Outdoor Security Cameras with Solar Panel & Continuous Power
Outdoor Security Cameras with Solar Panel Compatibility for Uninterrupted Use
When it comes to securing your home outdoors, having a reliable security camera that can operate continuously without frequent battery changes or power interruptions is essential. Solar panel compatibility or alternative power solutions ensure your cameras stay active day and night, rain or shine. Below, we explore the best Wyze outdoor security camera options designed for uninterrupted use, highlighting their specs, power options, and smart features.
Wyze Cam v4: Crystal-Clear Wired Security with Continuous Power
The Wyze Cam v4 is a wired outdoor security camera that delivers unmatched clarity and reliability. While it requires a wired power source, it offers exceptional video quality and smart features that make it a top choice for outdoor surveillance.
Key Features:
  • 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and sharp details.
  • Enhanced Color Night Vision: See more at night with color footage instead of traditional black and white.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected to deter intruders.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection even at greater distances.
  • 24/7 Local Recording: Supports microSD cards up to 512GB for continuous local storage.
  • Smart Alerts: Detects motion, sound, smoke, and CO alarms with instant notifications.
  • Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Power and Installation:
  • Requires a wired power adapter for continuous operation.
  • For outdoor use, the Wyze Outdoor Power Adapter is sold separately.
  • Compatible with the Wyze Lamp Socket v2, enabling power through existing outdoor light fixtures, eliminating the need for additional outlets or wiring.
The Wyze Cam v4 is perfect for homeowners who want high-resolution, always-on security with smart home integration.
Outdoor security camera mounted on home exterior at dusk Alt text: Outdoor security camera with night vision mounted on house exterior
Wyze Lamp Socket v2: Power Your Wyze Cams via Outdoor Light Fixtures
For those seeking solar panel compatibility alternatives or easier power solutions, the Wyze Lamp Socket v2 is a game-changer. It allows you to power compatible Wyze cameras directly from your existing outdoor light sockets, providing continuous power without the hassle of extra wiring or outlets.
Compatible Cameras:
  • Wyze Cam v3 / v3 Pro
  • Wyze Cam v4
  • Wyze Cam OG
  • Wyze Cam Pan v3
Benefits:
  • No Outlet Needed: Powers your camera through your outdoor light fixture.
  • Motion-Activated Lighting: Lights turn on automatically when the camera detects motion.
  • Dusk to Dawn Automation: Schedule your lights to operate only when needed, saving energy.
  • Link Multiple Sockets: Control multiple lamp sockets and cameras from the Wyze app for comprehensive coverage.
  • Easy Installation: Simply screw it into your existing E26 lamp socket like a lightbulb.
This solution is ideal for users wanting uninterrupted camera power without complex installations or solar panels.
Cam v4 + Lamp Socket v2 Bundle: Smart Lighting Meets Continuous Power
For a seamless setup, the Cam v4 + Lamp Socket v2 Bundle combines the high-performance Wyze Cam v4 with the convenience of the Lamp Socket v2. This bundle is designed to power your camera through your outdoor light fixture, ensuring uninterrupted operation and smart lighting control.
Bundle Highlights:
  • All the advanced features of Wyze Cam v4 (2.5K QHD, color night vision, motion spotlight).
  • Lamp Socket v2 powers the camera without an outlet.
  • Motion-activated lights enhance security and visibility.
  • Compatible with multiple Wyze cameras for flexible setups.
  • Easy to install and manage via the Wyze app.
This bundle is perfect for those who want a reliable, wired-quality camera powered smartly through existing outdoor lighting.
Why Choose Wyze for Outdoor Security with Solar or Alternative Power?
Wyze offers a unique ecosystem of cameras and accessories that provide flexible power options, including solar panel compatibility through indirect means like the Lamp Socket v2. While Wyze cameras themselves do not come with built-in solar panels, the Lamp Socket v2 allows you to harness existing outdoor lighting power, which can be supplemented by solar-powered light fixtures in your home.
Additional Advantages:
  • Weather Resistance: Wyze Cam v4 and compatible accessories are rated IP65, suitable for outdoor conditions.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Affordable Security: High-end features at budget-friendly prices.
  • Expandable Systems: Combine cameras with doorbells, locks, and sensors for full home security.
Home exterior with smart outdoor lighting and security camera Alt text: Home exterior with smart outdoor lighting and security camera installed
Summary: Best Outdoor Security Cameras with Solar Panel Compatibility Alternatives
ProductPower SolutionVideo QualityNight VisionSmart FeaturesPrice Range
Wyze Cam v4Wired (Outdoor Power Adapter or Lamp Socket v2)2.5K QHDColor Night VisionMotion spotlight, Alexa/Google$100 - $170
Wyze Lamp Socket v2Powers cameras via light socketN/AN/AMotion-activated lights, scheduling$50
Cam v4 + Lamp Socket v2 BundleCombined wired + lamp socket2.5K QHDColor Night VisionMotion lights, app control~$220
For uninterrupted outdoor security, pairing Wyze Cam v4 with the Lamp Socket v2 offers a practical alternative to solar panels, ensuring your cameras stay powered and your home stays protected.
