20ft Wyze Cam USB Extension Cable for Stable Outdoor Power
Enhance Your Wyze Cam Setup with a 20ft USB Extension Cable
When it comes to securing your home or monitoring your surroundings with Wyze Cam, cable length and power stability are crucial—especially in unpredictable weather conditions. The Wyze Cam USB Extension Cable - 20ft is designed to give you the freedom to place your camera exactly where you need it without worrying about short cables or unstable power connections.
Why Choose the Wyze Cam USB Extension Cable - 20ft?
  • Extended Reach: Say goodbye to the limitations of short cables. This 20ft USB extension cable allows you to position your Wyze Cam far from power outlets, perfect for outdoor or hard-to-reach indoor locations.
  • Wide Compatibility: Works seamlessly with a variety of Wyze Cam models including v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto.
  • Stable Power Supply: Ensures consistent power delivery to your camera, helping to maintain uninterrupted video streaming and recording even during adverse weather conditions.
  • Affordable and Reliable: At just $7.99, it’s a cost-effective solution to enhance your Wyze Cam’s performance and placement flexibility.
With this extension cable, you can confidently install your Wyze Cam in locations that were previously unreachable, ensuring your security system is both effective and weather-resilient.
Complement Your Setup with Wyze Cam v4 Outdoor Bundle
For those looking to maximize outdoor security, the Wyze Cam v4 Outdoor Bundle is an excellent companion to the USB extension cable. This bundle offers advanced features that keep your home safe and your camera powered reliably.
Key Features of Wyze Cam v4 Outdoor Bundle
  • 2.5K QHD Resolution: Crystal-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See vibrant colors even in low light conditions.
  • Motion-Activated Spotlight: Deters intruders and illuminates your property automatically.
  • 24/7 Local Recording: Continuous recording with included 128GB microSD card.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
  • Smart Home Compatibility: Works with Alexa and Google Assistant for voice control.
  • Weatherproof Design: Built to withstand rain, snow, and other harsh weather conditions.
  • Includes Wyze Outdoor Power Adapter: Ensures stable power supply outdoors.
Pairing this outdoor bundle with the 20ft USB extension cable means you can install your camera exactly where you need it, with a reliable power source that won’t falter in unpredictable weather. Outdoor Security Camera in Use Alt text: Wyze Cam v4 installed outdoors with stable power connection
Additional Wyze Accessories for Optimal Performance
While the 20ft USB extension cable is perfect for extending power reach, consider these accessories and bundles to enhance your Wyze Cam experience:
  • Combines Wyze Bird Feeder with Wyze Cam v4 and Outdoor Power Adapter.
  • Designed for birdwatching enthusiasts with weather-resistant features.
  • Easy installation with multiple mounting options.
  • Compatible with Wyze Solar Panel for battery-powered setups.
This bundle is ideal if you want to monitor wildlife or add a charming touch to your outdoor space while maintaining reliable camera power.
Whole Home Security Starter Kit
  • Includes Wyze Cam v4, Video Doorbell v2, and Home Monitoring Starter Kit.
  • Provides comprehensive home security with easy setup.
  • Available in multiple colors to match your home decor.
Conclusion: Secure Your Wyze Cam with the Right Cable
Unpredictable weather and limited power outlet locations should never compromise your home security. The Wyze Cam USB Extension Cable - 20ft is an essential accessory that stabilizes your camera’s power supply and extends its placement options. When combined with the Wyze Cam v4 Outdoor Bundle, you get a powerful, weather-resistant security solution that keeps your home safe and monitored around the clock. Invest in the right accessories today to ensure your Wyze Cam performs at its best, no matter the weather or location challenges.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor BundleBird Feeder Plug-in Cam v4 BundleWhole Home Security Starter Kit
Product TypeAccessorySecurity Camera BundleBundle (Bird Feeder + Cam v4 + Power Adapter)Security Kit Bundle
Price$7.99 USD$69.99 USD$89.98 USD$155.95 USD
Included Items20ft USB Extension Cable1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x 128GB MicroSD CardWyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power Adapter1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit
Camera ResolutionN/A2.5K QHD (2560x1440)Wyze Cam v4 (2.5K QHD)Wyze Cam v4 (2.5K QHD)
Night VisionN/AEnhanced Color Night VisionCompatible with Wyze Cam v4 night visionWyze Cam OG with color night vision
Weather ResistanceN/AIP65Weather-resistant for all seasonsIP65 (Wyze Cam OG)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Compatible with Wyze Battery Cam Pro, Cam v3, Cam v4, Cam Outdoor v1/v2Wyze Cam Pan v3, Wyze Cam OG
Power Adapter IncludedNoYes (Outdoor Power Adapter)Yes (Wyze Outdoor Power Adapter)No
StorageN/A128GB MicroSD Card includedDepends on Wyze Cam v4 includedLocal and cloud storage options
Special FeaturesExtends USB cable length to 20ftMotion-activated spotlight, Wi-Fi 6 support, Alexa/Google Assistant compatibleBird feeder with macro lens adapter, multiple mounting optionsIncludes Video Doorbell v2, Lock Bolt, Pan v3 camera, 2x Wyze Cam OG
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountWall, tree, pole, cord, suction cupVarious (depends on included devices)
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specifiedNot specified
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to place your camera farther from power outlets. This is especially useful for outdoor installations or hard-to-reach indoor locations, ensuring stable power delivery and uninterrupted camera operation.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with a wide range of Wyze Cam models, including Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto.
How does the Wyze Cam USB Extension Cable improve power stability?The Wyze Cam USB Extension Cable ensures consistent and stable power delivery to your camera, which helps maintain uninterrupted video streaming and recording, even during adverse weather conditions.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is ideal for outdoor use, especially when paired with weatherproof Wyze Cam models and the Wyze Outdoor Power Adapter. It allows you to install your camera in locations that are far from indoor power outlets while maintaining a stable power connection.
What are the benefits of the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle offers advanced security features such as 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with a 128GB microSD card, Wi-Fi 6 support, smart home compatibility with Alexa and Google Assistant, and a weatherproof design. It also includes a Wyze Outdoor Power Adapter for reliable outdoor power.
Can I use the 20ft USB extension cable with the Wyze Cam v4 Outdoor Bundle?Yes, pairing the 20ft USB extension cable with the Wyze Cam v4 Outdoor Bundle allows you to install your camera exactly where you need it, ensuring a reliable power source and optimal security coverage.
Are there other Wyze accessories that enhance camera performance?Yes, Wyze offers additional accessories such as the Bird Feeder Plug-in Cam v4 Bundle, which is perfect for birdwatching and outdoor monitoring, and the Whole Home Security Starter Kit, which provides comprehensive home security with easy setup and multiple color options.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it a cost-effective solution to enhance your Wyze Cam’s placement flexibility and power stability.
Why is a USB extension cable important for Wyze Cam outdoor installations?A USB extension cable is important for Wyze Cam outdoor installations because it allows you to position your camera in optimal locations for security and monitoring, even if power outlets are far away. It also helps maintain a stable power supply, which is crucial for continuous operation in unpredictable weather.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze Cam v4 Outdoor Bundle along with the USB extension cable?What is the return policy for the Wyze Cam USB Extension Cable?
