Multi-Segment LED Light Strips with App Control for Indoors
Multi-Segment LED Light Strips for Indoor Use with App-Controlled Automation
Transform your indoor spaces with advanced multi-segment LED light strips that offer vibrant colors, customizable zones, and seamless app-controlled automation. Whether you're looking to create ambient lighting for your living room, kitchen, or entertainment area, these smart LED strips provide the perfect blend of style, functionality, and smart home integration.
Wyze Light Strip Pro: Ultimate Multi-Segment Control
Customize Your Vibe with Precision
The Wyze Light Strip Pro stands out with its multi-color segment control, allowing you to divide the 16.4 or 32.8 feet strip into 16 individually customizable zones. This means you can display multiple colors simultaneously, creating dynamic lighting effects tailored to your mood or occasion.
Features That Enhance Your Smart Home
  • 16 Million Colors including RGB and tunable white for endless color possibilities
  • Music Mode syncs lights to the beat of your favorite songs
  • Voice Control compatible with Alexa and Google Assistant
  • Timers, Sleep Routines, and Vacation Mode for automated convenience
  • Trimmable Design lets you cut the strip to fit any space perfectly
  • Indoor Use Only with a durable design supporting temperatures from -4°F to 122°F
  • Connectivity: 802.11 b/g/n Wi-Fi (2.4 GHz) and Bluetooth for reliable app control
What’s in the Box?
  • Wyze Light Strip Pro
  • Controller and Power Adapter
  • Adhesive Clips for easy mounting
  • Quick Start Guide and Alcohol Wipes for prep
The Wyze Light Strip Pro is perfect for those who want detailed control over their lighting zones and vibrant color customization in a smart, easy-to-use package.
Wyze Light Strip Pro in Living Room
Wyze Light Strip: Brilliant Accent Lighting with App Control
Simple Yet Stunning LED Accent Lighting
The Wyze Light Strip offers a straightforward, single-zone LED strip available in 16.4 or 32.8 feet lengths. It delivers 16 million colors to brighten up your indoor spaces with vivid hues and smooth color transitions.
Key Specifications
  • Single Customizable Zone for uniform color across the strip
  • 16 Million Colors with high lumen output per LED (Blue 0.8lm, Red 1.0lm, Green 2.5lm)
  • Music Feature using a built-in microphone to sync lights with sound
  • Cuttable and Adhesive Backing for flexible installation
  • Connectivity: Wi-Fi (2.4 GHz) and Bluetooth for app control
  • Indoor Use Only with a lifespan of 25,000 hours
Included Accessories
  • Controller, Power Adapter, Adhesive Clips, Quick Start Guide, and Alcohol Wipes
Ideal for users who want vibrant, app-controlled lighting with easy installation and a single color zone.
Wyze Light Strip in Kitchen
Smart Lighting Kits: Bundles Featuring Light Strip Pro + Color Bulbs
Complete Smart Lighting Solutions
For those seeking a comprehensive lighting upgrade, the Smart Lighting Kits bundle the Wyze Light Strip Pro with Wyze Bulb Color BR30 or standard Wyze Bulb Color. These kits provide both strip and bulb lighting with full app control and voice assistant integration.
Highlights of the Bundles
  • Multi-Color 16.4 ft Light Strip Pro with 16 customizable zones
  • Wyze Bulb Color BR30 or Wyze Bulb Color with 16 million colors and tunable white (1800K - 6500K)
  • High Lumens Output: Bulbs range from 30 to 1100 lumens, perfect for ambient or task lighting
  • Smart Features: Alexa, Google Assistant, and IFTTT integration for voice and automation control
  • Suitable for Damp Locations (bulbs) and indoor use (light strips)
  • 1-Year Warranty for peace of mind
Bundle Variants
  • Bulb Color BR30 2-Pack + 16.4 ft Light Strip Pro
  • Bulb Color BR30 4-Pack + 16.4 ft Light Strip Pro
  • Bulb Color 2-Pack or 4-Pack + 16.4 ft Light Strip Pro
These kits are perfect for users who want to unify their smart lighting experience with both bulbs and multi-segment LED strips controlled from a single app.
Why Choose App-Controlled Multi-Segment LED Light Strips?
App-controlled LED light strips bring convenience, creativity, and smart automation to your indoor lighting. With features like customizable color zones, music sync, voice control, and scheduling, you can effortlessly set the perfect ambiance for any moment.
  • Personalized Lighting: Adjust colors and brightness instantly from your smartphone.
  • Automation & Routines: Set timers, sleep modes, and vacation settings to automate your lighting.
  • Voice Assistant Compatibility: Hands-free control with Alexa or Google Assistant.
  • Easy Installation: Adhesive backing and trimmable designs fit any indoor space.
  • Long Lifespan & Energy Efficient: Enjoy vibrant lighting with low power consumption and 25,000 hours of life expectancy.
Conclusion
For indoor multi-segment LED light strips with app-controlled automation, the Wyze Light Strip Pro is the top choice offering advanced zone customization and smart features. The Wyze Light Strip provides a simpler, single-zone option with vibrant colors and music sync. For a full smart lighting upgrade, consider the Smart Lighting Kits that combine multi-segment strips with color-tunable bulbs for a complete connected home lighting experience. Elevate your indoor lighting with these innovative LED strips and enjoy the convenience and creativity of app-controlled smart lighting.
