Maintenance-Free Outdoor Power Adapter for Wyze Cameras
Convenient Maintenance-Free Outdoor Power Supply for Wyze Camera Owners
For Wyze camera owners looking for a reliable, weather-resistant, and maintenance-free outdoor power solution, the Wyze Outdoor Power Adapter is the perfect accessory. Designed specifically to keep your Wyze cameras powered through all seasons, this adapter ensures your outdoor security setup remains uninterrupted and hassle-free.
Wyze Outdoor Power Adapter: Power Your Wyze Cameras Rain or Shine
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter boasts an IP67 weather-resistant rating, making it fully capable of withstanding rain, snow, and harsh outdoor conditions. This means you can confidently install your Wyze cameras outdoors without worrying about power interruptions caused by weather.
  • Compatible with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, and Wyze Battery Cam Pro (with appropriate adapters).
  • Requires pairing with L-shaped MicroUSB Adapter for Cam v3 Pro and Pan v3.
  • USB-C adapter needed for Wyze Battery Cam Pro.
  • Not compatible with OG Stack Kit.
Easy Installation and Versatile Use
The adapter comes in multiple variants, including bundles with L-shaped and USB-C adapters, allowing you to choose the perfect setup for your camera model. Its plug-and-play design means you can quickly set up your outdoor camera power supply without complex wiring or maintenance.
Ready for rain, snow, or shine — the Wyze Outdoor Power Adapter keeps your cameras powered no matter the weather.
Wyze Cam Pan v3: The Ideal Outdoor Camera Companion
Wyze Cam Pan v3 in snowy outdoor setting Experience 360° pan and 180° tilt with the weather-resistant Wyze Cam Pan v3.
Key Features
  • 360° horizontal and 180° vertical coverage for full outdoor surveillance.
  • IP65 weather resistance ensures durability in outdoor environments.
  • Full HD 1080p video resolution with 4 IR LEDs for night vision.
  • Built-in speaker and microphone for 2-way audio with noise and echo cancellation.
  • Supports up to 256 GB microSD card for local storage.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Requires Wyze Outdoor Power Adapter for safe outdoor use.
Specifications at a Glance
FeatureSpecification
Video Resolution1920 x 1080 (1080p)
Field of View120° FOV
Rotation SpeedUp to 110° per second
Operating Temperature-4°F to 122°F (-20°C to 50°C)
Connectivity2.4 GHz Wi-Fi only
Power Cable Length6" (1.8 m)
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security and Convenience
For those who want an all-in-one solution, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same robust camera features with added benefits:
  • Includes 30 days of Cam Plus service for advanced AI detection and cloud storage.
  • Comes with power adapter, mounting kit, and quick start guide for easy setup.
  • Perfect for users who want enhanced security features combined with reliable outdoor power.
Why Choose Wyze Outdoor Power Solutions?
  • Maintenance-Free: Once installed, the outdoor power adapter requires no upkeep, freeing you from frequent battery changes or power concerns.
  • Reliable Power: Designed specifically for Wyze cameras, ensuring compatibility and stable power delivery.
  • Weatherproof: IP67 rating means your camera stays powered through rain, snow, and extreme weather.
  • Versatile Compatibility: Works with multiple Wyze camera models, including the popular Pan v3 and Battery Cam Pro.
