Best Outdoor Video Doorbells with Continuous 2K Recording
When it comes to securing your home’s front porch, having a video doorbell that records clear 2K detail continuously is essential. Whether you want to monitor visitors, packages, or simply keep an eye on your doorstep, Wyze offers a range of smart video doorbells designed to deliver crystal-clear video, reliable local storage, and smart features that enhance your home security experience.
Wyze Video Doorbell v2: Crystal-Clear 2K Continuous Recording
Experience sharp 2K video and smart porch protection with Wyze Video Doorbell v2.
Wyze Video Doorbell v2 is the ultimate wired video doorbell for those who want continuous, high-resolution video coverage. It offers:
- 2K HD Video Quality: Capture every detail from head to toe with immaculate 2K resolution, ensuring you never miss a moment on your porch.
- 24/7 Local Recording: Thanks to the onboard microSD card slot, you can record continuously without relying solely on cloud storage. This local storage lets you review footage anytime.
- Motion-Activated Voice Deterrence: Automatically warn visitors with a voice prompt when motion is detected, helping deter unwanted activity.
- Two-Way Audio: Communicate with visitors instantly through the Wyze app, whether you’re home or away.
- Pre-Roll Motion Recording: Get 3-6 seconds of video before motion events start, so you see the full context of any activity.
- Works with Existing Chimes: Keep your traditional doorbell chime ringing with the included chime controller.
- Weatherproof Design: Rated IP65, it withstands rain, snow, and harsh weather conditions.
- Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
This doorbell is perfect for homeowners who want continuous, detailed video coverage with local storage flexibility.
Wyze Duo Cam Battery Doorbell: Dual 2K Cameras for Maximum Coverage
Dual camera views capture people and packages with stunning 2K clarity.
For those seeking advanced monitoring, the Wyze Duo Cam Battery Doorbell offers dual camera views:
- Dual 2K Video Feeds: One front-facing camera captures visitors, while a second camera monitors packages below, both in crisp 2K resolution.
- Battery-Powered with Optional Hardwired Setup: Enjoy flexible installation options with a removable battery pack or hardwired power.
- Local and Cloud Storage: Supports 24/7 local recording with a microSD card (sold separately) and cloud storage options.
- Real-Time AI Detections: Receive smart alerts for people, packages, and vehicles with AI-powered notifications.
- Motion-Activated Voice Deterrence: Warn visitors automatically with a recorded voice message.
- Two-Way Audio: Talk to visitors or delivery personnel directly from your phone.
- IP65 Weather Resistance: Built to endure all weather conditions.
- Wide Field of View: Front camera offers 132° horizontal and 100° vertical viewing angles for broad coverage.
This doorbell is ideal for busy households wanting comprehensive porch surveillance with dual perspectives and smart AI features.
Wyze Video Doorbell Pro: Flexible Wired or Wireless Installation
Install in 30 seconds with wired or battery power options.
Wyze Video Doorbell Pro combines convenience and performance with:
- HD Video Quality: Crystal-clear HD resolution with a wider ultra-wide viewing angle to cover more of your porch.
- Dual Power Options: Choose between hardwired or battery power for easy installation anywhere.
- Fast Notifications: Dual-band Wi-Fi extender chime ensures you get alerts quickly.
- Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus subscription.
- Motion-Activated Security Light: Built-in light activates on motion to illuminate your porch.
- Two-Way Audio and Quick Responses: Communicate instantly and use preset quick replies.
- Customizable Chime: Choose from 20 unique tunes and 8 sound levels.
- Smart Home Compatible: Works seamlessly with Alexa and Google Assistant.
- Includes Chime: Comes with a chime for indoor alerts.
Perfect for users who want a versatile doorbell with easy installation and smart detection features.
Enhance Your Doorbell View with Wyze Video Doorbell v2 Wedge Kit
If your porch or door frame is angled, the
Wyze Video Doorbell v2 Wedge Kit is the perfect accessory to optimize your doorbell’s viewing angle. It includes:
- 15° horizontal bracket and two 7.5° vertical brackets for precise angle adjustment.
- Weather-resistant plastic construction.
- Quick and easy installation.
- Compatible exclusively with Wyze Video Doorbell v2.
This accessory helps eliminate blind spots and ensures maximum coverage of your porch area.
Complete Front Porch Security with The Front Porch Security Bundle
For a comprehensive smart home security solution, consider the
Front Porch Security Bundle which includes:
- Wyze Video Doorbell (v2 or Pro) with 1080p HD video.
- Wyze Lock for remote door locking/unlocking and lock history monitoring.
