LED Strips with Sun Match for Natural Daily Light Cycles
LED Strips with Sun Match Feature for Natural Daily Light Cycles
Experience the perfect harmony of technology and nature with Wyze’s LED lighting solutions that feature the innovative Sun Match technology. Designed to mimic natural sunlight throughout the day, these smart LED strips and bulbs help regulate your circadian rhythm by adjusting color temperature automatically, bringing the outdoors inside your home. Whether you want to brighten your living space with vibrant colors or create a natural daylight ambiance that supports your daily wellness, Wyze offers versatile lighting products tailored to your needs.
Wyze Light Strip: Brilliant Accent Lighting with Sun Match
Natural Light Simulation for Your Home
The Wyze Light Strip is a 16.4 or 32.8 feet LED strip that delivers 16 million colors and a single customizable zone. With the Sun Match feature enabled via the Wyze app, this light strip automatically adjusts its color temperature to mimic the natural progression of sunlight throughout the day. This helps create a more natural and comfortable lighting environment indoors.
Key Features
  • Length options: 16.4 ft and 32.8 ft
  • Power: 18 watts (16.4 ft), 36 watts (32.8 ft)
  • 16 million colors with single-zone control
  • Cuttable design for custom fit
  • Adhesive backing for easy mounting
  • Connectivity: Wi-Fi (802.11 b/g/n 2.4 GHz) and Bluetooth
  • Life expectancy: 25,000 hours
  • Indoor use only
Usage and Control
Control your lighting easily through the Wyze app, where you can toggle Sun Match on or off, set schedules, or create automations to sync your lighting with your daily routine. The light strip also features a music mode that syncs lights to the beat of your favorite songs.
Bring the natural rhythm of sunlight indoors and enhance your mood and productivity with Wyze Light Strip’s Sun Match feature.
Wyze Light Strip in cozy kitchen lighting
Wyze Light Strip Pro: Multi-Color Segment Control with Sun Match
Customize Your Vibe with Advanced Lighting
For those seeking more control and customization, the Wyze Light Strip Pro offers multi-color segment control with 16 customizable segments. Like the standard Light Strip, it supports the Sun Match feature to simulate natural daylight cycles, but with enhanced flexibility to create dynamic lighting scenes.
Standout Specifications
  • Available in 16.4 ft and 32.8 ft lengths
  • Power consumption: 24 watts (16.4 ft), 48 watts (32.8 ft)
  • 16 million colors plus tunable white light
  • Multi-color segment control (16 segments)
  • Music Mode to sync lights with music beats
  • Voice control compatible with Alexa and Google Assistant
  • Trimmable design for perfect fit
  • Indoor use only, adhesive mounting
Smart Features for Daily Use
The Light Strip Pro supports sleep routines, vacation mode, timers, and automations, making it ideal for integrating natural light cycles into your smart home ecosystem. Use the Wyze app to enable Sun Match and enjoy lighting that adjusts seamlessly from warm morning hues to cool evening tones. Wyze Light Strip Pro behind sofa lighting
Wyze Bulb Color: Versatile Smart Bulb with Sun Match
16 Million Colors and Tunable White Light
The Wyze Bulb Color is a smart LED bulb that also supports the Sun Match feature, making it a perfect companion or alternative to LED strips for natural daily light cycles. It offers a wide color temperature range from 1800K to 6500K, allowing you to simulate everything from warm sunrise to bright daylight.
Features at a Glance
  • Brightness: Up to 1100 lumens
  • Compatible with Alexa, Google Assistant, and IFTTT
  • Suitable for damp locations (not enclosed luminaires)
  • Dimmable with app control
  • Operating temperature: -4°F to 104°F
Enhance Your Home Lighting
Use the Wyze app to activate Sun Match on the Wyze Bulb Color and create lighting that naturally shifts throughout the day, supporting your circadian rhythm and improving your overall well-being. Perfect for bedrooms, living rooms, or kitchens where natural light is limited. Wyze Bulb Color in cozy living room setting
Why Choose Wyze Lighting with Sun Match?
"Sun Match automatically adjusts your light’s color temperature to mimic natural sunlight, letting you bring the outdoors indoors!" – Wyze Support
Wyze’s Sun Match feature is designed to help you maintain a natural daily light cycle indoors, which can improve sleep quality, mood, and productivity. By integrating these smart LED strips and bulbs into your home, you can enjoy:
  • Dynamic lighting that changes with the time of day
  • Easy control and automation through the Wyze app
  • Compatibility with popular voice assistants
  • Energy-efficient LED technology with long lifespan
  • Flexible installation with adhesive backing and cuttable designs
Summary of Products Featuring Sun Match
Product NameKey FeaturesLength/Size OptionsPrice Range (USD)
Wyze Light Strip16 million colors, single zone, Sun Match16.4 ft, 32.8 ft$19.99 - $35.99
Wyze Light Strip ProMulti-color segments, music sync, Sun Match16.4 ft, 32.8 ft$29.99 - $44.99
Wyze Bulb Color16 million colors, tunable white, Sun MatchStandard A19 bulb$26.26 (2-pack)
Embrace natural lighting indoors with Wyze’s smart LED strips and bulbs featuring Sun Match. Transform your home lighting into a dynamic, health-supportive environment that follows the natural rhythms of the sun.