Summary
If you own a Wyze outdoor camera like the Cam Pan v3 or Battery Cam Pro, pairing it with the Wyze Outdoor Power Adapter is essential for a maintenance-free, weatherproof power supply. This combination guarantees your security cameras stay powered and operational in any weather, providing peace of mind and continuous surveillance.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
TypeAccessoryCameraCamera Bundle
Weather ResistanceIP67IP65IP65
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/Outdoor, 360° pan, 180° tiltIndoor/Outdoor, 360° pan, 180° tilt
Power Adapter IncludedYesYesYes
Micro USB Adapter IncludedOptional (L-shaped Micro USB adapter sold separately)NoNo
USB-C Adapter IncludedOptional (with Outdoor Adapter + L-shaped + USB-C variant)NoNo
Price$13.99 (Outdoor Power Adapter only)$39.98 (single camera)$39.98 (camera) + 30-Day Cam Plus subscription (free first 30 days, then $2.99/month)
Video ResolutionN/A1080p (1920 x 1080)1080p (1920 x 1080)
Pan & Tilt RangeN/A360° horizontal, 180° vertical360° horizontal, 180° vertical
Night VisionN/AColor Night Vision (4 IR LEDs, 850 nm)Color Night Vision (4 IR LEDs, 850 nm)
AudioN/ABuilt-in speaker, microphone, 2-way audioBuilt-in speaker, microphone, 2-way audio
Motion TrackingN/AYesYes
ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi802.11 b/g/n 2.4 GHz Wi-Fi
StorageN/ASupports up to 256 GB microSD (ExFAT)Supports up to 256 GB microSD (ExFAT)
Operating TemperatureN/A-20°C to 50°C (-4°F to 122°F)-20°C to 50°C (-4°F to 122°F)
Dimensions78.7 mm x 62.5 mm x 29.4 mm124 mm (H) x 60 mm (W) x 63 mm (D)124 mm (H) x 60 mm (W) x 63 mm (D)
Weight235 g320 g320 g
Included ItemsOutdoor Power Adapter (and adapters depending on variant)1x Wyze Cam Pan v3, 1x 6' micro USB Cable, 1x Power Adapter, 1x Mounting Kit, 1x Quick Start GuideSame as Wyze Cam Pan v3 plus 30-Day Cam Plus subscription
WarrantyNot specified1 Year1 Year
Additional FeaturesIP67 weather resistant for outdoor usePrivacy Mode, Pan Scan™ Patrol, Smoke & CO alerts, Alexa/Google Assistant/IFTTT integrationSame as Wyze Cam Pan v3 plus Cam Plus cloud features (unlimited event video cloud storage, advanced notifications)
What is the Wyze Outdoor Power Adapter and why do I need it for my Wyze camera?The Wyze Outdoor Power Adapter is a weather-resistant, maintenance-free power supply designed specifically for Wyze cameras. It ensures your outdoor cameras remain powered and operational in all weather conditions, eliminating the need for frequent battery changes or power interruptions.
Which Wyze camera models are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro, and Wyze Battery Cam Pro (with the appropriate adapters). Please note that it is not compatible with the OG Stack Kit.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it fully capable of withstanding rain, snow, and harsh outdoor conditions. This ensures your Wyze cameras stay powered no matter the weather.
Do I need any additional adapters to use the Wyze Outdoor Power Adapter with my camera?Some Wyze camera models require additional adapters for compatibility. The Cam v3 Pro and Pan v3 need an L-shaped MicroUSB Adapter, while the Wyze Battery Cam Pro requires a USB-C adapter. These are available in specific bundles.
How easy is it to install the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter features a plug-and-play design for quick and easy installation. It does not require complex wiring or ongoing maintenance, making it convenient for all users.
What are the key features of the Wyze Cam Pan v3 for outdoor use?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical coverage, IP65 weather resistance, Full HD 1080p video, night vision, 2-way audio, and compatibility with Alexa, Google Assistant, and IFTTT. It is ideal for comprehensive outdoor surveillance.
Why is the Wyze Outdoor Power Adapter recommended for the Wyze Cam Pan v3?The Wyze Outdoor Power Adapter is recommended for the Wyze Cam Pan v3 to provide a safe, reliable, and weatherproof power supply, ensuring uninterrupted operation and eliminating the need for battery replacements.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the Wyze Cam Pan v3 camera, a power adapter, mounting kit, quick start guide, and 30 days of Cam Plus service for advanced AI detection and cloud storage.
What are the benefits of using the Wyze Outdoor Power Adapter for my security cameras?Benefits include maintenance-free operation, reliable and stable power delivery, weatherproof protection (IP67 rating), and versatile compatibility with multiple Wyze camera models.
Can I use the Wyze Outdoor Power Adapter with the OG Stack Kit?No, the Wyze Outdoor Power Adapter is not compatible with the OG Stack Kit.
What are the key features of the Wyze Outdoor Power Adapter?How does the Wyze Outdoor Power Adapter ensure compatibility with different Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