FeatureWyze Light StripWyze Light Strip ProSmart Lighting Kit - Bulb Color + Light Strip Pro Bundle
TypeConnected HomeSmart LightingSmart Lighting
Size / Length16.4 Feet, 32.8 Feet16.4 Feet, 32.8 FeetWyze Light Strip Pro - 16.4 Feet
Price$19.99 (16.4 ft), $35.99 (32.8 ft)$29.99 (16.4 ft), $44.99 (32.8 ft)$52.98 (2 Pack Bulb Color + Strip), $74.97 (4 Pack Bulb Color + Strip)
Colors16 million colors (one color per strip)16 million colors (multi-color segment control)16 million colors (Light Strip Pro) + Bulb Color (30-1100 lumens)
Color ControlBasic lighting effectsAdvanced lighting effects with segment controlAdvanced lighting effects + Bulb color temperature 1800K-6500K
Protective CoatingNo epoxy coatingProtective epoxy coatingProtective epoxy coating (Light Strip Pro)
Customizable Zones1 color per stripUp to 16 customizable zonesLight Strip Pro with 16 customizable zones + Bulb Color bulbs
Music ModeYes, syncs to musicYes, syncs to musicYes, syncs to music
Sun MatchYesYesYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYesYes
Sleep RoutinesYesYesYes
Timers & AutomationsYesYesYes
Bulb IncludedNoNoWyze Bulb Color (2 or 4 Pack) included
Bulb SpecsN/AN/ABulb Color: 30-1100 lumens, 1800K-6500K, 12W, 25,000 hours life
Communication ModeWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Operating TemperatureNot specified-4°F to 122°F (-20°C to 50°C)Bulb: -4°F to 104°F; Strip Pro: -4°F to 122°F
UsageIndoor onlyIndoor onlyIndoor only
WarrantyNot specified1-Year1-Year
What are multi-segment LED light strips and how do they work indoors?Multi-segment LED light strips are advanced lighting solutions designed for indoor use. They feature individually customizable zones, allowing you to display multiple colors simultaneously along the strip. Controlled via a smartphone app, these strips offer vibrant colors, dynamic effects, and seamless integration with smart home systems for personalized indoor lighting.
What is the difference between Wyze Light Strip Pro and Wyze Light Strip?The Wyze Light Strip Pro offers multi-segment control with up to 16 customizable zones, allowing for multiple colors and dynamic effects on a single strip. The standard Wyze Light Strip features a single customizable zone, providing uniform color across the entire strip. Both are app-controlled, but the Pro version offers more advanced customization and effects.
How many colors can Wyze Light Strip Pro and Wyze Light Strip display?Both the Wyze Light Strip Pro and Wyze Light Strip can display up to 16 million colors, including RGB and tunable white, giving you endless possibilities for creating the perfect ambiance in your indoor spaces.
Can I control Wyze LED light strips with my smartphone?Yes, both Wyze Light Strip Pro and Wyze Light Strip are app-controlled. You can adjust colors, brightness, set schedules, and activate features like music sync directly from your smartphone using the Wyze app.
Are Wyze LED light strips compatible with voice assistants?Yes, Wyze LED light strips are compatible with popular voice assistants such as Amazon Alexa and Google Assistant, allowing for hands-free control of your lighting.
What smart features do Wyze Light Strip Pro and Wyze Light Strip offer?Smart features include music mode (syncs lights to music), timers, sleep routines, vacation mode, and voice control. The Pro version also offers multi-segment color control for advanced lighting effects.
Can I cut or trim Wyze LED light strips to fit my space?Yes, both Wyze Light Strip Pro and Wyze Light Strip are trimmable, allowing you to cut the strip to the desired length for a perfect fit in any indoor space.
What is included in the Wyze Light Strip Pro and Wyze Light Strip packages?Each package includes the LED light strip, a controller, power adapter, adhesive clips for easy mounting, a quick start guide, and alcohol wipes for surface preparation.
Are Wyze LED light strips suitable for outdoor use?No, Wyze Light Strip Pro and Wyze Light Strip are designed for indoor use only. They are built to operate in temperatures ranging from -4°F to 122°F.
What is the lifespan of Wyze LED light strips?Wyze LED light strips have a lifespan of up to 25,000 hours, providing long-lasting and energy-efficient lighting for your indoor spaces.
What are Smart Lighting Kits and what do they include?Smart Lighting Kits bundle the Wyze Light Strip Pro with Wyze Bulb Color BR30 or standard Wyze Bulb Color. These kits offer both strip and bulb lighting, all controllable via the Wyze app and compatible with voice assistants. Kits include various combinations of bulbs and a 16.4 ft Light Strip Pro.
Can Wyze Bulb Color BR30 be used in damp locations?Yes, Wyze Bulb Color BR30 and Wyze Bulb Color included in the Smart Lighting Kits are suitable for damp locations, making them versatile for different indoor environments.
What connectivity options do Wyze LED light strips support?Wyze LED light strips support 802.11 b/g/n Wi-Fi (2.4 GHz) and Bluetooth, ensuring reliable app control and easy integration with your smart home network.
Do Wyze LED light strips come with a warranty?Yes, Wyze Smart Lighting Kits, which include the Light Strip Pro and color bulbs, come with a 1-year warranty for added peace of mind.
Why should I choose app-controlled multi-segment LED light strips for my home?App-controlled multi-segment LED light strips offer personalized lighting, automation, voice assistant compatibility, easy installation, and energy efficiency. They allow you to create the perfect ambiance, automate routines, and enjoy hands-free control, making them an ideal choice for modern smart homes.
Can you tell me more about the features of the Wyze Light Strip Pro?How does the music mode work with the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Light Strips?
