Best Wyze Cam Window Mounts for Clear Outdoor Security
Best Way to Secure a Wyze Cam Behind Glass for a Clear Outdoor View
When it comes to securing your Wyze Cam behind glass for an unobstructed outdoor view, the Wyze Window Mount is the ultimate accessory designed specifically for this purpose. This guide will walk you through the best products and methods to achieve a clear, glare-free view while maintaining robust outdoor security.
Wyze Window Mount: Perfect for Glass Surfaces
Clear, Glare-Free Outdoor Monitoring
The Wyze Window Mount is engineered to attach your Wyze Cam (v3, v3 Pro, v4, OG, or OG Telephoto) directly to any glass surface such as windows or glass doors. This mounting solution eliminates common issues like glare and reflections that typically occur when cameras are placed behind glass.
  • Compatibility: Works seamlessly with Wyze Cam v3, v3 Pro, v4, OG, and OG Telephoto models.
  • Installation: Simple and secure attachment to glass surfaces without drilling or permanent fixtures.
  • View Quality: Provides a crystal-clear outdoor view by minimizing glare and reflection, ensuring your camera captures every detail accurately.
  • Use Case: Ideal for smart home security setups where outdoor cameras need to be discreetly mounted behind windows.
Mounting your Wyze Cam behind glass with this accessory upgrades your exterior security while maintaining a clean, unobstructed view.
Wyze Cam v4 Outdoor Bundle: Advanced Outdoor Security
High-Resolution, Smart Features for Outdoor Use
For those looking to enhance their outdoor security beyond just mounting, the Wyze Cam v4 Outdoor Bundle offers a powerful camera with advanced features:
  • Resolution: Stunning 2.5K QHD for crystal-clear video quality.
  • Night Vision: Enhanced Color Night Vision ensures visibility even in low-light conditions.
  • Motion-Activated Spotlight: Adds an extra layer of security by illuminating motion events.
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable streaming.
  • Compatibility: Works with Alexa and Google Assistant for voice control.
  • Recording: 24/7 local recording with included 128GB microSD card.
  • Outdoor Ready: Designed for outdoor use with weather resistance.
This bundle is perfect for users who want a comprehensive outdoor security solution that can be mounted behind glass using the Wyze Window Mount or installed outdoors directly. Outdoor Security Camera Mounted on Window
Cam v4 + Lamp Socket v2 Bundle: Power Your Camera Anywhere
Convenient Power Solution for Outdoor Cameras
If powering your Wyze Cam v4 is a concern, especially when mounting behind glass near outdoor lighting fixtures, the Cam v4 + Lamp Socket v2 Bundle is an excellent choice:
  • Power Source: Plugs into standard E26 lamp sockets, eliminating the need for traditional power outlets.
  • Smart Lighting: Includes motion-activated lights and dusk-to-dawn scheduling.
  • Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Materials: Durable polycarbonate and plastic construction.
  • Weather Suitability: Suitable for damp locations (not fully weatherproof).
  • Connectivity: Works with 2.4GHz Wi-Fi and Bluetooth.
This bundle allows you to power your camera discreetly and efficiently, making it ideal for window-mounted setups where power outlets are not easily accessible.
Tips for Securing Wyze Cam Behind Glass for Optimal Outdoor View
  • Use the Wyze Window Mount: This accessory is specifically designed to reduce glare and reflections when mounting cameras behind glass.
  • Disable IR Lights if Needed: Infrared lights can cause glare on glass. The Wyze Cam Outdoor allows you to toggle IR lights off to reduce this effect.
  • Positioning: Place the camera as close to the glass as possible using the window mount to minimize distortion.
  • Clean Glass Surface: Ensure the glass is clean and free of smudges for the clearest image.
  • Power Considerations: Use the Cam v4 + Lamp Socket v2 Bundle for convenient power solutions near windows without external outlets.
By combining the Wyze Window Mount with the right Wyze Cam model and power accessories, you can achieve a clear, secure, and smart outdoor monitoring system.
Summary of Recommended Products for Window-Mounted Wyze Cam Security
Product NameKey FeaturesPrice (USD)
Wyze Window MountGlass mounting, glare-free, compatible with multiple Wyze Cam models9.98
Wyze Cam v4 Outdoor Bundle2.5K QHD, color night vision, motion spotlight, 24/7 recording69.99
Cam v4 + Lamp Socket v2 BundlePowers Wyze Cam via lamp socket, motion-activated lights49.96
Smart Home Outdoor Security
Why Choose Wyze for Your Outdoor Window-Mounted Camera?
