Secure Your Wyze Camera on Angled or Curved Windows with the Wyze Window Mount
When it comes to enhancing your home or RV security, positioning your Wyze camera for the best possible coverage is essential. Angled or curved windows can pose a challenge for mounting security cameras securely and effectively. The
Wyze Window Mount is specifically designed to solve this problem by allowing you to attach your Wyze Cam directly to glass surfaces, including angled or curved windows, for optimal viewing angles without glare or reflection.
Why Choose the Wyze Window Mount?
The Wyze Window Mount is compatible with multiple Wyze camera models including Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto. This accessory provides a clean, secure attachment to glass surfaces, making it ideal for:
- Curved or angled windows where traditional mounts fail
- RV and camper windows for mobile security
- Clear, glare-free views through glass for better video quality
This mount ensures your camera stays firmly in place while capturing crisp, unobstructed footage, enhancing your exterior security setup.
Wyze Cam v4: Crystal-Clear Security with Flexible Mounting Options
The
Wyze Cam v4 is a top-tier security camera that pairs perfectly with the Wyze Window Mount for versatile placement on windows of any shape.
- 2.5K QHD resolution for ultra-clear video quality
- Enhanced Color Night Vision with built-in spotlight for 24/7 security
- Wide field of view: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
- Multiple mounting options: including magnetic wall mount with adhesive, perfect for glass surfaces
- Wi-Fi 6 support for faster, more reliable connectivity
- Weather-resistant IP65 rating for outdoor durability
- Supports microSD cards up to 512 GB for local storage
With the Wyze Window Mount, you can easily attach the Wyze Cam v4 to angled or curved windows, ensuring your camera captures the best possible coverage without compromising on style or security.
Wyze Cam OG: Reliable and Compact for Window Mounting
The
Wyze Cam OG remains a popular choice for those seeking a compact, reliable camera that works seamlessly with the Wyze Window Mount.
- 1080p Full HD video resolution with 120° field of view
- CMOS-Starlight Sensor for improved low-light performance
- Built-in spotlight and 90-decibel siren for enhanced security alerts
- Supports up to 256 GB microSD card for local video storage
- IP65 weather resistance for outdoor use
Two-way audio with noise and echo cancellation
Mounting the Wyze Cam OG on angled or curved windows using the Wyze Window Mount allows you to maximize your camera’s field of view while maintaining a sleek, unobtrusive installation.
Enhance Your Outdoor Security with Lifestyle-Friendly Mounting
"Mount your Wyze Cam on glass surfaces with ease and enjoy clear, glare-free views for superior security coverage."
Wyze Cam Floodlight providing outdoor security with easy mounting
The Wyze Window Mount is an essential accessory for anyone looking to secure their home or RV with Wyze cameras on challenging window surfaces. Whether you have curved camper windows or angled home windows, this mount offers a simple, effective solution to position your camera exactly where you need it.
Summary: Why the Wyze Window Mount is Your Best Choice for Angled or Curved Windows
- Compatible with multiple Wyze cameras (v3, v3 Pro, v4, OG series)
- Securely attaches to glass surfaces, including curved and angled windows
- Provides clear, glare-free video for better security footage
- Ideal for smart home setups, RVs, campers, and travel trailers
- Affordable and easy to install accessory
Additional Wyze Cameras Compatible with Window Mounting
While the Wyze Window Mount is designed for glass surfaces, here are other Wyze cameras that complement your security system but are typically mounted on walls or ceilings:
- Wyze Cam Floodlight v2 + Plug-In Mount: Offers 2K HD video with vibrant color night vision and a powerful 2800-lumen LED floodlight. Ideal for porch or yard lighting but not designed for window mounting.
- Wyze Cam Floodlight Pro + Plug-In Mount: Features 2.5K QHD resolution, 180° ultra-wide field of view, and 3000 lumens of light output. Perfect for outdoor wall or ceiling mounting.
- Wyze Cam Floodlight Plug-In Mount: A plug-and-play mount for floodlight cameras, simplifying installation without the need for junction boxes.
These cameras enhance your overall home security but are best suited for traditional mounting locations rather than glass surfaces.
What is the Wyze Window Mount and how does it work?
The Wyze Window Mount is a specialized accessory designed to securely attach Wyze cameras directly to glass surfaces, including angled or curved windows. It allows you to position your camera for optimal coverage and clear, glare-free video footage, making it ideal for both home and RV security setups.Which Wyze cameras are compatible with the Wyze Window Mount?
The Wyze Window Mount is compatible with several Wyze camera models, including Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and Wyze Cam OG Telephoto. This ensures flexibility and versatility for various security needs.Can I use the Wyze Window Mount on curved or angled windows?
Yes, the Wyze Window Mount is specifically designed to work on curved or angled windows where traditional mounts may not be effective. It provides a secure attachment and optimal viewing angles for your Wyze camera.Is the Wyze Window Mount suitable for RV or camper windows?
Absolutely. The Wyze Window Mount is ideal for RV and camper windows, allowing you to easily secure your Wyze camera to glass surfaces for mobile security and peace of mind while traveling.Does the Wyze Window Mount help reduce glare and reflections in video footage?
Yes, the Wyze Window Mount is designed to provide clear, glare-free views through glass, ensuring your security camera captures crisp and unobstructed footage.What are the benefits of using the Wyze Cam v4 with the Window Mount?
Pairing the Wyze Cam v4 with the Window Mount allows you to take advantage of its 2.5K QHD resolution, enhanced color night vision, wide field of view, and weather-resistant design. The mount enables flexible placement on any window shape for superior security coverage.Is the Wyze Cam OG compatible with the Window Mount?
Yes, the Wyze Cam OG works seamlessly with the Wyze Window Mount. Its compact design, 1080p Full HD video, and built-in spotlight make it a reliable choice for window mounting on angled or curved glass surfaces.Are Wyze Cam Floodlight models compatible with the Window Mount?
No, Wyze Cam Floodlight models such as the Floodlight v2 and Floodlight Pro are designed for wall or ceiling mounting and are not intended for use with the Wyze Window Mount on glass surfaces.Is the Wyze Window Mount weather-resistant for outdoor use?
The Wyze Window Mount is designed for secure attachment to glass surfaces, and many compatible Wyze cameras, such as the Wyze Cam v4 and OG, feature IP65 weather resistance, making them suitable for outdoor use when mounted on exterior windows.How easy is it to install the Wyze Window Mount?
The Wyze Window Mount is an affordable and easy-to-install accessory. It provides a clean, secure attachment to glass surfaces, allowing you to position your Wyze camera quickly and efficiently without the need for complex tools or hardware.
