD)
  • Night Vision: 4 IR LEDs + 2 white spotlight LEDs (72 lumens)
  • Field of View: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Audio: 99dB waterproof speaker, two-way talk, built-in siren
  • Power: Powered via micro USB; outdoor use requires Wyze Outdoor Power Adapter
Using the Wyze Outdoor Power Adapter, you can power your Wyze Cam v4 outdoors reliably, eliminating the need for frequent battery changes or indoor-only setups.
Bird Feeder Plug-in Cam v4 Bundle: Power and Watch Nature Outdoors
For bird enthusiasts, the Bird Feeder Plug-in Cam v4 Bundle combines the Wyze Bird Feeder with the Wyze Cam v4 and the Wyze Outdoor Power Adapter. This bundle allows you to power your camera outdoors while capturing stunning live video of feathered visitors.
  • Bundle Includes: Wyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power Adapter
  • Installation Options: Wall, tree, pole, cord, suction cup
  • Weather Resistance: Designed for all seasons
  • Compatibility: Works seamlessly with Wyze Solar Panel and other Wyze cameras
This setup is perfect for powering multiple outdoor cameras with a single adapter while enjoying nature’s beauty through high-quality video.
Why Choose Wyze Outdoor Power Adapter for Multiple Cameras?
"Powering multiple Wyze cameras outdoors has never been easier or more reliable."
  • Single Adapter, Multiple Cameras: Use the adapter with L-shaped or USB-C adapters to power various Wyze camera models outdoors.
  • Weatherproof and Durable: IP67 rating ensures your cameras stay powered in all weather conditions.
  • Long Cable Lengths: Ample cable length allows flexible camera placement without power concerns.
  • Easy Installation: Comes with mounting hardware and wire clips for a clean, secure setup.
  • Certified Safety: FCC and UL certifications guarantee safe and reliable operation.
Conclusion
For anyone looking to power multiple Wyze cameras outdoors, the Wyze Outdoor Power Adapter is the ideal solution. Whether you have Wyze Cam Pan v3, Wyze Cam v4, or the Bird Feeder Plug-in Cam v4 Bundle, this adapter ensures your cameras stay powered and protected from the elements. Enjoy peace of mind with continuous, weatherproof outdoor surveillance powered by a single, dedicated adapter.
Product Summary
Wyze Outdoor Power Adapter Wyze Cam Pan v3 Wyze Cam v4 Bird Feeder Plug-in Cam v4 Bundle
Two-way audio with Wyze Cam Enjoy two-way audio and clear communication with Wyze cameras powered outdoors.
Harness the power of the Wyze Outdoor Power Adapter to keep your outdoor Wyze cameras running smoothly and securely all year round!
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam v4Bird Feeder Plug-in Cam v4 Bundle
TypeAccessoryCameraCameraBundle (Bird Feeder + Cam v4 + Outdoor Power Adapter)
Weather ResistanceIP67IP65IP65Weather-resistant for all seasons
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, Battery Cam Pro (with adapters)Indoor/Outdoor cameraIndoor/Outdoor cameraCompatible with Battery Cam Pro, Cam v3, Cam v4, Cam Outdoor v1 & v2
Power Adapter RequiredYes (Outdoor Power Adapter + L-shaped MicroUSB or USB-C adapter depending on camera)Requires Wyze Outdoor Power Adapter (sold separately)Outdoor Power Adapter sold separatelyIncludes Wyze Outdoor Power Adapter
Video ResolutionN/A1080p (not specified, but Pan v3 is a security camera)2.5K QHD (2560x1440)2.5K QHD (via included Cam v4)
Pan & TiltN/A360° pan, 180° tiltFixed angle (no pan/tilt)360° pan, 180° tilt (via included Cam v4)
Night VisionN/AColor Night VisionEnhanced Color Night VisionEnhanced Color Night Vision (via included Cam v4)
AudioN/ATwo-way audioTwo-way audioTwo-way audio (via included Cam v4)
Local StorageN/ASupports microSD cardsSupports microSD cards up to 512GBIncludes 128GB microSD card
ConnectivityN/AWi-Fi 2.4 GHzWi-Fi 2.4 GHz, Wi-Fi 6Wi-Fi 2.4 GHz, Wi-Fi 6 (via included Cam v4)
DimensionsN/ANot specified2in x 2in x 2 3/8inBird Feeder dimensions not specified; Cam v4 included
