Wyze Duo Cam: Continuous Recording Video Doorbell for Security
Best Video Doorbells for Continuous Recording and Enhanced Security
When it comes to securing your home, having a video doorbell that records continuous footage is a game changer. It ensures you never miss a moment, providing peace of mind and detailed evidence if needed. Wyze offers a range of video doorbells designed to meet different needs, including the highly capable Wyze Duo Cam Doorbell, Wyze Video Doorbell v2, Wyze Video Doorbell Pro, and the comprehensive Front Porch Security Bundle. Below, we explore these options to help you find the perfect fit for your home security.
Wyze Duo Cam Doorbell: Dual Cameras with Battery Power and 24/7 Recording
Wyze Duo Cam Doorbell lifestyle Experience advanced home security with Wyze Duo Cam Doorbell. The Wyze Duo Cam Doorbell is Wyze’s most advanced battery-powered video doorbell, perfect for those who want flexibility without sacrificing performance.
Key Features:
  • Dual Camera Views: Front camera captures 2K resolution (2048 x 1536) with a wide 132° horizontal field of view, while the bottom camera covers packages and ground-level activity in 1080p.
  • Continuous Local Recording: Supports up to 256GB microSD card for 24/7 local recording when hardwired or with battery and microSD installed.
  • Battery Powered with USB-C Charging: Comes with a removable 6200 mAh lithium-ion battery pack for easy charging and uninterrupted operation.
  • AI-Powered Alerts: Real-time person, package, and vehicle detection with motion-activated voice deterrence saying, "Hi, you’re currently being recorded."
  • Weather Resistant: IP65 rating ensures reliable performance in harsh weather conditions.
  • Two-Way Audio & Siren: Communicate with visitors or deter unwanted guests with a 90 dB siren.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
This doorbell is ideal for homeowners who want a comprehensive view of their porch and package area with the convenience of battery power and continuous recording.
Wyze Video Doorbell v2: Wired 2K Video with Local MicroSD Storage
Wyze Video Doorbell v2 lifestyle Crystal-clear 2K video and continuous local recording with Wyze Video Doorbell v2. The Wyze Video Doorbell v2 is a wired doorbell that offers exceptional video quality and continuous local recording, making it a top choice for those wanting detailed footage without cloud dependency.
Highlights:
  • 2K HD Video Resolution: Capture every detail with 2304 x 1296 pixels, providing a crystal-clear head-to-toe view of your porch.
  • 24/7 Local Recording: Unique onboard microSD card slot allows continuous recording, so you never miss what happens before or after the doorbell rings.
  • Motion-Activated Voice Deterrence: Automatically warns visitors they are being recorded, enhancing security.
  • Two-Way Audio: Talk to visitors in real-time through the Wyze app.
  • Pre-Roll Motion Capture: Wired power enables 3-6 seconds of pre-roll video before motion events.
  • Works with Existing Chimes: Includes a chime controller to keep your traditional doorbell sounds.
  • Weatherproof: IP65 rating for all-weather durability.
  • Smart Features: Compatible with Alexa and Google Home, plus Cam Plus subscription for AI detections and unlimited cloud storage.
This wired doorbell is perfect for users who want continuous local recording with high-resolution video and integration with existing home chimes.
Wyze Video Doorbell Pro: Flexible Wired or Battery Power with Wide View
Wyze Video Doorbell Pro lifestyle Install in 30 seconds and enjoy wider views with Wyze Video Doorbell Pro. The Wyze Video Doorbell Pro offers a wider field of view and flexible power options, combining convenience with advanced smart features.
Features:
  • Wider Ultra-Wide Viewing Angle: Covers more area around your front door for enhanced security.
  • HD Video Quality: Crystal-clear resolution ensures you see visitors clearly.
  • Dual Power Options: Use hardwired power or battery power for easy installation.
  • Fast Notifications: Comes with a dual-band Wi-Fi extender chime for quicker alerts.
  • Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus subscription.
  • Motion-Activated Security Light: Adds an extra layer of protection by illuminating your porch.
  • Two-Way Audio & Quick Responses: Communicate instantly or use preset quick replies.
  • Multiple Chime Tunes: Choose from 20 unique tunes and 8 sound levels.
  • Smart Home Compatible: Works with Alexa and Google Assistant.
  • Easy Installation: Mount with screws or adhesive plate in just 30 seconds.