Wyze offers a comprehensive ecosystem of cameras and accessories designed to work together seamlessly. The Wyze Window Mount is a standout accessory that solves the common problem of glare and reflection when mounting cameras behind glass. Coupled with the Wyze Cam v4 Outdoor Bundle and power solutions like the Lamp Socket v2 Bundle, you get a smart, reliable, and easy-to-install outdoor security system.
Secure your home with confidence and enjoy crystal-clear outdoor views through your windows with Wyze’s innovative mounting and camera solutions.
FeatureWyze Window MountWyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 Bundle
Product TypeAccessoryCamera BundleBundle (Camera + Lamp Socket)
Compatible CamerasWyze Cam v3, v3 Pro, v4, OG, OG TelephotoWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Price$9.98$69.99$49.96
MountingWindow (glass surface)Included camera with mounting options (stand, wall, ceiling, magnetic)Included camera + lamp socket (E26 socket)
Camera ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440) (Cam v4 included)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision (Cam v4 included)
SpotlightN/AMotion-activated spotlightMotion-activated spotlight (Cam v4 included)
PowerN/AWired, includes power adapterLamp socket powers Cam v4 without outlet
Weather ResistanceN/AIP65 ratedLamp socket: Not weatherproof, suitable for damp locations
ConnectivityN/A2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Bluetooth (Lamp socket)
DimensionsNot specifiedCamera: 2in x 2in x 2 3/8inLamp Socket: 56.5mm x 56.5mm x 65mm
WeightNot specifiedCamera: 0.49 lb (222 g)Lamp Socket: 80 g
Additional FeaturesReduces glare, clear view through glass24/7 local recording, Alexa & Google Assistant compatibleMotion-activated lights, dusk to dawn scheduling
WarrantyNot specified1 Year1 Year
What is the best way to mount a Wyze Cam behind glass for outdoor security?The best way to mount a Wyze Cam behind glass is by using the Wyze Window Mount. This accessory is specifically designed to attach your Wyze Cam (v3, v3 Pro, v4, OG, or OG Telephoto) directly to glass surfaces, such as windows or glass doors, providing a clear, glare-free outdoor view.
Which Wyze Cam models are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, OG, and OG Telephoto models, making it a versatile solution for various Wyze cameras.
How does the Wyze Window Mount reduce glare and reflections?The Wyze Window Mount is engineered to minimize glare and reflections by securing the camera directly against the glass, ensuring a crystal-clear view and accurate outdoor monitoring.
Can I use the Wyze Cam v4 Outdoor Bundle behind glass?Yes, the Wyze Cam v4 Outdoor Bundle can be mounted behind glass using the Wyze Window Mount. This setup allows you to take advantage of the camera’s 2.5K QHD resolution, color night vision, and motion-activated spotlight while maintaining a clear view through your window.
What are the power options for mounting a Wyze Cam behind glass?If you need a convenient power solution near a window, the Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 using a standard E26 lamp socket. This eliminates the need for traditional power outlets and is ideal for window-mounted setups.
How do I prevent glare from infrared lights when using a Wyze Cam behind glass?To prevent glare from infrared (IR) lights, you can disable the IR lights on your Wyze Cam. This is especially useful when mounting the camera behind glass, as IR lights can reflect off the surface and obscure the image.
What tips can help achieve the clearest outdoor view with a Wyze Cam behind glass?For the clearest outdoor view, use the Wyze Window Mount to position the camera as close to the glass as possible, disable IR lights if needed, and ensure the glass surface is clean and free of smudges.
Is the Cam v4 + Lamp Socket v2 Bundle weatherproof for outdoor use?The Cam v4 + Lamp Socket v2 Bundle is suitable for damp locations but is not fully weatherproof. It is designed for use in areas protected from direct exposure to the elements, such as under eaves or inside enclosed fixtures.
Why should I choose Wyze for window-mounted outdoor security cameras?Wyze offers a comprehensive ecosystem of cameras and accessories, including the Wyze Window Mount, which is specifically designed to solve glare and reflection issues when mounting cameras behind glass. Combined with advanced camera features and convenient power solutions, Wyze provides a smart, reliable, and easy-to-install outdoor security system.
What are the key features of the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle features 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 connectivity, compatibility with Alexa and Google Assistant, 24/7 local recording with a 128GB microSD card, and weather resistance for reliable outdoor use.
How do I install the Wyze Window Mount securely on my glass surface?Can the Wyze Cam v4 be used with the Wyze Window Mount?What are the benefits of using the Wyze Cam v4 Outdoor Bundle for outdoor security?