Frequently Asked Questions
Can Wyze cameras be powered directly by solar panels?
Wyze cameras do not have built-in solar panel compatibility, but you can use solar-powered outdoor light fixtures combined with the Wyze Lamp Socket v2 to indirectly power your cameras.
Is the Lamp Socket v2 weatherproof?
The Lamp Socket v2 is not fully weatherproof but is suitable for damp outdoor locations such as covered porches or light fixtures.
What is the benefit of using the Lamp Socket v2 over traditional wiring?
It eliminates the need for additional outlets or complex wiring by using your existing outdoor light socket to power your camera and smart lighting.
Protect your home with Wyze’s innovative outdoor security solutions that combine high-quality video, smart features, and flexible power options for uninterrupted surveillance.
FeaturePan v3 + Lamp Socket v2 BundleCam v4 + Lamp Socket v2 BundleWyze Cam v4 Home Security Bundle
Product TypeBundleBundleBundle
Included DevicesWyze Cam Pan v3 + Lamp Socket v2Wyze Cam v4 + Lamp Socket v2Wyze Cam v4
Camera Colors AvailableBlack, WhiteBlack, Grey, WhiteDefault (no color variants specified)
Price$53.96$49.96$169.99
Compare at Price$56.96$52.96$211.88
Camera ResolutionNot specified (Pan v3 camera)Not specified (Cam v4 camera)2.5K QHD (2560x1440)
Camera Features360° pan, 180° tilt, IP65 weather resistantEnhanced Color Night Vision, motion-activated spotlightEnhanced Color Night Vision, motion-activated spotlight
Lamp Socket CompatibilityPowers Pan v3 without outletPowers Cam v4 without outletNot included
Device Compatibility (Lamp Socket v2)Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Cam Pan v3Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Cam Pan v3N/A
Smart Lighting FeaturesMotion-activated lights, dusk to dawn automation, app controlMotion-activated lights, dusk to dawn automation, app controlN/A
InstallationAs easy as screwing in a lightbulbAs easy as screwing in a lightbulbN/A
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
WarrantyNot specifiedNot specified1 Year
Can Wyze outdoor security cameras be powered by solar panels?Wyze outdoor security cameras do not have built-in solar panel compatibility. However, you can use solar-powered outdoor light fixtures in combination with the Wyze Lamp Socket v2 to indirectly power your cameras, providing a practical alternative to direct solar panel use.
What is the Wyze Lamp Socket v2 and how does it power outdoor cameras?The Wyze Lamp Socket v2 is an accessory that allows you to power compatible Wyze cameras directly from your existing outdoor light fixtures. Simply screw it into an E26 lamp socket, and it provides continuous power to your camera without the need for extra outlets or complex wiring.
Which Wyze cameras are compatible with the Lamp Socket v2?The Wyze Lamp Socket v2 is compatible with Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, Wyze Cam OG, and Wyze Cam Pan v3, allowing flexible installation options for various outdoor security needs.
Is the Wyze Lamp Socket v2 weatherproof for outdoor use?The Wyze Lamp Socket v2 is not fully weatherproof but is suitable for damp outdoor locations such as covered porches or protected light fixtures. It is designed to withstand typical outdoor conditions when installed in appropriate fixtures.
What are the benefits of using the Wyze Lamp Socket v2 over traditional wiring for outdoor cameras?Using the Wyze Lamp Socket v2 eliminates the need for additional electrical outlets or complex wiring. It powers your camera through your existing outdoor light socket, offers motion-activated lighting, dusk-to-dawn automation, and easy installation, making it a convenient and efficient power solution.
Does the Wyze Cam v4 require a wired power source for outdoor use?Yes, the Wyze Cam v4 requires a wired power adapter for continuous operation outdoors. It can be powered using the Wyze Outdoor Power Adapter or through the Wyze Lamp Socket v2, which utilizes your existing outdoor light fixtures.
What smart features does the Wyze Cam v4 offer for outdoor security?The Wyze Cam v4 offers 2.5K Quad HD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording with microSD support, smart alerts for motion, sound, smoke, and CO alarms, and compatibility with Alexa, Google Assistant, and IFTTT.
Are Wyze outdoor security cameras weather resistant?Yes, Wyze Cam v4 and its compatible accessories are rated IP65, making them suitable for outdoor use and resistant to various weather conditions.
What is included in the Cam v4 + Lamp Socket v2 bundle?The Cam v4 + Lamp Socket v2 bundle includes the high-performance Wyze Cam v4 and the Lamp Socket v2. This combination allows you to power your camera through your outdoor light fixture, providing uninterrupted operation and smart lighting control.
Can I control multiple Wyze cameras and lamp sockets from one app?Yes, you can control multiple Wyze cameras and Lamp Socket v2 devices from the Wyze app, allowing for comprehensive coverage and easy management of your outdoor security system.
What are the key features of the Wyze Cam v4?How does the Wyze Lamp Socket v2 work with outdoor security cameras?Do you have any deals, ongoing sales, discounts, or promotions available?