WeightN/ANot specified0.49 lb (222 g)Not specified
Additional FeaturesIP67 weather resistant for outdoor useAutomatic motion tracking, Privacy Mode, Pan Scan™ PatrolMotion-activated spotlight, Alexa & Google Assistant compatibleBird feeder with macro lens adapter, multiple mounting options
Price$14.99 - $19.99 (depending on variant)$39.98 (1 pack)$35.98 (1 pack)$89.98
What is the Wyze Outdoor Power Adapter and how does it work?The Wyze Outdoor Power Adapter is a weatherproof power solution designed to safely and efficiently power multiple Wyze cameras outdoors. With an IP67 weather resistance rating, it ensures continuous surveillance in rain, snow, or intense sun. The adapter provides 5V 2A DC output and comes with long cables and mounting accessories for flexible and secure installation.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3 Pro, Wyze Cam Pan v3 (requires L-shaped MicroUSB Adapter), Wyze Battery Cam Pro (requires USB-C adapter), Wyze Cam v3, Wyze Cam v4, and other outdoor Wyze camera models. It is not compatible with the OG Stack Kit.
Can I power multiple Wyze cameras outdoors with a single adapter?Yes, the Wyze Outdoor Power Adapter is designed to power multiple Wyze cameras outdoors using L-shaped or USB-C adapters for different models. This allows for a neat, weatherproof, and efficient setup with just one dedicated power source.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 rated, making it highly resistant to water and dust. It is built to withstand harsh outdoor conditions, ensuring your cameras remain powered in all weather.
What is included with the Wyze Outdoor Power Adapter kit?The kit includes the Wyze Outdoor Power Adapter, 8 wire clips, 6 screws with anchors for secure installation, and a weatherproof L-shaped Micro-USB Adapter. These accessories make it easy to set up and power your cameras outdoors.
What are the cable lengths provided with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) main cable, a 3.9 ft (1.2 m) AC cable, and an 8.5 ft (2.6 m) DC cable, offering ample length for flexible camera placement.
Does the Wyze Outdoor Power Adapter support all-weather operation?Yes, the adapter operates in temperatures ranging from -22°F to 122°F (-30°C to 50°C), making it suitable for year-round outdoor use.
Why do I need the Wyze Outdoor Power Adapter for outdoor camera use?The Wyze Outdoor Power Adapter is specifically designed to provide safe, reliable, and weatherproof power to Wyze cameras outdoors. It eliminates the need for frequent battery changes and ensures continuous surveillance without interruption.
Is the Wyze Outdoor Power Adapter certified for safety?Yes, the adapter is FCC and UL certified, ensuring safe and reliable operation for your outdoor security setup.
Can I use the Wyze Outdoor Power Adapter with the Bird Feeder Plug-in Cam v4 Bundle?Yes, the Bird Feeder Plug-in Cam v4 Bundle includes the Wyze Outdoor Power Adapter, allowing you to power your Wyze Cam v4 outdoors while enjoying live video of birds in all weather conditions.
What warranty does the Wyze Outdoor Power Adapter come with?The Wyze Outdoor Power Adapter comes with a 1-year warranty, providing peace of mind for your outdoor surveillance needs.
Does the Wyze Cam Pan v3 require the Wyze Outdoor Power Adapter for outdoor use?Yes, for safe and reliable outdoor operation, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter, which protects against weather and ensures continuous power.
Can I use the Wyze Outdoor Power Adapter with the Wyze Cam v4 for outdoor security?Absolutely. The Wyze Outdoor Power Adapter is ideal for powering the Wyze Cam v4 outdoors, providing reliable power for high-resolution security and eliminating the need for indoor-only setups.
What are the installation options for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with the Wyze Bird Feeder Plug-in Cam v4 Bundle?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