- Wyze Chime for indoor alerts.
- Two-way audio and smart notifications.
This bundle integrates video doorbell and smart lock technology for ultimate front porch protection and convenience.
Why Choose Wyze Outdoor Video Doorbells?
Wyze video doorbells stand out by offering continuous 2K video recording, local microSD storage, and smart AI-powered alerts — all at an affordable price point. Whether you want wired or battery-powered options, dual cameras, or integrated smart locks, Wyze has a solution tailored to your home security needs.
Summary of Top Outdoor Video Doorbells with 2K Continuous Recording
Product | Video Resolution | Power Options | Continuous Recording | Special Features |
Wyze Video Doorbell v2 | 2K (2304x1296) | Wired | Yes (local microSD) | Pre-roll recording, voice deterrence |
Wyze Duo Cam Battery Doorbell | Dual 2K cameras | Battery/Hardwired | Yes (local microSD) | Dual views, AI detections, voice deterrence |
Wyze Video Doorbell Pro | HD (1080p) | Wired/Battery | No (cloud-based) | Ultra-wide view, security light, quick install |
Front Porch Security Bundle | 1080p HD | Wired/Battery | Depends on doorbell | Includes smart lock and chime |
Wyze Video Doorbell v2 Wedge Kit | N/A | Accessory | N/A | Angle adjustment for Doorbell v2 |
Optimize your home security with Wyze’s advanced outdoor video doorbells that deliver clear 2K detail continuously, smart alerts, and seamless integration with your smart home ecosystem.
Product Images
Wyze Video Doorbell v2 installed on a front porch.
Wyze Duo Cam Doorbell capturing dual views of porch and packages.
Wyze Video Doorbell Pro showcasing easy installation and smart features.
What are the best outdoor video doorbells with continuous 2K recording?
The best outdoor video doorbells with continuous 2K recording from Wyze include the Wyze Video Doorbell v2 and the Wyze Duo Cam Battery Doorbell. Both models offer 2K resolution and support 24/7 local recording via a microSD card, ensuring you never miss any activity on your front porch.Does the Wyze Video Doorbell v2 support continuous recording?
Yes, the Wyze Video Doorbell v2 supports continuous 24/7 recording when you use a microSD card. This allows you to review all footage locally without relying solely on cloud storage.What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features 2K HD video quality, 24/7 local recording with a microSD card, motion-activated voice deterrence, two-way audio, pre-roll motion recording, compatibility with existing chimes, weatherproof IP65 design, and smart home integration with Alexa and Google Home.What makes the Wyze Duo Cam Battery Doorbell unique?
The Wyze Duo Cam Battery Doorbell stands out with its dual 2K cameras—one for visitors and one for packages—providing comprehensive coverage. It offers both battery-powered and hardwired installation, supports local and cloud storage, features real-time AI detections, motion-activated voice deterrence, two-way audio, and is weather-resistant.Can I install Wyze video doorbells without hardwiring?
Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell Pro offer battery-powered installation options, allowing for flexible placement without the need for hardwiring.Does the Wyze Video Doorbell Pro offer continuous recording?
The Wyze Video Doorbell Pro does not support continuous local recording. It offers cloud-based event recording and features such as HD video, dual power options, fast notifications, smart detection alerts, and a built-in security light.What is the Wyze Video Doorbell v2 Wedge Kit used for?
The Wyze Video Doorbell v2 Wedge Kit is an accessory designed to optimize your doorbell’s viewing angle. It includes horizontal and vertical brackets for precise adjustment, is weather-resistant, and is compatible exclusively with the Wyze Video Doorbell v2.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (v2 or Pro), Wyze Lock for remote locking and monitoring, Wyze Chime for indoor alerts, and features like two-way audio and smart notifications for comprehensive front porch security.Are Wyze video doorbells weatherproof?
Yes, Wyze video doorbells such as the Wyze Video Doorbell v2 and Wyze Duo Cam Battery Doorbell are rated IP65, making them weatherproof and suitable for outdoor use in rain, snow, and harsh conditions.Do Wyze video doorbells work with Alexa and Google Home?
Yes, Wyze video doorbells are compatible with Alexa and Google Home, allowing you to use voice commands and view live feeds on supported smart displays.What storage options are available for Wyze video doorbells?
Wyze video doorbells offer both local storage via microSD card (for continuous recording on select models) and cloud storage options for event-based recordings.What smart detection features do Wyze video doorbells offer?
Wyze video doorbells provide smart detection features such as person, package, vehicle, and pet detection (with Cam Plus subscription), as well as real-time AI-powered alerts for enhanced security.
