20ft Wyze Cam USB Extension Cable for Homes With Few Outlets
Extend Your Wyze Cam Setup with a 20ft USB Extension Cable
If you have a Wyze Cam and are dealing with limited power outlets in your home, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory allows you to extend the reach of your Wyze Cam’s power cable by 20 feet, giving you the flexibility to place your camera exactly where you need it without worrying about proximity to an outlet.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Length: A generous 20-foot cable length to overcome outlet limitations in your home.
  • Ease of Use: Simply plug it in between your camera’s USB cable and power source to extend your setup.
  • Affordable: Priced at $7.99, it’s a cost-effective way to enhance your camera placement options.
This cable is ideal for indoor use where outlets are scarce or inconveniently located, allowing you to monitor your home more effectively.
Replacement and Specialized USB Cables for Wyze Cam Models
For users with specific Wyze Cam models, such as the Pan v3, there is a dedicated Wyze Cam Pan v3 USB Cable available. This replacement cable ensures your Pan v3 camera stays powered without hassle.
Wyze Cam Pan v3 USB Cable Highlights
  • Designed for Pan v3: Perfect replacement or spare cable for Wyze Cam Pan v3.
  • Affordable: At just $1.99, it’s an economical choice for maintaining your camera’s power connection.
  • Reliable: Ensures consistent power delivery to keep your camera running smoothly.
This cable is a great backup or replacement option if your original cable is damaged or too short.
Innovative Power Solutions: Lamp Socket Bundles for Outlet-Free Power
If your home has very limited outlets or you want to power your Wyze Cam outdoors or in hard-to-reach places, consider the Cam v4 + Lamp Socket v2 Bundle or the Pan v3 + Lamp Socket v2 Bundle. These bundles allow you to power your Wyze Cam directly from a lamp socket, eliminating the need for a traditional power outlet.
Cam v4 + Lamp Socket v2 Bundle Features
  • Outlet-Free Power: Powers Wyze Cam v4 using a standard E26 lamp socket.
  • Smart Lighting: Includes motion-activated lights and dusk-to-dawn scheduling.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Durable Design: Made from polycarbonate and plastic, suitable for damp locations (not fully weatherproof).
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for easy setup.
  • Warranty: Comes with a 1-year warranty for peace of mind.
Pan v3 + Lamp Socket v2 Bundle Highlights
  • Same great features as the Cam v4 bundle but tailored for Wyze Cam Pan v3.
  • Color Options: Available in white and black to match your home decor.
  • Easy Installation: Simply screw into any standard lamp socket to power your camera.
These bundles are perfect for users who want to install cameras in locations without nearby outlets, such as porches, garages, or other indoor/outdoor transitional spaces.
Why Choose Wyze Cam Accessories for Your Home?
"Maximize your Wyze Cam’s potential with accessories designed for flexibility and convenience."
Using the 20ft USB extension cable or lamp socket bundles allows you to overcome common installation challenges like limited outlets or inconvenient power locations. Whether you want to extend your camera’s reach indoors or power it through a lamp socket, Wyze offers smart, affordable solutions to keep your home secure and monitored.
Summary of Recommended Products for Limited Outlet Setups
Product NamePurposePriceCompatibility
Wyze Cam USB Extension Cable - 20ftExtend USB power cable length$7.99Wyze Cam v2/v3/v4, Pan v2/v3, OG
Wyze Cam Pan v3 USB CableReplacement USB cable$1.99Wyze Cam Pan v3
Cam v4 + Lamp Socket v2 BundlePower Cam v4 via lamp socket$49.96Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Pan v3 + Lamp Socket v2 BundlePower Pan v3 via lamp socket$53.96Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Wyze Cam in Living Room Setup Alt text: Wyze Cam mounted in a living room with extended cable for flexible placement
Enhance your home security setup with the freedom to place your Wyze Cam exactly where you need it, even in rooms with limited power outlets.