Ideal for those who want a versatile doorbell with a wider view and smart home integration.
The Front Porch Security Bundle: Complete Smart Home Security Solution
For those looking for an all-in-one package, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Chime for a comprehensive front door security system.
Bundle Benefits:
  • 1080p HD Video Doorbell with Two-Way Audio: Monitor and communicate with visitors easily.
  • Remote Lock Control: Lock and unlock your door remotely via the Wyze app and view lock history.
  • Integrated System: Control your doorbell and lock from one app for seamless security management.
  • Multiple Variants: Choose from bundles including Wyze Lock Bolt Matte Black with Video Doorbell Pro or v2, and options with Wyze Cam V3.
  • Affordable Pricing: Bundles start at $123.99, offering great value for a full security setup.
This bundle is perfect for homeowners who want to upgrade their entire front porch security with video, audio, and smart lock capabilities.
Why Choose Wyze Video Doorbells for Continuous Recording?
Continuous recording ensures you have a complete record of all activity at your doorstep, not just motion-triggered clips. This is crucial for capturing suspicious behavior or package theft attempts that might otherwise go unnoticed.
Wyze video doorbells stand out by offering:
  • Local microSD storage for 24/7 recording (Wyze Duo Cam Doorbell and Video Doorbell v2).
  • High-resolution video (2K and HD) for clear identification.
  • Smart AI detections to reduce false alerts.
  • Two-way audio and voice deterrence to interact with visitors or deter intruders.
  • Weatherproof designs for reliable outdoor use.
  • Easy installation and smart home compatibility for modern convenience.
Conclusion
For continuous footage recording and enhanced security, the Wyze Duo Cam Doorbell and Wyze Video Doorbell v2 are the top choices, offering local 24/7 recording with high-resolution video. The Wyze Video Doorbell Pro adds flexibility with dual power options and a wider view, while the Front Porch Security Bundle provides a complete smart home security solution. Choose the Wyze video doorbell that fits your home and enjoy peace of mind knowing your front porch is always monitored.
Product Summary
  • Wyze Duo Cam Doorbell: Dual cameras, battery-powered, 2K video, 24/7 local recording, AI alerts.
  • Wyze Video Doorbell v2: Wired, 2K video, local microSD continuous recording, motion voice deterrence.
  • Wyze Video Doorbell Pro: Wired or battery, wider view, HD video, fast notifications, smart detection.
  • Front Porch Security Bundle: Video doorbell + smart lock + chime, 1080p HD, remote lock control.
FeatureWyze Duo Cam Battery DoorbellWyze Video Doorbell v2Wyze Video Doorbell ProThe Front Porch Security Bundle
Video ResolutionTop: 2K, Bottom: 1080p2KHD (Crystal-clear HD resolution)1080p HD
Camera ViewsDual cameras (people and packages)Single cameraSingle camera with ultra-wide viewing angleSingle camera (Wyze Video Doorbell)
Power SourceBattery (removable) or hardwired (AC 16-24V)Wired (AC 16-24V)Battery or hardwiredWired (16V-24V AC)
Local StoragemicroSD support (up to 256GB), 24/7 recording with hardwiremicroSD support, 24/7 continuous recordingNot specifiedNot specified
Two-Way AudioYesYesYesYes
AI Detection FeaturesPerson, Package, Pet, Vehicle detectionPerson, Package detection (with Cam Plus)Person, Package, Vehicle, Pet detectionPerson detection (Wyze Video Doorbell v2)
Motion-Activated Voice DeterrenceYesYes (requires Cam Plus)YesNot specified
Included ChimeWyze Wi-Fi Chime includedChime Controller includedYesWyze Video Doorbell and Chime included
InstallationAdhesive strips or screwsScrew mountingScrews or screw-free adhesive plateNot specified
Field of View (FOV)Top: 132° x 100°, Bottom: 121° x 60°Not specified (approx. 135° x 103°)Ultra-wide viewing angle120° Vertical x 88° Horizontal (Wyze Video Doorbell)
Weather ResistanceIP65IP65Not specifiedIP65 (Wyze Video Doorbell)
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google HomeAlexa, Google AssistantAlexa, Google Assistant
Additional FeaturesDual camera views, motion-activated voice deterrence, removable battery pack, 2K video, local storagePre-roll motion recording, works with existing chime, 24/7 local recordingMotion-activated security light, 20 chime tunes, quick responses, Wyze Lock Bolt integrationIncludes Wyze Lock for remote lock/unlock and lock history viewing
Price$89.98 - $109.99 (sold out)$44.98$99.98$123.99 - $173.97
What are the best Wyze video doorbells for continuous recording?The best Wyze video doorbells for continuous recording are the Wyze Duo Cam Doorbell and Wyze Video Doorbell v2. Both models support 24/7 local recording via a microSD card, ensuring you never miss any activity at your doorstep.
