Peel and Stick Rechargeable Night Light with Motion Sensor Setup
When it comes to convenient, energy-efficient, and smart lighting solutions, the
Wyze Night Light stands out as a top choice. Designed for easy peel-and-stick installation and rechargeable use, this night light is perfect for illuminating dark spaces with soft, motion-activated light. Whether you want to light up hallways, closets, or bedrooms, this rechargeable night light offers a hassle-free setup and long-lasting performance.
Wyze Night Light: Features and Setup Guide
Easy Peel-and-Stick Installation
The Wyze Night Light comes with a peel-and-stick mounting system that allows you to place the light anywhere without drilling or wiring. Simply peel off the adhesive backing and stick the light on any clean, flat surface. This makes it ideal for renters or anyone who wants a no-fuss installation.
Rechargeable Battery with USB-C Charging
Powered by a 300mAh Lithium Polymer battery, the Wyze Night Light can last up to 128 days on a single charge when used solo. Charging is quick and convenient via USB Type-C, taking only 1.5 to 2 hours to fully recharge. This rechargeable design eliminates the need for disposable batteries, making it eco-friendly and cost-effective.
Motion and Light Sensors for Smart Activation
Equipped with built-in motion and light sensors, the night light automatically turns on when it detects movement in low-light conditions (below 6.5 lux). This ensures the light only activates when needed, saving battery life and providing illumination exactly when you need it.
Link Up to 10 Units for Directional Lighting
For larger spaces or hallways, you can link up to 10 Wyze Night Lights together via 2.4GHz RF connection. This creates a directional lighting experience that guides your way through the dark with seamless coverage.
Compact and Lightweight Design
Measuring just 3.14” x 2.04” x 0.55” and weighing only 1.8oz, the Wyze Night Light is compact and unobtrusive. Its warm 2500K color temperature emits a soft glow of 4.5 lumens, perfect for nighttime visibility without disturbing sleep.
Setup Tip: After peeling and sticking the night light, charge it fully using the included USB-C cable. The light will automatically activate in low light when motion is detected, so no manual switching is required.
Soft, motion-activated lighting for your home hallway
Additional Lighting Options for Your Smart Home
Wyze Bulb Color: Vibrant Smart Lighting
If you want to complement your night light with versatile smart bulbs, the
Wyze Bulb Color offers 16 million colors and tunable white light. Perfect for living rooms, bedrooms, or kitchens, these bulbs provide up to 1100 lumens of brightness and integrate seamlessly with Alexa, Google Assistant, and IFTTT.
- 16 million colors and dimmable white light
- 25,000 hours life expectancy
- Compatible with Android and iOS apps
- Suitable for damp locations
This smart bulb is ideal for creating ambiance and can be scheduled or controlled remotely via the Wyze app.
Create vibrant moods with Wyze Bulb Color smart lighting
Why Choose Wyze Night Light for Your Home?
- No wiring or tools needed: Peel-and-stick design makes setup effortless.
- Long battery life: Up to 128 days on a single charge.
- Smart sensors: Motion and light sensors ensure energy-efficient operation.
- Expandable system: Link multiple units for comprehensive coverage.
- Rechargeable and eco-friendly: USB-C charging eliminates disposable batteries.
Whether you need a night light for safety, convenience, or ambiance, the Wyze Night Light offers a modern, smart solution that’s easy to install and maintain.
Summary
The
Wyze Night Light is the perfect peel-and-stick rechargeable night light with motion sensor setup. Its smart features, long battery life, and easy installation make it a must-have for any home. Pair it with other Wyze smart lighting products like the Wyze Bulb Color to create a fully connected and customizable lighting environment.
What is the Wyze Night Light and how does it work?
The Wyze Night Light is a peel-and-stick rechargeable night light equipped with motion and light sensors. It automatically turns on when it detects movement in low-light conditions, providing soft illumination for hallways, closets, bedrooms, and more. Its smart activation ensures energy-efficient operation and convenience.How do I install the Wyze Night Light?
Installation is simple with the Wyze Night Light’s peel-and-stick mounting system. Just peel off the adhesive backing and stick the light onto any clean, flat surface—no drilling or wiring required. This makes it ideal for renters or anyone seeking a hassle-free setup.How long does the Wyze Night Light battery last and how do I recharge it?
The Wyze Night Light features a 300mAh Lithium Polymer battery that can last up to 128 days on a single charge when used solo. Recharge the battery quickly and easily using the included USB Type-C cable; a full charge takes only 1.5 to 2 hours.Does the Wyze Night Light require disposable batteries?
No, the Wyze Night Light is fully rechargeable via USB-C, eliminating the need for disposable batteries. This makes it an eco-friendly and cost-effective lighting solution.Can I link multiple Wyze Night Lights together?
Yes, you can link up to 10 Wyze Night Lights together using a 2.4GHz RF connection. This allows you to create directional lighting for larger spaces or hallways, ensuring seamless coverage and guidance in the dark.What type of sensors does the Wyze Night Light have?
The Wyze Night Light is equipped with both motion and light sensors. It automatically activates when it detects movement in low-light conditions (below 6.5 lux), ensuring the light only turns on when needed and conserving battery life.What are the dimensions and brightness of the Wyze Night Light?
The Wyze Night Light measures 3.14” x 2.04” x 0.55” and weighs only 1.8oz. It emits a warm 2500K color temperature with a soft glow of 4.5 lumens, making it perfect for nighttime visibility without disturbing sleep.Is the Wyze Night Light suitable for renters?
Yes, the Wyze Night Light’s peel-and-stick design makes it perfect for renters. It requires no drilling or permanent installation, so it can be easily removed or repositioned without damaging walls or surfaces.What other smart lighting options does Wyze offer?
Wyze also offers the Wyze Bulb Color, a smart bulb with 16 million colors and tunable white light. It provides up to 1100 lumens of brightness, is compatible with Alexa, Google Assistant, and IFTTT, and can be controlled remotely via the Wyze app.Why should I choose the Wyze Night Light for my home?
The Wyze Night Light offers easy installation, long battery life, smart motion and light sensors, expandable linking for larger areas, and eco-friendly rechargeable design. It’s a modern, convenient, and energy-efficient solution for safe and comfortable nighttime lighting.