Optimize your Wyze Cam experience today by choosing the right accessories to fit your home’s unique power setup. Whether it’s the 20ft USB extension cable or the innovative lamp socket bundles, Wyze has you covered for flexible, reliable camera power solutions.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam Pan v3 USB CableCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 Bundle
TypeAccessoriesReplacement PartsBundleBundle
Price$7.99$1.99$49.96$53.96
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam Pan v3Wyze Cam v3, v3 Pro, v4, OG, Pan v3Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Cable Length20 ft USB extensionReplacement USB cable (length not specified)Included (not specified)Included (not specified)
Lamp Socket Connector TypeN/AN/AE26E26
Power InputN/AN/A120V~, 60Hz120V~, 60Hz
Max Lamp PowerN/AN/A20W20W
MaterialsN/AN/APolycarbonate, PlasticPolycarbonate, Plastic
DimensionsN/AN/A56.5mm x 56.5mm x 65mm56.5mm x 56.5mm x 65mm
WeightN/AN/A80 g80 g
FeaturesExtends USB cable length for Wyze CamsReplacement USB cable for Wyze Cam Pan v3Powers Cam v4 without outlet, motion-activated lights, linkability, dusk to dawn schedulingPowers Pan v3 without outlet, motion-activated lights, linkability, dusk to dawn scheduling
Weather ResistanceN/AN/ANot weatherproof, suitable for damp locationsNot weatherproof, suitable for damp locations
Warranty30-day hassle-free returns30-day hassle-free returns1-Year1-Year
What is the Wyze Cam USB Extension Cable - 20ft and how does it work?The Wyze Cam USB Extension Cable - 20ft is an accessory designed to extend the reach of your Wyze Cam’s power cable by 20 feet. Simply plug it between your camera’s USB cable and the power source to place your camera further from an outlet, providing more flexibility in camera placement.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
Is the Wyze Cam USB Extension Cable - 20ft suitable for outdoor use?The Wyze Cam USB Extension Cable - 20ft is ideal for indoor use, especially in areas where outlets are scarce or inconveniently located. For outdoor use, ensure the cable and connections are protected from weather exposure.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it a cost-effective solution for extending your camera’s power reach.
What is the Wyze Cam Pan v3 USB Cable and when should I use it?The Wyze Cam Pan v3 USB Cable is a replacement or spare cable specifically designed for the Wyze Cam Pan v3. It ensures reliable power delivery and is ideal if your original cable is damaged or too short.
How much does the Wyze Cam Pan v3 USB Cable cost?The Wyze Cam Pan v3 USB Cable is priced at just $1.99, making it an economical choice for maintaining your camera’s power connection.
What are the benefits of the Cam v4 + Lamp Socket v2 Bundle?The Cam v4 + Lamp Socket v2 Bundle allows you to power your Wyze Cam v4 directly from a standard E26 lamp socket, eliminating the need for a traditional power outlet. It also features motion-activated lights, dusk-to-dawn scheduling, and is compatible with several Wyze Cam models.
Which Wyze Cam models are compatible with the Lamp Socket v2 Bundles?The Lamp Socket v2 Bundles are compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
Are the Lamp Socket v2 Bundles weatherproof?The Lamp Socket v2 Bundles are made from durable polycarbonate and plastic and are suitable for damp locations, but they are not fully weatherproof. For outdoor use, ensure the installation is protected from direct exposure to the elements.
What color options are available for the Pan v3 + Lamp Socket v2 Bundle?The Pan v3 + Lamp Socket v2 Bundle is available in both white and black, allowing you to match your home decor.
How do I install the Lamp Socket v2 Bundle for my Wyze Cam?Installation is easy—simply screw the Lamp Socket v2 into any standard E26 lamp socket, connect your compatible Wyze Cam, and follow the setup instructions for power and connectivity.
Why should I use Wyze Cam accessories like extension cables and lamp socket bundles?Wyze Cam accessories such as the 20ft USB extension cable and lamp socket bundles help you overcome installation challenges like limited or inconveniently located outlets. They provide flexible, reliable power solutions, allowing you to place your cameras exactly where you need them for optimal home security.
Can you tell me more about the compatibility of the 20ft USB extension cable with different Wyze Cam models?What are the benefits of using the lamp socket bundles for powering Wyze Cams?Are there any ongoing promotions or discounts for Wyze Cam accessories?