### Product Tags Recap
FeatureWyze Light StripWyze Light Strip ProWyze Bulb Color
TypeConnected HomeSmart LightingSmart Lighting
Size/Variants16.4 ft ($19.99), 32.8 ft ($35.99)16.4 ft ($29.99), 32.8 ft ($44.99)2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)
Colors16 million colors (one color per strip)Up to 16 colors per strip (multi-color segment control)16 million colors
Lighting EffectsBasic lighting effectsAdvanced lighting effectsCustom presets, color-changing
Protective CoatingNo epoxy coatingProtective epoxy coatingN/A
Music ModeYesYesYes
Sun MatchYesYesN/A
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Vacation ModeYesYesYes
Sleep RoutinesYesYesYes
Timers & AutomationsYesYesN/A
ConnectivityNot specifiedNot specifiedWi-Fi 802.11 b/g/n 2.4GHz, Bluetooth
PowerNot specifiedNot specified12 watts
DimensionsNot specifiedNot specified2.5 x 2.5 x 5 inches
WeightNot specifiedNot specified0.31 lbs
Life ExpectancyNot specifiedNot specified25,000 hours
Additional FeaturesPeel, stick, plug anywhereTrimmable design, segment control chipDimmable, tunable white, CRI 90+
What is the Sun Match feature in Wyze LED lighting products?The Sun Match feature in Wyze LED strips and bulbs automatically adjusts the color temperature of your lights throughout the day to mimic the natural progression of sunlight. This helps regulate your circadian rhythm, improve sleep quality, and create a more natural and comfortable indoor lighting environment.
Which Wyze products support the Sun Match feature?Wyze offers several products with the Sun Match feature, including the Wyze Light Strip, Wyze Light Strip Pro, and Wyze Bulb Color. All these products can automatically adjust their color temperature to simulate natural daylight cycles.
How does the Wyze Light Strip enhance home lighting?The Wyze Light Strip provides 16 million colors with a single customizable zone and is available in 16.4 ft and 32.8 ft lengths. With Sun Match enabled, it automatically adjusts color temperature to mimic sunlight, helping to create a natural ambiance and support your daily wellness.
What are the main differences between Wyze Light Strip and Wyze Light Strip Pro?The Wyze Light Strip offers single-zone color control, while the Wyze Light Strip Pro features multi-color segment control with 16 customizable segments. Both support Sun Match, but the Pro version allows for more advanced lighting scenes and dynamic effects, as well as voice control compatibility with Alexa and Google Assistant.
Can I control Wyze LED strips and bulbs with my smartphone?Yes, you can control all Wyze LED strips and bulbs using the Wyze app. The app allows you to enable or disable Sun Match, set schedules, create automations, adjust colors, and use features like music sync and timers.
Are Wyze lighting products compatible with voice assistants?Yes, Wyze Light Strip Pro and Wyze Bulb Color are compatible with popular voice assistants such as Amazon Alexa and Google Assistant, allowing you to control your lighting hands-free.
How long do Wyze LED strips and bulbs last?Wyze LED strips and bulbs have a life expectancy of up to 25,000 hours, making them a long-lasting and energy-efficient lighting solution for your home.
Can Wyze Light Strips be cut to fit custom spaces?Yes, both Wyze Light Strip and Wyze Light Strip Pro feature a cuttable design, allowing you to trim the strips for a perfect fit in your desired space. They also come with adhesive backing for easy installation.
Is the Wyze Bulb Color suitable for all rooms?The Wyze Bulb Color is suitable for most indoor spaces, including bedrooms, living rooms, and kitchens. It is also rated for damp locations, but should not be used in fully enclosed luminaires.
What are the color and brightness options for Wyze Bulb Color?The Wyze Bulb Color offers 16 million colors and tunable white light with a color temperature range from 1800K to 6500K. It provides up to 1100 lumens of brightness and is dimmable via the Wyze app.
How do I enable Sun Match on my Wyze lighting products?To enable Sun Match, simply open the Wyze app, select your compatible Wyze Light Strip, Light Strip Pro, or Bulb Color, and toggle the Sun Match feature on. The lights will then automatically adjust their color temperature throughout the day.
What are the benefits of using Wyze lighting with Sun Match?Wyze lighting with Sun Match helps maintain a natural daily light cycle indoors, which can improve sleep, mood, and productivity. The dynamic lighting changes with the time of day, is easy to control and automate, and integrates seamlessly with your smart home ecosystem.
What are the different lengths available for the Wyze Light Strip?Can the Wyze Light Strip be cut to fit specific spaces?Do you have any ongoing sales or promotions for the Wyze Light Strip?
