Extend Your Wyze Cam Setup with the 20ft USB Extension Cable
If you're looking to place your Wyze Cam on a balcony rail or any location far from a power outlet, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This cable extends your camera’s reach, allowing flexible placement without worrying about short cables limiting your setup.
Key Features of the Wyze Cam USB Extension Cable - 20ft
- Length: 20 feet of durable USB extension cable for maximum flexibility.
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and Wyze Cam OG models.
- Easy Setup: Simply plug the extension cable between your Wyze Cam and power source to extend your camera’s placement options.
- Affordable: At just $7.99, it’s a cost-effective solution to enhance your home security setup.
Say goodbye to the frustration of limited cable length and enjoy the freedom to position your Wyze Cam exactly where you need it — like on a balcony rail for optimal outdoor surveillance.
Wyze Cam v4: The Ideal Camera for Balcony and Outdoor Use
The
Wyze Cam v4 is a versatile, weather-resistant security camera designed to deliver crystal-clear video and reliable performance, making it an excellent choice for balcony monitoring.
Why Choose Wyze Cam v4 for Your Balcony?
- High-Resolution Video: 2.5K QHD (2560x1440) resolution ensures sharp, detailed footage.
- Enhanced Color Night Vision: See vibrant colors even in low light, thanks to 4 IR LEDs and 2 white spotlight LEDs.
- Wide Field of View: 115.8° diagonal field of view covers a broad area, perfect for balcony surveillance.
- Weather Resistance: Rated IP65, the camera withstands rain, dust, and varying temperatures (-4°F to 122°F), ideal for outdoor balcony conditions.
- Multiple Mounting Options: Includes stand, wall mount, ceiling mount, and magnetic adhesive mount for flexible installation on balcony rails or walls.
- Smart Features: Motion detection, two-way audio, built-in siren, and Alexa/Google Assistant compatibility keep you connected and in control.
- Power Supply: Comes with a 6-foot flat micro USB to USB-A cable and indoor power adapter; extendable with the 20ft USB extension cable for balcony setups.
The Wyze Cam v4’s robust design and advanced features make it a top choice for outdoor security, especially when paired with the USB extension cable for convenient power access.
How to Set Up Your Wyze Cam on a Balcony Rail Using the 20ft USB Extension Cable
1.
Choose Your Camera: Use the Wyze Cam v4 for its weather resistance and high-quality video.
2.
Mounting: Attach the camera to the balcony rail using the included magnetic wall mount or adhesive mount for a secure hold.
3.
Power Connection: Connect the Wyze Cam’s original USB cable to the 20ft Wyze Cam USB Extension Cable.
4.
Power Source: Plug the other end of the extension cable into a nearby power outlet inside your home.
5.
Adjust Camera Angle: Use the camera’s flexible mounting options to get the perfect view of your balcony or surrounding area.
6.
Configure Settings: Use the Wyze app to set motion detection zones, alerts, and other preferences.
This setup ensures your camera stays powered and connected without unsightly or unsafe cable stretching.
Summary: Perfect Pairing for Balcony Security
- Wyze Cam USB Extension Cable - 20ft: Extends your camera’s power cable for flexible placement.
- Wyze Cam v4: Weatherproof, high-resolution camera with advanced night vision and smart features.
Together, they provide a seamless solution for placing your Wyze Cam on balcony rails or other hard-to-reach outdoor spots, ensuring your home stays secure with clear, reliable video coverage.
Alt text: Wyze Cam mounted on a balcony rail with extended USB cable for outdoor security
Product Specifications at a Glance
- Length: 20 feet
- Compatible with: Wyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG Telephoto
- Price: $7.99
Wyze Cam v4
- Video Resolution: 2.5K QHD (2560x1440)
- Night Vision: Enhanced color night vision with IR and spotlight LEDs
- Field of View: 115.8° diagonal
- Weather Resistance: IP65 rated
- Mounting: Stand, wall, ceiling, magnetic adhesive
- Power: 6-foot USB cable included; extendable with USB extension cable
- Smart Features: Motion detection, two-way audio, built-in siren, Alexa/Google Assistant compatible
Place your Wyze Cam confidently on your balcony rail with the 20ft USB extension cable and enjoy enhanced security coverage with the powerful Wyze Cam v4.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power connection, allowing you to place your camera in locations farther from a power outlet, such as balcony rails or other hard-to-reach spots.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and Wyze Cam OG models.How do I set up my Wyze Cam on a balcony using the 20ft USB Extension Cable?
To set up your Wyze Cam on a balcony, mount the camera using the included stand, wall mount, ceiling mount, or magnetic adhesive mount. Connect the original USB cable to the 20ft extension cable, then plug the other end into a nearby indoor power outlet. Adjust the camera angle and configure settings in the Wyze app for optimal coverage.Is the Wyze Cam v4 suitable for outdoor and balcony use?
Yes, the Wyze Cam v4 is ideal for outdoor and balcony use. It features weather resistance with an IP65 rating, high-resolution 2.5K QHD video, enhanced color night vision, and multiple mounting options for secure installation on balcony rails or walls.What are the key features of the Wyze Cam v4 for balcony security?
The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision with IR and spotlight LEDs, a wide 115.8° field of view, IP65 weather resistance, multiple mounting options, motion detection, two-way audio, a built-in siren, and compatibility with Alexa and Google Assistant.How long is the Wyze Cam USB Extension Cable and what is its price?
The Wyze Cam USB Extension Cable is 20 feet long and is priced at $7.99, making it an affordable solution for extending your camera’s power connection.Can I use the Wyze Cam v4’s USB extension cable with other Wyze Cam models?
Yes, the 20ft USB extension cable is compatible with several Wyze Cam models, including v2, v3, v4, v3 Pro, Pan v2/v3, and OG models, providing flexible placement options for your security cameras.What mounting options are available for the Wyze Cam v4 on a balcony?
The Wyze Cam v4 includes a stand, wall mount, ceiling mount, and magnetic adhesive mount, allowing you to securely attach the camera to balcony rails, walls, or ceilings for optimal surveillance.Does the Wyze Cam v4 come with a power cable, and can it be extended?
Yes, the Wyze Cam v4 comes with a 6-foot flat micro USB to USB-A cable and an indoor power adapter. You can extend the power connection using the 20ft Wyze Cam USB Extension Cable for more flexible placement.What are the benefits of using the Wyze Cam v4 and 20ft USB Extension Cable together for balcony security?
Pairing the Wyze Cam v4 with the 20ft USB Extension Cable allows you to place your camera in optimal outdoor locations, such as balcony rails, without worrying about power outlet proximity. This setup ensures reliable, high-quality video coverage and enhanced security for your home.
