Hardwired Wyze Refurbished Doorbell with Two-Way Audio Feature
When it comes to securing your home entrance with a reliable, feature-rich doorbell, Wyze offers some of the best hardwired video doorbells equipped with two-way audio. Whether you want crystal-clear video, real-time communication with visitors, or seamless integration with your smart home, Wyze’s refurbished wired doorbells deliver exceptional value and performance.
Explore the top Wyze hardwired doorbell options with two-way audio, designed to keep your front porch safe and connected.
Wyze Video Doorbell v2: The Clear Choice for Wired Doorbell Security
Crisp 2K Video Quality and Local Storage
Wyze Video Doorbell v2 stands out with its impressive 2K resolution, providing crystal-clear head-to-toe video of your porch. Unlike many doorbells, it features a local microSD card slot for continuous 24/7 recording, so you never miss a moment before or after a doorbell press.
Two-Way Audio and Motion-Activated Voice Deterrence
Communicate instantly with visitors using the built-in two-way audio system via the Wyze app. The doorbell also offers motion-activated voice deterrence, which plays an automated warning to potential intruders, enhancing your home security.
Easy Integration with Existing Chimes
This wired doorbell includes a chime controller, allowing you to keep your traditional doorbell chime working without bypassing it. It’s compatible with most home chimes, preserving the classic ding-dong sound.
Weatherproof and Night Vision Ready
Rated IP65 for weather resistance, the Wyze Video Doorbell v2 withstands rain, snow, and harsh conditions. Its award-winning starlight sensor delivers vibrant color night vision, ensuring clear video even in low light.
Additional Features
- 30° corner mounting wedge included for optimal viewing angle
- Works with Alexa and Google Home for voice commands and live feed viewing
- Pre-roll motion recording captures 3-6 seconds before motion events
- Custom detection zones and quick preset responses for visitor communication
Experience superior porch security with Wyze Video Doorbell v2.
Wyze Video Doorbell (Wired): Compact and Efficient 1080p Solution
Full HD 1080p Video with Wide Field of View
The Wyze Video Doorbell (Wired) offers a smaller form factor without compromising on quality. It delivers full HD 1080p video with a 120° vertical by 88° horizontal field of view, capturing everything happening at your doorstep.
Two-Way Audio with Noise and Echo Cancellation
Stay connected with visitors through the built-in speaker and microphone, featuring noise and echo cancellation for clear conversations.
Wired Power and Weather Resistance
This doorbell is hardwired for continuous power and rated IP65 for weatherproof durability. It includes a chime but note that the existing mechanical chime will not work after installation.
Motion Detection and Night Vision
Detect motion events with reliable alerts and see clearly at night with infrared LEDs.
Small but mighty, this wired doorbell is perfect for those seeking a straightforward, dependable video doorbell with two-way audio.
The Front Porch Security Bundle: Complete Smart Home Entry Solution
All-in-One Porch Security with Video Doorbell and Smart Lock
For those wanting a comprehensive security upgrade, the Front Porch Security Bundle combines the Wyze Video Doorbell v2 with Wyze Lock Bolt Matte Black. This bundle lets you view your porch in 1080p HD, communicate via two-way audio, and remotely lock or unlock your door.
Smart Features and Integration
- View motion events and lock history in the Wyze app
- Works with Alexa and Google Assistant for voice control
- IP65 weather-resistant doorbell with 120° x 88° field of view
- Built-in speaker and microphone with noise and echo cancellation
Included Accessories for Easy Installation
The bundle comes with the Wyze Chime, wall plate, wedge for angled mounting, wire caps, extension wires, and more, making installation straightforward and hassle-free.
Secure your home entry with the all-in-one Front Porch Security Bundle.
Optional Accessory: Wyze Video Doorbell v2 Wedge Kit
Perfect Viewing Angle for Any Porch Layout
The Wyze Video Doorbell v2 Wedge Kit is designed to eliminate blind spots by adjusting the doorbell’s angle. It includes a 15° horizontal and two 7.5° vertical wedges, ideal for porches with stairs or angled door frames.