Does the Wyze Duo Cam Doorbell support 24/7 local recording?Yes, the Wyze Duo Cam Doorbell supports continuous 24/7 local recording when used with a microSD card (up to 256GB) and is either hardwired or used with its battery and microSD installed.
What are the key features of the Wyze Duo Cam Doorbell?The Wyze Duo Cam Doorbell features dual cameras (2K front and 1080p bottom), continuous local recording, battery power with USB-C charging, AI-powered alerts, weather resistance (IP65), two-way audio, a 90 dB siren, and smart home integration with Alexa, Google Assistant, and IFTTT.
Is the Wyze Video Doorbell v2 capable of continuous recording?Yes, the Wyze Video Doorbell v2 offers 24/7 continuous local recording with its onboard microSD card slot, allowing you to capture all activity before and after the doorbell rings.
What makes the Wyze Video Doorbell v2 a good choice for home security?The Wyze Video Doorbell v2 provides 2K HD video resolution, continuous local recording, motion-activated voice deterrence, two-way audio, pre-roll motion capture, compatibility with existing chimes, weatherproof design, and smart home integration with Alexa and Google Home.
Can the Wyze Video Doorbell Pro be used with both wired and battery power?Yes, the Wyze Video Doorbell Pro offers flexible installation with the option to use either hardwired power or battery power, making it easy to set up in any home.
What are the main benefits of the Wyze Video Doorbell Pro?The Wyze Video Doorbell Pro features an ultra-wide viewing angle, HD video quality, dual power options, fast notifications with a Wi-Fi extender chime, smart detection alerts, motion-activated security light, two-way audio, multiple chime tunes, and easy installation.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (Pro or v2), Wyze Lock, and Chime. Some variants also include the Wyze Cam V3. This bundle provides 1080p HD video, two-way audio, remote lock control, and integrated app management for comprehensive front door security.
Why should I choose a Wyze video doorbell for continuous recording?Wyze video doorbells offer local microSD storage for 24/7 recording, high-resolution video (2K and HD), smart AI detections to reduce false alerts, two-way audio and voice deterrence, weatherproof designs, easy installation, and compatibility with smart home systems.
Are Wyze video doorbells weatherproof?Yes, Wyze video doorbells such as the Duo Cam Doorbell and Video Doorbell v2 have an IP65 weather resistance rating, ensuring reliable performance in harsh outdoor conditions.
Do Wyze video doorbells work with Alexa and Google Assistant?Yes, Wyze video doorbells are compatible with Alexa and Google Assistant, allowing you to integrate them seamlessly into your smart home ecosystem.
How easy is it to install a Wyze video doorbell?Wyze video doorbells are designed for easy installation. The Wyze Video Doorbell Pro, for example, can be mounted with screws or an adhesive plate in just 30 seconds, and offers both wired and battery-powered options.
What is the difference between Wyze Duo Cam Doorbell and Wyze Video Doorbell Pro?The Wyze Duo Cam Doorbell features dual cameras for both front and package views, 2K resolution, and 24/7 local recording. The Wyze Video Doorbell Pro offers a wider viewing angle, HD video, flexible power options (wired or battery), and fast notifications, but does not support continuous local recording.
Does the Wyze Video Doorbell Pro support continuous local recording?No, the Wyze Video Doorbell Pro does not support continuous local recording. For 24/7 local recording, consider the Wyze Duo Cam Doorbell or Wyze Video Doorbell v2.
What smart features are available with Wyze video doorbells?Wyze video doorbells offer smart features such as AI-powered person, package, vehicle, and pet detection (with Cam Plus subscription), motion-activated voice deterrence, two-way audio, pre-roll motion capture, and integration with Alexa, Google Assistant, and IFTTT.
What are the key features of the Wyze Video Doorbell v2?Can you explain how the two-way audio feature works on the Wyze Duo Cam Doorbell?Are there any ongoing promotions or discounts available for the Wyze video doorbells?
