Mount a Wyze Cam in Your RV Window for Travel Security
Mounting a Wyze Cam in an RV Window for Travel Security Monitoring
When traveling in an RV, ensuring your vehicle and surroundings are secure is a top priority. Using a Wyze Cam mounted on your RV window offers a smart, convenient way to monitor your travel trailer, camper, or motorhome. The Wyze Window Mount is specifically designed to attach your Wyze Cam directly to glass surfaces, providing a clear, glare-free view of the exterior. This setup is ideal for travel security monitoring, giving you peace of mind wherever your journey takes you.
Wyze Window Mount: Perfect for RV Window Installation
Clear, Glare-Free Exterior Monitoring
The Wyze Window Mount is engineered to hold Wyze Cam models such as the v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto securely on glass surfaces. This accessory is perfect for RV owners who want to mount their cameras on windows without worrying about reflections or glare obstructing the view.
  • Compatible with multiple Wyze Cam models
  • Easy to attach on any glass window of your RV
  • Provides a clear, unobstructed view for exterior security
  • Ideal for campers, motorhomes, vans, and travel trailers
Upgrade your RV’s exterior security by mounting your Wyze Cam on the window for a discreet and effective surveillance solution.
Wyze Cam Floodlight on Deck Evening Enhance your RV security with clear outdoor monitoring
Additional Mounting Options for Wyze Cameras in Your RV
Wyze Cam Mounting Kit
For those who want a more traditional mounting option inside or outside the RV, the Wyze Cam Mounting Kit offers a versatile solution. It includes a mounting bracket, adhesive tape, and a longer Micro USB cable, making it easy to install your Wyze Cam v2, v3, or v3 Pro in various locations.
  • Includes wall plate, adhesive tape, and 5-foot USB extension cable
  • Compatible with Wyze Cam v2, v3, and v3 Pro
  • Perfect for mounting on walls or ceilings inside the RV
Wyze Universal Mount (Long)
If you need a durable mount with a longer neck for versatile placement such as ceilings or patios around your RV, the Wyze Universal Mount (Long) is an excellent choice. It supports Wyze Cams with a standard 1/4”-20 mount and is made from heavy-duty metal for stability.
  • Adjustable and easy to install
  • Compatible with most Wyze Cam models except OG and OG Telephoto
  • Ideal for ceiling or patio mounting around your RV
Why Choose Wyze for RV Travel Security?
Wyze offers a range of affordable, easy-to-install security cameras and accessories tailored for smart home and travel use. The window mount accessory is a standout for RV owners because it allows you to:
  • Monitor your RV’s exterior discreetly without drilling holes
  • Avoid glare and reflections that can obscure camera footage
  • Use your existing Wyze Cam models without needing additional hardware
  • Enjoy peace of mind with clear, reliable video monitoring wherever you park
Whether you’re parked at a campsite or on the road, mounting your Wyze Cam on an RV window is a smart way to keep an eye on your travel security.
Wyze Cam Mounted Outdoor Security Wyze Cam mounted outdoors for smart travel security
Summary of Recommended Products for RV Window Mounting
Product NameKey FeaturesPrice (USD)
Wyze Window MountGlass surface mount, glare-free view, RV compatible9.98
Wyze Cam Mounting KitMounting bracket, adhesive, USB extension cable5.99
Wyze Universal Mount (Long)Heavy-duty metal, adjustable, versatile mounting9.99
These accessories complement your Wyze Cam perfectly for travel security monitoring in your RV, camper, or travel trailer.
Final Thoughts
Mounting a Wyze Cam on your RV window using the Wyze Window Mount is a simple, effective way to enhance your travel security. It provides a clear, glare-free view of your surroundings without complicated installation or damage to your vehicle. Pair it with other mounting accessories for flexible placement options inside or outside your RV. Stay secure on the road with Wyze’s smart, affordable camera accessories designed for travel and home security.