Durable and Weather-Resistant
Made from thick, heavy-duty plastic, this accessory is built to last outdoors and complements the Wyze Video Doorbell v2 perfectly.
Why Choose Wyze Hardwired Doorbells with Two-Way Audio?
- Reliable Wired Power: No need to worry about battery life or recharging.
- Clear Communication: Two-way audio lets you speak to visitors or delivery personnel from anywhere.
- Advanced Video Quality: From 1080p to 2K resolution, see every detail clearly.
- Smart Home Compatibility: Works seamlessly with Alexa and Google Assistant.
- Local and Cloud Storage Options: Keep your footage safe with microSD or cloud subscriptions.
- Weatherproof Design: Built to withstand all weather conditions for year-round security.
Wyze’s hardwired refurbished doorbells with two-way audio are an excellent choice for anyone looking to upgrade their home security with smart, dependable technology.
What are the main features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K resolution for crystal-clear video, local microSD card storage for 24/7 recording, two-way audio for real-time communication, motion-activated voice deterrence, compatibility with existing chimes, IP65 weather resistance, starlight color night vision, Alexa and Google Home integration, pre-roll motion recording, custom detection zones, and quick preset responses.Does the Wyze Video Doorbell v2 support two-way audio?
Yes, the Wyze Video Doorbell v2 features built-in two-way audio, allowing you to communicate instantly with visitors through the Wyze app.Can I use my existing doorbell chime with Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 includes a chime controller, making it compatible with most traditional home chimes so you can keep your classic ding-dong sound.Is the Wyze Video Doorbell v2 weatherproof?
Yes, the Wyze Video Doorbell v2 is rated IP65 for weather resistance, making it suitable for rain, snow, and harsh outdoor conditions.What is the difference between Wyze Video Doorbell v2 and Wyze Video Doorbell (Wired)?
The Wyze Video Doorbell v2 offers 2K resolution, local microSD storage, and compatibility with existing chimes, while the Wyze Video Doorbell (Wired) provides 1080p HD video, a compact design, and includes a chime (but disables your existing mechanical chime). Both models feature two-way audio, motion detection, night vision, and IP65 weather resistance.Does the Wyze Video Doorbell (Wired) have two-way audio?
Yes, the Wyze Video Doorbell (Wired) includes two-way audio with noise and echo cancellation for clear conversations with visitors.Can I use the Wyze Video Doorbell (Wired) with my existing mechanical chime?
No, after installing the Wyze Video Doorbell (Wired), your existing mechanical chime will not work. However, the doorbell comes with its own chime.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock Bolt Matte Black, Wyze Chime, wall plate, mounting wedge, wire caps, extension wires, and other accessories for easy installation. It provides video monitoring, two-way audio, and smart lock control for comprehensive porch security.Is the Wyze Video Doorbell compatible with Alexa and Google Assistant?
Yes, both the Wyze Video Doorbell v2 and Wyze Video Doorbell (Wired) work with Alexa and Google Assistant for voice commands and live video feed viewing.Does Wyze offer local storage for video recordings?
Yes, the Wyze Video Doorbell v2 supports local storage via a microSD card for continuous 24/7 recording. Both models also offer cloud storage options.What is the Wyze Video Doorbell v2 Wedge Kit and what does it do?
The Wyze Video Doorbell v2 Wedge Kit is an accessory that helps you adjust the doorbell’s angle for the perfect viewing position. It includes a 15° horizontal wedge and two 7.5° vertical wedges, ideal for porches with stairs or angled door frames. The kit is made from durable, weather-resistant plastic.Why should I choose a hardwired Wyze doorbell with two-way audio?
Hardwired Wyze doorbells with two-way audio provide reliable power without battery concerns, clear communication with visitors, advanced video quality (1080p to 2K), smart home compatibility, local and cloud storage options, and weatherproof design for year-round security.