FeatureWyze Window MountWyze Cam Mounting KitWyze Universal Mount (Long)
Compatible CamerasWyze Cam v3, v3 Pro, v4, Wyze Cam OG, OG TelephotoWyze Cam v2, v3, v3 ProWyze Cam v1, v2, v3, v3 Pro, Pan v1/v2/v3, Outdoor v1/v2, Battery Cam Pro
Mounting SurfaceGlass windowVarious surfaces (with adhesive or screws)Ceiling, patio, walls (standard 1/4”-20 mount)
Mount TypeWindow mount to reduce glare/reflectionMounting bracket with adhesive and longer USB cableDurable metal mount with longer neck, adjustable
Price$9.98$5.99$9.99
Included ItemsWindow mount accessoryMounting bracket, adhesive, longer Micro USB cableMetal mount, screw assembly
Outdoor UseYes (for exterior window mounting)NoNo
Compatibility NotesWorks with Wyze Cam OG series and newer camsOnly for Wyze Cam v2, v3, v3 ProNot compatible with Wyze Cam OG or OG Telephoto
Mount Load BearingNot specifiedNot specified70 oz (2 kg)
Installation EaseEasy, sticks to glassEasy, adhesive or screw mountingEasy installation, adjustable
Special FeaturesReduces glare and reflectionIncludes longer USB cable for extended reachHeavy-duty metal, adjustable angle
How do I mount a Wyze Cam on my RV window for travel security?To mount a Wyze Cam on your RV window, use the Wyze Window Mount, which is specifically designed to attach your camera directly to glass surfaces. This provides a clear, glare-free view of the exterior, making it ideal for travel security monitoring without drilling holes or causing damage to your RV.
Which Wyze Cam models are compatible with the Wyze Window Mount for RV use?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models. This makes it a versatile choice for RV owners looking to monitor their vehicle’s exterior.
What are the benefits of using a Wyze Window Mount in an RV?Using a Wyze Window Mount in your RV allows for discreet, glare-free exterior monitoring without drilling holes. It provides a clear, unobstructed view, is easy to install on any glass window, and helps enhance your RV’s security while traveling or parked.
Are there other mounting options for Wyze Cams inside or outside my RV?Yes, in addition to the Wyze Window Mount, you can use the Wyze Cam Mounting Kit for wall or ceiling installations inside your RV. The Wyze Universal Mount (Long) is another option, offering a durable, adjustable mount for ceilings or patios around your RV, compatible with most Wyze Cam models except OG and OG Telephoto.
What is included in the Wyze Cam Mounting Kit for RV installation?The Wyze Cam Mounting Kit includes a mounting bracket, adhesive tape, and a 5-foot USB extension cable. It is compatible with Wyze Cam v2, v3, and v3 Pro, making it easy to install your camera in various locations inside your RV.
Can I mount a Wyze Cam outside my RV using the Universal Mount (Long)?Yes, the Wyze Universal Mount (Long) is ideal for mounting your Wyze Cam on ceilings or patios outside your RV. It is made from heavy-duty metal, is adjustable, and supports most Wyze Cam models except OG and OG Telephoto.
Why should I choose Wyze cameras and accessories for RV travel security?Wyze offers affordable, easy-to-install security cameras and accessories tailored for both home and travel use. Their window mount accessory allows for discreet, glare-free monitoring without additional hardware, giving you peace of mind and reliable video surveillance wherever you park your RV.
Do I need to drill holes to mount a Wyze Cam on my RV window?No, the Wyze Window Mount attaches directly to glass surfaces using suction, so you do not need to drill any holes or cause damage to your RV when installing your Wyze Cam.
How much do Wyze mounting accessories for RVs cost?The Wyze Window Mount is priced at $9.98, the Wyze Cam Mounting Kit at $5.99, and the Wyze Universal Mount (Long) at $9.99. These accessories are affordable options for enhancing your RV’s travel security.
Can I use my existing Wyze Cam for RV security monitoring?Yes, you can use your existing Wyze Cam models, such as v3, v3 Pro, v4, OG, and OG Telephoto, with the Wyze Window Mount for RV security monitoring without needing additional hardware.
What are the installation steps for the Wyze Window Mount on an RV window?Can the Wyze Window Mount be used with other Wyze Cam models besides the ones mentioned?Are there any discounts available for purchasing the Wyze Window Mount?
